  4. [Aufruf] deConz Adapter Testen 1.1.2
zigbeedeconz
532 Beiträge 57 Kommentatoren 180.5k Aufrufe 24 Beobachtet
  • BigWumpusB Offline
    BigWumpusB Offline
    BigWumpus
    #426
    Habe gestern auf 1.1.1 umgestellt - startet nicht.
    Erst die 1.0.1 startet wieder, also ab 1.1.0 habe ich den Fehler drin:
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	info	Restart adapter system.adapter.deconz.0 because enabled
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	error	instance system.adapter.deconz.0 terminated with code 1 ()
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/index.js:3:19)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	error	Caught by controller[0]: at Module.require (module.js:504:17)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.198	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at Module.load (module.js:494:32)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at Module._compile (module.js:549:28)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: at createScript (vm.js:56:10)
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: SyntaxError: Unexpected token ...
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.197	error	Caught by controller[0]: ^^^
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.196	error	Caught by controller[0]: ...options
    host.Home-Pi-ioBroker	2019-05-05 01:31:23.196	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:347
    host.Home-Pi-ioBroker	2019-05-05 01:31:21.707	info	instance system.adapter.deconz.0 started with pid 18094
    Pi3B ioBroker: SONOFFs Tasmota mit TasmoAdmin, Shelly2.5 Rollladen
    Pi2B RaspBee DeConz ZigBee: Philips&Innr&OSRAM Lampen/Stecker, Xiaomi Sensoren, Lichttaster und -Schalter
    Heizung: EQ-3 Max!
    Netz: AVM 7490, Devolo Magic 1
    • BigWumpusB BigWumpus
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #427
      @BigWumpus läuft bei dir noch nodejs v6.x.x?
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      BigWumpusB 1 Antwort Letzte Antwort
      • Jey CeeJ Jey Cee
        BigWumpusB Offline
        BigWumpusB Offline
        BigWumpus
        schrieb am zuletzt editiert von BigWumpus
        #428
        @Jey-Cee
        jupp, v6.14.3
        So, Update nach hier durchgeführt.
        Läuft jetzt!
        Heizung: EQ-3 Max!
          BigWumpusB Offline
          BigWumpus
          #429
          Das Problem mit dem unbekannten "Drücken"-Zustand bei Switches habe ich mit einer Abfrage gelöst:
          Die letzte Änderung des Feldes "lastupdated" darf bei mir maximal 100ms alt sein, dann ist es frisch gedrückt, sonst kann es von einem Adapter-Neustart stammen. Diese Abfrage muß aber etwas verzögert erfolgen, weil der "Buttonevent" zuerst gesetzt wird und ca. 4ms später der "Lastupdated"...
          Heizung: EQ-3 Max!
          • Jey CeeJ Jey Cee
            @Wildbill hab den code 1:1 von @Asgothian übernommen, hab nur den PR nicht gemerged weil ich schon andere Änderungen lokal drin hatte. Die Zeit von 800ms ist drin.
            Ich schau mir das nochmal an.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #430
            @Jey-Cee sagte in [Aufruf] deConz Adapter Testen 1.1.0:
            der Pull request den ich auf Github abgelegt hab hatte 2 Anpassungen am main.js - einmal auf die "true/false" Variante, die du auch in den haupt-zweig übernommen hast. Diese hat so nicht sauber funktioniert, da nach dem Trägern immer noch der Wert des eigentlichen buttonevent abgefragt werden muss. Deswegen hatte ich eine 2. Anpassung im Pull-Request, die den 'buttonpressed' auf den Wert setzt der auch im buttonevent drin steht, und später auf 0. Nur so kann man auch schnelle Tastenkombinationen sauber abfangen, da der Timeout kurz gewählt werden kann.
            Kannst Du das noch anpassen ?
            A.
            siggi85S Jey CeeJ 2 Antworten Letzte Antwort
            • AsgothianA Asgothian
              A.
              siggi85S Offline
              siggi85S Offline
              siggi85
              #431
              @Asgothian sagte in [Aufruf] deConz Adapter Testen 1.1.0:
              A.
              Fande ich auch super. 😊
                A.
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #432
                @Asgothian mach ich
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  #433
                  Es ist jetzt 1.1.2 online.
                  WICHTIG: Nodejs 6 wird nicht mehr unterstützt.
                  Diese Version soll möglichst bald ins stable, also hoffe ich auf viel Feedback.
                  Ab jetzt gibt es erstmal nur Bugfixes, neue features erst wieder wenn die Aktuelle version im Stable ist.
                  • AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #434
                    Update gemacht - bei mir geht soweit alles. Wenn mir etwas auffällt meld ich mich noch einmal.
                    Nochmal danke für das anpassen des buttonpressed - so wie es jetzt ist war das gedacht.
                    A.
                    • eumatsE Offline
                      eumatsE Offline
                      eumats
                      #435
                      Bei mir läuft 1.1.2 bisher auch stabil.
                      • siggi85S Offline
                        siggi85S Offline
                        siggi85
                        #436
                        Habe auch gerade installiert. Die ersten Tests sehen gut aus. Werde weiter beobachten. :)
                          Kugelkopf
                          #437
                          Gibt es zufällig ein Script, welches alle SQL Datenpunkte umschreibt? Wenn ich Updaten würde (0.4.0) dann müsste ich unglaublich viele Datenpunkte aufrufen und mit neuem (alten) Namen versehen. Das ganze hab ich damals schon einmal gemacht. Die komplette SQL Datenbank auf die neuen Namen umgestellt. Das war unglaublich viel Arbeit. Ich bin auch nicht wirklich Fit was Datenbanken angeht. Falls jemand die nötigen Querys und Inserts weiß und mitteilen mag, wäre das super! Ansonsten werde ich wohl auf 0.4.0 bleiben bis es nicht mehr geht.
                          Viele Grüße!
                            BigWumpusB Offline
                            BigWumpus
                            #438
                            gelöscht wegen ist nicht so
                            Heizung: EQ-3 Max!
                            H 1 Antwort Letzte Antwort
                              Hoffiheller
                              #439
                              Hallo @all ich bin relativ neu im Forum, lese aber schon eine Weile mit, nun habe ich auch mal ein Problem bezüglich deCONZ Adapter und PhosconApp(ich glaube Phoscon gehört hier nicht her).
                              Zu aller erst einmal an Riesen Danke an alle Mitwirkenden. Dankeschön
                              Grundsätzlich sind es keine Probleme nur ein paar Schönheitsfehler, vermutlich durch falsche Installation ausgelöst, ich finde aber nicht den richtigen Weg, bin aber vielleicht auch nur zu blöd die richtigen Schlüsselwörter zu suchen.
                              Folgende Probleme sind diese das ich im DeCONZ Adapter für meine Xiaomi Aqara Multisensoren keine Batterie werte angezeigt bekomme das Feld mit dem Wert bleibt leer, folgend ein Bild wo diese Werte vorhanden sind. Bild Text
                              Und in der PhosconApp bekomme ich die Temperatur werte von den Xiaomi Mijia Tür-/Fensterkontakten nicht übermittelt diese bleiben bei mir auf 0grad stehen anbei nochmal ein Bild wo die werte vorhanden sind.
                              Bild Text
                              Ich bin leider gerade unterwegs und kann euch nicht alle Daten übermitteln falls es aber gewünscht ist reiche ich es nach. Ansonsten funktioniert alles bestens mit meinen ConBee USB Stick am RaspberryPi 3b, deCONZ Adapter 1.1.2
                              Vielen Dank nochmal an die gesamte Community.
                              H K 2 Antworten Letzte Antwort
                              • H Hoffiheller
                                Bild Text
                                Hoffiheller
                                schrieb am zuletzt editiert von Hoffiheller
                                #440
                                sorry das mit den Bildern hat nicht geklappt, versuche es später nochmal.
                                Dieser Post kann gelöscht werden habe zu spät den Bearbeitungsbutton gesehen.
                                • H Hoffiheller
                                  Bild Text
                                  Kugelkopf
                                  #441
                                  @Hoffiheller Moin!
                                  Bzgl. der Batteriewerte: Dies ist ein bekannter Fehler in der aktuellen Firmware von DresdenElektronik selbst und hat nichts mit dem ioBrokerAdapter zu tun. Siehe: deConz Github Issus
                                  Zum Thema Temperaturen: Die Werte der Aqara Tür/Fenster/PIR Sensoren sind eh für die Katz und völlig unbrauchbar.
                                  Viele Grüße!
                                  • K Kugelkopf
                                    @Hoffiheller Moin!
                                    Viele Grüße!
                                    Hoffiheller
                                    #442
                                    @Kugelkopf
                                    Danke das hilft mir schon weiter. Der Batteriewert wäre schön, die Temperatur brauch ich ja nicht von den Kontaktsensoren da ich ja eh in jeden Raum einen Multisensor habe. Ich dachte nur ich Frage mal weil es ja bei den ein oder anderen ja angezeigt wird.
                                    Nochmals vielen Dank an die Community
                                    • H Hoffiheller
                                      @Kugelkopf
                                      Kugelkopf
                                      #443
                                      @Hoffiheller Ich gehe davon aus, dass sie diesen Fehler mit der nächsten FW wieder beheben. Hättest du noch die alte FW drauf gehabt beim hinzufügen der Multisensoren, dann würde dir vermutlich auch noch der Batteriestand angezeigt werden. Offenbar tritt der Fehler nur bei Sensoren auf, die neu oder wieder hinzugefügt wurden, unter der neuen FW. Kannst den Git ja mal abonnieren um auf dem neusten Stand zu bleiben. Ich rate dir allerdings von BetaVersionen ab.
                                      Viele Grüße!
                                      • eumatsE Offline
                                        eumatsE Offline
                                        eumats
                                        schrieb am zuletzt editiert von eumats
                                        #444
                                        Moin.
                                        Ich bin gerade dabei eine Überwachung meiner Xiaomi Sensoren zu realisieren. Also das ich eine Telgrammeldung bekommen, wenn der Datenpunkt reachable der Sensoren gleich false ist. Danke @AlCalzone habe ich das Skript auch schlank hingekommen.
                                        Nun wollte ich dieses Skript testen und habe den Ausfall eines Temperatursensors simuliert indem ich die Batterie entfernt habe. Das war gestern Abend um 17:30 Uhr. Leider ist der Datenpunkt des betroffenen Sensors immer noch reachable = true. In der Phocon-Webobefläche wird der Sensor auch nicht als ausgefallen erkannt.
                                        Ich habe den Adapter auf debug gestellt. Im betreffenden Zeitraum gab es keine Aktualisierung des Sensors.
                                        NACHTRAG: Auch ein Reboot des iobroker Rechnern hat nichts geändert.
                                        Hat jemand eine Idee?
                                        Eckdaten:
                                        • Stick: ConBee
                                          Version: 2.05.64 / 22.4.2019
                                          Firmware; 26320500
                                        • deconz V1.1.2
                                        • node -v v10.15.3
                                          nodejs -v v10.15.3
                                          npm -v 6.9.0
                                        siggi85S K 2 Antworten Letzte Antwort
                                        • eumatsE eumats
                                          Moin.
                                          Eckdaten:
                                          • Stick: ConBee
                                            Firmware; 26320500
                                          • deconz V1.1.2
                                          • node -v v10.15.3
                                            nodejs -v v10.15.3
                                            npm -v 6.9.0
                                          siggi85S Offline
                                          siggi85S Offline
                                          siggi85
                                          #445
                                          @eumats
                                          Die Frage ist ja, wann wird dieser Datenpunkt als false markiert? Also ab wann zählt ein Sensor als "nicht mehr erreichbar"?!
