  4. Test js-controller v2.0.x (GitHub)
    apollon77A
js-controller
1.0k Beiträge 48 Kommentatoren 489.8k Aufrufe 35 Beobachtet
  • D darkiop
    @apollon77 Sorry, viel Text heute Morgen - hier noch die Aktualisierung auf 2.0.16:
    Alle Prozesse gestoppt, beide aktualisiert:
    ┬─[root@iobroker-master:/opt/iobroker]─[06:31:25]
    ╰─># sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
    > iobroker.js-controller@2.0.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.4.1
    > iobroker.js-controller@2.0.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/iobroker.pushbullet/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.0 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/chokidar/node_modules/fsevents):
    + iobroker.js-controller@2.0.16
    added 1 package from 3 contributors, removed 1 package, updated 8 packages and audited 40363 packages in 147.811s
    found 87 vulnerabilities (32 low, 10 moderate, 45 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    ┬─[darkiop@iobroker-hwr:/opt/iobroker]─[06:31:49]
    ╰─>$ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
    [sudo] Passwort für darkiop:
    NPM version: 6.9.0
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    removed 1 package, updated 8 packages and audited 1867 packages in 62.052s
    found 12 vulnerabilities (9 low, 3 high)
    Dann
    1. iobroker-master Container neu gestartet
    2. iobroker-hwr reboot
    Nach reboot auf iobroker-hwr:
    ┬─[darkiop@iobroker-hwr:~]─[06:40:21]
    ╰─>$ iobroker status
    iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    ┬─[darkiop@iobroker-hwr:~]─[06:40:26]
    ╰─>$ ps -ef | grep ^io
    ┬─[darkiop@iobroker-hwr:~]─[06:40:31]
    ╰─>$ tail -n 50 /opt/iobroker/log/iobroker.2019-10-01.log
    2019-10-01 02:33:27.294  - warn: host.iobroker-hwr Slave controller detected disconnection. Stop all instances.
    2019-10-01 02:33:27.301  - info: host.iobroker-hwr stopInstance system.adapter.smartmeter.0
    2019-10-01 02:33:27.302  - error: host.iobroker-hwr result is not defined
    2019-10-01 02:33:29.315  - warn: host.iobroker-hwr Cannot get view: ReplyError: Error Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
    2019-10-01 02:33:29.319  - info: host.iobroker-hwr instance system.adapter.smartmeter.1 terminated with code 0 (NO_ERROR)
    2019-10-01 02:33:29.320  - info: host.iobroker-hwr Do not restart adapter system.adapter.smartmeter.1 because disabled or deleted
    2019-10-01 02:33:29.360  - warn: host.iobroker-hwr Cannot get view: ReplyError: Error Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
    2019-10-01 02:33:29.361  - info: host.iobroker-hwr instance system.adapter.smartmeter.0 terminated with code 0 (NO_ERROR)
    2019-10-01 02:33:29.362  - info: host.iobroker-hwr Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted
    2019-10-01 02:33:42.303  - info: host.iobroker-hwr iobroker _restart
    2019-10-01 02:33:42.816  - info: host.iobroker-hwr iobroker Starting node restart.js
    2019-10-01 06:37:53.718  - info: host.iobroker-hwr iobroker.js-controller version 2.0.16 js-controller starting
    2019-10-01 06:37:53.726  - info: host.iobroker-hwr Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2019-10-01 06:37:53.726  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.16.3
    2019-10-01 06:37:53.728  - info: host.iobroker-hwr ip addresses:
    2019-10-01 06:37:53.749  - error: host.iobroker-hwr uncaught exception: connect ENETUNREACH 192.168.1.82:9001 - Local (0.0.0.0:0)
    2019-10-01 06:37:53.750  - error: host.iobroker-hwr Error: connect ENETUNREACH 192.168.1.82:9001 - Local (0.0.0.0:0)
        at internalConnect (net.js:881:16)
        at defaultTriggerAsyncIdScope (internal/async_hooks.js:294:19)
        at defaultTriggerAsyncIdScope (net.js:971:9)
        at process._tickCallback (internal/process/next_tick.js:61:11)
    2019-10-01 06:37:53.752  - info: host.iobroker-hwr terminated. Could not reset alive status for instances
    2019-10-01 06:37:53.756  - info: host.iobroker-hwr iobroker _restart
    ┬─[darkiop@iobroker-hwr:~]─[06:41:17]
    ╰─>$ iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 1448
    Dann startet der iobroker-hwr sauber:
    2019-10-01 06:42:00.051  - info: host.iobroker-hwr iobroker.js-controller version 2.0.16 js-controller starting
    2019-10-01 06:42:00.059  - info: host.iobroker-hwr Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2019-10-01 06:42:00.059  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.16.3
    2019-10-01 06:42:00.061  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::dea6:32ff:fe17:78f5
    2019-10-01 06:42:00.585  - info: host.iobroker-hwr connected to Objects and States
    2019-10-01 06:42:00.628  - warn: host.iobroker-hwr Multihost discovery server: service started on 0.0.0.0:50005
    2019-10-01 06:42:01.523  - info: host.iobroker-hwr Delete state "system.host.iobroker-hwr.compactModeEnabled"
    2019-10-01 06:42:01.755  - info: host.iobroker-hwr 85 instances found
    2019-10-01 06:42:01.773  - info: host.iobroker-hwr starting 2 instances
    2019-10-01 06:42:01.793  - info: host.iobroker-hwr instance system.adapter.smartmeter.0 started with pid 1474
    2019-10-01 06:42:02.063  - info: host.iobroker-hwr Some obsolete host states deleted.
    2019-10-01 06:42:05.790  - info: host.iobroker-hwr instance system.adapter.smartmeter.1 started with pid 1489
    apollon77A
    apollon77A
    #335
    @darkiop Wie startest und stoppst du das denn so? iobroker start/stop auf dem Raspi? Wie im Docker? Details
    • SBorgS
      SBorgS
      SBorg
      #336
      Außer dem Node-RED Dashboard habe ich dann noch zwei Adapter die wohl ein Upgrade brauchen:
      host.Ubuntu	2019-10-01 08:58:03.795	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
      daswetter.0	2019-10-01 08:58:03.774	error	(32174) force terminate, objects still in list: 1571
      läuft unter 1.15.14 problemlos, und
      broadlink2.0	2019-10-01 09:12:24.100	warn	(865) sendState could not find command or scene named 'LG_TV-Power'
      als Beispiel. Den state gibt es definitiv und läuft ebenfalls unter 1.15.14 klaglos.
      LG SBorg ( SBorg auf GitHub)
      • coyoteC
        coyoteC
        coyote
        #337
        @SBorg den Fehler von daswetter hatte ich aber auch vor dem Update schon
        @apollon77 @arteck ist es normal, dass mir das angezeigt wird bei der Umstellung auf redis/redis?
        Host name of this machine [debian]:
        It appears that this host should be connected to an existing ioBroker System as Slave. Data Migration will be skipped. Is this correct? [Y/n]: n
        Ich hab kein Master/Slave System
        SBorgS apollon77A 2 Antworten Letzte Antwort
        • coyoteC coyote
          SBorgS
          SBorgS
          SBorg
          #338
          @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
          Bei mir nicht. Bis heute morgen mit dem JS 1.15.14 lief es auch und die Daten waren korrekt, jetzt mit dem 2er steigt er mit dem error aus und liefert auch keine Daten mehr. Liegt aber am Adapter, nicht am Controller.
          coyoteC 1 Antwort Letzte Antwort
          • SBorgS SBorg
            coyoteC
            coyoteC
            coyote
            #339
            @SBorg Hm ok, komisch. Bei mir war es vorher schon, hier ein Auszug vom Log von gestern, da war ich noch bei 1.5.14
            2019-09-30 10:31:07.279  - error: daswetter.0 force terminate, objects still in list: 1887
            2019-09-30 10:31:07.441  - info: host.debian instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
            • SBorgS
              SBorgS
              SBorg
              #340
              Nicht ganz, du hast eine "desired termination" mit Code 11 (also eine 'erwünschte', die ist normal), ich habe eine "echte" Terminierung mit Code 15 (=harter Abbruch wegen Fehler).
              • SBorgS SBorg
                apollon77A
                apollon77A
                #341
                @SBorg sagte in [Aufruf] js-controller 2.0 Beta Test:
                Naja ich fürchte das gleiche Problem könnte es sein wie bei radar2, das die myadapter-Klasse falsch ist. Kannst Du mal testen bitte:
                File /opt/iobroker/node_modules/@frankjoke/myadapter/myadapter.js und dort die Änderungen aus https://github.com/frankjoke/myAdapter/pull/1/files einbauen (oder ganzes file mit https://github.com/frankjoke/myAdapter/blob/f06343bfe6e132536f6740a7f025b2122ecef6b6/myAdapter.js ersetzen)
                Ist der Fehler dann weg? Wenn ja bitte Issue bei broadlink2 anlegen und reinschreiben und mir schicken, dann müssen wir ggf wie bei radar2 ein Zwischenrelease bauen.
                Zu Daswetter weiss ich nix ... kommt das immer? Bzw war es schon vorher da. Kannst ja mal durch die alten Logfiles der 7 Tage in /opt/iobroker/logs suchen ...
                • SBorgS SBorg
                  coyoteC
                  coyoteC
                  coyote
                  #342
                  @SBorg ja ok, da hast du recht. Ich hatte nur nach dem "force terminate, objects still in list:" geschaut
                  • coyoteC coyote
                    arteckA
                    arteckA
                    arteck
                    #343
                    daswetter
                    ist ja komisch.. das wetter nutzt ich auch ... ich hab die Meldung nicht..
                    • coyoteC coyote
                      apollon77A
                      apollon77A
                      #344
                      @coyote Wenn Du komplett auf Redis umstellst weiss der Migrationsprozess nicht ob da schon ein anderer "Iobroker" seine Daten drin hat und weiss damit nicht ob das der "erste" ist der Redis nutzen soll oder er ein weiterer neuer Slave ist der dran soll.
                      Da die Frage aber auf ja/nein ausgelegt ist sagst Du hier einfach "n(ein)" dann macht er alles korrekt weiter. vllt ergänze ich das in der Meldung noch
                      • apollon77A apollon77
                        coyoteC
                        coyoteC
                        coyote
                        #345
                        @apollon77 ok, also alles normal. Ja wäre vllt nicht schlecht, die Meldung verwirrt auf den ersten Blick etwas.
                        • SBorgS
                          SBorgS
                          SBorg
                          #346
                          @apollon77 Mache ich heute abend.
                          Bzgl. DasWetter: Jepp, seit der 2er (alte Logfiles angeschaut), ist mir bis dato aber nicht aufgefallen. Erst als die Wetterprognose heute mal überhaupt nicht stimmte, und da für "heute" auch Sonntag stand... ;)
                          Mal noch eine prinzipielle Frage, gerade wegen aktuell Wetter oder Dashboard: besteht ein Unterschied für den Controller/Node-RED zwischen 32/64Bit ? Da man Linux ja nicht ohne weiteres switchen kann, bin ich auf meinem 32 Bit Linux auch noch mit NPM 8 unterwegs, da 10 ja nur noch unter 64 Bit läuft...
                          • coyoteC coyote
                            apollon77A
                            apollon77A
                            #347
                            @coyote Würde es ändern in:
                            VORHER:
                            NACHHER:
                            Please choose if this is a Master/single host (enter "m") or a Slave host (enter "s") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]:
                            Besser? Sonst gern textvorschläge :-)
                            • SBorgS SBorg
                              apollon77A
                              apollon77A
                              #348
                              Komisch. Dann starte es mal an der Kommandozeile, vllt gibt es da mehr logs:
                              Shell ins ioBroker Verzeichnis, dann
                              node node_modules/iobroker.daswetter/main.js --force --logs
                              • SBorgS
                                SBorgS
                                SBorg
                                #349
                                Nicht wirklich:
                                  Ubuntu  root  /  opt  iobroker  node node_modules/iobroker.daswetter/main.js --force --logs
                                2019-10-01 13:48:31.117  - info: daswetter.0 (28510) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.16.1
                                2019-10-01 13:49:31.200  - error: daswetter.0 (28510) force terminate, objects still in list: 1736
                                2019-10-01 13:49:31.203  - warn: daswetter.0 (28510) Terminated (15): Without reason
                                  VORHER:
                                  NACHHER:
                                  A
                                  A
                                  Adnim
                                  schrieb am zuletzt editiert von Adnim
                                  #350
                                  @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  Please choose if this is a Master/single host (enter "m") or a Slave host (enter "s") . For Slave hosts the data migration will be skipped. [S/m]:
                                  Kannst du nicht das etwas verschlanken?
                                  Choose Master or Slave (Migration Progress runs only on Master)
                                  Ps: bei den ganzen abfragen wäre es auch gut nochmal abzufragen ob ein Backup angelegt wurde, sicher ist sicher...
                                    D
                                    D
                                    darkiop
                                    schrieb am zuletzt editiert von darkiop
                                    #351
                                    @apollon77
                                    Und immer noch diese EHOSTUNREACH?? Das kapier ich nicht weil das für mch was mit Netzwerk und DNS und so ist .. .nichts wo der js-controller auch nur irgendeine Auswirkung haben sollte
                                    Ja, aber der kommt nur durch das direkte Starten nach dem booten. Manuell über 'iobroker start' (bzw. zu dem Zeitpunkt des iobroker start) funktioniert es.
                                    Docker ganz normal über das runskript des Containers [1]. Beim Raspi auch wie es nach der Standard Installation eingebunden wurde.
                                    [1] https://github.com/buanet/docker-iobroker/blob/master/scripts/iobroker_startup.sh
                                    Edit:
                                    Hier unter Rasbian 10 bzw. Diet Pi wurde init.d genommen. Über init.d kann ich nach dem fehlgeschlagenen Autostart ebenfalls den iobroker sauber starten ... Ich versteh grad die Welt nicht mehr. Kann mir eigentlich nur noch vorstellen das zum Zeitpunkt des Autostarts der Master noch nicht erreichbar ist - dies aber kurz danach wird ...
                                    ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                    • C
                                      C
                                      ChrisXY
                                      #352
                                      Hab mal testweise ein paar Adapter Probiert. Aktuell gibt es wohl probleme mit dem RING Adapter. Adapter ist Grün aber hab da einiges im LOG. Debug von Ring liefert das hier :
                                      ring.0	2019-10-01 14:16:59.524	info	(2112) TypeError: Converting circular structure to JSON
                                      ring.0	2019-10-01 14:16:59.523	debug	(2112) Ring: {"events":{"_events":{},"_eventsCount":0,"_maxListeners":100}}
                                      ring.0	2019-10-01 14:16:47.066	debug	(2112) system.adapter.admin.0: logging true
                                      ring.0	2019-10-01 14:16:42.103	info	(2112) TypeError: Converting circular structure to JSON
                                      ring.0	2019-10-01 14:16:42.102	debug	(2112) Ring: {"events":{"_events":{},"_eventsCount":0,"_maxListeners":100}}
                                      ring.0	2019-10-01 14:16:37.658	info	(2112) Ring adapter uses API: ring-api
                                      ring.0	2019-10-01 14:16:37.657	info	(2112) Starting Adapter ring.0 in version 1.0.4
                                      ring.0	2019-10-01 14:16:37.604	info	(2112) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.ring, node: v10.16.3
                                        SBorgS
                                        SBorgS
                                        SBorg
                                        #353
                                        Doch etwas schneller :)
                                        Done + Adapter neu gestartet + Fehler bleibt leider gleich.
                                        • A Adnim
                                          apollon77A
                                          apollon77A
                                          #354
                                          @Adnim Naja, wir haben User die noch nie was mit Maste roder Slave zu tun hatten und nur einen Host haben. Daher versuche ich alle Fälle abzufangen.
                                          Backup wird ja von Prozess direkt gemacht, steht auch im Prozess und bekommt sogar "-migration" an den Namen angehängt. Also das backup ist automatisch da
                                          84.0k
