  4. Objekte anlegen
Objekte anlegen
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
objekte anlegen
26 Beiträge 6 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    folgendes Script klappt soweit:
    const id = "mqtt.0.abcde";
    const obj = {
    "type":"state",
    "common": {
        "name": "abcde",
        "role": "",
        "type": "string",
        "read": true,
        "write": true,
        "desc": "per Javascript erzeugt",
        "def": ""}
    setObject(id, obj, function() {
        setState(id, obj.common.def,true);
    Trotzdem kommt noch im log ein Fehler:
    javascript.1	2019-08-02 12:18:47.405	warn	at Socket.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    javascript.1	2019-08-02 12:18:47.405	warn	at Manager.ondata (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:322:16)
    javascript.1	2019-08-02 12:18:47.405	warn	at Decoder.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-parser\index.js:246:12)
    javascript.1	2019-08-02 12:18:47.405	warn	at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-emitter\index.js:134:20)
    javascript.1	2019-08-02 12:18:47.405	warn	at Decoder.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    javascript.1	2019-08-02 12:18:47.405	warn	at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:332:8)
    javascript.1	2019-08-02 12:18:47.405	warn	at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    javascript.1	2019-08-02 12:18:47.405	warn	at Manager.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    javascript.1	2019-08-02 12:18:47.405	warn	at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:236:12)
    javascript.1	2019-08-02 12:18:47.405	warn	at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:312:9)
    javascript.1	2019-08-02 12:18:47.405	warn	at Socket.<anonymous> (script.js.Scripte.test3:17:5)
    javascript.1	2019-08-02 12:18:47.405	warn	at setState (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:1258:20)
    javascript.1	2019-08-02 12:18:47.404	warn	State "mqtt.0.abcde" not found
    Trotz Fehler wird die Variable angelegt.
    Offensichtlich ist da immer noch was falsch
    Danke.
    HomoranH IssiI 2 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      const obj = {
      "type":"state",
      "common": {
          "name": "abcde",
          "role": "",
          "type": "string",
          "read": true,
          "write": true,
          "def": ""}
      @bahnuhr sagte in Objekte anlegen:
      Wo?
      ich sehe nur "warn"
      https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#setobject
      fettgedrucktes beachten
      • bahnuhrB bahnuhr
        const obj = {
        "type":"state",
        "common": {
            "name": "abcde",
            "role": "",
            "type": "string",
            "read": true,
            "write": true,
            "def": ""}
        IssiI Offline
        IssiI Offline
        Issi
        @bahnuhr
        const obj = {
        "type":"state",
        "common": {
            "name": "abcde",
            "role": "",
            "type": "string",
            "read": true,
            "write": true,
            "def": ""}
        das ; bei "mqtt.o.abcde" weg machen dan kommt auch kein warnungen mehr
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          habe ; gelöscht.
          Hat sich aber nichts geändert.
          "warn" kommt immer noch.
          Danke.
          IssiI 1 Antwort Letzte Antwort
          • bahnuhrB bahnuhr
            habe ; gelöscht.
            IssiI Offline
            IssiI Offline
            Issi
            @bahnuhr hab mal dein script getestet bei mir kommen auch warn Meldungen wen ich dann die ; in Zeile 1 weg machen sowie oben von mir gepostet dann wird ein datenpunkt erstellt ohne das warn Meldungen kommen
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              Also bei mir kommt die Warn Meldung wenn die Var. noch nicht besteht (wird aber trotzdem dann angelegt.).
              Wenn sie schon besteht und ich dann das Script aktiviere; dann kommt keine Meldung mehr.
              Hast du dies mal probiert.
              Danke.
              • bahnuhrB bahnuhr
                @bahnuhr
                Etwas anderes steht auch nicht in der Warn drin.
                deswegen solltest du ja die Doku, die ich verlinkt habe lesen, insbesondere das fetgedruckte
                • bahnuhrB bahnuhr
                  IssiI Offline
                  IssiI Offline
                  Issi
                  schrieb am zuletzt editiert von Issi
                  @bahnuhr also ich habe kein mqtt adapter instalirt also wird der datenpunkt ganz neu angelegt
                    Da das anklicken eines Links wohl zuviel verlangt ist:
                    zu setObject steht in der Doku
                    You should use it to modify an existing object you read beforehand, e.g.:
                    und die warn sagt beim ersten mal nur, dass es noch nicht existiert
                    anschließend ist es angelegt und keine warn erscheint
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @Homoran sagte in Objekte anlegen:
                      Und immer die Spitzen (kommt jedenfalls so rüber).
                      Ich habe sehrwohl den Link angeklickt und auch gelesen; aber nicht verstanden.
                      Aber wenn dir dies klar ist, dann schreib doch mal wie die Lösung ist.
                      mfg
                      Danke.
                      thewhoboxT 1 Antwort Letzte Antwort
                      • bahnuhrB bahnuhr
                        mfg
                        thewhoboxT Offline
                        thewhoboxT Offline
                        thewhobox
                        @bahnuhr Es gibt keine Lösung. Das Verhalten ist so gewollt.
                        Die funktion ist nur ein Workaround um damit einen Datenpunkt zu erstellen.
                        Eigentlich bearbeitet die funktion einen vorhandenen Datenpunkt.
                        Deswegen heißt sie setObject und nicht createObject.
                        Wenn der Datenpunkt nicht vorhanden ist gibt es halt eine Warnung, erstellt ihn aber trotzdem.
                        Meine Adapter: emby | discovery
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          Danke.
                          Das ist ne klare Aussage.
                          Fazit:
                          Datenpunkt wird erstellt.
                          Warn-Meldung ist normal.
                          Danke.
                          • bahnuhrB bahnuhr
                            Danke.
                            Fazit:
                            Fazit:
                            Sorry, wenn das bei mir nicht so rüberkam - das wollte ich mit meinen Worten auch bereits mehrfach gesagt haben
                            • bahnuhrB bahnuhr
                              Danke.
                              Fazit:
                              @bahnuhr sagte:
                              So geht es auch ohne Warnung:
                              const obj = {
                                "type":"state",
                                "common": {
                                  "name": "abcde",
                                  "role": "",
                                  "type": "string",
                                  "read": true,
                                  "write": true,
                                  "def": ""
                              setObject(id, obj);
                              setTimeout(function() {setState(id, obj.common.def, true)}, 100);
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Danke Paul,
                                das ist die Lösung.
                                mfg
                                Dieter
                                Danke.
                                • bahnuhrB bahnuhr
                                  Danke Paul,
                                  das ist die Lösung.
                                  mfg
                                  Dieter
                                  @bahnuhr sagte:
                                  das ist die Lösung.
                                  Dann markiere die Lösung, damit das Fragezeichen verschwindet.
