  4. Adapter: ioBroker.info
info adapter
350 Beiträge 53 Kommentatoren 115.8k Aufrufe 23 Beobachtet
  • SBorgS SBorg
    War eigentlich oben schon alles, hatte nur die Spg. gekürzt:
    coretemp-isa-0000
    Adapter: ISA adapter
    Core 0:       +44.0°C  (crit = +100.0°C)
    Core 1:       +45.0°C  (crit = +100.0°C)
    w83627uhg-isa-0290
    in0:          +1.19 V  (min =  +0.00 V, max =  +1.74 V)
    in1:          +1.02 V  (min =  +1.42 V, max =  +0.02 V)  ALARM
    AVCC:         +4.92 V  (min =  +4.49 V, max =  +5.49 V)
    +5V:          +4.93 V  (min =  +4.49 V, max =  +5.51 V)
    in4:          +1.02 V  (min =  +0.53 V, max =  +0.50 V)  ALARM
    in5:          +1.50 V  (min =  +0.24 V, max =  +0.86 V)  ALARM
    5VSB:         +4.92 V  (min =  +4.49 V, max =  +5.49 V)
    Vbat:         +3.30 V  (min =  +2.69 V, max =  +3.64 V)
    fan1:           0 RPM  (min = 10546 RPM, div = 128)  ALARM
    fan2:           0 RPM  (min = 10546 RPM, div = 128)  ALARM
    SYSTIN:       +42.0°C  (high = +37.0°C, hyst = +111.0°C)  sensor = thermal diode
    CPUTIN:       +35.5°C  (high = +80.0°C, hyst = +75.0°C)  sensor = thermal diode
    intrusion0:  ALARM
    oder RAW:
    coretemp-isa-0000
    Core 0:
    temp2_input: 44.000
    temp2_crit: 100.000
    temp2_crit_alarm: 0.000
    Core 1:
    temp3_input: 45.000
    temp3_crit: 100.000
    temp3_crit_alarm: 0.000
    w83627uhg-isa-0290
    in0:
    in0_input: 1.192
    in0_min: 0.000
    in0_max: 1.744
    in0_alarm: 0.000
    in1:
    in1_input: 1.024
    in1_min: 1.424
    in1_max: 0.016
    in1_alarm: 1.000
    AVCC:
    in2_input: 4.925
    in2_min: 4.493
    in2_max: 5.491
    in2_alarm: 0.000
    +5V:
    in3_input: 4.931
    in3_min: 4.485
    in3_max: 5.513
    in3_alarm: 0.000
    in4:
    in4_input: 1.016
    in4_min: 0.528
    in4_max: 0.504
    in4_alarm: 1.000
    in5:
    in5_input: 1.496
    in5_min: 0.240
    in5_max: 0.856
    in5_alarm: 1.000
    5VSB:
    in7_input: 4.925
    in7_min: 4.493
    in7_max: 5.491
    in7_alarm: 0.000
    Vbat:
    in8_input: 3.298
    in8_min: 2.686
    in8_max: 3.638
    in8_alarm: 0.000
    fan1:
    fan1_input: 0.000
    fan1_min: 10546.000
    fan1_alarm: 1.000
    fan1_div: 128.000
    fan2:
    fan2_input: 0.000
    fan2_min: 10546.000
    fan2_alarm: 1.000
    fan2_div: 128.000
    SYSTIN:
    temp1_input: 41.000
    temp1_max: 37.000
    temp1_max_hyst: 111.000
    temp1_alarm: 0.000
    temp1_type: 3.000
    temp1_offset: 0.000
    CPUTIN:
    temp2_input: 35.500
    temp2_max: 80.000
    temp2_max_hyst: 75.000
    temp2_alarm: 0.000
    temp2_type: 3.000
    temp2_offset: 0.000
    intrusion0:
    intrusion0_alarm: 1.000
    ldittmarL Offline
    ldittmarL Offline
    ldittmar
    #270
    @SBorg Kannst du mir noch bitte sagen, ob die Werte im Objekte-Baum angezeigt werden?
    • SBorgS Offline
      SBorgS Offline
      SBorg
      #271
      Nö, glänzt durch gänzliche Leere :)
      LG SBorg ( SBorg auf GitHub)
      ldittmarL 1 Antwort Letzte Antwort
      • SBorgS SBorg
        ldittmarL Offline
        ldittmarL Offline
        ldittmar
        #272
        @SBorg Ahh... ja... Das Problem war, dass bei dir die Haupttemperatur nicht vom cotetemp-isa ausgegeben wird, sondern nur die Temperatur pro core. Ich bin davon ausgegangen, dass die Haupttemperatur immer dabei ist (wieder was gelernt) und geprüft ob da ein Wert drin ist. Wenn nicht habe ich dann halt nichts angezeigt. Ich habe es jetzt in der Github Version gefixt... Beim nächsten Update ist das auch dabei.
        Für die anderen Informationen aus lm-sensors existiert schon ein Issue. Es wird also daran gearbeitet und dann wird auch CPUTIN und SYSTIN berücksichtigt werden. https://github.com/sebhildebrandt/systeminformation/issues/220
        BBTownB 1 Antwort Letzte Antwort
        • SBorgS Offline
          SBorgS Offline
          SBorg
          #273
          Thx, Intel Atom Dual-Core halt...^^
          • ldittmarL ldittmar
            BBTownB Offline
            BBTownB Offline
            BBTown
            schrieb am zuletzt editiert von BBTown
            #274
            @ldittmar puhhhh .... im Augenblick habe ich den Info-Adapter nicht mehr lieb :-(
            Be jedem Aufruf oder refresh einer meiner ioBroker Seiten kommt eine nervige Warnung bzgl. des Z-Waves Adapters hoch.
            Davon mal abgesehen, dass ich diesen Adapter überhaupt nicht benutze, wäre ja ein einmaliger Hinweis in Ordnung, aber bei jedem Seitenaufruf???
            Ich habe den Adapter daher erst einmal deaktiviert - das nervt mich zu sehr :-(
            [Nachtrag]
            hmmm ... tue ich dem Adapter unrecht, kommen die nervigen Hinweise gar nicht vom Info-Adapter?
            Oder muss ich den sogar entfernen, damit das aufhört?
            ... so kann ich zumindest nicht mit ioBroker arbeiten ;-(
            ldittmarL DutchmanD 2 Antworten Letzte Antwort
            • BBTownB BBTown
              [Nachtrag]
              ldittmarL Offline
              ldittmarL Offline
              ldittmar
              #275
              @BBTown das ist ein Bug irgendwo im System. Wir sind dran es zu beheben. Die Meldungen verschwinden nach einer Zeit automatisch. Wir werden erstmal keine neue Nachrichten hinzufügen, bis die Ursache gefunden worden ist. Sorry....
              • BBTownB BBTown
                [Nachtrag]
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #276
                @BBTown sagte in Adapter: ioBroker.info:
                ich habe soeben die News gelöscht damit solltet ihr in 15-20 min das popup nicht mehr bekommen.
                Eigentlich sollte das pop-up nur einmal kommen und nach bestätigen nicht mehr, da geht aber leider etwas schief.
                Entschuldigt bitte de Unannehmlichkeiten die hierdurch entstanden sind
                ~ Dutch
                • liv-in-skyL Offline
                  liv-in-skyL Offline
                  #277
                  sorry für die frage, aber wo sollte den dieses popup erscheinen - ich sehe die fehlermeldung nur im infoadapter
                  ich habe die popups in chrome für iobroker blockiert - hat das damit zu tun, dass ich diese nicht sehe
                  • liv-in-skyL liv-in-sky
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #278
                    @liv-in-sky sagte in Adapter: ioBroker.info:
                    Danke.
                    • bahnuhrB bahnuhr
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #279
                      @bahnuhr das habe ich nicht gemeint - da seh ich es auch so wie abgebildet - weiter oben wird aber von popups gesprochen,
                      ich würde das gut finden, wenn ein popup kommt bei einer solchen warnung - mein browser ist meist den ganzen tag offen - ich hätte die warnung garnicht gesehen, wenn ich nicht zufällig im infoadapter nachgeschaut hätte, was es für updates gibt
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #280
                        Also ich hab nur diese meldung.
                        Popups hab ich nicht.
                        mfg
                        Danke.
                        • bahnuhrB bahnuhr
                          mfg
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #281
                          @bahnuhr :-) ich ja auch nicht - deshalb frage ich ja
                          vor ein paaar tagen hatte die cloud ein problem - kann vorkommen - ist kein problem - aber es wäre toll gewesen, darüber auch so eine nachricht zu bekommen und/oder ein ein popup im browser.
                          • BluemoonB Offline
                            BluemoonB Offline
                            Bluemoon
                            schrieb am zuletzt editiert von Bluemoon
                            #282
                            Hier habe ich die Meldung, sie kommt mehrmals am Tag!
                            Man muss nicht im Info Tab sein, da würde sie gleich kommen.
                            liv-in-skyL bahnuhrB 2 Antworten Letzte Antwort
                            • BluemoonB Bluemoon
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #283
                              @Bluemoon hast du mal die nachrichten im browser blockiert ?
                              BluemoonB 1 Antwort Letzte Antwort
                                BluemoonB Offline
                                BluemoonB Offline
                                Bluemoon
                                #284
                                @liv-in-sky
                                nein, habe ich noch nicht
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #285
                                  @Bluemoon sagte in Adapter: ioBroker.info:
                                  Also so ne Meldung hatte ich noch nicht.
                                  Benutze primär Chrome.
                                  Wüsste aber auch nicht, dass ich irgendein Blocker aktiviert habe.
                                  Danke.
                                    liv-in-skyL Offline
                                    #286
                                    wenn man in chrome darauf klickt - kann man popups blockieren (webseite einstellung)
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #287
                                      tatsächlich!
                                      Ist bei mir offensichtlich blockiert.
                                      Dann hat das aber chrome blockiert, oder?
                                      wahrscheinlich wg. dem "Nicht sicher", richtig ?
                                      mfg
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        tatsächlich!
                                        mfg
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #288
                                        @bahnuhr
                                        das weiß ich auch nicht so genau - aber vermutlich hast du recht
                                        ein paar zeilen weiter unten sind auch noch popups zum einstellen
                                        • ldittmarL Offline
                                          ldittmarL Offline
                                          ldittmar
                                          #289
                                          Das ist kein Popup, den man blockieren kann. Das ist eine Meldung vom Admin Adapter ab Version 3.6.1. Normalerweise sollte die Meldung nur einmal erscheinen, dann nie wieder. Irgendwo im System ist aber ein Fehler drin, der dazu führt, dass der Admin Adapter denkt er hätte die Meldung noch nicht angezeigt und deswegen kommt das Fenster immer wieder.
                                          Die Meldung wurde jetzt entfernt und sollte nicht mehr auftauchen. Ich werde jetzt auch ein Dummy Adapter bauen, um das Problem zu rekonstruieren um dann zusammen mit den anderen nach einer Lösung zu suchen. So lange werden keine neue Nachrichten im Info Adapter rein kommen.
                                          Und nochmals sorry... das Problem, warum das schon früher nicht bemerkt wurde, ist dass es beim Debuggen wunderbar funktioniert. Erst im Live Betrieb geht es nicht....
                                          Das Problem habt ihr auch nur wenn Admin 3.6.2 drauf ist...
                                          Also... wir sind dran es zu beheben.
                                          Grüße,
                                          ldittmar
