  4. Test Adapter Bosch Indego
144 Beiträge 19 Kommentatoren 34.6k Aufrufe 16 Beobachtet
    tombox
    @mike2712 Wenn du eine ständige aktuelle Position haben willst dann sollte der Interval bei 1minute liegen
    Mein Stand ist auch nur eine ValueList in der vis bei der man die wichtigsten states definiert.
      mike2712
      schrieb am zuletzt editiert von mike2712
      @tombox ok, das teste ich gleich mal, das mit der value list ist aber echt kompliziert und unübersichtlicht, habe es mit einen html widget gelöst:
      [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{v:boschindego.0.121604023.state.state; v ==   0 ? 'Reading status' : v == 257 ? 'Charging' : v == 258 ? 'Docked' : v == 259 ? 'Docked - Software update' : v == 260 ? 'Docked' : v == 261 ? 'Docked' : v == 262 ? 'Docked - Loading map' : v == 263 ? 'Docked - Saving map' : v == 513 ? 'Mowing' : v == 514 ? 'Relocalising' : v == 515 ? 'Loading map' : v == 516 ? 'Learning lawn' : v == 517 ? 'Paused' : v == 518 ? 'Border cut' : v == 519 ? 'Idle in lawn' : v == 769 ? 'Returning to Dock' : v == 770 ? 'Returning to Dock' : v == 771 ? 'Returning to Dock - Battery low' : v == 772 ? 'Returning to dock - Calendar timeslot ended' : v == 773 ? 'Returning to dock - Battery temp range' : v == 774 ? 'Returning to dock' : v == 775 ? 'Returning to dock - Lawn complete' : v == 776 ? 'Returning to dock - Relocalising' : v == 1025 ? 'Diagnostic mode' : v == 1026 ? 'EOL Mode' : v == 1281 ? 'Software update' : v == 1537 ? 'Low power mode' : v == 64513 ? 'Docked - Waking up'  : '---'}\n"},"style":{"left":"1340px","top":"690px","color":"#FFFFFF"},"widgetSet":"basic"}]
      ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
      • M mike2712
        tombox
        @mike2712 naja value list html kannst du den max value wert eintragen und dann für die bestimmten wert die Beschreibung besser als die Wertenliste
        • T tombox
          JohannesF
          Bzgl Abfragezeit 1 Minute:
          Hat jemand Erfahrung wie schnell/oft Bosch das abfragen zulässt?
          Ich wollte eine Karte mitzeichnen und hatte das irgendwo im Sekundenbereich. Irgendwann kam dann (auch in der App) eine Fehlermeldung. Am nächsten Tag ging es dann wieder.
          Johannes
          • pfriedP Offline
            pfriedP Offline
            pfried
            schrieb am zuletzt editiert von pfried
            Ich bin ja so was von begeistert, dass der Adapter nun wieder funktioniert! Vielen, vielen Dank!
            Edit: Abfragezeit: 1 Minute
            • pfriedP pfried
              JohannesF
              hat sich jemand die 'battery' Informationen schon mal näher angeschaut?
              Bei mir geht 'voltage' runter bis 1,8 und rauf bis 9,4. Was sind das für Werte? Das ist ein 18V LiIon Akku. Ich nehm mal an 4 Zellen. Also sollte der Spannungsbereich ca. 14,4 V bis 16,8V oder so sein.
              Gleichzeitig liefert Percent immer genau den 10 fachen Wert von Voltage.
              Also 5V sind 50% ???
              Wie ist das bei euch?
              • J JohannesF
                JohannesF
                @johannesf Nachtrag: Es sind 5 Zellen in Reihe. also nochmal 4v mehr als oben angegeben.
                pfriedP 1 Antwort Letzte Antwort
                • J JohannesF
                  pfriedP Offline
                  pfriedP Offline
                  pfried
                  Hallo @tombox, bin ich mit der Fehlermeldung alleine? Tritt bei mir seit einer Woche auf:
                  • pfriedP pfried
                    CodierknechtC Online
                    Codierknecht
                    @pfried sagte in Test Adapter Bosch Indego:
                    Nö - häng Dich dran ...
                    https://github.com/iobroker-community-adapters/ioBroker.boschindego/issues/73
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    • CodierknechtC Online
                      Codierknecht
                      Die neue Version 1.2.2 fixt das Problem mit dem nicht mehr funktionierenden Login.
                      Als Experte von NPM installierbar.
                      • CodierknechtC Codierknecht
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @codierknecht said in Test Adapter Bosch Indego:
                        Oder ganz normal über das LATEST Repository installieren:
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          Codierknecht
                          @mcm1957 sagte in Test Adapter Bosch Indego:
                          ... und anschließend nicht vergessen, das Repo wieder auf "stable" zurück zu stellen ;-)
                            pfriedP Offline
                            pfriedP Offline
                            pfried
                            @codierknecht @tombox Geht es nur mir so, oder haben die schon wieder etwas geändert?
                            integer63I 1 Antwort Letzte Antwort
                            • pfriedP pfried
                              integer63I Offline
                              integer63I Offline
                              integer63
                              @pfried Nein, wir sind schon mal mindestes zwei ;-)
                              • mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @integer63
                                TA2k war do offensichtlich schon aktiv - DANKE:
                                https://github.com/iobroker-community-adapters/ioBroker.boschindego?tab=readme-ov-file#132-2024-11-28
                                1.3.2 sollte spätestens morgen via LATEST verfügbar sein.
                                Wenn ich hier lese dass sie funktioniert (und mich ggF wer dran dran erinnert) kann / werde ich sie prior ins stable schieben.
                                • mcm1957M mcm1957
                                  @integer63
                                  integer63I Offline
                                  integer63I Offline
                                  integer63
                                  @mcm1957 1.3.2 funktioniert bei mir - vielen dank!
                                  • integer63I integer63
                                    pfriedP Offline
                                    pfriedP Offline
                                    pfried
                                    Danke für das schnelle Update - geht wieder bei mir!
                                      Dosierkappe
                                      ich habe mir vor kurzem eine VIS zusammengebaut. Ich kann nur den letzten Fehler nicht löschen. Wenn ich richtig in der Annahme bin braucht man doch nur reset_alerts auf true setzen oder?Screenshot 2024-12-31 104240.jpg
                                      Ich bekomme den Fehler nicht gelöscht.
                                      LG
                                        Dosierkappe
                                        Ok voller vorfreude in den Keller den Mäher geholt aktiviert und Adapter ist wieder rot.😥
                                        • integer63I Offline
                                          integer63I Offline
                                          integer63
                                          Bei mir leider auch:
