  4. Node.js v16.20.2 update v18.20.4 sinvoll ?
55 Beiträge 9 Kommentatoren 6.1k Aufrufe 7 Beobachtet
    @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
    @homoran ja der gute alte raspberry kommt an seine grenze
    hast du wenigstens diesen unnötigen Desktop Kram deaktiviert?
    klaris
    schrieb am zuletzt editiert von klaris
    @homoran welchen unötigen desktop kram ?
    vielen dank für deine GEDULD ...
    • K klaris
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      ~ Under-voltage detected
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2024-08-16 10:02:19 CEST
                 Universal time: Fri 2024-08-16 08:02:19 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        714M         66M        0.0K        140M        154M
      Swap:            99M         99M        0.0K
      Total:          1.0G        813M         67M
      Active iob-Instances:   4
                921 M total memory
                713 M used memory
                164 M active memory
                620 M inactive memory
                 66 M free memory
                 13 M buffer memory
                127 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
      MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
      MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.4G   22G  23% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  716K  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE     OPTIONS
      /                            /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
      | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
      `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.7G    /var/
      1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
      1.3G    /var/log
      193M    /var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      13M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      751M    /opt/iobroker/iobroker-data/
      608M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     2
      +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
      +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
      Adapter State
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
        system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
        system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
        system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
        system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
      Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
      Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
      Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      ^X
      Objects and States
      Please stand by - This may take a while        Objects:  9851
      States:         8648
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
      udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
      udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
      2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
      2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
      2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
      2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
      2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
      2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
      2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      Press any key for a summary
      @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
      Display-Server: true
        klaris
        @homoran was ist das schon wieder :-) wie kann ich das deaktivieren
        • K klaris
          @klaris
          sudo systemctl set-default multi-user.target
          iob stop
          sudo reboot
          K 3 Antworten Letzte Antwort
          • K klaris
            du wirst kein Raspberrypi OS lite verwendet haben, sondern eins mit vollem Destop und allen GUI-Programmen
              klaris
              @homoran wen du das sagst dan wird es stimmen ..nicht so viel ahnung von der materie ...
                @klaris
                iob stop
                sudo reboot
                klaris
                @thomas-braun soll ich das ausfuhren ? habe ich zugliff dan über meinen pc zur raspberry oberfläche ..
                Thomas BraunT HomoranH CodierknechtC 3 Antworten Letzte Antwort
                • K klaris
                  Genau den sollst du ausstellen. Zugriff ausschließlich über SSH/die Kommandozeile.
                    @klaris
                    iob stop
                    sudo reboot
                    klaris
                    @thomas-braun said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                    @klaris
                    iob stop
                    sudo reboot
                    • K klaris
                      Natürlich, aber....
                      wofür?
                      es geht doch gerade darum diese Oberfläche abzuschalten
                      • K klaris
                        CodierknechtC Offline
                        Codierknecht
                        Welche "Oberfläche"?
                        Sowas bedient man per SSH über die Konsole.
                        HmIP|ZigBee|Tasmota|Unifi
                        Zabbix Certified Specialist
                        K 2 Antworten Letzte Antwort
                        • CodierknechtC Codierknecht
                          klaris
                          @codierknecht said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                          ok gemacht !!
                            @klaris
                            iob stop
                            sudo reboot
                            klaris
                            @klaris
                            iob stop
                            sudo reboot
                            top - 11:47:12 up 3 min,  1 user,  load average: 3.47, 2.21, 0.91
                            Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  13.7/2.8    17[|||||||||||||||||        ]
                            MiB Mem :    922.0 total,     92.1 free,    683.2 used,    146.6 buff/cache
                            MiB Swap:    100.0 total,      4.7 free,     95.2 used.    187.0 avail Mem
                            width incr is 0, change to (0 default, -1 auto)
                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU
                              klaris
                              @codierknecht welches Raspberry model kannst du mir zum kauf empfehlen fur mein kleines projekt ?
                              • K klaris
                                @klaris
                                Einen mit minimal 4GB RAM.
                                Mehr ist besser.
                                  @klaris
                                  Mehr ist besser.
                                  klaris
                                  schrieb am zuletzt editiert von klaris
                                  @klaris
                                  Mehr ist besser.
                                  Raspberry Pi 4 Modell B (4 GB)
                                  haselchenH BananaJoeB 2 Antworten Letzte Antwort
                                  • K klaris
                                    @klaris
                                    Mehr ist besser.
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @klaris
                                    Bei Deinem Setup würde ich eher zu 8GB tendieren.
                                    Bestell gleich das dazugehörige Netzteil mit.
                                    Mach ein Backup von Deinem alten System ( bring vorher soweit es geht alles auf Stand) und dann fang vernünftig neu an,
                                    mit dem Wissen, was Du hier in den letzten Stunden mit an die Hand bekommen hast.
                                    • K klaris
                                      @klaris
                                      Mehr ist besser.
                                      BananaJoeB Offline
                                      BananaJoeB Offline
                                      BananaJoe
                                      @klaris und auch gleich den 5er nehmen.
                                      Gerne dann mit einem SSD-Hat (eine Aufsteckplatine) in welche man eine M.2 SSD setzen kann.
                                      Dann kannst du den Raspberry so umstellen das er von Festplatte startet (= die M.2 SSD) statt der MicroSD-Karte.
                                      Alternativ startet er von der MicroSD-Karte, du lagerst aber ioBroker etc. auf die SSD aus.
                                      Wenn du dann später History, SQL oder Influx einsetzt, also Dinge die viel auf Platte schreiben, geht das zum einen schneller, zum anderen ist die Lebensdauer sehr viel höher.
                                      Ja, da könnten schnell 200 Euro zusammenkommen.
                                      CodierknechtC K 2 Antworten Letzte Antwort
                                      • BananaJoeB BananaJoe
                                        Codierknecht
                                        @bananajoe sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                                        Da ist dann ein (generalüberholter) Mini-PC wie ein NUC oder ein ThinkCentre auch wieder 'ne (leistungsfähigere) Alternative.
                                        Mein Core i7 mit 16 GB RAM und 240 GB SSD lag bei ~ 150 €
                                          S Abwesend
                                          S Abwesend
                                          Shadowhunter23
                                          Kein i7 aber der selbe Preis: https://itreturn.at/HP-EliteDesk-800-G4-Tiny-/-Intel-i5-8500-360GHz-/-256-GB-SSD-/-16GB-RAM-/-Windows-11-Home-/-12-Monate-Garantie
                                          Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                          ioBroker Backup Analyzer
