  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • Merlin123M Merlin123
    @skb ups. stimmt... hier geht es ja um die 0.7.7. Hab die 0.8.1
    Liveansicht ist ebenfalls fehlerhaft, da ist es mir aufgefallen....
    update:
    jetzt richtiges Log
    functions.min.js?v=0.8.1:8 [Config] Using Instance: energiefluss-erweitert.1
    functions.min.js?v=0.8.1:8 [Language] Detected System-Language: en-US
    functions.min.js?v=0.8.1:8 [Config] Loaded additional file: /_socket/info.js
    functions.min.js?v=0.8.1:8 {instance: 1, lowPerformance: false, theme: false, namespace: 'energiefluss-erweitert.1', hostname: '192.168.0.251', …}
    socket.io.js:55 [2025-10-28T16:59:57.760Z] Try to connect
    functions.min.js?v=0.8.1:8 [Config] Getting Instances
    functions.min.js?v=0.8.1:8 [Socket] connected at 10/28/2025, 5:59:57 PM
    functions.min.js?v=0.8.1:8 [Language] Trying to get language from system!
    functions.min.js?v=0.8.1:8 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
    (anonymous) @ functions.min.js?v=0.8.1:8
    await in (anonymous)
    e @ jquery-3.6.4.min.js:2
    (anonymous) @ jquery-3.6.4.min.js:2
    setTimeout
    c @ jquery-3.6.4.min.js:2
    fireWith @ jquery-3.6.4.min.js:2
    fire @ jquery-3.6.4.min.js:2
    ready @ jquery-3.6.4.min.js:2
    $ @ jquery-3.6.4.min.js:2
    functions.min.js?v=0.8.1:8 [Language] Got it from ioBroker! Translating Texts to locale de!
    functions.min.js?v=0.8.1:8 [Socket] subscribed to: energiefluss-erweitert.1.configuration,energiefluss-erweitert.1.data,system.adapter.energiefluss-erweitert.1.alive at 10/28/2025, 5:59:57 PM
    functions.min.js?v=0.8.1:8 [Config] Trying to load configuration for instance 1 from state!
    functions.min.js?v=0.8.1:8 [Config] Using direct load via iconify-API!
    functions.min.js?v=0.8.1:8 [Config] Loading initial Data
    functions.min.js?v=0.8.1:8 [Config] Single-Fill-Gradient added for: 7
    functions.min.js?v=0.8.1:8 [Config] Single-Fill-Gradient added for: 13
    functions.min.js?v=0.8.1:8 [Config] Single-Fill-Gradient added for: 31
    functions.min.js?v=0.8.1:8 [Config] Border-Fill added for ID 5
    functions.min.js?v=0.8.1:8 [Config] Configuration loaded in 64.69999998807907 ms
    functions.min.js?v=0.8.1:8 [Config] Loaded additional file: js/iconify.min.js
    nzblnk.js:24 [NZBDonkey] Nzblnk content script loaded successfully
    SKBS Offline
    SKBS Offline
    SKB
    #4332
    @merlin123 das ist nicht der Inhalt des EF. Das ist VIS.
    Nur die Instanz öffnen - kein Frame, kein iFrame oder sonst was.
    Merlin123M 1 Antwort Letzte Antwort
    • SKBS SKB
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #4333
      @skb ups. sorry... falsch verstanden. Hab es oben aktualisiert
      Beta-Tester
      SKBS 1 Antwort Letzte Antwort
        SKBS Offline
        SKBS Offline
        SKB
        #4334
        @merlin123 sieht Anfangs völlig normal aus.
        Allerdings ist dort ein nzblnk.js drin - was soll das sein?
        • SKBS SKB
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          #4335
          @skb musste ich auch erstmal googeln....
          Kommt von einer Chrome Extension.
          wenn ich die deaktiviere ändert das aber nichts....
          kann ich irgendwie alles in eine neue Instanz kopieren? Irgendwas ist mit der ja ganz seltsam.
          Beta-Tester
          • SKBS Offline
            SKBS Offline
            SKB
            #4336
            @merlin123 Na, das sieht für mich auch komisch aus. Du kannst den Inhalt in eine neue Instanz kopieren - Datenpunkt configuration.
            Allerdings denke ich nicht, das der Fehler im Inhalt der Instanz ist. Aber ein Test kann nicht schaden.
            Ansonsten kannst du die Konfiguration auch hier einstellen und ich füge es mal bei mir ein - dann kann man vielleicht mehr sehen, wenn's keine geheimen Daten sind 😉
            Merlin123M 2 Antworten Letzte Antwort
            • SKBS SKB
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #4337
              @skb Das sind Top-Secret Daten! 😀
              {"basic":{"enable_grid":true,"enable_animation":false,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":false,"enable_icon_proxy":false,"enable_low_performance":false,"height":423,"width":433,"styles":"","font":{"family":"\"Arial\", sans-serif","size":"20","color":"","fill":"","align":"middle"},"rect":{"height":100,"width":100,"corners":10},"circle":{"radius":50},"elm":{"stroke_width":5,"color":"","fill":"","pos_x":50,"pos_y":50},"icon":{"height":24,"width":24,"color":""}},"calculation":{"battery":{"dod":null,"capacity":null,"percent":null,"charge":null,"charge_prop":false,"charge_kw":false,"discharge":null,"discharge_prop":false,"discharge_kw":false},"consumption":{"production":[-1],"production_kw":false,"gridFeed":null,"gridFeed_kw":false,"gridFeed_prop":false,"gridConsume":null,"gridConsume_kw":false,"gridConsume_prop":false,"batteryCharge":null,"batteryCharge_kw":false,"batteryCharge_prop":false,"batteryDischarge":null,"batteryDischarge_kw":false,"batteryDischarge_prop":false}},"animation":{"stroke":"#ffce4a","stroke_dasharray":"10 17 10 17 10  72","stroke_width":"6","animation_duration":"2000","stroke_linecap":"round","animation_timing_function":"linear"},"animation_configuration":{"dots":"3","distance":"17","length":"10"},"line":{"stroke_width":"8","stroke":"#000000"},"elements":{"5":{"position":5,"type":"rect","id":5,"rx":10,"height":150,"width":400,"pos_x":16,"pos_y":135,"fill":"none","color":"rgb(242, 14, 64)","stroke":2,"shadow":"rgba(0, 0, 0, 0.7)","frame":"_overlay","fill_type":-1,"fill_direction":90,"border_value":"#0E26FF","border_type":"value","border_direction":"cw","border_style":"round","border_max":35,"border_reverse":false,"border_start":0,"source":2,"threshold":0},"7":{"position":4,"type":"rect","id":7,"rx":10,"height":100,"width":100,"pos_x":317,"pos_y":309,"fill":"none","color":"rgb(161, 211, 67)","stroke":2,"shadow":"rgba(0, 0, 0, 0.7)","frame":"_overlay","fill_value":"rgb(161,211,67)","fill_type":"value","fill_direction":90,"fill_max":20,"border_type":-1,"border_direction":"cw","border_style":"round","border_reverse":false,"border_start":null,"source":1,"threshold":0,"override":{">100":{"fill":"#B5FF00"},"<100":{"fill":"none"}}},"9":{"position":4,"type":"text","subType":"datasource","id":9,"pos_x":368,"pos_y":391,"color":"none","fill":"rgb(0, 0, 0)","font_family":"Arial, sans-serif","font_size":18,"align":"middle","text":"ID 9","unit":"W","source":1,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"action":"none","subtract":[-1],"add":[-1],"frame":"_overlay"},"12":{"position":3,"type":"icon","id":"12","icon":"material-symbols:heat-pump-outline","width":70,"height":70,"color":"rgba(0, 0, 0, 0.7)","pos_x":"330","pos_y":"315","shadow":"","source":-1,"threshold":0,"frame":"_overlay","action":"none"},"13":{"position":3,"type":"rect","id":13,"rx":10,"height":100,"width":100,"pos_x":13,"pos_y":309,"fill":"none","color":"rgb(161, 211, 67)","stroke":2,"shadow":"rgba(0, 0, 0, 0.7)","frame":"_overlay","fill_value":"#8CFF08","fill_type":"value","fill_direction":90,"fill_max":200,"border_type":-1,"border_direction":"cw","border_style":"round","border_reverse":false,"border_start":null,"source":0,"threshold":0,"override":{">100":{"fill":"#B5FF00"},"<100":{"fill":"none"}}},"20":{"position":2,"type":"rect","id":20,"rx":10,"height":100,"width":100,"pos_x":315,"pos_y":309,"fill":"none","color":"rgb(139, 65, 201)","stroke":0,"shadow":"","frame":"_overlay","fill_type":-1,"fill_direction":90,"border_type":-1,"border_direction":"cw","border_style":"round","border_reverse":false,"border_start":180,"source":-1,"threshold":0},"21":{"position":3,"type":"text","subType":"datasource","id":21,"pos_x":225,"pos_y":224,"color":"none","fill":"rgb(0, 0, 0)","font_family":"Arial, sans-serif","font_size":26,"align":"middle","text":"ID 21","unit":"°C","source":2,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":1,"action":"none","subtract":[-1],"add":[-1],"frame":"_overlay"},"22":{"position":2,"type":"text","subType":"datasource","id":22,"pos_x":59,"pos_y":392,"color":"none","fill":"rgb(0, 0, 0)","font_family":"Arial, sans-serif","font_size":18,"align":"middle","text":"ID 22","unit":"W","source":0,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"action":"none","subtract":[-1],"add":[-1],"frame":"_overlay"},"23":{"position":2,"type":"icon","id":"23","icon":"cbi:pool-filter","width":70,"height":70,"color":"rgba(0, 0, 0, 0.7)","pos_x":"28","pos_y":"312","shadow":"","source":-1,"threshold":0,"frame":"_overlay","action":"none"},"26":{"position":1,"type":"text","subType":"datasource","id":26,"pos_x":356,"pos_y":113,"color":"none","fill":"rgb(0, 0, 0)","font_family":"Arial, sans-serif","font_size":26,"align":"middle","text":"ID 26","unit":"°C","source":3,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":1,"action":"none","subtract":[-1],"add":[-1],"frame":"_overlay"},"27":{"position":1,"type":"icon","id":"27","icon":"ph:sun-duotone","width":70,"height":70,"color":"rgb(250, 250, 62)","pos_x":"318","pos_y":"25","shadow":"","source":-1,"threshold":0,"frame":"_overlay","action":"none"},"28":{"position":1,"type":"image","id":"28","width":"300","height":"150","pos_x":"63","pos_y":"140","shadow":"","source":-1,"threshold":0,"href":"/vis-2.0/Voelker/Pool.jpg","preserveAspectRatio":"xMidYMid meet","frame":"_overlay","action":"none"},"29":{"position":0,"type":"icon","id":"29","icon":"mdi:robot-mower","width":70,"height":70,"color":"rgba(0, 0, 0, 0.7)","pos_x":"53","pos_y":"48","shadow":"","css_general":".rotateanimation0 {   -webkit-animation: rotation 20s infinite linear; }   @-webkit-keyframes rotation {   from {     -webkit-transform: rotate(0deg);   } to {      -webkit-transform: rotate(359deg);   } }","source":4,"threshold":0,"frame":"_overlay","action":"none","override":{"<50":{"display":"inline"},">50":{"display":"inline"}}},"30":{"position":0,"type":"text","subType":"datasource","id":30,"pos_x":89,"pos_y":115,"color":"none","fill":"rgb(0, 0, 0)","font_family":"Arial, sans-serif","font_size":18,"align":"middle","text":"ID 30","unit":"W","source":4,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"action":"none","subtract":[-1],"add":[-1],"frame":"_overlay","override":{"<5":{"display":"none"},">5":{"display":"inline"}}},"31":{"position":0,"type":"rect","id":31,"rx":10,"height":100,"width":100,"pos_x":41,"pos_y":30,"fill":"none","color":"rgb(161, 211, 67)","stroke":2,"shadow":"rgba(0, 0, 0, 0.7)","frame":"_overlay","fill_value":"#8CFF08","fill_type":"value","fill_direction":"90","fill_max":"10","border_type":"-1","border_direction":"cw","border_style":"round","border_reverse":false,"border_start":null,"source":"4","threshold":0,"override":{">100":{"fill":"#B5FF00"},"<100":{"fill":"none"}}}},"defs":{"path_5_13":{"type":"def","id":"path_5_13","d":"M196 286  V 296.6   V 324 A 15 15 0 0 1 181 339  H 114","startSlot":"bottom_left","endSlot":"right_top"},"path_13_7":{"type":"def","id":"path_13_7","d":"M114 379  H 316","startSlot":"right_bottom","endSlot":"left_bottom"},"path_7_5":{"type":"def","id":"path_7_5","d":"M316 339  H 300   H 251 A 15 15 0 0 1 236 324  V 286","startSlot":"left_top","endSlot":"bottom_right"},"path_20_5":{"type":"def","id":"path_20_5","d":"M315 339  H 299.2   H 251 A 15 15 0 0 1 236 324  V 286","startSlot":"left_top","endSlot":"bottom_right"}},"lines":{"line_path_5_13":{"type":"line","id":"line_path_5_13","href":"#path_5_13","color":"rgb(0, 0, 0)","shadow":""},"line_path_13_7":{"type":"line","id":"line_path_13_7","href":"#path_13_7","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_5":{"type":"line","id":"line_path_7_5","href":"#path_7_5","color":"rgb(0, 0, 0)","shadow":""},"line_path_20_5":{"type":"line","id":"line_path_20_5","href":"#path_20_5","color":"rgb(0, 0, 0)","shadow":"","override":{">49":{"display":"inline"},"<50":{"display":"none"}}}},"animations":{"anim_path_5_13":{"type":"animation","id":"anim_path_5_13","href":"#path_5_13","color":"rgb(0, 181, 221)","source":0,"threshold":50,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1},"anim_path_13_7":{"type":"animation","id":"anim_path_13_7","href":"#path_13_7","color":"rgb(0, 181, 221)","source":0,"threshold":50,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1},"anim_path_7_5":{"type":"animation","id":"anim_path_7_5","href":"#path_7_5","color":"rgb(0, 181, 221)","source":0,"threshold":50,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1},"anim_path_20_5":{"type":"animation","id":"anim_path_20_5","href":"#path_20_5","color":"rgb(255, 0, 0)","source":1,"threshold":5,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1,"override":{"<50":{"stroke":"none"},">50":{"stroke":"rgba(255, 0, 0,1)"}}}},"datasources":{"0":{"source":"alias.0.Garten.Poolpumpe.Power","alias":"Poolpumpe Leistung","factor":1},"1":{"source":"alias.0.Garten.Wärmepumpe.Power","alias":"Wärmepumpe","factor":1},"2":{"source":"alias.0.Garten.Pooltemperatur.ACTUAL","alias":"Pooltemperatur","factor":1},"3":{"source":"alias.0.Garten.Lufttemperatur.outdoortemp","alias":"Lufttemperatur","factor":1},"4":{"source":"alias.0.Garten.Poolroboter.Power","alias":"Poolroboter","factor":1}}}
              Beta-Tester
              • SKBS SKB
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                #4338
                @skb eine neue Instanz, wo ich die Konfig rein kopiere, sieht leider genauso aus. Auch der Bearbeitungsbereich oben...
                Beta-Tester
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #4339
                  @merlin123 Habe dies gerade in meine Test-Instanz eingefügt. Kann keinen Fehler feststellen:
                  2025-10-28 22_30_39-Support Adapter Energiefluss-erweitert v0.7.7 — Mozilla Firefox.png
                  Sowohl in Firefox, Edge als auch in Chrome auf Windows wird es korrekt dargestellt.
                  Nutzt du andere Systeme?
                  • SKBS SKB
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #4340
                    @skb nö... Chrome unter Win11....
                    Hmmm.
                    Aktuell hab ich 3 Instanzen:
                    0: alte Version der Stromübersicht (auch unauffällig)
                    1: die defekte Übersicht für den Pool
                    2: die aktuelle Stromübersicht, die problemlos geht.
                    hatte dann Instanz 3 zum Test gemacht, die aber auch nicht ging. Ist aber wieder gelöscht.
                    Kann höchstens mal versuchen, alle zu löschen und neu anzulegen.
                    wenn ich den configuration DP sichere reicht das ja, oder?
                    Beta-Tester
                      Hmmm.
                      SKBS Offline
                      SKBS Offline
                      SKB
                      #4341
                      @merlin123 Na, die Konfiguration geht ja. Auch wird das Layout nicht durch diese beeinflusst.
                      Irgendwas stimmt beim Aufruf nicht.
                      Installier mal die Version von GitHub drüber, dann einen Upload des Adapters und die Seiten (Konfig + Live-Ansicht) mit Strg + F5 neu laden.
                      • SKBS SKB
                        Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        #4342
                        @skb ne, die Konfig ist ja auch beschädigt. Da wo man Elemente hinzufügt usw. sind auch nur leere Flächen bei der Instanz, es läuft nur "irgendwie" ein grauer Balken von links nach rechts düber. Schwer zu beschreiben.
                        Ich muss mal schauen, ob ich das von hier im Büro testen kann, sonst heute Nachmittag....
                        Beta-Tester
                          SKBS Offline
                          SKBS Offline
                          SKB
                          #4343
                          @merlin123 Nein, deine Konfiguration ist nicht beschädigt, denn sonst würde sie bei mir ja nicht laufen!
                          Ja, der Balken ist eine Ladeanimation, bis die Seite geladen ist.
                          • SKBS SKB
                            Merlin123M Offline
                            Merlin123M Offline
                            Merlin123
                            #4344
                            @skb ah so meintest Du da.. Ich meinte die Konfigmöglichkeit.
                            Also:
                            Github&Upload erledigt.
                            Leider kann ich weder über iobroker.pro noch über meinen externen Link auf die Vis die Oberfläche bzw. die Anzeige Deines Adapters aufrufen.
                            ABER: Auf dem Handy via VPN sah es jetzt richtig aus. Icons haben die richtige Größe und der Konfigurationsbereich wird richtig angezeigt. Mal zu Haus am Rechner nochmal schauen.
                            Hast Du ne Idee, wieso es mit der neusten Version jetzt geht? (Nur aus Neugier).
                            Danke auf jeden Fall für die Hilfe! Da nächste mal achte ich auch drauf, im richtigen Thread zu sein :P
                            Beta-Tester
                              Also:
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #4345
                              @merlin123 Den Adapter kannst Du problemlos auf iorboker.pro aufrufen.
                              Anmelden, Anwendungen klicken und schon erscheint er dort 😉
                              • SKBS SKB
                                Merlin123M Offline
                                Merlin123M Offline
                                Merlin123
                                #4346
                                @skb da sehe ich nur die Instanz 0...
                                Beta-Tester
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  #4347
                                  @merlin123 Dann rufst Du diese auf und hängst hinten ein ?instance=x (x = instance - 0, 1, 2 usw) an.
                                  • SKBS SKB
                                    Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #4348
                                    @skb ah ok... Leider ist es am Rechner nur bedingt besser geworden....
                                    Zumindest das Bearbeiten oben geht jetzt
                                    Beta-Tester
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #4349
                                      So sieht es auf dem Handy via VPN aus:
                                      stimmt irgendwie der Hintergrund nicht, aber das nutze ich am Handy normalerweise auch nicht.
                                      Beta-Tester
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #4350
                                        @merlin123 Na, da stimmen die Icons ja. Was heisst, der Hintergrund stimmt nicht? Hat dieser vielleicht einen absoluten Pfad?
                                        • SKBS SKB
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #4351
                                          @skb Der sollte eigentlich weiß sein...... Musste das neu im Adapter einstellen.
                                          Bin jetzt grad an nem anderen Rechner, da stimmt es:
                                          Am anderen Rechner sind die Icons immer noch klein.
                                          Jetzt versteh ich gar nix mehr.....
                                          Beta-Tester
                                          SKBS P 2 Antworten Letzte Antwort
