  4. Node.js v16.20.2 update v18.20.4 sinvoll ?
55 Beiträge 9 Kommentatoren 6.1k Aufrufe 7 Beobachtet
  • K klaris
    @homoran ja der gute alte raspberry kommt an seine grenze
    was meinst du damit"Keine nachträglichen Änderungen ohne Kennzeichnung!!
    @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
    hast du wenigstens diesen unnötigen Desktop Kram deaktiviert?
      klaris
      schrieb am zuletzt editiert von klaris
      @homoran welchen unötigen desktop kram ?
      vielen dank für deine GEDULD ...
      • K klaris
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v7+
              Architecture: arm
        Model           : Raspberry Pi 3 Model B Plus Rev 1.3
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        ~ Under-voltage detected
        Previously detected issues:
        ~ Under-voltage has occurred
        *** Time and Time Zones ***
                       Local time: Fri 2024-08-16 10:02:19 CEST
                   Universal time: Fri 2024-08-16 08:02:19 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            921M        714M         66M        0.0K        140M        154M
        Swap:            99M         99M        0.0K
        Total:          1.0G        813M         67M
        Active iob-Instances:   4
                  921 M total memory
                  713 M used memory
                  164 M active memory
                  620 M inactive memory
                   66 M free memory
                   13 M buffer memory
                  127 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
        Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
        MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
        MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.4G   22G  23% /
        devtmpfs       devtmpfs  333M     0  333M   0% /dev
        tmpfs          tmpfs     461M     0  461M   0% /dev/shm
        tmpfs          tmpfs     185M  716K  184M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE         FSTYPE     OPTIONS
        /                            /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
        | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
        `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        1.7G    /var/
        1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
        1.3G    /var/log
        193M    /var/cache
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        13M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        751M    /opt/iobroker/iobroker-data/
        608M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
          Installed: 20.16.0-1nodesource1
          Candidate: 20.16.0-1nodesource1
          Version table:
         *** 20.16.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     2
        +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
        +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
        Adapter State
          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
          system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
          system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
          system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
          system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
          system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
          system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
          system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
        + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
          system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
          system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
          system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name     │ url                                              │ auto upgrade │
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
        │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
        │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.16   , installed 3.0.16
        Adapter    "countdown"    : 2.2.0    , installed 2.2.0
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "deconz"       : 1.4.1    , installed 1.4.1
        Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
        Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
        Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        ^X
        Objects and States
        Please stand by - This may take a while        Objects:  9851
        States:         8648
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
        udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
        udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
        2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
        2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
        2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
        2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
        2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
        2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
        2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
        2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
        2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
        iob diag has finished.
        Press any key for a summary
        @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
        Display-Server: true
          klaris
          @homoran was ist das schon wieder :-) wie kann ich das deaktivieren
          • K klaris
            @klaris
            sudo systemctl set-default multi-user.target
            iob stop
            sudo reboot
            K 3 Antworten Letzte Antwort
            • K klaris
              du wirst kein Raspberrypi OS lite verwendet haben, sondern eins mit vollem Destop und allen GUI-Programmen
                klaris
                @homoran wen du das sagst dan wird es stimmen ..nicht so viel ahnung von der materie ...
                  @klaris
                  iob stop
                  sudo reboot
                  klaris
                  @thomas-braun soll ich das ausfuhren ? habe ich zugliff dan über meinen pc zur raspberry oberfläche ..
                  Thomas BraunT HomoranH CodierknechtC 3 Antworten Letzte Antwort
                  • K klaris
                    Genau den sollst du ausstellen. Zugriff ausschließlich über SSH/die Kommandozeile.
                      @klaris
                      iob stop
                      sudo reboot
                      klaris
                      @thomas-braun said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                      @klaris
                      iob stop
                      sudo reboot
                      • K klaris
                        Natürlich, aber....
                        wofür?
                        es geht doch gerade darum diese Oberfläche abzuschalten
                        • K klaris
                          CodierknechtC Offline
                          Codierknecht
                          Welche "Oberfläche"?
                          Sowas bedient man per SSH über die Konsole.
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          K 2 Antworten Letzte Antwort
                          • CodierknechtC Codierknecht
                            klaris
                            @codierknecht said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                            ok gemacht !!
                              @klaris
                              iob stop
                              sudo reboot
                              klaris
                              @klaris
                              iob stop
                              sudo reboot
                              top - 11:47:12 up 3 min,  1 user,  load average: 3.47, 2.21, 0.91
                              Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  13.7/2.8    17[|||||||||||||||||        ]
                              MiB Mem :    922.0 total,     92.1 free,    683.2 used,    146.6 buff/cache
                              MiB Swap:    100.0 total,      4.7 free,     95.2 used.    187.0 avail Mem
                              width incr is 0, change to (0 default, -1 auto)
                                PID USER      PR  NI    VIRT    RES    SHR S  %CPU
                                klaris
                                @codierknecht welches Raspberry model kannst du mir zum kauf empfehlen fur mein kleines projekt ?
                                • K klaris
                                  @klaris
                                  Einen mit minimal 4GB RAM.
                                  Mehr ist besser.
                                    @klaris
                                    Mehr ist besser.
                                    klaris
                                    schrieb am zuletzt editiert von klaris
                                    @klaris
                                    Mehr ist besser.
                                    Raspberry Pi 4 Modell B (4 GB)
                                    haselchenH BananaJoeB 2 Antworten Letzte Antwort
                                    • K klaris
                                      @klaris
                                      Mehr ist besser.
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @klaris
                                      Bei Deinem Setup würde ich eher zu 8GB tendieren.
                                      Bestell gleich das dazugehörige Netzteil mit.
                                      Mach ein Backup von Deinem alten System ( bring vorher soweit es geht alles auf Stand) und dann fang vernünftig neu an,
                                      mit dem Wissen, was Du hier in den letzten Stunden mit an die Hand bekommen hast.
                                      • K klaris
                                        @klaris
                                        Mehr ist besser.
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        @klaris und auch gleich den 5er nehmen.
                                        Gerne dann mit einem SSD-Hat (eine Aufsteckplatine) in welche man eine M.2 SSD setzen kann.
                                        Dann kannst du den Raspberry so umstellen das er von Festplatte startet (= die M.2 SSD) statt der MicroSD-Karte.
                                        Alternativ startet er von der MicroSD-Karte, du lagerst aber ioBroker etc. auf die SSD aus.
                                        Wenn du dann später History, SQL oder Influx einsetzt, also Dinge die viel auf Platte schreiben, geht das zum einen schneller, zum anderen ist die Lebensdauer sehr viel höher.
                                        Ja, da könnten schnell 200 Euro zusammenkommen.
                                        CodierknechtC K 2 Antworten Letzte Antwort
                                        • BananaJoeB BananaJoe
                                          Codierknecht
                                          @bananajoe sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                                          Da ist dann ein (generalüberholter) Mini-PC wie ein NUC oder ein ThinkCentre auch wieder 'ne (leistungsfähigere) Alternative.
                                          Mein Core i7 mit 16 GB RAM und 240 GB SSD lag bei ~ 150 €
