  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.2k Aufrufe 40 Beobachtet
  • S Shadowhunter23
    Jetzt ist es wohl spät, ich...
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.4 COM-Port is NOT matching 'by-id'.
    tcp
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    sed: -e expression #1, char 134: unknown command: `/'
    *** NodeJS-Installation ***
    #768
    @Shadowhunter23
    Ich hab sed jetzt angepasst. Versuch nochmal.
    • S Abwesend
      S Abwesend
      Shadowhunter23
      schrieb am zuletzt editiert von Shadowhunter23
      #769
      Erwartest du das so?
      USB-Devices by-id:
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
      ioBroker Backup Analyzer
      • S Abwesend
        S Abwesend
        Shadowhunter23
        #770
        Und nochmal:
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        zigbee.X
        \nExtended Pan ID:
        \n*** MASKED ***
        \nPan ID:
        \n*** MASKED ***
        \nChannel:
        \n*** MASKED ***
        \nNetwork Key:
        \n*** MASKED ***
        awk: run time error: regular expression compile failed (missing operand)
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                FILENAME="-" FNR=1 NR=1
        + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
        + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
        + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
        • S Shadowhunter23
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          zigbee.X
          \nExtended Pan ID:
          \n*** MASKED ***
          \nPan ID:
          \n*** MASKED ***
          \nChannel:
          \n*** MASKED ***
          \nNetwork Key:
          \n*** MASKED ***
          #771
          @Shadowhunter23
          Mist...
          Dann halt einfacheren Code...
          Bitte nochmal.
          • S Abwesend
            S Abwesend
            Shadowhunter23
            #772
            Hatt sich noch nichts geändert
            USB-Devices by-id:
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            zigbee.X
            \nExtended Pan ID:
            \n*** MASKED ***
            \nPan ID:
            \n*** MASKED ***
            \nChannel:
            \n*** MASKED ***
            \nNetwork Key:
            \n*** MASKED ***
            • S Shadowhunter23
              USB-Devices by-id:
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              zigbee.X
              \nExtended Pan ID:
              \n*** MASKED ***
              \nPan ID:
              \n*** MASKED ***
              \nChannel:
              \n*** MASKED ***
              \nNetwork Key:
              \n*** MASKED ***
              #773
              @Shadowhunter23 sagte in iob diag - Skript:
              Ich hab es auch vergessen hochzuladen...
              Bitte jetzt nochmal.
              • S Abwesend
                S Abwesend
                Shadowhunter23
                #774
                Habs x mal erneuert:
                USB-Devices by-id:
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                zigbee.X
                \nExtended Pan ID:
                \n*** MASKED ***
                \nPan ID:
                \n*** MASKED ***
                \nChannel:
                \n*** MASKED ***
                \nNetwork Key:
                \n*** MASKED ***
                • S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #775
                  Jetzt sieht es besser aus:
                  USB-Devices by-id:
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  zigbee.X
                  \nExtended Pan ID:
                  \n*** MASKED ***
                  \nPan ID:
                  \n*** MASKED ***
                  \nChannel:
                  \n*** MASKED ***
                  \nNetwork Key:
                  \n*** MASKED ***
                  zigbee.0        tcp://192.168.0.64:20108            -                                   tcp
                  zigbee.1        tcp://192.168.0.69:20108            -                                   tcp
                  zigbee.2        tcp://192.168.0.79:20108            -                                   tcp
                  zigbee.3        tcp://192.168.0.63:20108            -                                   tcp
                  zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
                  • S Shadowhunter23
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    \nExtended Pan ID:
                    \n*** MASKED ***
                    \nPan ID:
                    \n*** MASKED ***
                    \nChannel:
                    \n*** MASKED ***
                    \nNetwork Key:
                    \n*** MASKED ***
                    #776
                    @Shadowhunter23
                    Ah, das sieht wie gewollt aus.
                    Kannst du es jetzt nochmal laden?
                    Ich hoffe das war es dann.
                    Bei mir schaut die Ausgabe nun so aus:
                    zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
                    • S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #777
                      USB-Devices by-id:
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      zigbee.X
                      \nExtended Pan ID:
                      \n*** MASKED ***
                      \nPan ID:
                      \n*** MASKED ***
                      \nChannel:
                      \n*** MASKED ***
                      \nNetwork Key:
                      \n*** MASKED ***
                      • S Shadowhunter23
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        \nExtended Pan ID:
                        \n*** MASKED ***
                        \nPan ID:
                        \n*** MASKED ***
                        \nChannel:
                        \n*** MASKED ***
                        \nNetwork Key:
                        \n*** MASKED ***
                        #778
                        @Shadowhunter23
                        Super, so sollte es aussehen. Und die Werte sind auch richtig zugeordnet?
                        Also zigbee.0 ist mit tcp://192.168.0.64:20108 konfiguriert?
                          @Shadowhunter23
                          S Abwesend
                          S Abwesend
                          Shadowhunter23
                          #779
                          @Thomas-Braun sagte in iob diag - Skript:
                          Ja bei allen passt es.
                          • S Shadowhunter23
                            #780
                            @Shadowhunter23
                            Ganz herzlichen Dank für dein geduldiges Testen!
                            Ich hab jetzt nur noch was kleines optisches angepasst.
                            Die Trennlinien sind jetzt länger... :-)
                            Jetzt wäre es toll, wenn noch jemand mit mehreren USB-Sticks oder einem Mix aus USB-Stick und tcp-Verbindung mal schauen könnte wie es dort aussieht.
                              @Shadowhunter23
                              TT-Tom
                              #781
                              @Thomas-Braun
                              von wo muss es gestartet werden? aus dem iobroker Verzeichnis oder aus meinem user Verzeichnis??
                              beim User habe ich ein paar Fehlermeldungen, arbeite da mit einem LXC Container.
                              Script v.2026-03-08
                              *** BASE SYSTEM ***
                              Operating System: Debian GNU/Linux 13 (trixie)
                               Static hostname: iobtest
                                     Icon name: computer-container
                                       Chassis: container ☐
                                Virtualization: lxc
                                        Kernel: Linux 6.17.13-1-pve
                                  Architecture: x86-64
                              OS is similar to:
                              model name	: Intel(R) N100
                              CPU threads     : 4
                              Docker          : false
                              Virtualization  : lxc
                              Kernel          : x86_64
                              Userland        : 64bit
                              Systemuptime and Load:
                               09:21:36 up 5 days, 17:02,  1 user,  load average: 0.69, 0.68, 0.52
                              *** LIFE CYCLE STATUS ***
                              Operating System is the current Debian stable version codenamed 'trixie'!
                              *** TIME AND TIMEZONES ***
                                             Local time: Mon 2026-03-09 09:21:36 CET
                                         Universal time: Mon 2026-03-09 08:21:36 UTC
                                               RTC time: n/a
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              tom
                              HOME=/home/tom
                              GROUPS=tom sudo users iobroker
                              iobroker
                              [sudo] password for tom:
                              HOME=/home/iobroker
                              SUDO_HOME=/home/tom
                              GROUPS=iobroker tty dialout audio video plugdev
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server:		Unknown
                              Display-Manager: 	Not found
                              Desktop:
                              Session:		tty
                              *** MEMORY ***
                              Mem:            8.4G        2.7G        5.5G        3.0M        145M        5.6G
                              Swap:           536M        234M        302M
                              Total:          8.9G        3.0G        5.8G
                              Active iob-Instances: 	16
                                       8000 M total memory
                                       2612 M used memory
                                       1649 M active memory
                                       1011 M inactive memory
                                       5250 M free memory
                                          0 M buffer memory
                                        139 M swap cache
                                        512 M total swap
                                        223 M used swap
                                        288 M free swap
                              top - 09:21:47 up 5 days, 17:02,  1 user,  load average: 0.90, 0.73, 0.54
                              Tasks:  41 total,   1 running,  40 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  3.6 us,  1.8 sy,  0.0 ni, 78.6 id, 16.1 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8000.0 total,   5250.4 free,   2613.2 used,    139.2 buff/cache
                              MiB Swap:    512.0 total,    288.4 free,    223.6 used.   5386.8 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                              * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                              Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                      ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                      SUB    -> The low-level unit activation state, values depend on unit type.
                              2 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              dmesg: read kernel buffer failed: Operation not permitted
                              No critical errors detected
                              *** FILESYSTEM ***
                              Filesystem               Type      Size  Used Avail Use% Mounted on
                              DATEN1/subvol-101-disk-1 zfs        64G   14G   51G  22% /
                              none                     tmpfs     492K  4.0K  488K   1% /dev
                              udev                     devtmpfs   16G     0   16G   0% /dev/tty
                              tmpfs                    tmpfs      16G     0   16G   0% /dev/shm
                              tmpfs                    tmpfs     6.3G  132K  6.3G   1% /run
                              tmpfs                    tmpfs      16G  2.8M   16G   1% /tmp
                              tmpfs                    tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                    tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
                              Messages concerning filesystems in dmesg:
                              Show mounted filesystems:
                              TARGET SOURCE                   FSTYPE OPTIONS
                              /      DATEN1/subvol-101-disk-1 zfs    rw,relatime,xattr,posixacl,casesensitive
                              /var:
                              319M	/var/
                              181M	/var/cache
                              178M	/var/cache/apt
                              125M	/var/cache/apt/archives
                              70M	/var/lib
                              Archived and active journals take up 4.2M in the file system.
                              /opt/iobroker/backups:
                              139M	/opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              245M	/opt/iobroker/iobroker-data/
                              121M	/opt/iobroker/iobroker-data/backup-objects
                              113M	/opt/iobroker/iobroker-data/files
                              24M	/opt/iobroker/iobroker-data/files/mytime.admin
                              23M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets
                              15M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
                              7.8M	/opt/iobroker/iobroker-data/objects.jsonl
                              4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_08-19_objects.jsonl.gz
                              4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_06-19_objects.jsonl.gz
                              4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_04-19_objects.jsonl.gz
                              USB-Devices by-id:
                              zigbee.X
                              \nExtended Pan ID:
                              \n*** MASKED ***
                              \nPan ID:
                              \n*** MASKED ***
                              \nChannel:
                              \n*** MASKED ***
                              \nNetwork Key:
                              \n*** MASKED ***
                              /usr/bin/nodejs		v22.22.0
                              /usr/bin/node		v22.22.0
                              /usr/bin/npm		10.9.4
                              /usr/bin/npx		10.9.4
                              ✓ Node.js installation is correct
                              nodejs:
                                Installed: 22.22.0-1nodesource1
                                Candidate: 22.22.0-1nodesource1
                                Version table:
                               *** 22.22.0-1nodesource1 1001
                                   22.21.0-1nodesource1 1001
                                   22.20.0-1nodesource1 1001
                                   22.19.0-1nodesource1 1001
                                   22.18.0-1nodesource1 1001
                                   22.17.1-1nodesource1 1001
                                   22.17.0-1nodesource1 1001
                                   22.16.0-1nodesource1 1001
                                   22.15.1-1nodesource1 1001
                                   22.15.0-1nodesource1 1001
                                   22.14.0-1nodesource1 1001
                                   22.13.1-1nodesource1 1001
                                   22.13.0-1nodesource1 1001
                                   22.12.0-1nodesource1 1001
                                   22.11.0-1nodesource1 1001
                                   22.10.0-1nodesource1 1001
                                   22.9.0-1nodesource1 1001
                                   22.8.0-1nodesource1 1001
                                   22.7.0-1nodesource1 1001
                                   22.6.0-1nodesource1 1001
                                   22.5.1-1nodesource1 1001
                                   22.5.0-1nodesource1 1001
                                   22.4.1-1nodesource1 1001
                                   22.4.0-1nodesource1 1001
                                   22.3.0-1nodesource1 1001
                                   22.2.0-1nodesource1 1001
                                   22.1.0-1nodesource1 1001
                                   22.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main amd64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              node:fs:2437
                                  return binding.writeFileUtf8(
                              Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                                  at Object.writeFileSync (node:fs:2437:20)
                                  at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
                                  at Object.onceWrapper (node:events:634:26)
                                  at ClientRequest.emit (node:events:519:28)
                                  at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:772:27)
                                  at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17)
                                  at TLSSocket.socketOnData (node:_http_client:614:22)
                                  at TLSSocket.emit (node:events:519:28)
                                  at addChunk (node:internal/streams/readable:561:12)
                                  at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
                                errno: -13,
                                code: 'EACCES',
                                syscall: 'open',
                                path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                              Node.js v22.22.0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 493355)
                              Core adapters versions
                              js-controller: 	7.1.0
                              admin: 		7.8.2
                              javascript: 	9.0.18
                              nodejs modules from github: 	3
                              +-- iobroker.fahrplan@1.4.1 (git+ssh://git@github.com/tt-tom17/ioBroker.fahrplan.git#a25514b1774a271768b58081fe4031bf3eb9ebca)
                              +-- iobroker.nspanel-lovelace-ui@0.13.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803)
                              +-- iobroker.public-transport@0.0.5 (git+ssh://git@github.com/tt-tom17/ioBroker.public-transport.git#335d0dd3595a1dd8da7aa69116f84923b001ff5b)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                              + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                                system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobtest                                  - disabled
                                system.adapter.devices.0                : devices               : iobtest                                  - disabled
                              + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                                system.adapter.hmip.0                   : hmip                  : iobtest                                  - disabled
                                system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                              + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                              + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                              + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                              + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 1883
                              + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.mqtt.1                   : mqtt                  : iobtest                                  - disabled, port: 1883, bind: 0.0.0.0
                                system.adapter.mytime.0                 : mytime                : iobtest                                  - disabled
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                              + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  -  enabled
                                system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                                system.adapter.openweathermap.0         : openweathermap        : iobtest                                  -  enabled
                              + system.adapter.pirate-weather.0         : pirate-weather        : iobtest                                  -  enabled
                                system.adapter.proxmox.0                : proxmox               : iobtest                                  - disabled
                              + system.adapter.public-transport.0       : public-transport      : iobtest                                  -  enabled
                              + system.adapter.simple-api.0             : simple-api            : iobtest                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.socketio.0               : socketio              : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                                system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobtest                                  -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobtest                                  -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobtest                                  -  enabled
                                system.adapter.vis.0                    : vis                   : iobtest                                  -  enabled
                              + system.adapter.web.0                    : web                   : iobtest                                  -  enabled, port: 8082, bind: 192.168.178.53, run as: admin
                                system.adapter.ws.0                     : ws                    : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                                system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobtest                                  - disabled
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): beta
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: beta
                              Adapter    "admin"        : 7.8.3    , installed 7.8.2  [Updatable]
                              Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                              Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                              Adapter    "cloudless-homeconnect": 1.6.3, installed 1.6.3
                              Adapter    "devices"      : 1.2.14   , installed 1.2.14
                              Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                              Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                              Adapter    "ical"         : 1.19.7   , installed 1.19.7
                              Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                              Controller "js-controller": 7.1.0    , installed 7.1.0
                              Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                              Adapter    "mytime"       : 2.3.2    , installed 2.3.2
                              Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                              Adapter    "nspanel-lovelace-ui": 0.13.4, installed 0.13.4
                              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                              Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                              Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
                              Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                              Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                              Adapter    "sql"          : 3.0.1    , installed 3.0.1
                              Adapter    "trashschedule": 5.2.1    , installed 5.2.1
                              Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                              Adapter    "web"          : 8.0.0    , installed 8.0.0
                              Adapter    "ws"           : 4.0.0    , installed 4.0.0
                              Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                              Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
                              Objects and States
                              Objects: 	10075
                              States: 	8039
                              Hit:1 http://security.debian.org trixie-security InRelease
                              Hit:2 http://deb.debian.org/debian trixie InRelease
                              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                              Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                              Reading package lists... Done
                              Pending systemupdates: 1
                              *** Listening Ports ***
                              Netid State  Recv-Q Send-Q  Local Address:Port     Peer Address:Port Process
                              udp   UNCONN 0      0             0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=5),("systemd",pid=1,fd=35))
                              udp   UNCONN 0      0                [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=7),("systemd",pid=1,fd=37))
                              tcp   LISTEN 0      511    192.168.178.53:8082          0.0.0.0:*     users:(("io.web.0",pid=637,fd=35))
                              tcp   LISTEN 0      100         127.0.0.1:smtp          0.0.0.0:*     users:(("master",pid=294,fd=13))
                              tcp   LISTEN 0      4096          0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=4),("systemd",pid=1,fd=34))
                              tcp   LISTEN 0      511         127.0.0.1:9001          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=23))
                              tcp   LISTEN 0      511         127.0.0.1:9000          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=29))
                              tcp   LISTEN 0      511                 *:tproxy              *:*     users:(("io.admin.0",pid=882,fd=39))
                              tcp   LISTEN 0      511                 *:8087                *:*     users:(("io.simple-api.0",pid=684,fd=35))
                              tcp   LISTEN 0      100             [::1]:smtp             [::]:*     users:(("master",pid=294,fd=14))
                              tcp   LISTEN 0      4096                *:ssh                 *:*     users:(("sshd",pid=165,fd=3),("systemd",pid=1,fd=61))
                              tcp   LISTEN 0      4096             [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=6),("systemd",pid=1,fd=36))
                              2026-03-09 09:01:43.488  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 25570
                              2026-03-09 09:01:44.377  - info: nspanel-lovelace-ui.0 (25570) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                              2026-03-09 09:01:44.429  - info: nspanel-lovelace-ui.0 (25570) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                              2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                              2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                              2026-03-09 09:01:46.351  - info: nspanel-lovelace-ui.0 (25570) [Buero] Setting panel to offline until first message!
                              2026-03-09 09:01:46.392  - info: nspanel-lovelace-ui.0 (25570) [DEV-Panel] Setting panel to offline until first message!
                              2026-03-09 09:01:53.211  - info: nspanel-lovelace-ui.0 (25570) [controller] 2 Panels initialized
                              2026-03-09 09:01:54.380  - info: nspanel-lovelace-ui.0 (25570) [Buero] is online!
                              2026-03-09 09:01:54.803  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                              2026-03-09 09:05:01.421  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
                              2026-03-09 09:05:20.941  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                              2026-03-09 09:05:21.194  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2026-03-09 09:10:26.298  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                              2026-03-09 09:10:26.578  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2026-03-09 09:11:37.614  - warn: admin.0 (882) nspanel-lovelace-ui has an invalid jsonConfig: [{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"attr"},"message":"must NOT have additional properties"},{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/items/allOf/18/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower/items/pagePowerdata","schemaPath":"#/patternProperties/%5E.%2B/allOf/57/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                              2026-03-09 09:15:05.013  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 25592
                              2026-03-09 09:15:05.673  - info: netatmo-crawler.0 (25592) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.22.0, js-controller: 7.1.0
                              2026-03-09 09:15:05.690  - info: netatmo-crawler.0 (25592) Getting data for stationid:70:ee:50:35:dc:b6
                              2026-03-09 09:15:06.537  - info: netatmo-crawler.0 (25592) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                              2026-03-09 09:15:07.047  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 25592 terminated with code 0 (NO_ERROR)
                              2026-03-09 09:15:30.461  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                              2026-03-09 09:15:30.698  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2026-03-09 09:20:34.384  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
                              2026-03-09 09:20:34.716  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
                              zum Vergleich die normal iob diag Ausgabe
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                              CPU threads: 4
                                             Local time: Mon 2026-03-09 09:51:54 CET
                                         Universal time: Mon 2026-03-09 08:51:54 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              tom
                              HOME=/home/tom
                              iobroker
                              HOME=/home/iobroker
                              SUDO_HOME=/home/tom
                              Display-Server: 	false
                              Unit display-manager.service could not be found.
                              Display-Manager:
                              Desktop:
                              Session: 		tty
                              *** MEMORY ***
                              Mem:            8.4G        2.0G        6.2G        3.1M        194M        6.4G
                              Swap:           536M        339K        536M
                              Total:          8.9G        2.0G        6.8G
                                       8000 M total memory
                                       1865 M used memory
                                       1904 M active memory
                                         43 M inactive memory
                                       5952 M free memory
                                          0 M buffer memory
                                        185 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        511 M free swap
                              top - 09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
                              Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8000.0 total,   5951.3 free,   1866.2 used,    185.3 buff/cache
                              MiB Swap:    512.0 total,    511.7 free,      0.3 used.   6133.8 avail Mem
                              *** FILESYSTEM ***
                              /var:
                              319M	/var/
                              181M	/var/cache
                              178M	/var/cache/apt
                              70M	/var/lib
                              Archived and active journals take up 4.3M in the file system.
                              242M	/opt/iobroker/iobroker-data/
                              7.6M	/opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm 		10.9.4
                              /usr/bin/npx 		10.9.4
                              nodejs:
                                Candidate: 22.22.1-1nodesource1
                                Version table:
                                   22.22.1-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 316)
                              admin: 		7.8.2
                              javascript: 	9.0.18
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	10019
                              States: 	7993
                              tcp        0      0 192.168.178.53:8082     0.0.0.0:*               LISTEN      1001       31394874   27969/io.web.0
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          30032      294/master
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17403      1/init
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31384629   27130/iobroker.js-c
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31384634   27130/iobroker.js-c
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31384845   27149/io.admin.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31395098   28008/io.simple-api
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          30033      294/master
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          21994      1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          17405      1/init
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17404      1/init
                              udp6       0      0 :::111                  :::*                                0          17406      1/init
                              2026-03-09 09:47:37.959  - error: javascript.0 (27223) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr
                              2026-03-09 09:47:39.217  - info: vis.0 (28024) Terminated (NO_ERROR): Without reason
                              2026-03-09 09:47:39.744  - info: host.iobtest instance system.adapter.vis.0 terminated while should be started once
                              2026-03-09 09:47:41.039  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 28082
                              2026-03-09 09:47:41.820  - info: nspanel-lovelace-ui.0 (28082) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
                              2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
                              2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
                              2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                              2026-03-09 09:47:43.781  - info: nspanel-lovelace-ui.0 (28082) [Buero] Setting panel to offline until first message!
                              2026-03-09 09:47:43.823  - info: nspanel-lovelace-ui.0 (28082) [DEV-Panel] Setting panel to offline until first message!
                              2026-03-09 09:47:44.836  - info: host.iobtest instance system.adapter.public-transport.0 in version "0.0.5" (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) started with pid 28097
                              2026-03-09 09:47:45.575  - info: public-transport.0 (28097) starting. Version 0.0.5 (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) in /opt/iobroker/node_modules/iobroker.public-transport, node: v22.22.0, js-controller: 7.1.0
                              2026-03-09 09:47:45.634  - info: public-transport.0 (28097) HAFAS-Client initialisiert mit Profil: vbb
                              2026-03-09 09:47:45.635  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                              2026-03-09 09:47:45.635  - info: public-transport.0 (28097)   - S Zepernick (ID: 900350163)
                              2026-03-09 09:47:45.635  - info: public-transport.0 (28097) Rufe Abfahrten ab für: S Zepernick (900350163)
                              2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Abfahrten aktualisiert für: S Zepernick (900350163)
                              2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Erste Abfrage abgeschlossen: 1 erfolgreich, 0 fehlgeschlagen
                              2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Warte auf die nächste Abfrage in 60 Minuten...
                              2026-03-09 09:47:46.242  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
                              2026-03-09 09:47:46.242  - info: public-transport.0 (28097) Infos für: S Zepernick (900350163) abfragen...
                              2026-03-09 09:47:50.280  - info: nspanel-lovelace-ui.0 (28082) [Buero] is online!
                              2026-03-09 09:47:50.972  - info: nspanel-lovelace-ui.0 (28082) [controller] 2 Panels initialized
                              2026-03-09 09:47:51.086  - info: nspanel-lovelace-ui.0 (28082) [Buero] Panel startup finished!
                              Gruß Tom
                              Public Transport
                              NSPanel Adapter Wiki
                              • T TT-Tom
                                @Thomas-Braun
                                Script v.2026-03-08
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                CPU threads     : 4
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64bit
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                tom
                                HOME=/home/tom
                                iobroker
                                HOME=/home/iobroker
                                SUDO_HOME=/home/tom
                                Desktop:
                                Session:		tty
                                *** MEMORY ***
                                         8000 M total memory
                                         2612 M used memory
                                         5250 M free memory
                                            0 M buffer memory
                                          139 M swap cache
                                          512 M total swap
                                          223 M used swap
                                          288 M free swap
                                *** FILESYSTEM ***
                                /var:
                                319M	/var/
                                181M	/var/cache
                                178M	/var/cache/apt
                                70M	/var/lib
                                USB-Devices by-id:
                                zigbee.X
                                \nExtended Pan ID:
                                \n*** MASKED ***
                                \nPan ID:
                                \n*** MASKED ***
                                \nChannel:
                                \n*** MASKED ***
                                \nNetwork Key:
                                \n*** MASKED ***
                                /usr/bin/npm		10.9.4
                                /usr/bin/npx		10.9.4
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                node:fs:2437
                                  errno: -13,
                                  code: 'EACCES',
                                  syscall: 'open',
                                Node.js v22.22.0
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin: 		7.8.2
                                javascript: 	9.0.18
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects: 	10075
                                States: 	8039
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                tom
                                HOME=/home/tom
                                iobroker
                                HOME=/home/iobroker
                                SUDO_HOME=/home/tom
                                Display-Manager:
                                Desktop:
                                Session: 		tty
                                *** MEMORY ***
                                         8000 M total memory
                                         1865 M used memory
                                         5952 M free memory
                                            0 M buffer memory
                                          185 M swap cache
                                          512 M total swap
                                            0 M used swap
                                          511 M free swap
                                *** FILESYSTEM ***
                                /var:
                                319M	/var/
                                181M	/var/cache
                                178M	/var/cache/apt
                                70M	/var/lib
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm 		10.9.4
                                /usr/bin/npx 		10.9.4
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin: 		7.8.2
                                javascript: 	9.0.18
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects: 	10019
                                States: 	7993
                                #782
                                @TT-Tom sagte in iob diag - Skript:
                                Aus dem Verzeichnis, wo das heruntergeladene Skript liegt. Sollte i.d.R. das home-Verzeichnis des users sein.
                                Die Meldung
                                sollte eigentlich nicht kommen. Aber da es beim 'ordentlichen' Aufruf via 'iob diag' funktioniert ist es auch nicht weiter wichtig.
                                Den ZibBee-Adapter hast du gar nicht am Start, dafür aber zigbee2mqtt. Passt also in der Ausgabe dann.
                                Am Rande:
                                Spiel das nodejs-Update ein. ;-)
                                T 2 Antworten Letzte Antwort
                                • S Abwesend
                                  S Abwesend
                                  Shadowhunter23
                                  #783
                                  Ob das was ausmacht kann @thomas-braun beantworten, dein User hat nicht alle Gruppen. Laut Anleitung müsstest du folgendes tun:
                                  Falls ein User nachträglich angelegt werden soll muss dieser noch per
                                  usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker tom
                                  den relevanten Gruppen hinzugefügt werden.
                                  Ich rufe das Script auch aus dem user Verzeichnis auf und es läuft ohne Probleme ( auch ein LXC ).
                                    Die Meldung
                                    Am Rande:
                                    TT-Tom
                                    #784
                                    @Thomas-Braun
                                    okay dann ist die obere Ausgabe, wie geschrieben aus dem User-Verzeichnis und unten die normale iob diag vom ioBroker.
                                    mach ich :)
                                    Gruß Tom
                                    Public Transport
                                    • S Shadowhunter23
                                      TT-Tom
                                      #785
                                      @Shadowhunter23
                                      bleiben die selben Meldungen
                                      Gruß Tom
                                      Public Transport
                                        Die Meldung
                                        Am Rande:
                                        TT-Tom
                                        #786
                                        @Thomas-Braun
                                        habe es mal mit unmask aufgerufen
                                        hier ein Fehler in der PanID, wobei ich ja kein Zigbee.0 habe und auch ein ZigbeeOnLan im System
                                        Pan ID:
                                        ./iob_diag.sh: line 693: printf: 0x906": invalid hex number
                                        2310
                                        die andern Zigbee Ausgaben passen.
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          @Thomas-Braun
                                          Pan ID:
                                          2310
                                          #787
                                          Danke! Das muss ich abfangen, der Wert wird aus einem USB-Stick bzw. dem nvbackup ausgelesen. Wenn das nicht vorhanden ist kommt diese Meldung.
                                          Kannst du mir die Zigbee-Passage bei dir mal vollständig mit der --unmask Option zeigen?
                                          (Wobei, so ganz eigentlich sollte der Code gar nicht durchlaufen werden, wenn es keine zigbee.X Instanz gibt)
