  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.2k Aufrufe 40 Beobachtet
  • S Abwesend
    S Abwesend
    Shadowhunter23
    #770
    Und nochmal:
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.4 COM-Port is NOT matching 'by-id'.
    tcp
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    awk: run time error: regular expression compile failed (missing operand)
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
            FILENAME="-" FNR=1 NR=1
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
    *** NodeJS-Installation ***
    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
    ioBroker Backup Analyzer
    • S Shadowhunter23
      Erwartest du das so?
      USB-Devices by-id:
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      sed: -e expression #1, char 134: unknown command: `/'
      #771
      @Shadowhunter23
      Mist...
      Dann halt einfacheren Code...
      Bitte nochmal.
      • S Abwesend
        S Abwesend
        Shadowhunter23
        schrieb am zuletzt editiert von Shadowhunter23
        #772
        Hatt sich noch nichts geändert
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        zigbee.X
        \nExtended Pan ID:
        \n*** MASKED ***
        \nPan ID:
        \n*** MASKED ***
        \nChannel:
        \n*** MASKED ***
        \nNetwork Key:
        \n*** MASKED ***
        • S Shadowhunter23
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          zigbee.X
          \nExtended Pan ID:
          \n*** MASKED ***
          \nPan ID:
          \n*** MASKED ***
          \nChannel:
          \n*** MASKED ***
          \nNetwork Key:
          \n*** MASKED ***
          #773
          @Shadowhunter23 sagte in iob diag - Skript:
          Ich hab es auch vergessen hochzuladen...
          Bitte jetzt nochmal.
          • S Abwesend
            S Abwesend
            Shadowhunter23
            #774
            Habs x mal erneuert:
            USB-Devices by-id:
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            zigbee.X
            \nExtended Pan ID:
            \n*** MASKED ***
            \nPan ID:
            \n*** MASKED ***
            \nChannel:
            \n*** MASKED ***
            \nNetwork Key:
            \n*** MASKED ***
            • S Abwesend
              S Abwesend
              Shadowhunter23
              #775
              Jetzt sieht es besser aus:
              USB-Devices by-id:
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              zigbee.X
              \nExtended Pan ID:
              \n*** MASKED ***
              \nPan ID:
              \n*** MASKED ***
              \nChannel:
              \n*** MASKED ***
              \nNetwork Key:
              \n*** MASKED ***
              zigbee.0        tcp://192.168.0.64:20108            -                                   tcp
              zigbee.1        tcp://192.168.0.69:20108            -                                   tcp
              zigbee.2        tcp://192.168.0.79:20108            -                                   tcp
              zigbee.3        tcp://192.168.0.63:20108            -                                   tcp
              zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
              • S Shadowhunter23
                USB-Devices by-id:
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                zigbee.X
                \nExtended Pan ID:
                \n*** MASKED ***
                \nPan ID:
                \n*** MASKED ***
                \nChannel:
                \n*** MASKED ***
                \nNetwork Key:
                \n*** MASKED ***
                #776
                @Shadowhunter23
                Ah, das sieht wie gewollt aus.
                Kannst du es jetzt nochmal laden?
                Ich hoffe das war es dann.
                Bei mir schaut die Ausgabe nun so aus:
                zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
                • S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #777
                  USB-Devices by-id:
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  zigbee.X
                  \nExtended Pan ID:
                  \n*** MASKED ***
                  \nPan ID:
                  \n*** MASKED ***
                  \nChannel:
                  \n*** MASKED ***
                  \nNetwork Key:
                  \n*** MASKED ***
                  • S Shadowhunter23
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    \nExtended Pan ID:
                    \n*** MASKED ***
                    \nPan ID:
                    \n*** MASKED ***
                    \nChannel:
                    \n*** MASKED ***
                    \nNetwork Key:
                    \n*** MASKED ***
                    #778
                    @Shadowhunter23
                    Super, so sollte es aussehen. Und die Werte sind auch richtig zugeordnet?
                    Also zigbee.0 ist mit tcp://192.168.0.64:20108 konfiguriert?
                      @Shadowhunter23
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #779
                      @Thomas-Braun sagte in iob diag - Skript:
                      Ja bei allen passt es.
                      • S Shadowhunter23
                        #780
                        @Shadowhunter23
                        Ganz herzlichen Dank für dein geduldiges Testen!
                        Ich hab jetzt nur noch was kleines optisches angepasst.
                        Die Trennlinien sind jetzt länger... :-)
                        Jetzt wäre es toll, wenn noch jemand mit mehreren USB-Sticks oder einem Mix aus USB-Stick und tcp-Verbindung mal schauen könnte wie es dort aussieht.
                          @Shadowhunter23
                          TT-Tom
                          #781
                          @Thomas-Braun
                          von wo muss es gestartet werden? aus dem iobroker Verzeichnis oder aus meinem user Verzeichnis??
                          beim User habe ich ein paar Fehlermeldungen, arbeite da mit einem LXC Container.
                          Script v.2026-03-08
                          *** BASE SYSTEM ***
                          Operating System: Debian GNU/Linux 13 (trixie)
                           Static hostname: iobtest
                                 Icon name: computer-container
                                   Chassis: container ☐
                            Virtualization: lxc
                                    Kernel: Linux 6.17.13-1-pve
                              Architecture: x86-64
                          OS is similar to:
                          model name	: Intel(R) N100
                          CPU threads     : 4
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : 64bit
                          Systemuptime and Load:
                           09:21:36 up 5 days, 17:02,  1 user,  load average: 0.69, 0.68, 0.52
                          *** LIFE CYCLE STATUS ***
                          Operating System is the current Debian stable version codenamed 'trixie'!
                          *** TIME AND TIMEZONES ***
                                         Local time: Mon 2026-03-09 09:21:36 CET
                                     Universal time: Mon 2026-03-09 08:21:36 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          tom
                          HOME=/home/tom
                          GROUPS=tom sudo users iobroker
                          iobroker
                          [sudo] password for tom:
                          HOME=/home/iobroker
                          SUDO_HOME=/home/tom
                          GROUPS=iobroker tty dialout audio video plugdev
                          *** DISPLAY-SERVER SETUP ***
                          Display-Server:		Unknown
                          Display-Manager: 	Not found
                          Desktop:
                          Session:		tty
                          *** MEMORY ***
                          Mem:            8.4G        2.7G        5.5G        3.0M        145M        5.6G
                          Swap:           536M        234M        302M
                          Total:          8.9G        3.0G        5.8G
                          Active iob-Instances: 	16
                                   8000 M total memory
                                   2612 M used memory
                                   1649 M active memory
                                   1011 M inactive memory
                                   5250 M free memory
                                      0 M buffer memory
                                    139 M swap cache
                                    512 M total swap
                                    223 M used swap
                                    288 M free swap
                          top - 09:21:47 up 5 days, 17:02,  1 user,  load average: 0.90, 0.73, 0.54
                          Tasks:  41 total,   1 running,  40 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  3.6 us,  1.8 sy,  0.0 ni, 78.6 id, 16.1 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   8000.0 total,   5250.4 free,   2613.2 used,    139.2 buff/cache
                          MiB Swap:    512.0 total,    288.4 free,    223.6 used.   5386.8 avail Mem
                          *** FAILED SERVICES ***
                            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                  SUB    -> The low-level unit activation state, values depend on unit type.
                          2 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          dmesg: read kernel buffer failed: Operation not permitted
                          No critical errors detected
                          *** FILESYSTEM ***
                          Filesystem               Type      Size  Used Avail Use% Mounted on
                          DATEN1/subvol-101-disk-1 zfs        64G   14G   51G  22% /
                          none                     tmpfs     492K  4.0K  488K   1% /dev
                          udev                     devtmpfs   16G     0   16G   0% /dev/tty
                          tmpfs                    tmpfs      16G     0   16G   0% /dev/shm
                          tmpfs                    tmpfs     6.3G  132K  6.3G   1% /run
                          tmpfs                    tmpfs      16G  2.8M   16G   1% /tmp
                          tmpfs                    tmpfs     5.0M     0  5.0M   0% /run/lock
                          tmpfs                    tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
                          Messages concerning filesystems in dmesg:
                          Show mounted filesystems:
                          TARGET SOURCE                   FSTYPE OPTIONS
                          /      DATEN1/subvol-101-disk-1 zfs    rw,relatime,xattr,posixacl,casesensitive
                          /var:
                          319M	/var/
                          181M	/var/cache
                          178M	/var/cache/apt
                          125M	/var/cache/apt/archives
                          70M	/var/lib
                          Archived and active journals take up 4.2M in the file system.
                          /opt/iobroker/backups:
                          139M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          245M	/opt/iobroker/iobroker-data/
                          121M	/opt/iobroker/iobroker-data/backup-objects
                          113M	/opt/iobroker/iobroker-data/files
                          24M	/opt/iobroker/iobroker-data/files/mytime.admin
                          23M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets
                          15M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
                          7.8M	/opt/iobroker/iobroker-data/objects.jsonl
                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_08-19_objects.jsonl.gz
                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_06-19_objects.jsonl.gz
                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_04-19_objects.jsonl.gz
                          USB-Devices by-id:
                          zigbee.X
                          \nExtended Pan ID:
                          \n*** MASKED ***
                          \nPan ID:
                          \n*** MASKED ***
                          \nChannel:
                          \n*** MASKED ***
                          \nNetwork Key:
                          \n*** MASKED ***
                          /usr/bin/nodejs		v22.22.0
                          /usr/bin/node		v22.22.0
                          /usr/bin/npm		10.9.4
                          /usr/bin/npx		10.9.4
                          ✓ Node.js installation is correct
                          nodejs:
                            Installed: 22.22.0-1nodesource1
                            Candidate: 22.22.0-1nodesource1
                            Version table:
                           *** 22.22.0-1nodesource1 1001
                               22.21.0-1nodesource1 1001
                               22.20.0-1nodesource1 1001
                               22.19.0-1nodesource1 1001
                               22.18.0-1nodesource1 1001
                               22.17.1-1nodesource1 1001
                               22.17.0-1nodesource1 1001
                               22.16.0-1nodesource1 1001
                               22.15.1-1nodesource1 1001
                               22.15.0-1nodesource1 1001
                               22.14.0-1nodesource1 1001
                               22.13.1-1nodesource1 1001
                               22.13.0-1nodesource1 1001
                               22.12.0-1nodesource1 1001
                               22.11.0-1nodesource1 1001
                               22.10.0-1nodesource1 1001
                               22.9.0-1nodesource1 1001
                               22.8.0-1nodesource1 1001
                               22.7.0-1nodesource1 1001
                               22.6.0-1nodesource1 1001
                               22.5.1-1nodesource1 1001
                               22.5.0-1nodesource1 1001
                               22.4.1-1nodesource1 1001
                               22.4.0-1nodesource1 1001
                               22.3.0-1nodesource1 1001
                               22.2.0-1nodesource1 1001
                               22.1.0-1nodesource1 1001
                               22.0.0-1nodesource1 1001
                               20.19.2+dfsg-1 500
                                  500 http://deb.debian.org/debian trixie/main amd64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          node:fs:2437
                              return binding.writeFileUtf8(
                          Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                              at Object.writeFileSync (node:fs:2437:20)
                              at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
                              at Object.onceWrapper (node:events:634:26)
                              at ClientRequest.emit (node:events:519:28)
                              at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:772:27)
                              at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17)
                              at TLSSocket.socketOnData (node:_http_client:614:22)
                              at TLSSocket.emit (node:events:519:28)
                              at addChunk (node:internal/streams/readable:561:12)
                              at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
                            errno: -13,
                            code: 'EACCES',
                            syscall: 'open',
                            path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                          Node.js v22.22.0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 493355)
                          Core adapters versions
                          js-controller: 	7.1.0
                          admin: 		7.8.2
                          javascript: 	9.0.18
                          nodejs modules from github: 	3
                          +-- iobroker.fahrplan@1.4.1 (git+ssh://git@github.com/tt-tom17/ioBroker.fahrplan.git#a25514b1774a271768b58081fe4031bf3eb9ebca)
                          +-- iobroker.nspanel-lovelace-ui@0.13.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803)
                          +-- iobroker.public-transport@0.0.5 (git+ssh://git@github.com/tt-tom17/ioBroker.public-transport.git#335d0dd3595a1dd8da7aa69116f84923b001ff5b)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                          + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                            system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobtest                                  - disabled
                            system.adapter.devices.0                : devices               : iobtest                                  - disabled
                          + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                            system.adapter.hmip.0                   : hmip                  : iobtest                                  - disabled
                            system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                          + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                          + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 1883
                          + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.mqtt.1                   : mqtt                  : iobtest                                  - disabled, port: 1883, bind: 0.0.0.0
                            system.adapter.mytime.0                 : mytime                : iobtest                                  - disabled
                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                          + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  -  enabled
                            system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                            system.adapter.openweathermap.0         : openweathermap        : iobtest                                  -  enabled
                          + system.adapter.pirate-weather.0         : pirate-weather        : iobtest                                  -  enabled
                            system.adapter.proxmox.0                : proxmox               : iobtest                                  - disabled
                          + system.adapter.public-transport.0       : public-transport      : iobtest                                  -  enabled
                          + system.adapter.simple-api.0             : simple-api            : iobtest                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.socketio.0               : socketio              : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                            system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobtest                                  -  enabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobtest                                  -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobtest                                  -  enabled
                            system.adapter.vis.0                    : vis                   : iobtest                                  -  enabled
                          + system.adapter.web.0                    : web                   : iobtest                                  -  enabled, port: 8082, bind: 192.168.178.53, run as: admin
                            system.adapter.ws.0                     : ws                    : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                            system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobtest                                  - disabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): beta
                          Upgrade policy: none
                          Installed ioBroker-Adapters
                          Used repository: beta
                          Adapter    "admin"        : 7.8.3    , installed 7.8.2  [Updatable]
                          Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                          Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                          Adapter    "cloudless-homeconnect": 1.6.3, installed 1.6.3
                          Adapter    "devices"      : 1.2.14   , installed 1.2.14
                          Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                          Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                          Adapter    "ical"         : 1.19.7   , installed 1.19.7
                          Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                          Controller "js-controller": 7.1.0    , installed 7.1.0
                          Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                          Adapter    "mytime"       : 2.3.2    , installed 2.3.2
                          Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                          Adapter    "nspanel-lovelace-ui": 0.13.4, installed 0.13.4
                          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                          Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                          Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
                          Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                          Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                          Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                          Adapter    "trashschedule": 5.2.1    , installed 5.2.1
                          Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                          Adapter    "web"          : 8.0.0    , installed 8.0.0
                          Adapter    "ws"           : 4.0.0    , installed 4.0.0
                          Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                          Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
                          Objects and States
                          Objects: 	10075
                          States: 	8039
                          Hit:1 http://security.debian.org trixie-security InRelease
                          Hit:2 http://deb.debian.org/debian trixie InRelease
                          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                          Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                          Reading package lists... Done
                          Pending systemupdates: 1
                          *** Listening Ports ***
                          Netid State  Recv-Q Send-Q  Local Address:Port     Peer Address:Port Process
                          udp   UNCONN 0      0             0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=5),("systemd",pid=1,fd=35))
                          udp   UNCONN 0      0                [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=7),("systemd",pid=1,fd=37))
                          tcp   LISTEN 0      511    192.168.178.53:8082          0.0.0.0:*     users:(("io.web.0",pid=637,fd=35))
                          tcp   LISTEN 0      100         127.0.0.1:smtp          0.0.0.0:*     users:(("master",pid=294,fd=13))
                          tcp   LISTEN 0      4096          0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=4),("systemd",pid=1,fd=34))
                          tcp   LISTEN 0      511         127.0.0.1:9001          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=23))
                          tcp   LISTEN 0      511         127.0.0.1:9000          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=29))
                          tcp   LISTEN 0      511                 *:tproxy              *:*     users:(("io.admin.0",pid=882,fd=39))
                          tcp   LISTEN 0      511                 *:8087                *:*     users:(("io.simple-api.0",pid=684,fd=35))
                          tcp   LISTEN 0      100             [::1]:smtp             [::]:*     users:(("master",pid=294,fd=14))
                          tcp   LISTEN 0      4096                *:ssh                 *:*     users:(("sshd",pid=165,fd=3),("systemd",pid=1,fd=61))
                          tcp   LISTEN 0      4096             [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=6),("systemd",pid=1,fd=36))
                          2026-03-09 09:01:43.488  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 25570
                          2026-03-09 09:01:44.377  - info: nspanel-lovelace-ui.0 (25570) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                          2026-03-09 09:01:44.429  - info: nspanel-lovelace-ui.0 (25570) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                          2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                          2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                          2026-03-09 09:01:46.351  - info: nspanel-lovelace-ui.0 (25570) [Buero] Setting panel to offline until first message!
                          2026-03-09 09:01:46.392  - info: nspanel-lovelace-ui.0 (25570) [DEV-Panel] Setting panel to offline until first message!
                          2026-03-09 09:01:53.211  - info: nspanel-lovelace-ui.0 (25570) [controller] 2 Panels initialized
                          2026-03-09 09:01:54.380  - info: nspanel-lovelace-ui.0 (25570) [Buero] is online!
                          2026-03-09 09:01:54.803  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                          2026-03-09 09:05:01.421  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                          2026-03-09 09:05:20.941  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                          2026-03-09 09:05:21.194  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2026-03-09 09:10:26.298  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                          2026-03-09 09:10:26.578  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2026-03-09 09:11:37.614  - warn: admin.0 (882) nspanel-lovelace-ui has an invalid jsonConfig: [{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"attr"},"message":"must NOT have additional properties"},{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/items/allOf/18/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower/items/pagePowerdata","schemaPath":"#/patternProperties/%5E.%2B/allOf/57/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                          2026-03-09 09:15:05.013  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 25592
                          2026-03-09 09:15:05.673  - info: netatmo-crawler.0 (25592) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.22.0, js-controller: 7.1.0
                          2026-03-09 09:15:05.690  - info: netatmo-crawler.0 (25592) Getting data for stationid:70:ee:50:35:dc:b6
                          2026-03-09 09:15:06.537  - info: netatmo-crawler.0 (25592) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                          2026-03-09 09:15:07.047  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 25592 terminated with code 0 (NO_ERROR)
                          2026-03-09 09:15:30.461  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                          2026-03-09 09:15:30.698  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2026-03-09 09:20:34.384  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                          2026-03-09 09:20:34.716  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                          zum Vergleich die normal iob diag Ausgabe
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                          CPU threads: 4
                                         Local time: Mon 2026-03-09 09:51:54 CET
                                     Universal time: Mon 2026-03-09 08:51:54 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          tom
                          HOME=/home/tom
                          iobroker
                          HOME=/home/iobroker
                          SUDO_HOME=/home/tom
                          Display-Server: 	false
                          Unit display-manager.service could not be found.
                          Display-Manager:
                          Desktop:
                          Session: 		tty
                          *** MEMORY ***
                          Mem:            8.4G        2.0G        6.2G        3.1M        194M        6.4G
                          Swap:           536M        339K        536M
                          Total:          8.9G        2.0G        6.8G
                                   8000 M total memory
                                   1865 M used memory
                                   1904 M active memory
                                     43 M inactive memory
                                   5952 M free memory
                                      0 M buffer memory
                                    185 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    511 M free swap
                          top - 09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                          Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   8000.0 total,   5951.3 free,   1866.2 used,    185.3 buff/cache
                          MiB Swap:    512.0 total,    511.7 free,      0.3 used.   6133.8 avail Mem
                          *** FILESYSTEM ***
                          /var:
                          319M	/var/
                          181M	/var/cache
                          178M	/var/cache/apt
                          70M	/var/lib
                          Archived and active journals take up 4.3M in the file system.
                          242M	/opt/iobroker/iobroker-data/
                          7.6M	/opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm 		10.9.4
                          /usr/bin/npx 		10.9.4
                          nodejs:
                            Candidate: 22.22.1-1nodesource1
                            Version table:
                               22.22.1-1nodesource1 1001
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 316)
                          admin: 		7.8.2
                          javascript: 	9.0.18
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects: 	10019
                          States: 	7993
                          tcp        0      0 192.168.178.53:8082     0.0.0.0:*               LISTEN      1001       31394874   27969/io.web.0
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          30032      294/master
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17403      1/init
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31384629   27130/iobroker.js-c
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31384634   27130/iobroker.js-c
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31384845   27149/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31395098   28008/io.simple-api
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          30033      294/master
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          21994      1/init
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          17405      1/init
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17404      1/init
                          udp6       0      0 :::111                  :::*                                0          17406      1/init
                          2026-03-09 09:47:37.959  - error: javascript.0 (27223) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr
                          2026-03-09 09:47:39.217  - info: vis.0 (28024) Terminated (NO_ERROR): Without reason
                          2026-03-09 09:47:39.744  - info: host.iobtest instance system.adapter.vis.0 terminated while should be started once
                          2026-03-09 09:47:41.039  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 28082
                          2026-03-09 09:47:41.820  - info: nspanel-lovelace-ui.0 (28082) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                          2026-03-09 09:47:43.781  - info: nspanel-lovelace-ui.0 (28082) [Buero] Setting panel to offline until first message!
                          2026-03-09 09:47:43.823  - info: nspanel-lovelace-ui.0 (28082) [DEV-Panel] Setting panel to offline until first message!
                          2026-03-09 09:47:44.836  - info: host.iobtest instance system.adapter.public-transport.0 in version "0.0.5" (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) started with pid 28097
                          2026-03-09 09:47:45.575  - info: public-transport.0 (28097) starting. Version 0.0.5 (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) in /opt/iobroker/node_modules/iobroker.public-transport, node: v22.22.0, js-controller: 7.1.0
                          2026-03-09 09:47:45.634  - info: public-transport.0 (28097) HAFAS-Client initialisiert mit Profil: vbb
                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097)   - S Zepernick (ID: 900350163)
                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097) Rufe Abfahrten ab für: S Zepernick (900350163)
                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Abfahrten aktualisiert für: S Zepernick (900350163)
                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Erste Abfrage abgeschlossen: 1 erfolgreich, 0 fehlgeschlagen
                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Warte auf die nächste Abfrage in 60 Minuten...
                          2026-03-09 09:47:46.242  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                          2026-03-09 09:47:46.242  - info: public-transport.0 (28097) Infos für: S Zepernick (900350163) abfragen...
                          2026-03-09 09:47:50.280  - info: nspanel-lovelace-ui.0 (28082) [Buero] is online!
                          2026-03-09 09:47:50.972  - info: nspanel-lovelace-ui.0 (28082) [controller] 2 Panels initialized
                          2026-03-09 09:47:51.086  - info: nspanel-lovelace-ui.0 (28082) [Buero] Panel startup finished!
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • T TT-Tom
                            @Thomas-Braun
                            Script v.2026-03-08
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            CPU threads     : 4
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64bit
                                             RTC time: n/a
                                      RTC in local TZ: no
                            tom
                            HOME=/home/tom
                            iobroker
                            HOME=/home/iobroker
                            SUDO_HOME=/home/tom
                            Desktop:
                            Session:		tty
                            *** MEMORY ***
                                     8000 M total memory
                                     2612 M used memory
                                     5250 M free memory
                                        0 M buffer memory
                                      139 M swap cache
                                      512 M total swap
                                      223 M used swap
                                      288 M free swap
                            *** FILESYSTEM ***
                            /var:
                            319M	/var/
                            181M	/var/cache
                            178M	/var/cache/apt
                            70M	/var/lib
                            USB-Devices by-id:
                            zigbee.X
                            \nExtended Pan ID:
                            \n*** MASKED ***
                            \nPan ID:
                            \n*** MASKED ***
                            \nChannel:
                            \n*** MASKED ***
                            \nNetwork Key:
                            \n*** MASKED ***
                            /usr/bin/npm		10.9.4
                            /usr/bin/npx		10.9.4
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            node:fs:2437
                              errno: -13,
                              code: 'EACCES',
                              syscall: 'open',
                            Node.js v22.22.0
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin: 		7.8.2
                            javascript: 	9.0.18
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	10075
                            States: 	8039
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            tom
                            HOME=/home/tom
                            iobroker
                            HOME=/home/iobroker
                            SUDO_HOME=/home/tom
                            Display-Manager:
                            Desktop:
                            Session: 		tty
                            *** MEMORY ***
                                     8000 M total memory
                                     1865 M used memory
                                     5952 M free memory
                                        0 M buffer memory
                                      185 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      511 M free swap
                            *** FILESYSTEM ***
                            /var:
                            319M	/var/
                            181M	/var/cache
                            178M	/var/cache/apt
                            70M	/var/lib
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm 		10.9.4
                            /usr/bin/npx 		10.9.4
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin: 		7.8.2
                            javascript: 	9.0.18
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	10019
                            States: 	7993
                            #782
                            @TT-Tom sagte in iob diag - Skript:
                            Aus dem Verzeichnis, wo das heruntergeladene Skript liegt. Sollte i.d.R. das home-Verzeichnis des users sein.
                            Die Meldung
                            sollte eigentlich nicht kommen. Aber da es beim 'ordentlichen' Aufruf via 'iob diag' funktioniert ist es auch nicht weiter wichtig.
                            Den ZibBee-Adapter hast du gar nicht am Start, dafür aber zigbee2mqtt. Passt also in der Ausgabe dann.
                            Am Rande:
                            Spiel das nodejs-Update ein. ;-)
                            T 2 Antworten Letzte Antwort
                            • S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #783
                              Ob das was ausmacht kann @thomas-braun beantworten, dein User hat nicht alle Gruppen. Laut Anleitung müsstest du folgendes tun:
                              Falls ein User nachträglich angelegt werden soll muss dieser noch per
                              usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker tom
                              den relevanten Gruppen hinzugefügt werden.
                              Ich rufe das Script auch aus dem user Verzeichnis auf und es läuft ohne Probleme ( auch ein LXC ).
                                Die Meldung
                                Am Rande:
                                TT-Tom
                                #784
                                @Thomas-Braun
                                okay dann ist die obere Ausgabe, wie geschrieben aus dem User-Verzeichnis und unten die normale iob diag vom ioBroker.
                                mach ich :)
                                Gruß Tom
                                Public Transport
                                • S Shadowhunter23
                                  TT-Tom
                                  #785
                                  @Shadowhunter23
                                  bleiben die selben Meldungen
                                  Gruß Tom
                                  Public Transport
                                    Die Meldung
                                    Am Rande:
                                    TT-Tom
                                    #786
                                    @Thomas-Braun
                                    habe es mal mit unmask aufgerufen
                                    hier ein Fehler in der PanID, wobei ich ja kein Zigbee.0 habe und auch ein ZigbeeOnLan im System
                                    Pan ID:
                                    ./iob_diag.sh: line 693: printf: 0x906": invalid hex number
                                    2310
                                    die andern Zigbee Ausgaben passen.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @Thomas-Braun
                                      Pan ID:
                                      2310
                                      #787
                                      Danke! Das muss ich abfangen, der Wert wird aus einem USB-Stick bzw. dem nvbackup ausgelesen. Wenn das nicht vorhanden ist kommt diese Meldung.
                                      Kannst du mir die Zigbee-Passage bei dir mal vollständig mit der --unmask Option zeigen?
                                      (Wobei, so ganz eigentlich sollte der Code gar nicht durchlaufen werden, wenn es keine zigbee.X Instanz gibt)
                                      • S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #788
                                        Schade das hier nicht viele mit Zigbee den Code von @thomas-braun testen.
                                        • S Shadowhunter23
                                          #789
                                          es geht doch jetzt um die absolut seltene Kombination von (mehreren) LAN mit einem oder mehreren USB Konvertern
