  4. Test Adapter Daikin-Cloud 0.4.0
282 Beiträge 41 Kommentatoren 81.2k Aufrufe 43 Beobachtet
  • ArmilarA Armilar
    @lemmi
    habe mal ein wenig Zeit gefunden, um das Skript auf alle Device-Typen und Adapterinstanzen anzupassen.
    TypeScript anlegen. Inhalt reinwerfen. Sollte nichts angepasst werden müssen. Skript starten...
    Die Daten für jedes Daikin-Device in der Onnecta-App (Klima, Wärmepumpe, heating, cooling, Total, etc.) werden unter 0_userdata.0.daikin-cloud.... angelegt.
    @apollon77 - evtl. kann man das in den Adapter schreddern...
    /* TypeScript (TS) @Armilar
     * This Script will read the consumption Data from Daikin-Cloud adapter and transform the raw data into individual data points similar to how it's shown in the Daikin Onecta App.
     * It will also sum up the historic consumption from the current and previous year and update the total consumption meter going forward.
     * The data is created in the following path analogous to the daikin cloud data
     * 0_userdata.0.daikin-cloud.0...
     * Createtd: 14.11.2024
    // Log-Mode
    const logMode: any = 'info'; // 'info' or 'debug'
    // Path in 0_userdata
    const mainPath: string = '0_userdata.0.';
    // Onnecta hours (if d-raw)
    const hourly: Array<string>  = ["00:00 - 02:00", "02:00 - 04:00", "04:00 - 06:00", "06:00 - 08:00", "08:00 - 10:00", "10:00 - 12:00", "12:00 - 14:00", "14:00 - 16:00", "16:00 - 18:00", "18:00 - 20:00", "20:00 - 22:00", "22:00 - 24:00"];
    // Onnecta weekdays (if w-raw)
    const daily: Array<string>   = ["01_Monday", "02_Tuesday", "03_Wednesday", "04_Thursday", "05_Friday", "06_Saturday", "07_Sunday"];
    // Onnecta months  (if m-raw)
    const monthly: Array<string> = ["01_Januray", "02_February", "03_March", "04_April", "05_May", "06_June", "07_July", "08_August", "09_September", "10_October", "11_November", "12_December"];
    let devices: string[] = getDeviceNames("daikin-cloud.");
    function setOrCreateState(id: string, value: any, forceCreation: boolean = true, common: Partial<iobJS.StateCommon> = {}, callback?: iobJS.SetStateCallback): void {
        if (!existsState(id)) {
            createState(id, value, forceCreation, common, callback);
        } else {
            setState(id, value, true);
    // Get Daikin Device Names
    function getDeviceNames(vAdapterInstance: string): string[] {
        let devices = [];
        $(vAdapterInstance + '*raw').each(function (id) {
            if (devices.indexOf(id) == -1) {
                devices.push(id);
        return devices;
    async function writeConsumtionData(path: string, rawType: string, rawData: number[]): Promise<void> {
        log(rawType + ' - ' + rawData, logMode);
        let total: number = 0;
        switch (rawType) {
    	case "d-raw":
                for (let j = 0; j < 12; j++) {
                    let dpName = "Yesterday." + hourly[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j], role: 'value.power', unit: 'kWh'});
                    log(mainPath + path + dpName + ': ' + rawData[j], logMode);
                    total = total + rawData[j];
                setOrCreateState(mainPath + path + 'Total.Yesterday', total, true, {type: 'number', name: 'Yesterday', role: 'value.power',unit: 'kWh'});
                total = 0;
                for (let j = 12; j < 24; j++) {
                    let dpName = "Today." + hourly[j-12];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j-12], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.Today', total, true, {type: 'number', name: 'Today', role: 'value.power',unit: 'kWh'});
                break;
    	case "w-raw":
                for (let j = 0; j < 7; j++) {
                    let dpName = "LastWeek." + daily[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.LastWeek', total, true, {type: 'number', name: 'LastWeek', role: 'value.power',unit: 'kWh'});
                total = 0;
                for (let j = 7; j < 14; j++) {
                    let dpName = "ThisWeek." + daily[j-7];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j-7], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.ThisWeek', total, true, {type: 'number', name: 'ThisWeek', role: 'value.power',unit: 'kWh'});
                break;
    	case "m-raw":
                    let dpName = "LastYear." + monthly[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.LastYear', total, true, {type: 'number', name: 'LastYear', role: 'value.power',unit: 'kWh'});
                total = 0;
                    let dpName = "ThisYear." + monthly[j-12];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j-12], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.ThisYear', total, true, {type: 'number', name: 'ThisYear', role: 'value.power',unit: 'kWh'});
                break;
    async function readConsumtionData(): Promise<void> {
        for (let i = 0; i < devices.length; i++) {
            //get d-raw; w-raw; m-raw
            let dev: any = devices[i].split('.');
            let state = getState(devices[i]).val;
            state = state.slice(1,-1);
            state = state.replaceAll('null', '0');
            await writeConsumtionData(devices[i].slice(0,-5), dev[dev.length -1], Array.from(state.split(','), Number));
    readConsumtionData();
    on({ id: [].concat(Array.prototype.slice.apply($('daikin-cloud.*.lastUpdateReceived'))), change: 'any' }, async (obj) => {
        await readConsumtionData();
    topsurfer
    schrieb am zuletzt editiert von topsurfer
    #227
    @armilar Auch von mir ein Danke für das Script, lief auf Anhieb!
    Frage (hoffe es ist nicht zu OT),
    Jetzt sieht man ja die DP auch mit historischen Daten (z.B. letzte 12 Monate je ein Monatsverbrauch), gibt es einen Trick, diese Daten mit entsprechendem Timestamp in eine InfluxDB zu bekommen, oder ist händige Arbeit angesagt (mittels insert ...)
    Die jetzt neuen Monatswerte würde ich per Cron am Monatsende dann in die DB schreiben lassen (oder?)
    • apollon77A Offline
      #228
      @Armilar Soll ich den Post mit dem Skript mal in der Adapter Readme verlinken?
      • apollon77A apollon77
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #229
        @apollon77
        ja gerne... 😊
        hier verschwindet es ja irgendwann im "ich habe ja nicht alle Posts gelesen" ;-)
        • T topsurfer
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #230
          @topsurfer
          ja, du kannst je Gerät die Totalwerte nutzen...
          Wenn die sich ändern in die influxdb schreiben...
          Sollte ja alles vorhanden sein, was für eine Auswertung erforderlich ist.
          • ArmilarA Armilar
            @topsurfer
            topsurfer
            #231
            @armilar Ja, das gilt aber doch nur für aktuelle Werte, die sich noch ändern.
            Meinte ja alte Daten von z.B. Monatswert 08.2024, der ändert sich ja nicht mehr.
            Den will ich ja mit Timestamp 31.08.2024 in die DB bekommen, das geht wohl nur händig, oder?
            • T topsurfer
              #232
              @topsurfer sagte in Test Adapter Daikin-Cloud 0.4.0:
              das ist aber doch kein Thema für diesen Thread, oder?
                breaksrmine
                #233
                Hat jemand schon die firmeware drauf und den adapter getestet ?
                • B breaksrmine
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #234
                  @breaksrmine
                  Habe zwar keine v3.5.0 auf v4.0.1, sondern eine v7.7.0 auf v7.8.0 - aber das scheint Geräteabhängig zu sein... Ist bei mir eine Altherma
                  Update in der App durchgeführt und dann ist es im Adapter "nicht erfolgreich" durchgelaufen. Die Datenpunkte waren komplett weg, bis auf die Consumption Ordner...
                  Ich habe folgendes gemacht:
                  • Adapter auf Debug gestellt - ich konnte sehen, dass die Werte aus der Cloud zwar zu sehen waren, jedoch funktionierte das Schreiben nicht
                  • facaecb4-1d82-49d0-bd78-f39f63d9b93a-image.png auch nochmal durchgeführt (wahrscheinlich nicht notwendig)
                  • alles unter daikin-cloud.0.... gelöscht und den Adapter durchgestartet
                  Dann war wieder alles wie gewohnt da...
                  • ArmilarA Armilar
                    @breaksrmine
                    breaksrmine
                    schrieb am zuletzt editiert von breaksrmine
                    #235
                    @armilar danke für die Antwort. ja 7.8.0 hab ich auch drauf. Jetzt kam 4.0.1 glaube das war für wifi gateway. Jedenfalls es läuft nach dem update alles problemlos !
                    Ich habe eine Daikin Altherma 3 Ech2O 6 KW Split
                    • PLCHome 0P Offline
                      PLCHome 0P Offline
                      PLCHome 0
                      #236
                      Hallo zusammen, ich suche diese Einstellung in dem Adapter. Zumindest Auto und 40% bis 100% fest.
                      Gibt es die Möglichkeit, das in dem Adapter zu implementieren?
                      Oder ist es schon drin und ich finde es nur nicht 😖 ?
                      K FernetMentaF 2 Antworten Letzte Antwort
                      • PLCHome 0P PLCHome 0
                        Kymchy
                        schrieb am zuletzt editiert von Kymchy
                        #237
                        @plchome-0 Fände ich auch cool, wenn das implementiert würde. Auch die Liquidtemperaturen.
                          #238
                          Dann wendet Euch bitte an Daikin. Der Adapter arbeitet zu 100000% generisch. Alles was von Daikin an Daten kommt ist in den Objekten. Ergo: Was fehlt ist nicht da.
                          Daikin hat - why ever - entschieden das nicht in den Cloud API DAten zu haben. Nur Daikin kann das auf Druck der User ändern.
                            Kymchy
                            #239
                            @apollon77 alles klar, hatte ich mir schon gedacht. Die Smarthome Anbindung der Daikin Geräte ist schon ziemlich unterirdisch...
                            Btw., ich habe in einer meiner Perferas das aktuelle WLan Modul abgeklemmt und ein Daikin BRP069B4x Wlan Modul verbaut. Dort ist die lokale Anbindung noch gegeben und es funktioniert ohne Cloud, selbst mit der neuen, aktuellen Firmware. Mit dem "alten" Daikin Adapter hat man dann auch neuerdings die Bedarfssteuerung.
                            B PLCHome 0P 3 Antworten Letzte Antwort
                              #240
                              hehe cool.Ja ich bekomme demnächst auf 3 neue Geräte und hab mit B41er besorgt in Italien und will versuchen die zu tauschen
                              • K Kymchy
                                bakerman23
                                #241
                                @kymchy du kannst die daikin auch per LAN anbinden.
                                • B bakerman23
                                  Kymchy
                                  #242
                                  @bakerman23 Wie soll das gehen? Wo kann man da ein LAN Kabel anschließen?
                                    FernetMentaF Online
                                    FernetMentaF Online
                                    FernetMenta
                                    #243
                                    @plchome-0 Ich habe die Bedarfssteuerung immer auf Auto. Kannst du etwas über deinen UseCase erzählen? Warum willst du das dynamisch anpassen? Versprichst du dir Einsparung bzgl. Strom? Falls ja, auf welche Daten schaust du da? Ich habe das Gefühl, dass "Einblicke" nicht wircklich funktioneirt. Bei mir bewegt sich Verbrauch in der selben Range als Wäremeabgare. Letztes sollte eigentlich Faktor 4-5 größer sein (Heizen).
                                    PLCHome 0P 1 Antwort Letzte Antwort
                                    • FernetMentaF FernetMenta
                                      PLCHome 0P Offline
                                      PLCHome 0P Offline
                                      PLCHome 0
                                      schrieb am zuletzt editiert von PLCHome 0
                                      #244
                                      @fernetmenta wenn im Sommer die PV Akkus voll sind regel ich die Anlage so aus das sie maximal kühlt und den Strom wegsaugt ehe ich den für 9,5 Ct verschenke. Wenn das Auto vor der Tür stehet nehmen ich das. Andersrum kann man die Anlage drüber auch ganz gut drosseln um im PV Ertrag zu bleiben…
                                      • K Kymchy
                                        PLCHome 0P Offline
                                        PLCHome 0P Offline
                                        PLCHome 0
                                        #245
                                        @kymchy hab des gestern gelesen… ich hab 3 FTXA25BT Geräte mit BRP069B4x ich glaube die kamen damals separat und ein Gerät FTXM25R mit …C4x. War echt doof da war der schon drin, hab 50€ gespart und das blöde Ding erwischt. Ich hab jetzt mal einen BRP069B45 bestellt der war im Kaufland Marketplace unter 37€ mal schauen ob der funktioniert und da reinpasst…. Wenn ja wäre es ein Schnäppchen…
                                          Kymchy
                                          #246
                                          @plchome-0 ich habe in den meisten meiner 5 Perferas Faikin Module verbaut. Kann man auch nette Sachen mit machen, vor allem die Möglichkeit ein externes Wandthermostat zu nutzen finde ich cool. Kosten auch so um die 37€. Muss man sich allerdings etwas reinfuchsen.
