  4. Astro-Tageszeit abfragen und in Datenpunkt eintragen
349 Beiträge 72 Kommentatoren 172.9k Aufrufe 23 Beobachtet
  • Q quorle
    @paul53 :
    Bei mir funktioniert dein Script leider nicht.
    Javascript Adapter ist auf 4.1.12
    js-controller ist auf 1.5.11
    Fehlerlog:
    javascript.0	2019-06-02 18:36:53.028	error	at Timer.listOnTimeout (timers.js:290:5)
    javascript.0	2019-06-02 18:36:53.028	error	at tryOnTimeout (timers.js:323:5)
    javascript.0	2019-06-02 18:36:53.028	error	at ontimeout (timers.js:511:34)
    javascript.0	2019-06-02 18:36:53.028	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
    javascript.0	2019-06-02 18:36:53.027	error	at Object.<anonymous> (script.js.common.System.Astrozeiten_berechnen_V2:302:16)
    javascript.0	2019-06-02 18:36:53.027	error	at getAstroDate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1220:42)
    javascript.0	2019-06-02 18:36:53.027	error	Error in callback: TypeError: date.getDate is not a function
    javascript.0	2019-06-02 18:36:53.027	error	at Timer.listOnTimeout (timers.js:290:5)
    javascript.0	2019-06-02 18:36:53.027	error	at tryOnTimeout (timers.js:323:5)
    javascript.0	2019-06-02 18:36:53.027	error	at ontimeout (timers.js:511:34)
    javascript.0	2019-06-02 18:36:53.027	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
    javascript.0	2019-06-02 18:36:53.026	error	at getAstroDate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1220:42)
    javascript.0	2019-06-02 18:36:53.026	error	Error in callback: TypeError: date.getDate is not a function
    javascript.0	2019-06-02 18:36:53.026	error	at Timer.listOnTimeout (timers.js:290:5)
    javascript.0	2019-06-02 18:36:53.026	error	at tryOnTimeout (timers.js:323:5)
    javascript.0	2019-06-02 18:36:53.026	error	at ontimeout (timers.js:511:34)
    javascript.0	2019-06-02 18:36:53.026	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
    javascript.0	2019-06-02 18:36:53.026	error	at Object.<anonymous> (script.js.common.System.Astrozeiten_berechnen_V2:302:16)
    paul53P
    paul53P
    #276
    @quorle sagte:
    Fehlerlog:
    Dann verwendest Du die JS-Version von Github, die noch einen Fehler enthält, wenn date an getAstroDate() in ms übergeben wird. Deshalb ändere Zeile 292 in
            var tomorrow = new Date(today.setDate(today.getDate()+1));
    Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
    P 2 Antworten Letzte Antwort
    • J Jan1
      Kein Plan warum man sich da ein JavaScript dafür von jemand übernimmt (@paul53 kann man machen und nichts gegen Dein Script).
      Wenn man schlicht die Astrozeiten als DP haben möchte und von Javascript nichts versteht, dann bietet Blockly schon alles was man braucht.
      sieht dann so aus:
      Hier dann mal der Blockly Export, falls es einer haben möchte:
      <block type="create" id="v72H-N1#%w_zseA#CMc" x="13" y="13">
      <field name="NAME">01-Nachtende</field>
      <statement name="STATEMENT">
      <block type="create" id="@kYi)AXak/ydmJCF!oo]">
      <field name="NAME">02-Morgendämmerung</field>
      <block type="create" id=";T8PP:ZCKeM4
      +U5?yi">
      <field name="NAME">03-Sonnenaufgang</field>
      <block type="create" id="gIfB:POQ4@(+!BTUapf">
      <field name="NAME">04-Sonneneaufgang_Ende</field>
      <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
      <field name="NAME">05-Golden_Houer_Ende</field>
      <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
      <field name="NAME">06-Mittag</field>
      <block type="create" id="eYe;t8x=FwBT4B,.|k."> <field name="NAME">07-Golden_Houer</field> <statement name="STATEMENT"> <block type="create" id="tVROR/kUT3MINh%SOcdY"> <field name="NAME">08-Sonnenuntergang_Anfang</field> <statement name="STATEMENT"> <block type="create" id="kCb|+j}(0FzG/abd,q1">
      <field name="NAME">09-Sonnenuntergang</field>
      <block type="create" id="4UB
      zNj{JG:saTpO/G">
      <field name="NAME">10-Abenddämmerung</field>
      <block type="create" id="%kf8::E|Nt2i
      cPYM.aB">
      <field name="NAME">11-Nacht</field>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      <next>
      <block type="schedule" id="c;,oPug#y[hH+R/Az:)Z">
      <field name="SCHEDULE">0 0,6,12,18 * * *</field>
      <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
      <mutation delay_input="false"></mutation>
      <field name="OID">javascript.0.01-Nachtende</field>
      <value name="VALUE">
      <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
      <mutation format="false" language="false"></mutation>
      <field name="OPTION">hh:mm:ss</field>
      <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
      <field name="TYPE">nightEnd</field>
      <field name="OFFSET">0</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
      <field name="OID">javascript.0.02-Morgendämmerung</field>
      <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
      <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
      <field name="TYPE">dawn</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
      <field name="OID">javascript.0.03-Sonnenaufgang</field>
      <block type="convert_from_date" id="AMyc:3
      Tp9XP+4kq(nv-">
      <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
      <field name="TYPE">sunrise</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="DwtR_scz+f42pEJ/sKn?">
      <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
      <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
      <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
      <field name="TYPE">sunriseEnd</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
      <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
      <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
      <block type="time_astro" id="]qS[Z+Pab*WUXun969T"> <field name="TYPE">goldenHourEnd</field> <field name="OFFSET">0</field> </block> </value> </block> </value> <next> <block type="update" id="FjU7x+vB-{|nz?Ntgi]B"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.06-Mittag</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
      <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
      <field name="TYPE">solarNoon</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
      <field name="OID">javascript.0.07-Golden_Houer</field>
      <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^"> <mutation format="false" language="false"></mutation> <field name="OPTION">hh:mm:ss</field> <value name="VALUE"> <block type="time_astro" id="~MgPI%%B44O6EzrHu._C"> <field name="TYPE">goldenHour</field> <field name="OFFSET">0</field> </block> </value> </block> </value> <next> <block type="update" id="g|Q7g?g_fO6AjzFr(le">
      <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
      <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF"> <mutation format="false" language="false"></mutation> <field name="OPTION">hh:mm:ss</field> <value name="VALUE"> <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
      <field name="TYPE">sunsetStart</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
      <field name="OID">javascript.0.09-Sonnenuntergang</field>
      <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
      <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
      <field name="TYPE">sunset</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="okk0X1l~(0(nUW+Re46b">
      <field name="OID">javascript.0.10-Abenddämmerung</field>
      <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
      <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
      <field name="TYPE">dusk</field>
      </block>
      </value>
      </block>
      </value>
      <next>
      <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
      <field name="OID">javascript.0.11-Nacht</field>
      <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
      <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
      <field name="TYPE">night</field>
      </block>
      </value>
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </xml>
      paul53P
      paul53P
      #277
      @Jan1 sagte:
      sieht dann so aus:
      Du hast Glück, dass Du so weit südlich wohnst und deshalb "Nacht" und "Nachtende" bei Dir auch im Sommer funktioniert.
      Mitternachtsdämmerung
      • Q
        Q
        quorle
        #278
        Danke für deine schnelle und Hilfreiche Antwort. So funktioniert es ohne Fehler und Probleme.
        Ich hoffe es werden bal alle Fehler des Javascript-Adapters ausgemerzt sein....
          @Jan1 sagte:
          sieht dann so aus:
          J
          J
          Jan1
          #279
          @paul53 sagte in Astro-Tageszeit abfragen und in Datenpunkt eintragen:
          @Jan1 sagte:
          sieht dann so aus:
          Ich hatte ursprünglich auch ein Script dafür hier aus dem Forum und da gabs dann auch Probleme bei Sommer und Winter. Da aber die "normalen" Astrozeiten für ein Großteil der User eigentlich reicht, oder man die vorhandenen einfach mit einem Offset etwas anpasst, sind eben auch die von Blockly zur Verfügung stehenden Astro Zeiten auch ausreichend.
          OK, es gibt eben immer User die was extra haben wollen, aber für die bist dann eben Du zuständig 😉
            @quorle sagte:
            Fehlerlog:
            P
            P
            ple
            #280
            @quorle sagte:
            Fehlerlog:
            Besten Dank :-)👍
            Intel Nuc + Proxmox
            • M
              M
              Mitch
              #281
              Bisher leif das Script hier wunderbar
              Jetzt bekomme ich diese Fehler:
              javascript.0	2019-06-03 22:59:03.011	error	Cannot get astro date for "nightEnd"
              javascript.0	2019-06-03 22:59:03.010	error	Cannot get astro date for "night"
              javascript.0	2019-06-03 22:59:00.038	error	Cannot get astro date for "nightEnd"
              javascript.0	2019-06-03 22:59:00.038	warn	missing or unrecognized endTime expression: NaN
              javascript.0	2019-06-03 22:59:00.038	error	Cannot get astro date for "night"
              javascript.0	2019-06-03 22:59:00.037	error	Cannot get astro date for "night"
              Hier die Script-Version:
              erstellt: 01.06.2015 von Pix
              11.12.2015 getAstroDate ermittelt nun auch Sonnenaufgang und Untergang
              Astrotag (isAstroDay) eingebaut
              23.02.2018 checkSec eingebaut (Uhrzeit sekundengenau?)
              andere Astrozeiten werden nun auch gespeichert
              Neuer Pfad
              24.02.2018 Unterteilung in zwei Bereiche
              27.02.2018 Bestimmung, welche AstroZeit aktuell ist (mit der ioBroker-Funktion compareTime)
              Beschreibung Objekt Astrotag korrigiert
              Objekte werden jetzt bei jedem Zeitplan angelegt, falls nicht (mehr) vorhanden
              Weiss jemand Abhilfe?
              • M Mitch
                Neuer Pfad
                paul53P
                paul53P
                #282
                @Mitch sagte:
                Du wohnst zu weit nördlich. Es gibt ein modifiziertes Skript.
                  @Mitch sagte:
                  M
                  M
                  Mitch
                  #283
                  Wie immer, klasse Hilfe!
                  • D
                    D
                    darkiop
                    #284
                    Habe mal begonnen das ganze in ein Blockly zu packen, offen ist noch die "nächste Tageszeit":
                    https://gist.github.com/darkiop/236a5755b5f3d6f361907f59d10963ef
                    ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                    SpegeliS 1 Antwort Letzte Antwort
                      @quorle sagte:
                      Fehlerlog:
                      P
                      P
                      ple
                      #285
                      @quorle sagte:
                      Fehlerlog:
                      Gibt es auch die Möglichkeit die Ausgabe in 24h Format zu bekommen? bei mir sind die alle in 12h Format. Für Vis ist das ein wenig blöde.
                      Gruß und Danke
                      Intel Nuc + Proxmox
                      • Q quorle
                        paul53P
                        paul53P
                        #286
                        @quorle Mittlerweile ist es umgekehrt: Die Version 4.1.13 enthält diesen Fehler und auf Github ist er gefixt.
                        In Version 4.1.13 ist der fehlerhafte Vergleich "zwischen Astrozeit und Uhrzeit" in der Zeit zwischen Mitternacht und "nadir" gefixt.
                        • P ple
                          @quorle sagte:
                          Fehlerlog:
                          Besten Dank :-)👍
                          simatecS
                          simatecS
                          simatec
                          #287
                          Der Adapter shuttercontrol gibt Dir inzwischen auch alle Astrozeiten als Datenpunkt raus und ist dazu inzwischen recht funktionstüchtig für viele Möglichkeiten der Rolladensteuerung
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                          • simatecS simatec
                            sigi234S
                            sigi234S
                            #288
                            @simatec sagte in Astro-Tageszeit abfragen und in Datenpunkt eintragen:
                            Wohin?
                            • sigi234S sigi234
                              Wohin?
                              simatecS
                              simatecS
                              simatec
                              #289
                              @sigi234
                              Die Datenpunkte findest du im schuttercontrol.0.info
                              • simatecS simatec
                                @sigi234
                                sigi234S
                                sigi234S
                                #290
                                @sigi234
                                Aha, Danke dauerte ein wenig bzw. musste die Objekte aktualisieren........
                                • P
                                  P
                                  piet
                                  #291
                                  mein Iobroker läuft in einer VM auf Proxmox.
                                  Ich benutze das Script von paul53.
                                  Ich schaffe es nicht die Anzeige auf 24 Std zu bekommen.
                                  Ich habe die letzten zwei Tage diesen Thread 2 mal komplett durchgelesen.
                                  Alle Tipps befolgt, aber keine Lösung gefunden.
                                  Anzeige Date:
                                  root@iobroker:/etc/default# date
                                  Di 11. Jun 15:27:36 CEST 2019
                                  Zeitzone:
                                  root@iobroker:/etc/default# timedatectl
                                        Local time: Di 2019-06-11 15:29:19 CEST
                                    Universal time: Di 2019-06-11 13:29:19 UTC
                                          RTC time: Di 2019-06-11 13:29:19
                                   Network time on: yes
                                  NTP synchronized: yes
                                   RTC in local TZ: no
                                  Vielleicht hat ja noch jemand eine Idee für mich.
                                  Vielen Dank
                                  Aktiv: Pi 3
                                  Test: NUC mit Proxmox LXC und VM, Iobroker auf Debian.
                                  P 1 Antwort Letzte Antwort
                                  • P piet
                                    Anzeige Date:
                                    Zeitzone:
                                     RTC in local TZ: no
                                    Vielen Dank
                                    P
                                    P
                                    PrinzEisenherz1
                                    #292
                                    @piet Versuchs mal mit folgender Änderung
                                    setState(idSonnenaufgang, sonnenaufgang.toLocaleTimeString('de-DE', { hour12: false }));
                                    setState(idSonnenuntergang, sonnenuntergang.toLocaleTimeString('de-DE', { hour12: false }));
                                    Gruß Johnny
                                    Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                                    BBTownB 1 Antwort Letzte Antwort
                                    • P PrinzEisenherz1
                                      Gruß Johnny
                                      BBTownB
                                      BBTownB
                                      BBTown
                                      #293
                                      @PrinzEisenherz1 und wo fügst Du das ein?
                                      ioBroker auf NUC (VM debian v13 (Trixie ), node v24.22.2 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                                      • P
                                        P
                                        piet
                                        #294
                                        Ich würde auch gerne wissen wo das einzufügen ist.
                                        Aktiv: Pi 3
                                        • P piet
                                          P
                                          P
                                          PrinzEisenherz1
                                          #295
                                          das müsst ihr im Script an der Stelle wo die beiden setstate aufrufe sind abändern und nicht zusätzlich einfügen.
                                          Kuckt doch im Skript wo die zwei Zeilen sind
                                          setState(idSonnenaufgang,.............
                                          setState(idSonnenuntergang,........
                                          Und die ändert ihr mit meinem Vorschlag ab
                                          33.2k
                                          84.3k
