[Tutorial] VIS Fritzbox Status & Up/Downloadanzeige
Widget Icons
[{"tpl":"tplMfdCustom10","data":{"oid":"ping.0.Medion.192_168_178_1","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"icon0":"/icons-mfd-svg/it_router.svg","icon1":"","icon2":"","icon3":"","icon4":"","icon5":"","icon6":"","icon7":"","icon8":"","icon9":"","icon10":"/icons-mfd-svg/it_router.svg","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"","max":"","show_active":false,"iconValue0":"false","iconValue1":"","iconValue2":"","iconValue3":"","iconValue4":"","iconValue5":"","iconValue6":"","iconValue7":"","iconValue8":"","iconValue9":"","iconValue10":"true","iconColor0":"#ff0000","iconColor10":"#35ff05","iconColor8":"","iconColor9":"","iconColor3":"","iconColor1":"","iconColor5":"","invert_value":false,"iconColor2":"","iconColor4":"","iconColor7":"","iconColor6":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"391px","top":"548px","z-index":"1","width":"103px","height":"100px","border-style":"solid","border-color":"#0e5bec","border-radius":"2px","border-width":"1px"},"widgetSet":"jqui-mfd"}]Widget Rohre (Linien)
[{"tpl":"tplPlump_pipe_H","data":{"oid":"tr-064.0.states.wlan24","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","pipe_size":"5","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"color_on":"#35ff05","color_off":"#ff050d","conLeft":"w01273"},"style":{"left":"631px","top":"722px","width":"38px","height":"10px","z-index":"0"},"widgetSet":"plumb"}] -
Hat jemand noch das Problem, das diese Werte nicht übereinstimmen von der FritzBox?
upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived
upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesSentWenn auch der Received einen Wert von 5GB ca erreicht hat, fängt der wieder bei 0 an.
Alle anderen Daten werden mir richtig angezeigt.
Siehe hier meine Erkenntnisse dazu
Hallo
bei mir hat alles angefangen zu funktionieren. Jetzt gab es aber updates von Adaptern und nix ging mehr. Ich habe festgestellt das die Ordnerstruktur in den Objekten sich geändert hat und somit auch die Pfade. Ich habe es im Javascript und Blockly angepasst, aber es läuft nicht mehr.
Wer hat noch das Problem, oder habe ich was übersehen?Gruß
Werner -
@WernerS
Richtig, die Struktur des UPnP Adapters hat sich geändert.
Meine FritzBox Punkte finde ich jetzt z.B. unterupnp.0.FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfigEDIT:
Korrektur:
So sieht es jetzt aus:upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig. -
Hallo
bei mir das jetzt so aus
upnp.0.AVM_FRITZ!Mediaserver
upnp.0.InternetGatewayDeviceV2_-FRITZ!Box_7490
upnp.0.WANConnectionDevice-FRITZ!Box_7490
upnp.0.WANDevice-_FRITZ!Box_7490Es liegt aber anscheinend nicht an den Scripten, sondern da kommen jetzt wohl keine Daten mehr an. Alle Werte sind leer.
Werner -
Wie lange läuft der UPnP denn schon? Beim ersten Start kann es bis zu 20 Minuten dauern bis alle Datenpunkte angelegt sind und dann auch mit Daten befüllt werden.
Hast du denn überhaupt den Scheduler für die gewünschten Datenpunkte aktiviert, bzw. bekommst du Daten wenn du einen Request manuell auslöst?
Also das mit dem Request kannte ich nicht. Wieder was gelernt :-)
Wenn ich den auslöse kommen Daten.
Der Scheduler ist ja im Script angegeben. Da habe ich nichts geändert ausser die Pfade.Gruß
Werner@WernerS sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
Der Scheduler ist ja im Script angegeben...
... und da ist der Fehler :)
Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten. -
Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten.na da muss man erst mal drauf kommen. :-) Danke für die Info, werde es mir später mal anschauen.
Im Javascript nur die Zeile raus machen oder den Inhalt in der Klammer löschen? Mal sehen wie das für Blockly geht. Kriege ich schon hin.gruß
Werner -
Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten.@SBorg sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten.Gut zu wissen dass sich da in UPnP generell was geändert hat - ich hab schon an mir selber gezweifelt wieso der Wert nicht mehr aktualisiert wird...
Allerdings ist der request-Datenpunkt in meinen Objekten auch nicht vorhanden. Wo bekomme ich den denn her? Hab schon die neueste Version des UPnP-Adapters installiert... -
Das Script kann nun kpl. weggelassen werden. Das hat nichts weiter gemacht als die Datenpunkte abzufragen. Dies macht der UPnP-Adapter nun per Scheduling (und genau das hatte eigentlich das Script gemacht) von alleine.
@Thisoft sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
Hmm, hast du mal den Broker neu gestartet? Das hatten wir auch mal während des Beta-Testes des Adapters. Kann mich nur nicht mehr an den Fix erinnern. Notfalls Adapter anhalten, sämtliche Datenpunkte des UPnP löschen (also direkt das root UPnP.0) + Adapter neu starten. Dann sollte nach ~10-20 Minuten die Datenpunkte alle da sein.
Welchen Schraubenschlüssel meinst du? Der vom Datenpunkt da konfiguriere ich ja das abspeichern in zB. einer SQL Datenbank. Ansonsten kann ich nur die gesamte UPNP Instanz per scheduler einstellen.
Werner -
@sigi234 sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
Also ich habe es so gemacht mit upnp Adapter:
Views noch nicht fertig.
Hallo Sigi, sieht gut aus! Bestimmt jetzt fertig :-) Würdest du das das zum Download bereit stellen? View Export?
Wäre klasse. Hab genau die selbe Cabel Box
cu Deta
