  4. Test Adapter Bosch Indego
144 Beiträge 19 Kommentatoren 34.6k Aufrufe 16 Beobachtet
  • M mike2712
    @tombox ok, das teste ich gleich mal, das mit der value list ist aber echt kompliziert und unübersichtlicht, habe es mit einen html widget gelöst:
    [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{v:boschindego.0.121604023.state.state; v ==   0 ? 'Reading status' : v == 257 ? 'Charging' : v == 258 ? 'Docked' : v == 259 ? 'Docked - Software update' : v == 260 ? 'Docked' : v == 261 ? 'Docked' : v == 262 ? 'Docked - Loading map' : v == 263 ? 'Docked - Saving map' : v == 513 ? 'Mowing' : v == 514 ? 'Relocalising' : v == 515 ? 'Loading map' : v == 516 ? 'Learning lawn' : v == 517 ? 'Paused' : v == 518 ? 'Border cut' : v == 519 ? 'Idle in lawn' : v == 769 ? 'Returning to Dock' : v == 770 ? 'Returning to Dock' : v == 771 ? 'Returning to Dock - Battery low' : v == 772 ? 'Returning to dock - Calendar timeslot ended' : v == 773 ? 'Returning to dock - Battery temp range' : v == 774 ? 'Returning to dock' : v == 775 ? 'Returning to dock - Lawn complete' : v == 776 ? 'Returning to dock - Relocalising' : v == 1025 ? 'Diagnostic mode' : v == 1026 ? 'EOL Mode' : v == 1281 ? 'Software update' : v == 1537 ? 'Low power mode' : v == 64513 ? 'Docked - Waking up'  : '---'}\n"},"style":{"left":"1340px","top":"690px","color":"#FFFFFF"},"widgetSet":"basic"}]
    tombox
    @mike2712 naja value list html kannst du den max value wert eintragen und dann für die bestimmten wert die Beschreibung besser als die Wertenliste
    • T tombox
      @mike2712 Wenn du eine ständige aktuelle Position haben willst dann sollte der Interval bei 1minute liegen
      Mein Stand ist auch nur eine ValueList in der vis bei der man die wichtigsten states definiert.
      JohannesF
      Bzgl Abfragezeit 1 Minute:
      Hat jemand Erfahrung wie schnell/oft Bosch das abfragen zulässt?
      Ich wollte eine Karte mitzeichnen und hatte das irgendwo im Sekundenbereich. Irgendwann kam dann (auch in der App) eine Fehlermeldung. Am nächsten Tag ging es dann wieder.
      Johannes
      • pfriedP Offline
        pfriedP Offline
        pfried
        schrieb am zuletzt editiert von pfried
        Ich bin ja so was von begeistert, dass der Adapter nun wieder funktioniert! Vielen, vielen Dank!
        Edit: Abfragezeit: 1 Minute
        • pfriedP pfried
          JohannesF
          hat sich jemand die 'battery' Informationen schon mal näher angeschaut?
          Bei mir geht 'voltage' runter bis 1,8 und rauf bis 9,4. Was sind das für Werte? Das ist ein 18V LiIon Akku. Ich nehm mal an 4 Zellen. Also sollte der Spannungsbereich ca. 14,4 V bis 16,8V oder so sein.
          Gleichzeitig liefert Percent immer genau den 10 fachen Wert von Voltage.
          Also 5V sind 50% ???
          Wie ist das bei euch?
          • J JohannesF
            JohannesF
            @johannesf Nachtrag: Es sind 5 Zellen in Reihe. also nochmal 4v mehr als oben angegeben.
            pfriedP 1 Antwort Letzte Antwort
            • J JohannesF
              pfriedP Offline
              pfriedP Offline
              pfried
              Hallo @tombox, bin ich mit der Fehlermeldung alleine? Tritt bei mir seit einer Woche auf:
              • pfriedP pfried
                CodierknechtC Online
                Codierknecht
                @pfried sagte in Test Adapter Bosch Indego:
                Nö - häng Dich dran ...
                https://github.com/iobroker-community-adapters/ioBroker.boschindego/issues/73
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • CodierknechtC Online
                  Codierknecht
                  Die neue Version 1.2.2 fixt das Problem mit dem nicht mehr funktionierenden Login.
                  Als Experte von NPM installierbar.
                  • CodierknechtC Codierknecht
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @codierknecht said in Test Adapter Bosch Indego:
                    Oder ganz normal über das LATEST Repository installieren:
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      Codierknecht
                      @mcm1957 sagte in Test Adapter Bosch Indego:
                      ... und anschließend nicht vergessen, das Repo wieder auf "stable" zurück zu stellen ;-)
                        pfriedP Offline
                        pfriedP Offline
                        pfried
                        @codierknecht @tombox Geht es nur mir so, oder haben die schon wieder etwas geändert?
                        integer63I 1 Antwort Letzte Antwort
                        • pfriedP pfried
                          integer63I Offline
                          integer63I Offline
                          integer63
                          @pfried Nein, wir sind schon mal mindestes zwei ;-)
                          • mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @integer63
                            TA2k war do offensichtlich schon aktiv - DANKE:
                            https://github.com/iobroker-community-adapters/ioBroker.boschindego?tab=readme-ov-file#132-2024-11-28
                            1.3.2 sollte spätestens morgen via LATEST verfügbar sein.
                            Wenn ich hier lese dass sie funktioniert (und mich ggF wer dran dran erinnert) kann / werde ich sie prior ins stable schieben.
                            • mcm1957M mcm1957
                              @integer63
                              integer63I Offline
                              integer63I Offline
                              integer63
                              @mcm1957 1.3.2 funktioniert bei mir - vielen dank!
                              • integer63I integer63
                                pfriedP Offline
                                pfriedP Offline
                                pfried
                                Danke für das schnelle Update - geht wieder bei mir!
                                  Dosierkappe
                                  ich habe mir vor kurzem eine VIS zusammengebaut. Ich kann nur den letzten Fehler nicht löschen. Wenn ich richtig in der Annahme bin braucht man doch nur reset_alerts auf true setzen oder?Screenshot 2024-12-31 104240.jpg
                                  Ich bekomme den Fehler nicht gelöscht.
                                  LG
                                    Dosierkappe
                                    Ok voller vorfreude in den Keller den Mäher geholt aktiviert und Adapter ist wieder rot.😥
                                    • integer63I Offline
                                      integer63I Offline
                                      integer63
                                      Bei mir leider auch:
                                      • D Dosierkappe
                                        tombox
                                        @dosierkappe bitte version 1.3.3 testen
                                        integer63I D 2 Antworten Letzte Antwort
                                        • T tombox
                                          integer63I Offline
                                          integer63I Offline
                                          integer63
                                          @tombox
                                          fast ...
