  4. Sonoff-Adapter
Sonoff-Adapter
sonoff-adapter
102 Beiträge 8 Kommentatoren 16.5k Aufrufe 6 Beobachtet
  • L Offline
    Leon111
    beim updaten.....
    root@raspberrypi:/opt/iobroker# sudo iobroker upgrade self
    Update js-controller from @1.5.8 to @1.5.12
    NPM version: 6.4.1
    npm install iobroker.js-controller@1.5.12 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
    #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack at emitTwo (events.js:126:13)
    gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.79-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.15.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    prebuild-install WARN install No prebuilt binaries found (target=8.15.0 runtime=node arch=arm libc= platform=linux)
    In file included from ../src/./serialport.h:6:0,
    from ../src/serialport.cpp:1:
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:291:12: internal compiler error: Speicherzugriffsfehler
    NAN_METHOD(Get) {
    ../node_modules/nan/nan.h:1566:33: note: in definition of macro ‘NAN_METHOD’
    Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
    make: *** [Release/obj.target/bindings/src/serialport.o] Fehler 1
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! not ok
    gyp ERR! not ok
    npm WARN JSON.parse Failed to parse json
    npm WARN JSON.parse Unexpected token
    npm WARN JSON.parse in JSON at position 14 while parsing '{
    npm WARN JSON.parse "_argsb: [
    npm WARN JSON.parse [
    npm WARN JSON.parse {
    npm WARN JSON.parse $ "ra'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 (node_modules/@serialport/bindings):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    Host "raspberrypi" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    root@raspberrypi:/opt/iobroker# Please submit a full bug report,
    -bash: Please: Kommando nicht gefunden.
    root@raspberrypi:/opt/iobroker# with preprocessed source if appropriate.
    -bash: with: Kommando nicht gefunden.
    root@raspberrypi:/opt/iobroker# See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
    -bash: file:///usr/share/doc/gcc-6/README.Bugs: Datei oder Verzeichnis nicht gefunden
    root@raspberrypi:/opt/iobroker# make: *** [Release/obj.target/bindings/src/serialport.o] Fehler 1
    -bash: make:: Kommando nicht gefunden.
    root@raspberrypi:/opt/iobroker# gyp ERR! build error
    -bash: gyp: Kommando nicht gefunden.
    root@raspberrypi:/opt/iobroker# gyp ERR! stack Error: make failed with exit code: 2
    make: *** Es wurden keine Ziele angegeben und keine „make“-Steuerdatei gefunden. Schluss.
    root@raspberrypi:/opt/iobroker# gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    -bash: Syntaxfehler beim unerwarteten Wort (' root@raspberrypi:/opt/iobroker# gyp ERR! stack at emitTwo (events.js:126:13) -bash: Syntaxfehler beim unerwarteten Wort ('
    root@raspberrypi:/opt/iobroker# gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    -bash: Syntaxfehler beim unerwarteten Wort (' root@raspberrypi:/opt/iobroker# gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12) -bash: Syntaxfehler beim unerwarteten Wort ('
    root@raspberrypi:/opt/iobroker# gyp ERR! System Linux 4.14.79-v7+
    root@raspberrypi:/opt/iobroker# gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    root@raspberrypi:/opt/iobroker# gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    root@raspberrypi:/opt/iobroker# gyp ERR! node -v v8.15.0
    root@raspberrypi:/opt/iobroker# gyp ERR! node-gyp -v v3.8.0
    root@raspberrypi:/opt/iobroker# gyp ERR! not ok
    sind ja irgendwelche Fehler aufgetreten
    • L Offline
      Leon111
      Plattform: linux
      RAM: 927.1 MB
      Node.js: v8.16.0
      NPM: v6.4.1
      raspberrypi
      Typ: js-controller
      Titel: JS controller
      OS: linux
      Verfügbar: 1.5.12
      Eingerichtet: 1.5.12
      Ereignisse: ⇥10 / ↦13
      visibility
      build
      Host raspberrypi
      ioBroker.admin 3.6.3
      • L Offline
        Leon111
        ein Update steht noch zur Verfügung und zwar Bluetooth von 0.5.2 zur 0.7.3 , aber wenn ich es ausfüre dann funktioniert der Adapter nicht mehr und dem entsprechen meine Bluetooth-Geräte , also lasse ich es lieber.
        Soll ich jetzt die Adapter "Sonoff" und "Mihome" wieder instalieren?
        • L Offline
          Leon111
          Der Sonoff-Adapter bleibt gelb....
          • L Leon111
            crunchipC Abwesend
            crunchipC Abwesend
            @Leon111 zeig mal
            und MQTT Einstellung eines deiner Sonoff Geräte
            • L Offline
              Leon111
              Der Port ist beim mir gleich 1883 im Adapter und in den Geräten
              • crunchipC Abwesend
                crunchipC Abwesend
                versuchs mal mit nodejs zu reparieren bzw altes löschen neu updaten
                du hast nodejs 8.16 und node8.15?
                • L Offline
                  Leon111
                  das habe ich auf Empfehlung Heute upgedatet. Habe bis jetzt die 8.15 gehabt.
                  Allerdings habe ich jetzt was anderes festgestellt:
                  mit dem Rechner, der über LAN mit dem internen Netzwerk verbunden ist kann ich z.B. aud die Visualisierung (192.168.178.57:8082) kommen. Alles richtig.
                  mit dem Handy über WLAN kann ich mich mit der Adresse nicht verbinden.
                  Auch die App IoBroker.vis funktioniert im internen WLAN nicht.
                  Gehe ich über Mobilfunk - VPN dann verbinde ich mich mit dem Iobroker ( bzw.Vis)
                  Ich denke also, das das Problemm irgendwo im WLan.... Fritzbox liegt.
                  Aber ich wieß nich wo genau.
                  Irgendwelche Ideen, Tips....?
                  J crunchipC 2 Antworten Letzte Antwort
                  • L Leon111
                    Jan1
                    @Leon111
                    wenn der BLE Adapter nach einem Update gelb wird, dann hast den Fixer auch noch nicht laufen lasen oder?
                    Das Log oben deutet auch auf einige Rechte Probleme hin, deshalb mal den Fix er drüber laufen lassen.
                    Ich habe bei mir alles aktuell inklusive des BLE und alles grün, wenn da was nicht grün wird, dann sind Probleme vorhanden und die lösen sich nicht, wenn man einfach die alte Version beibehält. Heißt da stimmt was nicht und wird früher oder später für noch mehr Probleme sorgen.
                    Fixer:
                    curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
                    • L Leon111
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @Leon111 gegebenenfalls die Fritzbox neu starten, die Wlan einstellungen kontrollieren, eventuell frequenzband abgeschaltet, Kanäle überprüfen
                      • L Offline
                        Leon111
                        Ich werde verrückt....... seit 24 Stunden bastle ich daran und es war kleiner Fehler. Beim Einrichten des Smart-TVs ist von den Fritzbox-Einstellungen „Die unten angezeigten aktiven WLAN-Geräte dürfen untereinander kommunizieren“ Hacken weggekommen.
                        Deshalb konnten sich die ganzen Geräte miteinander nicht unterhalten. Kleine Ursache….große Wirkung.
                        Jetzt läuft alles wieder wie es sein soll außer des BLE-Adapters. Den kann ich nicht updaten, da er dann gelb bleibt. Mit dem Fixer weiß ich nicht wie ich den aufspielen soll…
                        Erstmal aber herzlichen Dank an alle, die sich an der Lösung des Problems beteiligt haben.
                        Man weißt, dass man nicht alleine ist und früher oder später es zum Erfolg führen wird.
                        • L Leon111
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @Leon111 tja, so blöd manchmal es ist,
                          @Leon111 sagte in Sonoff-Adapter:
                          Mein Smart TV ist erst seit Heute online
                          hattest es ja selbst geschrieben, was du ver/geändert hast😀
                          ble sollte eigentlich auch laufen, steht hier ja genug im forum, so wie auch der Umgang mit dem Fixer-skript
                            Jan1
                            @crunchip
                            den Fixer einfach in die Konsole eingeben und vorher den IOBroker stoppen
                            cd /opt/iobroker
                            sudo iobroker stop
                            dann den Fixer und danach sudo iobroker start.
                            Wenn dann der BLE Adapter nicht läuft, ist was anderes noch nicht in Ordnung.
                            • J Jan1
                              @crunchip
                              cd /opt/iobroker
                              sudo iobroker stop
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @Jan1 https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
                              • L Offline
                                Leon111
                                Hallo Jan1, soll ich das so
                                in die Console eingeben?
                                noch vor dem Update von 0.5.2 zur 0.7.3 oder erst danach wenn der BLE Adapter gelb ist.
                                • L Leon111
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @Leon111 ja mach es zuerst
                                  • R Offline
                                    robson
                                    ich habe heute den Sonoff-Adapter (v2.2.2) installiert. Leider bekomme ich den Adapter nicht "grün". Er bleibt ständig "gelb". Ich habe zwei Gosund-Steckdosen (Tasmota), die passend konfiguriert sind und auf den MQTT-Port 1885 lauschen. Der Adapter wurde ebenfalls entsprechend auf Port 1885 eingestellt (Port 1883 war per default eingestellt. Habe diesen geändert, da ich den Port als Fehlerquelle ausschließen wollte).
                                    User und Passwort sind bei den Steckdosen und dem Adapter identisch.
                                    Die Log-Stufe habe ich auf "Debug" gestellt:
                                    sonoff.0	2019-10-30 13:14:10.630	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1572437650621,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1572434652804}
                                    sonoff.0	2019-10-30 13:14:10.626	info	Starting MQTT authenticated server on port 1885
                                    sonoff.0	2019-10-30 13:14:10.571	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.16.0
                                    host.ioBroker-RasPi4	2019-10-30 13:14:09.821	info	instance system.adapter.sonoff.0 started with pid 4030
                                    Einen Fehler lese ich aus dem Log nicht raus. Woran kann es liegen, dass der Adapter nicht auf "grün" springt?
                                    Einen anderen MQTT-Adapter habe ich nicht laufen.
                                    Die Installation des Adapters lieferte die Fehler, die auch @Leon111 bereits am 08.06. gepostet hat. Da der Adapter aber schlussendlich installiert wurde, glaube ich nicht, dass es daran liegt.
                                    Mein System:
                                    • Raspberry Pi 4
                                    • Admin 3.6.7
                                    • NPM 6.9.0
                                    • Node.js 10.16.0
                                    Kann mir jemand helfen?
                                    • R robson
                                      Mein System:
                                      • Raspberry Pi 4
                                      • Admin 3.6.7
                                      • NPM 6.9.0
                                      • Node.js 10.16.0
                                      Jan1
                                      @robson
                                      Sonoff Adapter ist 2.3.2 im latest aktuell.
                                      R 1 Antwort Letzte Antwort
                                      • J Jan1
                                        @robson
                                        robson
                                        @Jan1
                                        Danke. Habe jetzt 2.3.2 installiert, aber leider keine Besserung. Instanz steht weiterhin auf "gelb" und es sind keine Objekte aufgelistet.
                                        Im Log sind aber ein paar Punkte hinzugekommen:
                                        sonoff.0	2019-10-30 13:33:41.046	debug	system.adapter.admin.0: logging true
                                        sonoff.0	2019-10-30 13:33:33.795	debug	system.adapter.admin.0: logging false
                                        sonoff.0	2019-10-30 13:33:13.503	debug	system.adapter.admin.0: logging true
                                        sonoff.0	2019-10-30 13:33:03.500	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1572438783494,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1572434652804}
                                        sonoff.0	2019-10-30 13:33:03.492	info	Starting MQTT authenticated server on port 1885
                                        sonoff.0	2019-10-30 13:33:03.356	info	starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.16.0
                                        sonoff.0	2019-10-30 13:33:03.240	debug	statesDB connected
                                        sonoff.0	2019-10-30 13:33:03.205	debug	objectDB connected
                                        host.ioBroker-RasPi4	2019-10-30 13:33:02.432	info	instance system.adapter.sonoff.0 started with pid 5400
                                        J v522533V 2 Antworten Letzte Antwort
                                        • R robson
                                          @Jan1
                                          Jan1
                                          @robson
                                          Es wäre interessanter was für Fehler bei der Installation aufgetreten sind.
                                          Merke, wenn die Installation nicht sauber läuft, läuft der Adapter danach zu 99,9% nicht.
