  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.2k Aufrufe 40 Beobachtet
  • S Abwesend
    S Abwesend
    Shadowhunter23
    schrieb am zuletzt editiert von Shadowhunter23
    #762
    Komplett ohne Log:
    Script v.2026-03-08
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.13-1-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
    CPU threads     : 6
    Docker          : false        Virtualization  : lxc        Kernel          : x86_64        Userland        : 64bit        Systemuptime and Load:        22:55:31 up  3:01,  2 users,  load average: 0.41, 0.39, 0.31        *** LIFE CYCLE STATUS ***        Operating System is the current Debian stable version codenamed 'trixie'!        *** TIME AND TIMEZONES ***        Local time: Sun 2026-03-08 22:55:31 CET        Universal time: Sun 2026-03-08 21:55:31 UTC        RTC time: n/a        Time zone: Europe/Berlin (CET, +0100)        System clock synchronized: yes        NTP service: inactive        RTC in local TZ: no        *** Users and Groups ***        User that called 'iob diag':        tobias
    HOME=/home/tobias
    GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/tobias
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             10G        4.6G        6.1G        2.4M         63M        6.2G
    Swap:           5.4G          0B        5.4G
    Total:           16G        4.6G         11G
    Active iob-Instances:   46
            10240 M total memory
             4355 M used memory
             4240 M active memory
                0 M inactive memory
             5825 M free memory
                0 M buffer memory
               60 M swap cache
             5120 M total swap
                0 M used swap
             5120 M free swap
    top - 22:55:31 up  3:01,  2 users,  load average: 0.41, 0.39, 0.31
    Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.6 us,  1.6 sy,  0.0 ni, 96.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10240.0 total,   5824.9 free,   4356.4 used,     60.8 buff/cache
    MiB Swap:   5120.0 total,   5120.0 free,      0.0 used.   5883.6 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type      Size  Used Avail Use% Mounted on
    DATA/subvol-400-disk-0 zfs        20G  4.3G   16G  22% /
    none                   tmpfs     492K  4.0K  488K   1% /dev
    udev                   devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                  tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                  tmpfs     6.3G  152K  6.3G   1% /run
    tmpfs                  tmpfs      16G  1.9M   16G   1% /tmp
    tmpfs                  tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                  tmpfs     3.2G   12K  3.2G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    Show mounted filesystems:
    TARGET SOURCE                 FSTYPE OPTIONS
    /      DATA/subvol-400-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    559M    /var/
    221M    /var/cache
    219M    /var/cache/apt
    209M    /var/lib
    166M    /var/cache/apt/archives
    Archived and active journals take up 125.1M in the file system.
    /opt/iobroker/backups:
    136M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    31M     /opt/iobroker/iobroker-data/
    27M     /opt/iobroker/iobroker-data/files
    20M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    3.3M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    2.8M    /opt/iobroker/iobroker-data/objects.jsonl
    1.2M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
    1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.4 COM-Port is NOT matching 'by-id'.
    tcp
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        tcp://192.168.0.64:20108
    tcp://192.168.0.69:20108 -                                   tcp
    zigbee.1        tcp://192.168.0.69:20108
    tcp://192.168.0.79:20108 -                                   tcp
    zigbee.2        tcp://192.168.0.79:20108
    tcp://192.168.0.63:20108 -                                   tcp
    zigbee.3        tcp://192.168.0.63:20108
    tcp://192.168.0.99:20108 -                                   tcp
    zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 10891)
    Core adapters versions
    js-controller:  7.1.0
    admin:          7.8.3
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.ankersolix2.0            : ankersolix2           : iobroker                                 - disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.8.3    , installed 7.8.3
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
    Adapter    "cloud"        : 6.0.1    , installed 6.0.1
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.0    , installed 7.1.0
    Adapter    "lg-thinq"     : 1.1.6    , installed 1.1.6
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "mytime"       : 2.3.2    , installed 2.3.2
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "operating-hours": 1.4.1  , installed 1.4.1
    Adapter    "ping"         : 2.1.0    , installed 2.1.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "sayit"        : 5.1.0    , installed 5.1.0
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 5.2.1    , installed 5.2.1
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        12439
    States:         11004
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid    State     Recv-Q    Send-Q       Local Address:Port         Peer Address:Port    Process        udp      UNCONN    0         0                  0.0.0.0:6666              0.0.0.0:*        users:(("io.tuya.0",pid=943,fd=40))                                                   udp      UNCONN    0         0                  0.0.0.0:6667              0.0.0.0:*        users:(("io.tuya.0",pid=943,fd=41))                                                   udp      UNCONN    0         0                  0.0.0.0:sunrpc            0.0.0.0:*        users:(("rpcbind",pid=141,fd=5),("systemd",pid=1,fd=35))                              udp      UNCONN    0         0                  0.0.0.0:mdns              0.0.0.0:*        users:(("io.chromecast.0",pid=615,fd=35))                                             udp      UNCONN    0         0                  0.0.0.0:coap              0.0.0.0:*        users:(("io.shelly.0",pid=899,fd=52))                                                 udp      UNCONN    0         0                     [::]:sunrpc               [::]:*        users:(("rpcbind",pid=141,fd=7),("systemd",pid=1,fd=37))                              tcp      LISTEN    0         511          192.168.0.222:9092              0.0.0.0:*        users:(("io.nuki.0",pid=808,fd=31))                                                   tcp      LISTEN    0         4096               0.0.0.0:sunrpc            0.0.0.0:*        users:(("rpcbind",pid=141,fd=4),("systemd",pid=1,fd=34))                              tcp      LISTEN    0         511                0.0.0.0:1882              0.0.0.0:*        users:(("io.shelly.1",pid=921,fd=45))                                                 tcp      LISTEN    0         511                0.0.0.0:1883              0.0.0.0:*        users:(("io.mqtt.0",pid=756,fd=35))                                                   tcp      LISTEN    0         100              127.0.0.1:smtp              0.0.0.0:*        users:(("master",pid=371,fd=13))                                                      tcp      LISTEN    0         511              127.0.0.1:redis             0.0.0.0:*        users:(("redis-server",pid=164,fd=8))                                                 tcp      LISTEN    0         100                  [::1]:smtp                 [::]:*        users:(("master",pid=371,fd=14))                                                      tcp      LISTEN    0         511                  [::1]:redis                [::]:*        users:(("redis-server",pid=164,fd=9))                                                 tcp      LISTEN    0         4096                  [::]:sunrpc               [::]:*        users:(("rpcbind",pid=141,fd=6),("systemd",pid=1,fd=36))                              tcp      LISTEN    0         511                      *:http                    *:*        users:(("apache2",pid=207,fd=4),("apache2",pid=206,fd=4),("apache2",pid=204,fd=4))    tcp      LISTEN    0         4096                     *:ssh                     *:*        users:(("sshd",pid=191,fd=3),("systemd",pid=1,fd=65))                                 tcp      LISTEN    0         511                      *:3000                    *:*        users:(("io.fullybrowser",pid=689,fd=30))                                             tcp      LISTEN    0         511                      *:8087                    *:*        users:(("io.simple-api.0",pid=1316,fd=35))                                            tcp      LISTEN    0         511                      *:8082                    *:*        users:(("io.web.0",pid=1441,fd=35))                                                   tcp      LISTEN    0         511                      *:tproxy                  *:*        users:(("io.admin.0",pid=401,fd=39))
    Das einfügen ab Listening Ports ist gerade schwierig. Müsste ich morgen Mal vom PC machen.
    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
    ioBroker Backup Analyzer
    • S Shadowhunter23
      Komplett ohne Log:
      Script v.2026-03-08
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      CPU threads     : 6
      HOME=/home/tobias
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           5.4G          0B        5.4G
      Total:           16G        4.6G         11G
               4355 M used memory
                  0 M inactive memory
               5825 M free memory
                  0 M buffer memory
                 60 M swap cache
               5120 M total swap
                  0 M used swap
               5120 M free swap
      *** FILESYSTEM ***
      /var:
      559M    /var/
      221M    /var/cache
      219M    /var/cache/apt
      209M    /var/lib
      USB-Devices by-id:
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin:          7.8.3
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        12439
      States:         11004
      #763
      @Shadowhunter23
      Nur die Tabelle mit den Zigbee-Ports (oder wie es gerade bei dir aussieht) reicht.
      Versuch nochmal.
      • S Abwesend
        S Abwesend
        Shadowhunter23
        #764
        Leider als Bild
        • S Abwesend
          S Abwesend
          Shadowhunter23
          #765
          Oder meinst du den Bereich:
          • S Shadowhunter23
            Leider als Bild
            #766
            @Shadowhunter23
            Nein, ich meine nur die Zigbee-relevante Tabelle mit
            überschrieben.
            Bei mir halt dieses Layout:
            zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
            Deine Listening Ports spielen keine Rolle.
            • S Abwesend
              S Abwesend
              Shadowhunter23
              #767
              Jetzt ist es wohl spät, ich...
              USB-Devices by-id:
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              zigbee.X
              \nExtended Pan ID:
              \n*** MASKED ***
              \nPan ID:
              \n*** MASKED ***
              \nChannel:
              \n*** MASKED ***
              \nNetwork Key:
              \n*** MASKED ***
              sed: -e expression #1, char 134: unknown command: `/'
              • S Shadowhunter23
                USB-Devices by-id:
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                zigbee.X
                \nExtended Pan ID:
                \n*** MASKED ***
                \nPan ID:
                \n*** MASKED ***
                \nChannel:
                \n*** MASKED ***
                \nNetwork Key:
                \n*** MASKED ***
                #768
                @Shadowhunter23
                Ich hab sed jetzt angepasst. Versuch nochmal.
                • S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #769
                  Erwartest du das so?
                  USB-Devices by-id:
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  zigbee.X
                  \nExtended Pan ID:
                  \n*** MASKED ***
                  \nPan ID:
                  \n*** MASKED ***
                  \nChannel:
                  \n*** MASKED ***
                  \nNetwork Key:
                  \n*** MASKED ***
                  • S Abwesend
                    S Abwesend
                    Shadowhunter23
                    #770
                    Und nochmal:
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    \nExtended Pan ID:
                    \n*** MASKED ***
                    \nPan ID:
                    \n*** MASKED ***
                    \nChannel:
                    \n*** MASKED ***
                    \nNetwork Key:
                    \n*** MASKED ***
                    awk: run time error: regular expression compile failed (missing operand)
                            FILENAME="-" FNR=1 NR=1
                    • S Shadowhunter23
                      USB-Devices by-id:
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      zigbee.X
                      \nExtended Pan ID:
                      \n*** MASKED ***
                      \nPan ID:
                      \n*** MASKED ***
                      \nChannel:
                      \n*** MASKED ***
                      \nNetwork Key:
                      \n*** MASKED ***
                      #771
                      @Shadowhunter23
                      Mist...
                      Dann halt einfacheren Code...
                      Bitte nochmal.
                      • S Abwesend
                        S Abwesend
                        Shadowhunter23
                        #772
                        Hatt sich noch nichts geändert
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        \nExtended Pan ID:
                        \n*** MASKED ***
                        \nPan ID:
                        \n*** MASKED ***
                        \nChannel:
                        \n*** MASKED ***
                        \nNetwork Key:
                        \n*** MASKED ***
                        • S Shadowhunter23
                          USB-Devices by-id:
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          zigbee.X
                          \nExtended Pan ID:
                          \n*** MASKED ***
                          \nPan ID:
                          \n*** MASKED ***
                          \nChannel:
                          \n*** MASKED ***
                          \nNetwork Key:
                          \n*** MASKED ***
                          #773
                          @Shadowhunter23 sagte in iob diag - Skript:
                          Ich hab es auch vergessen hochzuladen...
                          Bitte jetzt nochmal.
                          • S Abwesend
                            S Abwesend
                            Shadowhunter23
                            #774
                            Habs x mal erneuert:
                            USB-Devices by-id:
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            zigbee.X
                            \nExtended Pan ID:
                            \n*** MASKED ***
                            \nPan ID:
                            \n*** MASKED ***
                            \nChannel:
                            \n*** MASKED ***
                            \nNetwork Key:
                            \n*** MASKED ***
                            • S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #775
                              Jetzt sieht es besser aus:
                              USB-Devices by-id:
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              zigbee.X
                              \nExtended Pan ID:
                              \n*** MASKED ***
                              \nPan ID:
                              \n*** MASKED ***
                              \nChannel:
                              \n*** MASKED ***
                              \nNetwork Key:
                              \n*** MASKED ***
                              zigbee.0        tcp://192.168.0.64:20108            -                                   tcp
                              zigbee.1        tcp://192.168.0.69:20108            -                                   tcp
                              zigbee.2        tcp://192.168.0.79:20108            -                                   tcp
                              zigbee.3        tcp://192.168.0.63:20108            -                                   tcp
                              • S Shadowhunter23
                                USB-Devices by-id:
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                zigbee.X
                                \nExtended Pan ID:
                                \n*** MASKED ***
                                \nPan ID:
                                \n*** MASKED ***
                                \nChannel:
                                \n*** MASKED ***
                                \nNetwork Key:
                                \n*** MASKED ***
                                #776
                                @Shadowhunter23
                                Ah, das sieht wie gewollt aus.
                                Kannst du es jetzt nochmal laden?
                                Ich hoffe das war es dann.
                                Bei mir schaut die Ausgabe nun so aus:
                                • S Abwesend
                                  S Abwesend
                                  Shadowhunter23
                                  #777
                                  USB-Devices by-id:
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  zigbee.X
                                  \nExtended Pan ID:
                                  \n*** MASKED ***
                                  \nPan ID:
                                  \n*** MASKED ***
                                  \nChannel:
                                  \n*** MASKED ***
                                  \nNetwork Key:
                                  \n*** MASKED ***
                                  • S Shadowhunter23
                                    USB-Devices by-id:
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    zigbee.X
                                    \nExtended Pan ID:
                                    \n*** MASKED ***
                                    \nPan ID:
                                    \n*** MASKED ***
                                    \nChannel:
                                    \n*** MASKED ***
                                    \nNetwork Key:
                                    \n*** MASKED ***
                                    #778
                                    @Shadowhunter23
                                    Super, so sollte es aussehen. Und die Werte sind auch richtig zugeordnet?
                                    Also zigbee.0 ist mit tcp://192.168.0.64:20108 konfiguriert?
                                      @Shadowhunter23
                                      S Abwesend
                                      S Abwesend
                                      Shadowhunter23
                                      #779
                                      @Thomas-Braun sagte in iob diag - Skript:
                                      Ja bei allen passt es.
                                      • S Shadowhunter23
                                        #780
                                        @Shadowhunter23
                                        Ganz herzlichen Dank für dein geduldiges Testen!
                                        Ich hab jetzt nur noch was kleines optisches angepasst.
                                        Die Trennlinien sind jetzt länger... :-)
                                        Jetzt wäre es toll, wenn noch jemand mit mehreren USB-Sticks oder einem Mix aus USB-Stick und tcp-Verbindung mal schauen könnte wie es dort aussieht.
                                          @Shadowhunter23
                                          TT-Tom
                                          #781
                                          @Thomas-Braun
                                          von wo muss es gestartet werden? aus dem iobroker Verzeichnis oder aus meinem user Verzeichnis??
                                          beim User habe ich ein paar Fehlermeldungen, arbeite da mit einem LXC Container.
                                          Script v.2026-03-08
                                          *** BASE SYSTEM ***
                                           Static hostname: iobtest
                                            Virtualization: lxc
                                          OS is similar to:
                                          model name	: Intel(R) N100
                                          CPU threads     : 4
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64bit
                                           09:21:36 up 5 days, 17:02,  1 user,  load average: 0.69, 0.68, 0.52
                                                         Local time: Mon 2026-03-09 09:21:36 CET
                                                     Universal time: Mon 2026-03-09 08:21:36 UTC
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          tom
                                          HOME=/home/tom
                                          GROUPS=tom sudo users iobroker
                                          iobroker
                                          [sudo] password for tom:
                                          HOME=/home/iobroker
                                          SUDO_HOME=/home/tom
                                          Desktop:
                                          Session:		tty
                                          *** MEMORY ***
                                          Mem:            8.4G        2.7G        5.5G        3.0M        145M        5.6G
                                          Swap:           536M        234M        302M
                                          Total:          8.9G        3.0G        5.8G
                                          Active iob-Instances: 	16
                                                   8000 M total memory
                                                   2612 M used memory
                                                   1649 M active memory
                                                   1011 M inactive memory
                                                   5250 M free memory
                                                      0 M buffer memory
                                                    139 M swap cache
                                                    512 M total swap
                                                    223 M used swap
                                                    288 M free swap
                                          top - 09:21:47 up 5 days, 17:02,  1 user,  load average: 0.90, 0.73, 0.54
                                          Tasks:  41 total,   1 running,  40 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  3.6 us,  1.8 sy,  0.0 ni, 78.6 id, 16.1 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8000.0 total,   5250.4 free,   2613.2 used,    139.2 buff/cache
                                          MiB Swap:    512.0 total,    288.4 free,    223.6 used.   5386.8 avail Mem
                                          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                          2 loaded units listed.
                                          *** FILESYSTEM ***
                                          DATEN1/subvol-101-disk-1 zfs        64G   14G   51G  22% /
                                          tmpfs                    tmpfs     6.3G  132K  6.3G   1% /run
                                          tmpfs                    tmpfs      16G  2.8M   16G   1% /tmp
                                          tmpfs                    tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
                                          /      DATEN1/subvol-101-disk-1 zfs    rw,relatime,xattr,posixacl,casesensitive
                                          /var:
                                          319M	/var/
                                          181M	/var/cache
                                          178M	/var/cache/apt
                                          125M	/var/cache/apt/archives
                                          70M	/var/lib
                                          Archived and active journals take up 4.2M in the file system.
                                          139M	/opt/iobroker/backups/
                                          245M	/opt/iobroker/iobroker-data/
                                          121M	/opt/iobroker/iobroker-data/backup-objects
                                          113M	/opt/iobroker/iobroker-data/files
                                          24M	/opt/iobroker/iobroker-data/files/mytime.admin
                                          23M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets
                                          15M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
                                          7.8M	/opt/iobroker/iobroker-data/objects.jsonl
                                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_08-19_objects.jsonl.gz
                                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_06-19_objects.jsonl.gz
                                          4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_04-19_objects.jsonl.gz
                                          USB-Devices by-id:
                                          zigbee.X
                                          \nExtended Pan ID:
                                          \n*** MASKED ***
                                          \nPan ID:
                                          \n*** MASKED ***
                                          \nChannel:
                                          \n*** MASKED ***
                                          \nNetwork Key:
                                          \n*** MASKED ***
                                          /usr/bin/nodejs		v22.22.0
                                          /usr/bin/node		v22.22.0
                                          /usr/bin/npm		10.9.4
                                          /usr/bin/npx		10.9.4
                                          nodejs:
                                            Installed: 22.22.0-1nodesource1
                                            Candidate: 22.22.0-1nodesource1
                                            Version table:
                                           *** 22.22.0-1nodesource1 1001
                                               20.19.2+dfsg-1 500
                                          node:fs:2437
                                              return binding.writeFileUtf8(
                                          Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                                              at Object.writeFileSync (node:fs:2437:20)
                                              at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
                                              at Object.onceWrapper (node:events:634:26)
                                              at ClientRequest.emit (node:events:519:28)
                                              at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:772:27)
                                              at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17)
                                              at TLSSocket.socketOnData (node:_http_client:614:22)
                                              at TLSSocket.emit (node:events:519:28)
                                              at addChunk (node:internal/streams/readable:561:12)
                                              at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
                                            errno: -13,
                                            code: 'EACCES',
                                            syscall: 'open',
                                            path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                                          Node.js v22.22.0
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 493355)
                                          admin: 		7.8.2
                                          javascript: 	9.0.18
                                          nodejs modules from github: 	3
                                          +-- iobroker.fahrplan@1.4.1 (git+ssh://git@github.com/tt-tom17/ioBroker.fahrplan.git#a25514b1774a271768b58081fe4031bf3eb9ebca)
                                          +-- iobroker.nspanel-lovelace-ui@0.13.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803)
                                          +-- iobroker.public-transport@0.0.5 (git+ssh://git@github.com/tt-tom17/ioBroker.public-transport.git#335d0dd3595a1dd8da7aa69116f84923b001ff5b)
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                                          + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                                            system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobtest                                  - disabled
                                            system.adapter.devices.0                : devices               : iobtest                                  - disabled
                                          + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                                            system.adapter.hmip.0                   : hmip                  : iobtest                                  - disabled
                                            system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                                          + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                                          + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                                          + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                                          + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 1883
                                          + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.mqtt.1                   : mqtt                  : iobtest                                  - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.mytime.0                 : mytime                : iobtest                                  - disabled
                                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                                          + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  -  enabled
                                            system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                                            system.adapter.openweathermap.0         : openweathermap        : iobtest                                  -  enabled
                                          + system.adapter.pirate-weather.0         : pirate-weather        : iobtest                                  -  enabled
                                            system.adapter.proxmox.0                : proxmox               : iobtest                                  - disabled
                                          + system.adapter.public-transport.0       : public-transport      : iobtest                                  -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : iobtest                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.socketio.0               : socketio              : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                                            system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobtest                                  -  enabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobtest                                  -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobtest                                  -  enabled
                                            system.adapter.vis.0                    : vis                   : iobtest                                  -  enabled
                                          + system.adapter.web.0                    : web                   : iobtest                                  -  enabled, port: 8082, bind: 192.168.178.53, run as: admin
                                            system.adapter.ws.0                     : ws                    : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                            system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                                            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobtest                                  - disabled
                                          + instance is alive
                                          Adapter    "admin"        : 7.8.3    , installed 7.8.2  [Updatable]
                                          Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                                          Adapter    "cloudless-homeconnect": 1.6.3, installed 1.6.3
                                          Adapter    "devices"      : 1.2.14   , installed 1.2.14
                                          Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                                          Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                          Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                                          Adapter    "nspanel-lovelace-ui": 0.13.4, installed 0.13.4
                                          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                          Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                                          Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
                                          Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                          Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                                          Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                                          Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
                                          Objects and States
                                          Objects: 	10075
                                          States: 	8039
                                          Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                                          Pending systemupdates: 1
                                          udp   UNCONN 0      0             0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=5),("systemd",pid=1,fd=35))
                                          udp   UNCONN 0      0                [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=7),("systemd",pid=1,fd=37))
                                          tcp   LISTEN 0      511    192.168.178.53:8082          0.0.0.0:*     users:(("io.web.0",pid=637,fd=35))
                                          tcp   LISTEN 0      100         127.0.0.1:smtp          0.0.0.0:*     users:(("master",pid=294,fd=13))
                                          tcp   LISTEN 0      4096          0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=4),("systemd",pid=1,fd=34))
                                          tcp   LISTEN 0      511         127.0.0.1:9001          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=23))
                                          tcp   LISTEN 0      511         127.0.0.1:9000          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=29))
                                          tcp   LISTEN 0      511                 *:tproxy              *:*     users:(("io.admin.0",pid=882,fd=39))
                                          tcp   LISTEN 0      511                 *:8087                *:*     users:(("io.simple-api.0",pid=684,fd=35))
                                          tcp   LISTEN 0      100             [::1]:smtp             [::]:*     users:(("master",pid=294,fd=14))
                                          tcp   LISTEN 0      4096                *:ssh                 *:*     users:(("sshd",pid=165,fd=3),("systemd",pid=1,fd=61))
                                          tcp   LISTEN 0      4096             [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=6),("systemd",pid=1,fd=36))
                                          2026-03-09 09:01:43.488  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 25570
                                          2026-03-09 09:01:44.377  - info: nspanel-lovelace-ui.0 (25570) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                                          2026-03-09 09:01:44.429  - info: nspanel-lovelace-ui.0 (25570) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                                          2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                                          2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                                          2026-03-09 09:01:46.351  - info: nspanel-lovelace-ui.0 (25570) [Buero] Setting panel to offline until first message!
                                          2026-03-09 09:01:46.392  - info: nspanel-lovelace-ui.0 (25570) [DEV-Panel] Setting panel to offline until first message!
                                          2026-03-09 09:01:53.211  - info: nspanel-lovelace-ui.0 (25570) [controller] 2 Panels initialized
                                          2026-03-09 09:01:54.380  - info: nspanel-lovelace-ui.0 (25570) [Buero] is online!
                                          2026-03-09 09:01:54.803  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                                          2026-03-09 09:05:01.421  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                                          2026-03-09 09:05:20.941  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                                          2026-03-09 09:05:21.194  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                                          2026-03-09 09:10:26.298  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                                          2026-03-09 09:10:26.578  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                                          2026-03-09 09:11:37.614  - warn: admin.0 (882) nspanel-lovelace-ui has an invalid jsonConfig: [{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"attr"},"message":"must NOT have additional properties"},{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/items/allOf/18/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower/items/pagePowerdata","schemaPath":"#/patternProperties/%5E.%2B/allOf/57/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                                          2026-03-09 09:15:05.013  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 25592
                                          2026-03-09 09:15:05.673  - info: netatmo-crawler.0 (25592) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.22.0, js-controller: 7.1.0
                                          2026-03-09 09:15:05.690  - info: netatmo-crawler.0 (25592) Getting data for stationid:70:ee:50:35:dc:b6
                                          2026-03-09 09:15:06.537  - info: netatmo-crawler.0 (25592) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                                          2026-03-09 09:15:07.047  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 25592 terminated with code 0 (NO_ERROR)
                                          2026-03-09 09:15:30.461  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                                          2026-03-09 09:15:30.698  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                                          2026-03-09 09:20:34.384  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                                          2026-03-09 09:20:34.716  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                                          zum Vergleich die normal iob diag Ausgabe
                                          Script v.2026-01-31
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                                          CPU threads: 4
                                                         Local time: Mon 2026-03-09 09:51:54 CET
                                                     Universal time: Mon 2026-03-09 08:51:54 UTC
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          tom
                                          HOME=/home/tom
                                          iobroker
                                          HOME=/home/iobroker
                                          SUDO_HOME=/home/tom
                                          Display-Server: 	false
                                          Unit display-manager.service could not be found.
                                          Display-Manager:
                                          Desktop:
                                          Session: 		tty
                                          *** MEMORY ***
                                          Mem:            8.4G        2.0G        6.2G        3.1M        194M        6.4G
                                          Swap:           536M        339K        536M
                                          Total:          8.9G        2.0G        6.8G
                                                   8000 M total memory
                                                   1865 M used memory
                                                   1904 M active memory
                                                     43 M inactive memory
                                                   5952 M free memory
                                                      0 M buffer memory
                                                    185 M swap cache
                                                    512 M total swap
                                                      0 M used swap
                                                    511 M free swap
                                          top - 09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                                          Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8000.0 total,   5951.3 free,   1866.2 used,    185.3 buff/cache
                                          MiB Swap:    512.0 total,    511.7 free,      0.3 used.   6133.8 avail Mem
                                          *** FILESYSTEM ***
                                          /var:
                                          319M	/var/
                                          181M	/var/cache
                                          178M	/var/cache/apt
                                          70M	/var/lib
                                          Archived and active journals take up 4.3M in the file system.
                                          242M	/opt/iobroker/iobroker-data/
                                          7.6M	/opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm 		10.9.4
                                          /usr/bin/npx 		10.9.4
                                          nodejs:
                                            Version table:
                                               20.19.2+dfsg-1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 316)
                                          admin: 		7.8.2
                                          javascript: 	9.0.18
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	10019
                                          States: 	7993
                                          tcp        0      0 192.168.178.53:8082     0.0.0.0:*               LISTEN      1001       31394874   27969/io.web.0
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          30032      294/master
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17403      1/init
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31384629   27130/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31384634   27130/iobroker.js-c
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31384845   27149/io.admin.0
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31395098   28008/io.simple-api
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          30033      294/master
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          21994      1/init
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          17405      1/init
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17404      1/init
                                          udp6       0      0 :::111                  :::*                                0          17406      1/init
                                          2026-03-09 09:47:37.959  - error: javascript.0 (27223) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr
                                          2026-03-09 09:47:39.217  - info: vis.0 (28024) Terminated (NO_ERROR): Without reason
                                          2026-03-09 09:47:39.744  - info: host.iobtest instance system.adapter.vis.0 terminated while should be started once
                                          2026-03-09 09:47:41.039  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 28082
                                          2026-03-09 09:47:41.820  - info: nspanel-lovelace-ui.0 (28082) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                                          2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                                          2026-03-09 09:47:43.781  - info: nspanel-lovelace-ui.0 (28082) [Buero] Setting panel to offline until first message!
                                          2026-03-09 09:47:43.823  - info: nspanel-lovelace-ui.0 (28082) [DEV-Panel] Setting panel to offline until first message!
                                          2026-03-09 09:47:44.836  - info: host.iobtest instance system.adapter.public-transport.0 in version "0.0.5" (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) started with pid 28097
                                          2026-03-09 09:47:45.575  - info: public-transport.0 (28097) starting. Version 0.0.5 (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) in /opt/iobroker/node_modules/iobroker.public-transport, node: v22.22.0, js-controller: 7.1.0
                                          2026-03-09 09:47:45.634  - info: public-transport.0 (28097) HAFAS-Client initialisiert mit Profil: vbb
                                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097)   - S Zepernick (ID: 900350163)
                                          2026-03-09 09:47:45.635  - info: public-transport.0 (28097) Rufe Abfahrten ab für: S Zepernick (900350163)
                                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Abfahrten aktualisiert für: S Zepernick (900350163)
                                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Erste Abfrage abgeschlossen: 1 erfolgreich, 0 fehlgeschlagen
                                          2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Warte auf die nächste Abfrage in 60 Minuten...
                                          2026-03-09 09:47:46.242  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                                          2026-03-09 09:47:46.242  - info: public-transport.0 (28097) Infos für: S Zepernick (900350163) abfragen...
                                          2026-03-09 09:47:50.280  - info: nspanel-lovelace-ui.0 (28082) [Buero] is online!
                                          2026-03-09 09:47:50.972  - info: nspanel-lovelace-ui.0 (28082) [controller] 2 Panels initialized
                                          2026-03-09 09:47:51.086  - info: nspanel-lovelace-ui.0 (28082) [Buero] Panel startup finished!
                                          Gruß Tom
                                          Public Transport
                                          NSPanel Adapter Wiki
