  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • H Offline
    Hotze
    schrieb am zuletzt editiert von Hotze
    #4501
    Geniale Arbeit der Adapter!
    Ich habe vermutlich einen Fehler in der Animation. Die springt.
    Ein fix ist für mich nicht nötig, ich wollte nur Bescheid geben.
    {"basic":{"enable_grid":true,"enable_animation":false,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":false,"enable_icon_proxy":true,"enable_low_performance":true,"enable_ds_autocomplete":false,"enable_show_coordinates":true,"tourVisited":true,"height":271,"width":433,"animation_timer":1000,"background_color":"#D1D1D1","styles":"","font":{"family":"\"Arial\", sans-serif","size":20,"align":"middle"},"rect":{"height":100,"width":100,"corners":10},"circle":{"radius":50},"elm":{"stroke_width":5,"pos_x":50,"pos_y":50},"icon":{"width":24,"height":24},"enable_line_animation":false},"calculation":{"battery":{"dod":-1,"capacity":-1,"percent":-1,"charge":-1,"charge_prop":false,"discharge":-1,"discharge_prop":false},"consumption":{"production":[],"gridFeed":-1,"gridFeed_prop":false,"gridConsume":-1,"gridConsume_prop":false,"batteryCharge":-1,"batteryCharge_prop":false,"batteryDischarge":-1,"batteryDischarge_prop":false}},"animation":{"stroke_dasharray":"10 17 10 17 10 72","stroke_width":6,"animation_duration":2000,"stroke_linecap":"round","animation_timing_function":"linear"},"animation_configuration":{"dots":3,"gap":72,"distance":17,"length":10},"line":{"stroke_width":8,"stroke":"#000000","stroke_linecap":"square"},"elements":{"2":{"type":"text","align":"middle","subType":"datasource","id":2,"pos_x":230,"pos_y":55,"color":"rgb(0, 0, 0)","fill":"rgb(255, 206, 74)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 2","unit":"W","source":10,"shadow":"","threshold":0,"convert":false,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":11},"5":{"type":"rect","id":5,"rx":10,"height":100,"width":100,"pos_x":180,"pos_y":5,"fill":"none","color":"rgb(255, 206, 74)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":3},"6":{"type":"icon","id":6,"icon":"mdi:solar-power-variant-outline","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":214,"pos_y":10,"shadow":"","position":2},"7":{"type":"rect","id":7,"rx":10,"height":100,"width":100,"pos_x":321,"pos_y":99,"fill":"none","color":"rgb(0, 181, 221)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":0},"8":{"type":"icon","id":8,"icon":"mdi:battery-high","width":40,"height":40,"color":"rgba(0, 0, 0, 0.7)","pos_x":47,"pos_y":90,"shadow":"","position":1,"source":1},"9":{"type":"text","align":"middle","subType":"datasource","id":9,"pos_x":371,"pos_y":147,"color":"none","fill":"rgb(0, 181, 221)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 9","unit":"W","source":3,"shadow":"","threshold":0,"convert":false,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":8},"10":{"type":"text","align":"middle","id":10,"pos_x":230,"pos_y":78,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Produktion","shadow":""},"11":{"type":"text","align":"middle","id":11,"pos_x":371,"pos_y":175,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Verbrauch","shadow":""},"12":{"type":"icon","id":12,"icon":"mdi:home-outline","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":354,"pos_y":101,"shadow":"","position":0},"13":{"type":"rect","id":13,"rx":10,"height":180,"width":120,"pos_x":7,"pos_y":84,"fill":"none","color":"rgb(161, 211, 67)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":1,"position":2,"fill_direction":90,"fill_type":"percent","fill_value":"rgba(161, 211, 67, 0.63)"},"14":{"type":"rect","id":14,"rx":10,"height":100,"width":100,"pos_x":180,"pos_y":164,"fill":"none","color":"rgba(97, 104, 122, 0.7)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":1},"16":{"type":"text","align":"middle","subType":"datasource","id":16,"pos_x":58,"pos_y":140,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"Wh","source":"0","shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":11},"18":{"type":"text","align":"middle","subType":"datasource","id":18,"pos_x":59,"pos_y":159,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 18","unit":"%","source":1,"shadow":"","threshold":0,"convert":false,"decimal_places":0,"source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":5},"19":{"type":"text","align":"middle","subType":"datasource","id":19,"pos_x":230,"pos_y":215,"color":"none","fill":"rgb(97, 104, 122)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 19","unit":"W","source":4,"shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":3},"20":{"type":"icon","id":20,"icon":"mdi:electricity-from-grid","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":217,"pos_y":168,"shadow":"","position":3},"21":{"type":"text","align":"middle","id":21,"pos_x":230,"pos_y":237,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Netz","shadow":""},"22":{"position":3,"id":22,"pos_x":69,"pos_y":187,"source":6,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 22","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"%:","source_action":-1,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_size":15,"font_family":"\"Arial\", sans-serif","prepend":"Rest bis"},"23":{"type":"text","align":"middle","subType":"datasource","id":23,"pos_x":58,"pos_y":214,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"","source":7,"shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":6,"group":null},"24":{"type":"text","align":"middle","subType":"datasource","id":24,"pos_x":58,"pos_y":236,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"Wh","source":8,"shadow":"","threshold":0,"convert":true,"decimal_places":1,"source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":7,"group":null},"25":{"position":4,"id":25,"pos_x":117,"pos_y":37,"source":5,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 25","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"W","source_action":-1,"color":"none","fill":"rgb(0, 0, 0)","font_size":20,"font_family":"\"Arial\", sans-serif","url":"","frame":"_overlay"},"26":{"position":0,"id":26,"pos_x":338,"pos_y":37,"source":9,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 26","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"W","source_action":-1,"color":"none","fill":"rgb(0, 0, 0)","font_size":20,"font_family":"\"Arial\", sans-serif"}},"defs":{"path_5_7":{"type":"def","id":"path_5_7","d":"M281 55 H 356 A 15 15 0 0 1 371 70 V 98","startSlot":"right","endSlot":"top"},"path_5_13":{"type":"def","id":"path_5_13","d":"M179 55 H 81 A 14 14 0 0 0 67 69 V 83","startSlot":"left","endSlot":"top"},"path_14_7":{"type":"def","id":"path_14_7","d":"M281 234 H 356 A 15 15 0 0 0 371 219 V 200","startSlot":"right_bottom","endSlot":"bottom"},"path_5_14":{"type":"def","id":"path_5_14","d":"M230 106 V 163","startSlot":"bottom","endSlot":"top"}},"lines":{"line_path_5_7":{"type":"line","id":"line_path_5_7","href":"#path_5_7","color":"rgb(0, 0, 0)","position":2},"line_path_5_13":{"type":"line","id":"line_path_5_13","href":"#path_5_13","color":"rgb(0, 0, 0)","position":3},"line_path_14_7":{"type":"line","id":"line_path_14_7","href":"#path_14_7","color":"rgb(0, 0, 0)","position":1},"line_path_5_14":{"type":"line","id":"line_path_5_14","href":"#path_5_14","color":"rgb(0, 0, 0)","position":0}},"animations":{"anim_path_5_7":{"type":"animation","id":"anim_path_5_7","href":"#path_5_7","color":"rgb(161, 211, 67)","threshold":0,"source":9,"animation_properties":"positive","animation_type":"dots","dots":10,"power":400},"anim_path_5_13":{"type":"animation","id":"anim_path_5_13","href":"#path_5_13","color":"rgb(255, 206, 74)","threshold":0,"source":5,"animation_properties":"positive","animation_option":true,"animation_type":-1,"dots":100,"power":1600},"anim_path_14_7":{"type":"animation","id":"anim_path_14_7","href":"#path_14_7","color":"rgb(255, 0, 0)","threshold":10,"source":4,"animation_properties":"positive"},"anim_path_5_14":{"type":"animation","id":"anim_path_5_14","href":"#path_5_14","color":"rgb(255, 206, 74)","threshold":0,"source":4,"animation_properties":"negative"}},"icons":{},"datasources":{"0":{"source":"mqtt.0.b2500.S.battery.remaining_capacity","alias":"b2500/S/battery/remaining_capacity","factor":1},"1":{"source":"0_userdata.0.PVKram.Akkukapazität","alias":"Akkukapazität%","factor":1},"2":{"source":"mqtt.0.b2500.S.power.power","alias":"b2500/S/power/power","factor":1},"3":{"source":"0_userdata.0.PVKram.Hausverbrauch","alias":"Hausverbrauch","factor":1},"4":{"source":"shelly.0.shellypro3em#34987a45a8b8#1.EM0.TotalActivePower","alias":"TotalActivePower","factor":1},"5":{"source":"0_userdata.0.PVKram.Rein+Raus-","alias":"Rein+Raus-","factor":1},"6":{"source":"0_userdata.0.PVKram.EntladenBis","alias":"EntladenBis","factor":1},"7":{"source":"energiefluss-erweitert.0.calculation.battery.remaining_target","alias":"energiefluss Target of the remaining Time of the battery","factor":1},"8":{"source":"energiefluss-erweitert.0.calculation.battery.remaining_energy","alias":"energiefluss Current Power available in battery","factor":1},"9":{"source":"opendtu.0.total.power","alias":"Total power over all inverters","factor":1},"10":{"source":"mqtt.0.b2500.S.pv.power","alias":"b2500/S/pv/power","factor":1},"11":{"source":"0_userdata.0.PVKram.RestzeitAkku","alias":"RestzeitAkku","factor":1}}}
    Das gif ist schlecht geschnitten!
    Die Punkte kommen ganz normal raus und springen dann nach vorne.
    Das kann man nur einmal sehen danach fängt das gif von vorne an. Dass das gif erneut anfängt sieht man an den gelben und roten Punkten.
    Evtl habe ich auch einfach nur zu viele Punkte auf die Linie gemacht und es springt deswegen.
    SKBS 1 Antwort Letzte Antwort
    • jvfleJ Offline
      jvfleJ Offline
      jvfle
      #4502
      Es ist die Version 0.8.1 installiert. Ich bitte um Nachsicht, mit der Browser-Konsole kann ich nichts anfangen. Kannst du kurz sagen, was ich machen muss? Danke
      • jvfleJ Offline
        jvfleJ Offline
        jvfle
        #4503
        SKBS S 2 Antworten Letzte Antwort
        • jvfleJ jvfle
          Sesamstrasse
          #4504
          @jvfle Ich finde deine Ursprüngliche Frage nicht, aber wenn es dir um die Menüs geht, die in deinem Snapshot nicht geladen werden, hier musst du einfach unter Speichern einmal speichern drücken und dann die Seite neu laden. Bei mir ist es genauso. Auch wenn ich eine neue Instanz mache, muss ich erst einmal speichern, damit die Menüs auftauchen.
          Desweiteren habe ich auch das Problem, das unter Chrome und Edge die Seitenmenüs zum konfigurieren nur bei den Verbindungen auftauchen, klicke ich z.B. eine Umrandung an, taucht das Menü nicht auf. Im Firefox funktioniert es zum Glück ohne Probleme. Noch als zusätzlichen Tipp, falls es bei dir genauso ist.
          jvfleJ 1 Antwort Letzte Antwort
            Sesamstrasse
            #4505
            Jetzt zu meiner Frage. Ich möchte eine weitere Sicht erstellen, die meine Basissicht weiter ausdetaliert. Kann ich meine Konfiguration von Instanz 0 auf meine neue Instanz 1 übertragen? Ich finde kein Export / Import. Den Json sehe ich ja beim Speichern. Oder muss ich alles manuel nochmal anlegen?
            • skvarelS Online
              skvarelS Online
              skvarel
              #4506
              Ich habe 'einfach' den Inhalt aus diesem Datenpunkt in die neue Instanz kopiert:
              energiefluss-erweitert.0.configuration
              Beim Eingaben des Inhalts steht dort zwar, dass der Datenpunkt schreibgeschützt ist, klappt aber trotzdem.
              #TeamInventwo
              Unsere Adapter:
              • S Sesamstrasse
                jvfleJ Offline
                jvfleJ Offline
                jvfle
                #4507
                @Sesamstrasse sagte in Support Adapter Energiefluss-erweitert v0.7.7:
                Das liegt daran, dass das Thema hier hin verschoben wurde.
                https://forum.iobroker.net/topic/75485/test-adapter-energiefluss-erweitert-v0-8-x-github-latest/1553?_=1771063237721
                Für den Energieflussadapter (erw.) V0.8.1 gibt es ein neues Update auf Github. Das funktioniert bei mir bis jetzt sehr gut.
                • skvarelS skvarel
                  Sesamstrasse
                  #4508
                  @skvarel Daaaaaaaankeeeeee!
                    Sesamstrasse
                    #4509
                    ich möchte gerne meine beiden Batterien zu dem Block mit der gesamtsicht verbinden. Leider erzeugt er mir nur so einen geraden Strich.
                    Frage: Kann ich irgendwie Beinflussen, welchen "Weg" die Verbindung geht? Und falls nein, wie würde man so etwas optisch dann schön gestallten?
                    HomoranH skvarelS 2 Antworten Letzte Antwort
                    • S Sesamstrasse
                      #4510
                      nur in Grenzen über die Option "Abstand bis zum ersten Knick" (ähnlich 😉 )
                      in deinem Fall eher nicht.
                      das liegt an dir und deinem Geschmack!
                      ggf. B1 und B2 übereinander und dann seitlich mit Btotal verbinden
                      • S Sesamstrasse
                        skvarelS Online
                        skvarelS Online
                        skvarel
                        schrieb am zuletzt editiert von skvarel
                        #4511
                        @Sesamstrasse .. wenn du die mittleren Andockpunkte nimmst, sieht es etwas besser aus
                        EDIT:
                        Hier mit einem anderen Radius
                        #TeamInventwo
                        Unsere Adapter:
                          MikeRow
                          schrieb am zuletzt editiert von MikeRow
                          #4512
                          Du kannst ein Rechteck oder Kreis einfügen. Die farblos einstellen und von deinen Geräten 2 Linien zusammenführen. Damit bekommst du jede gewünschte Position hin
                          So zb
                          • M MikeRow
                            So zb
                            Sesamstrasse
                            #4513
                            @MikeRow genau das habe ich gesucht. Aber verdeckt dann nicht eine Verbindung "den Energiefluss" der dahinterliegenden?
                            HomoranH M 2 Antworten Letzte Antwort
                            • S Sesamstrasse
                              #4514
                              wenn du so ein Element unter Batterie1 setzst, passiert doch nichts!?
                              • S Sesamstrasse
                                MikeRow
                                #4515
                                @Sesamstrasse
                                Nein, kannst du doch definieren
                                  Sesamstrasse
                                  #4516
                                  Das weiß ich. Aber überlappen sich bei dir nicht Verbindungen? Oder sind das alles einzelverbindungen, die du "mehrfach belegst"? Aber wie synchronisierst du dass dann grafisch? Oder verstehe ich gerade etwas völlig falsch.
                                    MikeRow
                                    #4517
                                    So richtig verstehe ich dein Problem nicht. Musst du mal damit experimentieren. Bei mir sieht das so aus.
                                      Sesamstrasse
                                      #4518
                                      Genau das meinte ich, ob alle Punkte gleichzeitig angezeigt werden, oder die vordere Linie die Punkte der da hinter verdeckt. Ich probiere jetzt mal. Vielen, vielen Dank für den input! Ihr habt mir wie immer super weitergeholfen.
                                      • hotspot_2H Offline
                                        hotspot_2H Offline
                                        hotspot_2
                                        #4519
                                        Hallo zusammen, kurze Frage zur Animation der Elemente oder der Funktion "Elemente nach Wert füllen": Kann man die Animation beim Start irgendwie deaktivieren so das der Wert sofort korrekt angezeigt wird?
                                        • hotspot_2H hotspot_2
                                          SKBS Offline
                                          SKBS Offline
                                          SKB
                                          #4520
                                          @hotspot_2 sagte:
                                          Die Füllung wird zum aktuellen Wert animiert, welches ca. 1 Sekunde dauert. Wieso sollte man dies deaktivieren können?
