  4. Tester Zigbee Adapter 3.x gesucht
zigbeezigbee adapter
259 Beiträge 27 Kommentatoren 66.5k Aufrufe 38 Beobachtet
    MeisterQ 0
    schrieb am zuletzt editiert von MeisterQ 0
    #218
    Jetzt haben fast garkeine Geräte mehr Bilder 😅
    Nach einem Neustart waren die Bilder wieder da.
    179
    Log-Größe: 2.3 MB
    Zeit
    zigbee.0
    	2025-07-18 11:46:25.360	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2025-07-18 11:46:24.583	info	Closing Zigbee network, 117 seconds remaining
    zigbee.0
    	2025-07-18 11:46:24.359	info	Saved local configuration data
    zigbee.0
    	2025-07-18 11:46:24.359	info	cleaning everything up...
    zigbee.0
    	2025-07-18 11:46:24.358	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
    zigbee.0
    	2025-07-18 11:46:24.356	error	Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.355	error	TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at StatesController.AddModelFromHerdsman (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:96:31) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    	2025-07-18 11:46:24.355	error	unhandled promise rejection: Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.355	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-07-18 11:46:24.350	error	Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.350	error	TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at StatesController.AddModelFromHerdsman (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:96:31) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    	2025-07-18 11:46:24.350	error	unhandled promise rejection: Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-07-18 11:46:24.349	warn	New device: '0x744dbdfffe61ce69' does not have a known model. please provide an external converter for 'ZigbeeRangeExtender'.
    zigbee.0
    	2025-07-18 11:46:24.348	info	Successfully interviewed '0x744dbdfffe61ce69', device has successfully been paired
    zigbee.0
    	2025-07-18 11:46:23.853	warn	Device 0x744dbdfffe61ce69 "ZigbeeRangeExtender" not found.
    zigbee.0
    	2025-07-18 11:46:23.698	info	Device '0x744dbdfffe61ce69' announced itself
    zigbee.0
    	2025-07-18 11:46:23.636	info	Starting interview of '0x744dbdfffe61ce69'
    zigbee.0
    	2025-07-18 11:46:20.979	info	Opening zigbee Network for 120 seconds
    Leider trotzdem das selbe Spiel
    HomoranH arteckA 2 Antworten Letzte Antwort
    • M MeisterQ 0
      179
      Log-Größe: 2.3 MB
      Zeit
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      #219
      @meisterq-0 sagte in Tester Zigbee Adapter 3.x gesucht:
      vollkommen normal!
      dann warst du zu schnell
      • AsgothianA Asgothian
        @haselchen sagte in Tester Zigbee Adapter 3.x gesucht:
        @asgothian
        Okay. Die Meldung suggeriert aber , dass etwas nicht geklappt hat. Not Supported ist von der Aussage her ja negativ behaftet.
        Weil , in der Map dann selber alles korrekt angezeigt wird.
        Alle Striche grün und alle Geräte verbunden.
        Da würde ich als User durch die Nachricht einfach nur (unnötig) verunsichert werden.
        Das siehst du falsch. In der Map wird es gerade nicht korrekt dargestellt. Es fehlen die meisten Linien die von den Plug_01 ausgehen - in den meisten fällen scheinen diese nicht einmal mit dem Koordinator verbunden zu sein, wenn du die 'nachbarn' ausblendest.
        Es geht also nicht darum das Linien nicht grün sind. Es geht darum das Linien vollständig fehlen !
        A.
        Nachtrag: Es wird möglicherweise eine Option geben diese Meldung zu unterdrücken, bzw. die Meldung automatisch auszublenden. Das ist aber noch nicht konkret, und wenn es kommt wird es etwas sein was der Nutzer aktiv wird einschalten müssen.
        haselchenH Offline
        haselchenH Offline
        haselchen
        #220
        @asgothian sagte in Tester Zigbee Adapter 3.x gesucht:
        @asgothian
        A.
        Ich weiss, dass ihr die Dinger nicht mögt.
        Scheine ich der Einzige zu sein, der damit keine Probleme hat ;)
        In technischer Hinsicht, muss ich Dir vermutlich, mangels Wissen, Recht geben.
        In visueller Hinsicht sieht das aber so aus:
        Alles mit jedem verbunden , ebenso mit dem Coordinator.
        Dementsprechend, würde ich aus meiner Sicht, Deiner Darstellung widersprechen.
        • M MeisterQ 0
          179
          Log-Größe: 2.3 MB
          Zeit
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          arteckA Offline
          arteckA Offline
          arteck
          #221
          @meisterq-0 poste mal die shepherd.db.. ich muss mir die Struktur mal laden.
          • haselchenH haselchen
            @asgothian
            A.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #222
            Jein. Die Plug 01 werden als Nachbarn von anderen Geräten mit grünen Linien verbunden, aber:
            Den Plug-01 fehlt die blaue Linie. Blende mal in der ansicht der Karte die Nachbarn aus, dann siehst du nur welche 'aktiven' routen exisiteren. Dabei wird auffallen das die Plug 01 eben gerade keine Verbindung gemeldet haben.
            A.
              A.
              haselchenH Offline
              haselchenH Offline
              haselchen
              #223
              @asgothian
              Huhu...ich hab zum Test nochmal 2 BWM bei wieder einem anderen Anbieter bestellt.
              Es scheint, dass es überwiegend nur noch die HOBEIAN Geräte gibt.
              Auf der Packung steht auch New Zigbee PIR LUX.
              Er wird zwar als ZG-204ZL erkannt, aber auf der Packung stehen , vermutlich, Updatebezeichnungen des Gerätes.
              ZG-204ZS /ZG-204ZM
              Und da ist vermutlich der Knackpunkt.
              Beim Anlernen (ich habe zum Testen ein Downgrade des Adapters gemacht) wird alles fein säuberlich erkannt und mit ok abgeschlossen.
              Danach ist aber nichts okay. Das Gerät ist zwar in der Kachel und zeigt Verbindung. Aber es wird nichts aktualisiert. Es ist quasi eingefroren.
              Jetzt die Frage, ist es möglich , ohne von Github die Version laden, dieses Gerät einzupflegen?
              Zigbee2Mqttt hat es ja.
              zigbee.0 2025-07-22 11:23:14.095	info	Successfully interviewed '0xa4c13871cd6e84b7', device has successfully been paired
              zigbee.0 2025-07-22 11:23:03.071	info	Device '0xa4c13871cd6e84b7' announced itself
              zigbee.0 2025-07-22 11:23:02.709	info	Starting interview of '0xa4c13871cd6e84b7'
              zigbee.0 2025-07-22 11:22:48.451	info	Zigbee: allowing new devices to join.
              Kein "WLAN" Zeichen vorm Gerät
              AsgothianA S 2 Antworten Letzte Antwort
                @asgothian
                ZG-204ZS /ZG-204ZM
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #224
                @haselchen ja das geht. Du musst den passenden converter bei z2m identifizieren, den Code in einen externen konverter speichern und diesen in der Konfiguration eintragen.
                Dann bei Adapter Start das log prüfen das er geladen wird und dann ist alles grün.
                Aktuell würde ich einfach die 3.0.3 von GitHub installieren - die soll mittelfristig ( eine Woche oder so ) ins latest.
                A.
                  A.
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #225
                  A.
                  Kann ich mir mit der 3.0.3 dann Deine obige Vorgehensweise sparen? :)
                    A.
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #226
                    @haselchen Das kann ich dir nicht sagen. Das kannst du aber selber heraus finden:
                    • schau auf der Info-Kachel vom Adapter nach der genauen Herstellerbezeichnung / benennung des Gerätes
                    • Such im Changelog der ZHC nach dieser Bezeichnung - dann weisst du welche ZHC Version benötigt wird.
                    • die 3.0.3 nutzt ZHC 23.72.1
                    A.
                      A.
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #227
                      @asgothian
                      Oha, ganz schön viel zum Durchgucken :)
                      Das Changelog ist bei 24.5.0.
                      Ich hab ja keine Ahnung, wie Du das so aufbereitest, bleibst Du Versionstechnisch immer ein wenig zurück zum Testen?
                      Ich hab nur hier was gefunden zu dem Gerät. Version 23.51.0
                      https://github.com/Koenkk/zigbee-herdsman-converters/pull/9394
                        @locito09 sagte in Tester Zigbee Adapter 3.x gesucht:
                        @dimaiv
                        Muss ich ab github installieren damit der Adapter diese Version zieht oder wie ist das?
                        Der folgende weg führt zum Erfolg:
                        • GitHub Account anlegen
                        • iobroker.zigbee adapter Forken
                        • Package.json Zeile 32 anpassen, von "zigbee-herdsman-converters": "23.35.0" zu "zigbee-herdsman-converters": "23.57.0” ändern
                        • von deinem GitHub installieren
                        • testen ob alles wie gewohnt geht. Wenn ja - PR von deinem GitHub zum iobroker repositiory machen.
                        A.
                        P.s. das Testen ist das wichtige. Da ich das aktuell nicht leisten kann werd ich das hochziehen der ZHC nicht mal eben so machen.
                        GaspodeG Offline
                        GaspodeG Offline
                        Gaspode
                        schrieb am zuletzt editiert von Gaspode
                        #228
                        @haselchen said in Tester Zigbee Adapter 3.x gesucht:
                        @asgothian said in Tester Zigbee Adapter 3.x gesucht:
                        Und zum Testen der neuesten ZHC Version:
                        https://forum.iobroker.net/post/1280579
                        Aber hattest du das nicht schon mal vor ein paar Tagen schon so genutzt?
                        • GaspodeG Gaspode
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #229
                          @Asgothian
                          Du bist mit Geld nicht zu bezahlen 😬
                          Funktioniert auf Anhieb mit der 3.0.3 von Github.
                          Klasse.
                          Dann warte ich auf Stable, dann kanns auch ins Produktivsystem.
                          @Gaspode
                          Ich meine, ich hatte letztens ne URL zum Installieren.
                          Da war der BWM dann drin, aber drumherum gabs Probleme.
                          Ich hab 4 von den Dingern und mich schon grün und blau geärgert, dass sie nicht funktionieren.
                            @Asgothian
                            Klasse.
                            @Gaspode
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #230
                            @Asgothian
                            Ja, die Version gab es, nachdem die hinreichend oft installiert wurde und die ‘probleme’ die du angesprochen hast Gefixed wurden hab ich die 3.0.3 gebaut. Die nutzt dann die fast aktuellen ZHC
                            A.
                              @Asgothian
                              A.
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #231
                              @asgothian
                              Ist der Adapter schon kompatibel mit NodeJS 22.17.1 ?
                              Ich bekomme aktuelle Update Container nur noch mit dieser Version angeboten.
                                @asgothian
                                #232
                                @haselchen
                                Ja. nodejs@22 dürfte in den nächsten Tagen auch zur offiziellen Empfehlung für den ioBroker werden.
                                Gibt entsprechende PRs dafür. Und der Container muss natürlich auch darauf aufbauen. Ist nur etwas 'vorgeprescht' mit dem Release.
                                  @haselchen
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #233
                                  Puh. Dann ist ja gut.
                                  Durch Zufall die neue Version gesehen.
                                  Meistens sinds so kleine "Schönheits"Updates.
                                  Hier kam ich ein wenig ins Schwitzen....
                                    #234
                                    Wegen eines schnöden Updates von nodejs? Warum wird da eigentlich immer so ein Gewese drum gemacht?
                                    nodejs@22 ist vor mehr als einem Jahr released worden, da sind also schon diverse Tests gegen gelaufen.
                                    Die gängigsten und gepflegten Adapter laufen alle damit. Bei verwaisten Adaptern kann das zugegeben anders aussehen, aber die können auch aus anderen Gründen den Betrieb einstellen.
                                    • ste_gleiS ste_glei
                                      @mickemup Versuch mal bitte die andere Variante - mit dem Cluster und Attribute via read im send_payload. Es ist denkbar das die SendToZigbee Funktion buggy ist in der 2.x/3.x.
                                      A.
                                      mit diesem Payload funktioniert es
                                      { "read": { "cluster": "genPowerCfg", "attributes": ["batteryPercentageRemaining"] }}
                                      Danke für die rege Diskussion und die ganzen Tipps da lerne ich jeden Tag dazu
                                      mickemupM Offline
                                      mickemupM Offline
                                      mickemup
                                      #235
                                      @Asgothian
                                      Mit dem gleichen Payload wollte ich nun die "Batterie" auch bei den IKEA Styrbar aktualisieren.
                                      Es kommt auch eine "Antwort":
                                      Batterie Level bleibt aber im Gegensatz zu den Parasolls auf:
                                      Irgendwer eine Idee?
                                      @ste_glei sagte in Tester Zigbee Adapter 3.x gesucht:
                                      A.
                                      AsgothianA A 2 Antworten Letzte Antwort
                                      • mickemupM mickemup
                                        @Asgothian
                                        A.
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #236
                                        @mickemup sagte in Tester Zigbee Adapter 3.x gesucht:
                                        Setz das Gerät mal auf Debug (bug icon auf der Kachelrückseite) und schau dir an wie die Antwort verarbeitet wird (und ob sie verarbeitet wird) - geht via debug tab im Adapter oder via ELEVATED log Meldungen
                                        A.
                                        mickemupM 1 Antwort Letzte Antwort
                                          A.
                                          mickemupM Offline
                                          mickemupM Offline
                                          mickemup
                                          #237
                                          @asgothian
                                          Bei einem Parasoll mit 82% Bat Anzeige kommt folgende Response:
                                          Scheint irgendwie Faktor zwei darin zu stecken....
                                          Beim Styrbar im DEBUG dies:
                                          Kann es sein, dass 255 dafür steht, dass kein Wert vorhanden ist?
