  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.9k Aufrufe 45 Beobachtet
  • G Gismoh
    @asgothian
    Merci,
    ist hier evtl. etwas dabei?
    zigbee2mqtt.0
    2025-01-08 20:23:07.250	debug	Error: connect ECONNREFUSED 192.168.145.51:8080
    zigbee2mqtt.0
    2025-01-08 20:23:06.250	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    zigbee2mqtt.0
    2025-01-08 20:23:06.247	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2025-01-08 20:23:06.246	debug	Error: connect ECONNREFUSED 192.168.145.51:8080
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	==================================================================================
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	|| Coordinator Check Cron : 0 3 * * *
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	|| Coordinator Check Loglevel: debug
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	|| Use Automatic Coordinator Check: yes
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	|| Use Simple Press/Release State: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.108	info	|| Use Simple Move/Stop State: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use Simple Hold/Release State: yes
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use Device Icons: yes
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use Event In Desc: yes
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use BrightnessStep OnOff: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use BrightnessMove OnOff: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use ColorTemperature ColorSync: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Use Kelvin: no
    zigbee2mqtt.0
    2025-01-08 20:23:06.107	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Debug Log: deactivated
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Websocket Dummy MQTT-Server: deactivated
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Websocket Auth-Token: unused
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Websocket Port: 8080
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Websocket Server: 192.168.145.51
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Websocket Scheme: wss
    zigbee2mqtt.0
    2025-01-08 20:23:06.106	info	|| Zigbee2MQTT Connection Type: ws
    zigbee2mqtt.0
    2025-01-08 20:23:06.105	info	|| Zigbee2MQTT Frontend Port: 8080
    zigbee2mqtt.0
    2025-01-08 20:23:06.105	info	|| Zigbee2MQTT Frontend Server: 192.168.145.51
    zigbee2mqtt.0
    2025-01-08 20:23:06.105	info	|| Zigbee2MQTT Frontend Scheme: http
    zigbee2mqtt.0
    2025-01-08 20:23:06.105	info	================================= Adapter Config =================================
    zigbee2mqtt.0
    2025-01-08 20:23:06.095	info	starting. Version 3.0.2 (non-npm: arteck/ioBroker.zigbee2mqtt#refs/tags/v3.0.2) in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v20.18.1, js-controller: 7.0.3
    zigbee2mqtt.0
    2025-01-08 20:23:05.990	debug	States connected to redis: 127.0.0.1:9000
    zigbee2mqtt.0
    2025-01-08 20:23:05.898	debug	States create User PubSub Client
    zigbee2mqtt.0
    2025-01-08 20:23:05.897	debug	States create System PubSub Client
    zigbee2mqtt.0
    2025-01-08 20:23:05.873	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    zigbee2mqtt.0
    2025-01-08 20:23:05.813	debug	Objects connected to redis: 127.0.0.1:9001
    zigbee2mqtt.0
    2025-01-08 20:23:05.809	debug	Objects client initialize lua scripts
    zigbee2mqtt.0
    2025-01-08 20:23:05.694	debug	Objects create User PubSub Client
    zigbee2mqtt.0
    2025-01-08 20:23:05.694	debug	Objects create System PubSub Client
    zigbee2mqtt.0
    2025-01-08 20:23:05.692	debug	Objects client ready ... initialize now
    zigbee2mqtt.0
    2025-01-08 20:23:05.644	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    (Hatte vorhin gerade auf die neueste zigbee2mqtt Version geupdatet - hat nichts geändert)
    1Topf1 Offline
    1Topf1 Offline
    1Topf
    #508
    @gismoh
    Läuft z2m überhaupt?
    systemctl status zigbee2mqtt.service
    G 1 Antwort Letzte Antwort
    • G Gismoh
      @asgothian
      Merci,
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      crunchipC Abwesend
      crunchipC Abwesend
      #509
      @gismoh sagte in Test Adapter zigbee2mqtt:
      Auch Z2M?
      Passt deine yaml Datei noch?
      • 1Topf1 1Topf
        @gismoh
        Gismoh
        schrieb am zuletzt editiert von Gismoh
        #510
        @1topf
        Merci, ja, dort scheint es Schwierigkeiten zu geben:
        ● zigbee2mqtt.service - zigbee2mqtt
             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: >
             Active: activating (auto-restart) (Result: exit-code) since Thu 2025-01-09>
            Process: 35767 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
           Main PID: 35767 (code=exited, status=1/FAILURE)
                CPU: 1.000s
        Hatte sogar Backups eingespielt, wo es noch Lief, eines von heute Morgen und eines von vor ein paar Tagen.
        Obwohl es bis heute ca. 17:00 Uhr lief, läuft es nun bei den Backups auch nicht mehr.
        Da das Ergebnis überall gleich ist (selbe Fehlermeldung) habe ich das Backup von vorhin wieder eingespielt.
        Der Zigbee Stick: SLZB-06P7
        ist allerdings erreichbar, und hatte automatische Updates dort auch deaktiviert (dort alles beim alten Stand).
        Bin nun hingegangen und habe versucht, die Schritte der Anleitung welche ich habe (Zigbee2Mqtt Installation)
        nochmals nachzugehen, aber habe bei einem Befehl Probleme mit der Konsole im Proxmox.
        Bin in Linux Sachen nicht wirklich der "Experte", sondern weit weg davon ;)
        ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
          Auch Z2M?
          Gismoh
          #511
          @crunchip
          Merci, die yaml müsste ich mir später noch ansehen, nun bin ich gerade zu fertig ;)
          Was meinst du mit "Z2M"
          Ist dies nicht die Kurzschreibweise von Zigbee2Mqtt, oder etwas anderes ?
          • G Gismoh
            @crunchip
            crunchipC Abwesend
            crunchipC Abwesend
            #512
            Ja
            Vergleich mal mit der aktuellen und der aus einem backup
              Ja
              Gismoh
              #513
              @crunchip
              die yaml sieht scheinbar gut aus
              (Muss diese allerdings noch vergleichen - war aber nicht explizit an dieser Datei nachträglich dran):
              homeassistant: false
              frontend: true
              mqtt:
                base_topic: zigbee2mqtt
                server: mqtt://192.168.145.51:1884
                user: mqttuser
                password: XXXXXXXXX
              serial:
                port: tcp://192.168.145.197:6638
                adapter: auto
                baudrate: 115200
              advanced:
                network_key:
                  - 25
                  - 95
                  - 206
                  - 213
                  - 156
                  - 132
                  - 70
              Wenn ich nun allerdings (wie in der mir vorliegenden Anleitung)
              cd /opt/zigbee2mqtt npm start
              eingebe, kommt:
              > zigbee2mqtt@1.42.0 start
              > node index.js
              Starting Zigbee2MQTT without watchdog.
                          READ THIS CAREFULLY
              Refusing to start because configuration is not valid, found the following errors:
              - devices/0x00178801061f8b7b/homeassistant/name must be string
              If you don't know how to solve this, read https://www.zigbee2mqtt.io/guide/configuration
              Womit ich selber nicht klarkomme/verstehe.
              Die "0x00178801061f8b7b" ist bei mir eine Hue:
              • G Gismoh
                @crunchip
                frontend: true
                mqtt:
                  user: mqttuser
                  password: XXXXXXXXX
                serial:
                  adapter: auto
                  baudrate: 115200
                advanced:
                  network_key:
                    - 25
                    - 95
                    - 206
                    - 213
                    - 156
                    - 132
                    - 70
                eingebe, kommt:
                > node index.js
                            READ THIS CAREFULLY
                crunchipC Abwesend
                crunchipC Abwesend
                #514
                Da fehlen paar Einträge, gerade im Bezug auf die Neue Version
                  Gismoh
                  #515
                  @crunchip
                  Du meinst die Version der Instanz/Adapter?
                  Dann werde ich nochmal die alte Version aufspielen, allerdings hatte ich dort ja bereits die Fehlermeldung gehabt.
                  Aber Versuch macht klug ;)
                  Nachtrag:
                  mit Adapter 2.13.6 bleibt es leider bei den Meldungen:
                  zigbee2mqtt.0
                  2025-01-09 15:27:44.959	debug	Error: connect ECONNREFUSED 192.168.145.51:8080
                  zigbee2mqtt.0
                  2025-01-09 15:27:43.959	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                  zigbee2mqtt.0
                  2025-01-09 15:27:43.958	warn	Start try again in 1 seconds...
                  Wenn ich die Fehlermeldung richtig verstehe, müsste ich noch einen Platzhalter irgendwo am Ende einfügen.
                  Vermutlich ist ein "*" gemeint?
                  Leider habe ich bisher nichts dazu gefunden, wo ich im Adapter dies noch am Ende einfügen muss.
                  • G Gismoh
                    @crunchip
                    Nachtrag:
                    zigbee2mqtt.0
                    zigbee2mqtt.0
                    zigbee2mqtt.0
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #516
                    @gismoh dein z2m muss erst mal laufen, ansonsten läuft der Adapter ohne hin nicht
                    https://github.com/Koenkk/zigbee2mqtt/releases/tag/2.0.0
                    den Hinweis gab es ja auch beim Update des Adapters
                    mein oberer Abschnitt meiner yaml sieht z.b so aus
                    homeassistant:
                      enabled: false
                    frontend:
                      enabled: true
                      port: 9442
                      host: 0.0.0.0
                    mqtt:
                      server: mqtt://10.1.1.219:1883
                      user: blubblub
                      password: 'blablabla'
                      keepalive: 90
                      reject_unauthorized: true
                      version: 4
                    serial:
                      port: tcp://10.1.20.116:6638
                      adapter: ember
                    advanced:
                      pan_id: 6755
                      ext_pan_id:
                        - 221
                        - 221
                        - 221
                        - 221
                        - 221
                        - 221
                        - 221
                        - 170
                      channel: 11
                      network_key:
                        - 1
                        - 3
                        - 5
                        - 23
                        - 9
                        - 11
                        - 29
                        - 15
                        - 0
                        - 2
                        - 4
                        - 6
                        - 8
                        - 10
                        - 12
                        - 13
                      last_seen: ISO_8601_local
                      homeassistant_legacy_entity_attributes: false
                      legacy_api: false
                      legacy_availability_payload: false
                      output: json
                      transmit_power: 20
                      log_level: warning
                      log_syslog:
                        app_name: Zigbee2MQTT
                        eol: /n
                        host: localhost
                        localhost: localhost
                        path: /dev/log
                        pid: process.pid
                        port: 123
                        protocol: tcp4
                        type: '5424'
                    device_options:
                      legacy: false
                    availability:
                      enabled: true
                      active:
                        timeout: 5
                      passive:
                        timeout: 1500
                    devices:
                    edit
                    hab grad nochmal zurückgeblättert, du bist noch auf
                      homeassistant:
                        enabled: false
                      frontend:
                        enabled: true
                        port: 9442
                        host: 0.0.0.0
                      mqtt:
                        user: blubblub
                        keepalive: 90
                        version: 4
                      serial:
                        adapter: ember
                      advanced:
                        pan_id: 6755
                        ext_pan_id:
                          - 221
                          - 221
                          - 221
                          - 221
                          - 221
                          - 221
                          - 221
                          - 170
                        channel: 11
                        network_key:
                          - 1
                          - 3
                          - 5
                          - 23
                          - 9
                          - 11
                          - 29
                          - 15
                          - 0
                          - 2
                          - 4
                          - 6
                          - 8
                          - 10
                          - 12
                          - 13
                        legacy_api: false
                        output: json
                        transmit_power: 20
                        log_level: warning
                        log_syslog:
                          eol: /n
                          host: localhost
                          path: /dev/log
                          pid: process.pid
                          port: 123
                          protocol: tcp4
                          type: '5424'
                      device_options:
                        legacy: false
                      availability:
                        enabled: true
                        active:
                          timeout: 5
                        passive:
                          timeout: 1500
                      devices:
                      edit
                      Gismoh
                      #517
                      @crunchip
                      In der yaml hatte sich bei dem angemeckerten Gerät
                      Ein Homeassistant Eintrag eingeschlichen - keine Ahnung wo her der gekommen ist (?)
                      Nach dem rauslöschen von diesem Eintrag sah es so aus:
                      # npm start
                      > node index.js
                      [2025-01-09 22:24:50] info:     z2m: Logging to console, file (filename: log.log)
                      [2025-01-09 22:24:50] info:     z2m: Starting Zigbee2MQTT version 1.42.0 (commit #861cba63)
                      [2025-01-09 22:24:50] info:     z2m: Starting zigbee-herdsman (2.1.9)
                      [2025-01-09 22:24:50] info:     zh:zstack:znp: Opening TCP socket with 192.168.145.197:6638
                      [2025-01-09 22:24:50] info:     zh:zstack:znp: Socket connected
                      [2025-01-09 22:24:50] info:     zh:zstack:znp: Socket ready
                      [2025-01-09 22:24:50] info:     zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
                      [2025-01-09 22:24:51] info:     zh:zstack:znp: Skip bootloader for CC2652/CC1352
                      [2025-01-09 22:24:51] info:     z2m: zigbee-herdsman started (resumed)
                      [2025-01-09 22:24:51] info:     z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20240716,"transportrev":2},"type":"zStack3x0"}'
                      [2025-01-09 22:24:51] info:     z2m: Test_TFK_Aqara (0x00158d000ad9b20b): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                      ---> weiter unten werden weitere Geräte aufgezählt, und Werte von Gestern, vor dem Absturz angezeigt.
                      dann noch:
                      [2025-01-09 22:24:53] info:     z2m: Started frontend on port 8080
                      Error: listen EADDRINUSE: address already in use :::8080
                          at Server.setupListenHandle [as _listen2] (node:net:1908:16)
                          at listenInCluster (node:net:1965:12)
                          at Server.listen (node:net:2067:7)
                          at Frontend.start (/opt/zigbee2mqtt/lib/extension/frontend.ts:107:25)
                          at Controller.callExtensions (/opt/zigbee2mqtt/lib/controller.ts:399:42)
                          at processTicksAndRejections (node:internal/process/task_queues:95:5)
                          at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:218:9)
                          at start (/opt/zigbee2mqtt/index.js:154:5
                      Sieht zumindest schon anders aus als vorher.
                      .... starte mal die Maschine vom iobroker komplett neu.
                      • G Gismoh
                        @crunchip
                        # npm start
                        > node index.js
                        dann noch:
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #518
                        2025-01-09 22:24:53] info: z2m: Started frontend on port 8080 Error: listen EADDRINUSE: address already in use :::8080
                        Ist das nicht der falsche Port?
                          Gismoh
                          #519
                          @crunchip
                          der war auch vorher eingestellt, wo es noch lief.
                          Bin gerade noch daran, aber es sieht bisher so aus, ob es wieder laufen würde ;)
                          Zumindest reagiert schon mal wieder etwas.
                          • G Gismoh
                            @crunchip
                            Gismoh
                            #520
                            Ahhh, ist das eine Wohltat, es funktioniert wieder. 👍
                            Lag wohl wirklich nur daran, das sich ein Gerät irgendwie in der yaml mit "homeassistant" eingetragen hat - und dies nachträglich.
                            Denn dieses Gerät (Bei mir eine Hue-Birne) war schon lange integriert gewesen.
                            Sollte also jemand das selbe Problem haben/bekommen, dies hat bei mir geholfen:
                            nano /opt/zigbee2mqtt/data/configuration.yaml
                            Weiter runterscollen, dann werden die Geräte aufgelistet.
                            Dann nach einem Gerät suchen, wo "homeassistant" Einträge vorhanden sind.
                            Dort diese Einträge von "homeassistant" in der yaml löschen (waren bei mir drei Zeilen).
                            War bei mir bei einem Gerät der Fall, und zwar genau bei diesem, bei welchem bereits gemeckert wurde:
                            nach:
                            cd /opt/zigbee2mqtt
                            npm start
                            Wenn man es nun weis, war es eigentlich ganz einfach,
                            die verschiedenen Fehlermeldung (s.o.) haben mich "etwas" als Anfänger irritiert und mich daher auf Irrwege geschickt.
                            • AutodidaktA Offline
                              AutodidaktA Offline
                              Autodidakt
                              schrieb am zuletzt editiert von Autodidakt
                              #521
                              Servus.
                              Hat das noch jemand, dass im IoBroker die Einstellugsseite weiß bleibt wenn links in der Übersicht auf Zigbee2Mqtt klicke?
                              Und noch was fällt mir auf, die Geräte werden in den Objekten als offline angezeigt obwohl sie da sind und senden und sich schalten lassen...
                              Mfg
                              Tom
                              • AutodidaktA Autodidakt
                                Servus.
                                Mfg
                                Tom
                                TT-Tom
                                #522
                                @autodidakt
                                Bei mir ist alles okay, welche Version hat du? Admin, Adapter, nodeJS und JS-controller?
                                Gruß Tom
                                Public Transport
                                NSPanel Adapter Wiki
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #523
                                  @autodidakt sagte in Test Adapter zigbee2mqtt:
                                  ja von wenn dein admin mit httpa läuft und zigbee2mqtt nur mit http
                                  ansonten Doku bitte lesen
                                    AutodidaktA Offline
                                    Autodidakt
                                    #524
                                    @arteck
                                    Hab die Webui Adresse vergessen einzugeben...
                                    Danke euch.
                                    Warum aber, werden die Geräte als offline angezeigt?
                                      @arteck
                                      Danke euch.
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #525
                                      RTFM
                                      AutodidaktA 1 Antwort Letzte Antwort
                                      • arteckA arteck
                                        RTFM
                                        AutodidaktA Offline
                                        AutodidaktA Offline
                                        Autodidakt
                                        #526
                                        @arteck sagte in Test Adapter zigbee2mqtt:
                                        RTFM
                                        😂 Ok. Ich habs verstanden...
