  4. js-controller 6.0.x jetzt für alle User im STABLE!
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 97.7k Aufrufe 45 Beobachtet
  • XBiTX XBiT
    Nach dem update auf den js-controller 6.0.9 bekomme ich folgende Fehler im log zu so fast jeden Adapter:
    host.IoBroker
    2024-08-02 20:33:23.911	info	Restart adapter system.adapter.vis-inventwo.0 because enabled
    host.IoBroker
    2024-08-02 20:33:23.910	error	instance system.adapter.vis-inventwo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: Node.js v18.20.4
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14:33)
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: ^
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: class visInventwo extends utils.Adapter {
    host.IoBroker
    2024-08-02 20:33:23.910	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14
    host.IoBroker
    2024-08-02 20:33:23.725	info	instance system.adapter.upnp.0 in version "1.0.21" started with pid 8475
    host.IoBroker
    2024-08-02 20:33:23.709	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
    host.IoBroker
    2024-08-02 20:33:23.709	error	instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: Node.js v18.20.4
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31:36)
    host.IoBroker
    2024-08-02 20:33:23.709	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    host.IoBroker
    2024-08-02 20:33:23.708	error	Caught by controller[0]: ^
    host.IoBroker
    2024-08-02 20:33:23.708	error	Caught by controller[0]: class Sourceanalytix extends utils.Adapter {
    host.IoBroker
    2024-08-02 20:33:23.706	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31
    host.IoBroker
    2024-08-02 20:33:23.018	info	instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 8468
    host.IoBroker
    2024-08-02 20:33:22.942	info	instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 8461
    host.IoBroker
    2024-08-02 20:33:22.149	info	Restart adapter system.adapter.upnp.0 because enabled
    iob diag sagt:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: IoBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-23-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Fri 2024-08-02 20:39:02 CEST
               Universal time: Fri 2024-08-02 18:39:02 UTC
                     RTC time: Fri 2024-08-02 18:39:02
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    stephan
    HOME=/home/stephan
    GROUPS=stephan cdrom floppy sudo audio dip video plugdev netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             16G        4.8G         11G        524K        1.0G         11G
    Swap:           6.4G          0B        6.4G
    Total:           23G        4.8G         17G
    Active iob-Instances:   45
            15992 M total memory
             4618 M used memory
              478 M active memory
             4274 M inactive memory
            10743 M free memory
              161 M buffer memory
              799 M swap cache
             6140 M total swap
                0 M used swap
             6140 M free swap
    top - 20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
    Tasks: 161 total,   4 running, 157 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15992.7 total,  10742.4 free,   4619.5 used,    960.9 buff/cache
    MiB Swap:   6141.0 total,   6141.0 free,      0.0 used.  11373.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  520K  1.6G   1% /run
    /dev/sda1      ext4       34G   13G   19G  42% /
    tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE      FSTYPE      OPTIONS
    /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
    |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12580
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=8169164k,nr_inodes=2042291,mode=755,inode64
    | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
    | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
    | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
    `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=1637652k,mode=755,inode64
      |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1637648k,nr_inodes=409412,mode=700,uid=1000,gid=1000,inode64
      `-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
    /var:
    1.1G    /var/
    468M    /var/log
    450M    /var/log/journal/81661bec9382417183506b6886357c63
    409M    /var/cache
    Archived and active journals take up 41.3M in the file system.
    /opt/iobroker/backups:
    879M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    48M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     11
    +-- iobroker.deyeidc@0.0.14 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#1e9919216a6173e4089dff844edb4abb35eb2366)
    +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
    +-- iobroker.fullybrowser@3.0.12 (git+ssh://git@github.com/arteck/ioBroker.fullybrowser.git#e962587ed6e25b749b28c8537318c39f2c0deefe)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#91ce6d3d470cba4011b7861103c4bfffa32dffbe)
    +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
    +-- iobroker.mercedesme@0.1.6 (git+ssh://git@github.com/TA2k/iobroker.mercedesme.git#b58e9673d5c28e358830fd45d231dd97ab425219)
    +-- iobroker.omada@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#8fb0331b97155bd4fae67c940d98c57b2ea34be2)
    +-- iobroker.sayit@3.0.5 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#581f2fb99f33c2b8b0a628d91be14967788ac120)
    +-- iobroker.sourceanalytix@0.4.12-2 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#c9b9e18e1694e45ce88e21e868e38e565aad6910)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.zendure-solarflow@1.7.0 (git+ssh://git@github.com/nograx/ioBroker.zendure-solarflow.git#f2c56c734ba9176aa75b36391c868a3c0fe33a60)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : IoBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : IoBroker                                 -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
    + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
    + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
    + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
      system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
    + system.adapter.govee-app.0              : govee-app             : IoBroker                                 -  enabled
    + system.adapter.govee-local.0            : govee-local           : IoBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : IoBroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
    + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : IoBroker                                 - disabled
    + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
      system.adapter.meater.0                 : meater                : IoBroker                                 - disabled
    + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
    + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
    + system.adapter.onvif.0                  : onvif                 : IoBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
      system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
    + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
    + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
      system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
    + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
    + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
    + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zendure-solarflow.0      : zendure-solarflow     : IoBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
    Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "meater"       : 1.1.1    , installed 1.1.1
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "roborock"     : 0.6.4    , installed 0.6.4
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "sia"          : 1.0.4    , installed 1.0.4
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synochat"     : 1.3.1    , installed 1.3.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "zendure-solarflow": 1.6.7, installed 1.7.0
    Objects and States
    Objects:        39665
    States:         34253
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       50826      6428/io.shelly.1
    tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       49127      6181/io.hm-rpc.0
    tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       49781      6210/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14944      470/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          580        1/init
    tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       49844      6240/io.hm-rpc.3
    tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       49815      6225/io.hm-rpc.2
    tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          841        454/node
    tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       52164      6930/io.lovelace.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50203      5950/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48035      5950/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14946      470/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14335      1/init
    tcp6       0      0 :::3500                 :::*                    LISTEN      0          843        454/node
    tcp6       0      0 :::3501                 :::*                    LISTEN      1001       49964      6328/io.sonos.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       56808      7478/io.fullybrowse
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54993      7174/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50231      5968/io.admin.0
    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       55243      7295/io.onvif.0
    udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       50102      6375/io.tr-064.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          581        1/init
    udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       58098      7557/io.govee-local
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       52279      6270/io.mihome-vacu
    udp6       0      0 :::111                  :::*                                0          12022      1/init
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
    2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
    2024-08-02 20:39:33.951  - error: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-02 20:39:33.951  - info: host.IoBroker Restart adapter system.adapter.sourceanalytix.0 because enabled
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.upnp/main.js:88
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     adapter = new utils.Adapter(options);
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:               ^
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: TypeError: utils.Adapter is not a constructor
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.upnp/main.js:88:15)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.upnp/main.js:1931:5)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
    2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
    2024-08-02 20:39:34.096  - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-02 20:39:34.096  - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
    2024-08-02 20:39:35.857  - info: host.IoBroker instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 12932
    2024-08-02 20:39:35.916  - info: host.IoBroker instance system.adapter.upnp.0 in version "1.0.21" started with pid 12939
    kann mir da wer helfen?
    mcm1957M
    mcm1957M
    mcm1957
    @xbit said in js-controller 6.0.x jetzt für alle User im STABLE!:
    instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: ...
    Dieser GitHub Stand wird wohl veraltet sein. Von Github Installationen wir generell abgeraten. Kontaktiere den Dev bzw. installiere eine neuere Version.
    Hast du nur 2 Adapter?
    Ich seh nur sourceanaytix und vis-inventwo. Wobei vis-inventwo ein veraltetes adapter-core benutzt; dieses Problem sollte aber seit Wochen behoben sein. Bei Github Installationen kann es divereste Gründe geben dass diese nicht funktionieren - hier bitte mit dem Dev Kontaktaufnehmen wenn er die Github Installation empfohlen hat oder selbst suchen ...
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • XBiTX XBiT
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      iob diag sagt:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      stephan
      HOME=/home/stephan
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           6.4G          0B        6.4G
      Total:           23G        4.8G         17G
               4618 M used memory
                478 M active memory
              10743 M free memory
                161 M buffer memory
                799 M swap cache
               6140 M total swap
                  0 M used swap
               6140 M free swap
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      468M    /var/log
      409M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.22
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        39665
      States:         34253
      Pending Updates: 0
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @xbit
      iob nodejs-update 20
      XBiTX 1 Antwort Letzte Antwort
        @xbit
        XBiTX
        XBiTX
        XBiT
        schrieb am zuletzt editiert von XBiT
        Danke mache ich gerade..
        @mcm1957
        die Adapter die es betrifft sind: (fast alle war sehr übertrieben sorry)
        google-sharelocation
        Sia09
        UPNP
        Sourceanalytix
        bei den oberen 2 gibt es kein update werde ich mal nachfragen... Sourceanalytix mache ich gleich ein update
        Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
        • XBiTX XBiT
          @mcm1957
          Sia09
          UPNP
          Sourceanalytix
          Thomas BraunT
          Thomas BraunT
          #66
          @xbit
          Das solltest du auf ein Maß zurückstutzen, das du auch noch überblicken kannst:
            @xbit
            XBiTX
            XBiTX
            XBiT
            #67
            @thomas-braun & @mcm1957
            Vielen Dank es läuft soweit wieder alles.
            Die anderen Adapter (UPNP,SIA09 etc.) gehen nun auch wieder warum auch immer ist mir leider erst nach dem update von Sourceanalytix aufgefallen habe aber nur dieses update gemacht und das nodejs update auf V20
            • XBiTX XBiT
              Thomas BraunT
              Thomas BraunT
              #68
              @xbit
              Du solltest das Vehikel dennoch möglichst konsistent halten und sowenig github-Zeuch wie möglich verwenden.
              • XBiTX XBiT
                @mcm1957
                Sia09
                UPNP
                Sourceanalytix
                mcm1957M
                mcm1957M
                mcm1957
                #69
                Nehme an du meinst google-sharedlocation
                Ich kann diesen Adapter nicht in den ioBroker rpositories finden. Er scheint auch schon lange nicht mehr gewartet worden zu sein. Prinzipiell ist es immer ein Risiko Adapter zu verwenden die nicht im Repository gelistet sind da diese weder den minimalen Review durchlaufen haben noch bei div. Checks wie z.B. einem Update des js-controllers beachtet werden können.
                Sia09
                Den Adapter find ich nicht. meinst du https://github.com/schmupu/ioBroker.sia
                Der scheint eher dahin zu dämmern. Erstell bitte ggF im Adapterverzeichnis ein Issue und mention mich. Der Adaptercode ist dort total veraltet. Eine Codeanpassung könnte hier notwendig sein.
                UPNP
                Hier rate ich dir den dev zu kontaktieren bzw. ein Issue beim Adapter anzulegen. Da wurden erst letzte Woche Anpassungen vorgenommen die anscheinend noch nicht auf npm verfügbar sind. Repo: (https://github.com/Jey-Cee/ioBroker.upnp)
                Sourceanalytix
                Hier aktualisisere mal auf die aktuelle LATEST version. Falls diese nicht funktioniert erstell ein Issue im Adapter Repo.
                • XBiTX XBiT
                  mcm1957M
                  mcm1957M
                  mcm1957
                  #70
                  OK, dann feier mal schön :-)
                  An sich sollte der js-controller implizit versuchen veraltete Adapter zu aktualisiseren. Scheinbar hat das bei deinem Upgrade nicht gleich gezogen.
                  Trotzdem sei dir bewußt dass wenn du Aapter verwendest die nicht im repository gelistet sind du ein erhöhtes Risiko hast, dass diese ausfallen bzw. dass niemand sich der Sache annehmen kann / wird.
                  • mcm1957M mcm1957
                    XBiTX
                    XBiTX
                    XBiT
                    #71
                    @mcm1957
                    der google-sharedlocations Adapter wurde zuletzt von @Garfonso betreut welcher auch die Lovelace UI betreut warum die nicht ins rpositorie kommen oder sind kann ich nicht sagen bin ja nur Anwender :-)
                    der SIA Adapter ist wirklich schon 5 Jahre alt versuche mal ein Issu auf Git zu machen aber was soll ich da schreiben er läuft ja jetzt wieder?
                    Sourceanalytix von @Dutchman betreut aber soll ja komplett neu gemacht werden so meine letzte Info...
                    • L
                      L
                      lamo1966
                      schrieb am zuletzt editiert von lamo1966
                      #72
                      ich hab gerade den JS Controller von5.019 auf 6.09 upgedatet.
                      Zufällig stell ich gerade fest, dass in meinen Modbus Objekten hinten das Zahnrad nicht mehr aktiv ist. (
                      Ganz rechts)
                      b4fe00a5-5428-498a-a78c-a669165c0dff-image.png Sorry, kann es nicht besser beschreiben
                      Beispiel
                      Ich erzeuge seit Tagen ein EChart mit den Spannungs-Werten der PV-Strings. Dazu hab ich die Werte in die Histroy geschrieben.
                      Unter dem Chart sind die History-Einträge schön zu sehen, die es jetzt nicht mehr gibt
                      Ich hoffe dass es zufällig ein anderer Fehler ist, aber ich hab nichts anderes gemacht. Nein stimmt nicht, die Admin Instanz hab ich auch noch upgedatet.
                      • L lamo1966
                        Ganz rechts)
                        Beispiel
                        crunchipC
                        crunchipC
                        Developer Global Moderator Most Active Forum Testing
                        #73
                        @lamo1966 werden die Datenpunkte gelistet, wenn du history auswählst
                        L 2 Antworten Letzte Antwort
                        • foxriver76F foxriver76
                          Hallo ioBroker-Community,
                          Ab heute wird der js-controller v6 im stable Repository verfügbar sein.
                          Vorab Danke an alle fleißigen Alpha und Beta Tester.
                          Node.js Versions-Anforderungen
                          In diesem Release entfällt Node.js 14.x und 16.x. Die unterstützten Node.js Versionen sind: 18.x, 20.x und voraussichtlich 22.x. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 20.x angehoben.
                          Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
                          Informationen zur Version
                          In dieser Version wurde die Umstellung des Quellcodes auf TypeScript nochmal vorangetrieben (5.X 76%, mit 6.X 90% der Codebase), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können.
                          Ebenfalls läuft der Controller nun komplett als ESM Modul, was uns technisch alle Möglichkeiten offen hält und auch Adapter nun komplett als ESM Module laufen können und somit keine Einschränkungen mehr haben falls Dependencies nur für ESM verfügbar sind.
                          Weiterhin sind auch einige neue Features unter anderem die Möglichkeit des automatisierten Adapter-Upgrades (Admin Funktionalität wird zeitnah implementiert), Informationen über das System Management (neue Pakete, restart nötig, ...) sowie das Management von geblockten Adapter-Versionen hinzugefügt.
                          Auch wenn mit dieser Version keine neuen relevanten Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
                          Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                          Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
                          Darüber hinaus ist der js-controller 6.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der Version 5.x ist problemlos möglich.
                          Ansonsten empfehlen wir ein schrittweises Update auf die 6.0 (3.3.x -> 4.0 -> 5.0).
                          Installation
                          VOR der Installation
                          Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
                          Eine alte 5.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 5.0.19)
                          Nötige Adapter-Aktualisierungen
                          Am besten VOR dem js-controller Update alle verfügbaren Adapter-Updates (vorallem den javascript Adapter) prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 5.0 oder höher hinweisen.
                          Mit den stable Versionen der jeweiligen Adapter sollten keine Probleme auftreten, falls doch bitte hier melden.
                          Achtung: MASTER/SLAVE-Systeme Reihenfolgen beachten!
                          Bei einem Multi-Host-System, welches auf js-controller 5.0.x läuft, ist es beim Update auf Version 6.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                          Bei Updates von Master/Slave-Systemen mit js-controller 4.x oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
                          Windows
                          Es wird empfohlen einmalig bei bestehenden Installationen den fixer auszuführen und falls noch vorhanden die iobroker.bat zu löschen.
                          Hierzu werden folgende Befehle genutzt:
                          del iobroker.bat
                          iob fix
                          Anschließend vorzugsweise das Upgrade mit dem Installer durchführen siehe https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
                          Alternativ im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
                          Linux
                          Entweder den GUI installationsprozess im Admin nutzen oder
                          • ioBroker stoppen (iobroker stop)
                          • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                          • cd /opt/iobroker
                          • Das Update erfolgt via iob upgrade self
                          • ioBroker starten (iobroker start)
                          Bei Fehlern:
                          Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels iob upgrade self versuchen. Bitte berichtet solche Fälle hier im Thread.
                          NACH der Installation
                          Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                          Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                          Was hat sich geändert, was besonders ansehen/beachten?
                          Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                          • generell siehe Changelog, speziell auch für die Features
                          • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript und ESM Umstellungen haben sehr viel Code angefasst.
                          Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                          Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                          6.0.1 Release Kiera
                          Breaking changes
                          • Support for Node.js 16 is dropped!
                          • Binary states have been removed
                          • Let's encrypt has been removed
                          Features
                          • (foxriver76) Added possibility to automatically upgrade adapters (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#automatic-adapter-upgrade)
                          • (foxriver76) if updates for OS packages are available a notification is generated (Linux only)
                          • (foxriver76) the controller creates a notification if free disk space is critical (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#disk-space-warnings)
                          • (foxriver76) allow to ignore specific adapter versions (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#ignoring-specific-adapter-version)
                          • (foxriver76) if an adapter is blocklisted and thus stopped the controller now generates a notification
                          • (foxriver76) allow to configure redis tls during setup custom
                          Optimizations and fixes
                          • (foxriver76) we now send SIGKILL instead of SIGTERM if adapter does not stop in normal time to prevent ghost processes
                          • (foxriver76) prevent crash case if an invalid pattern is scanned in the database
                          • (foxriver76) we now log the pid if a adapter process is stopped
                          • (foxriver76/Apollon77) fixed crash case on file rotation
                          • (foxriver76) optimized error messages and help text for cli commands url and install
                          • (foxriver76) if users want to install non existing adapters we now hint to the url command instead of recommending the use of npm
                          • (foxriver76) when interacting with aliases we no longer check permissions of the alias and the original object, we now only check the alias
                          • (foxriver76) host object is now already created during setup first run, allowing eg to disable sentry globally before first start of ioBroker
                          • (foxriver76) if the user sets a custom title for instances this is now preserved during upload
                          • (foxriver76) on reinstallation of adapters we uninstall the package manually first to ensure a correct reinstall
                          • (foxriver76) fixed problem on multihost discover
                          • (foxriver76) if getState is called on a non existing or non linked alias we return null like for all other non existing states
                          • (foxriver76) optimize alias subscribe performance for non-redis dbs
                          • (foxriver76/bluefox/Apollon77) updated dependencies
                          • (foxriver76/bluefox/Apollon77) minor fixes and stability improvements
                          Developer relevant DEPRECATIONS/WARNINGS
                          • (foxriver76) adapters need to specify adapter-core version 3.1.4 or higher or allow an upgrade to this version by specifying e.g. ^3.x.x
                          • (foxriver76) it is now validated that obj.native is of type Record<string, unknown>
                          • (foxriver76) Let's encrypt has been removed (@iobroker/webeserver should be used instead)
                          • (foxriver76) deprecated delete/createState/channel/device methods
                          • (foxriver76) deprecated ioPack common.license which is replaced by the new object common.licenseInfo
                          • (foxriver76) ioPack mode subscribe has been removed as you can achieve the same with mode once and setting system.adapter.xy.alive state (also removed common.wakeup and common.subscribe because of this)
                          Developer relevant new features
                          • (foxriver76) js-controller (and thus the whole ioBroker) is now running as an ESM module internally while staying a 100 % backward compatible to adapters written in cjs
                          • (foxriver76) adapters can now be written as ESM modules having full support (including compact mode)
                          • (foxriver76) we provide all exports as ESM and as CJS to allow adapter developers to choose what to use
                          • (foxriver76) added convenient methods to manage node modules (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#managing-node-modules)
                          • (foxriver76) allow to specify reason and exit code on adapter.stop
                          • (foxriver76) if you blocklist a version in your io-package.json the controller won't start it anymore and will generate a notification
                          • (foxriver76) for adapters of type schedule and connectionType set to cloud the schedule will be automatically delayed by up to 60 seconds randomly per user if the CRON does not contain a seconds argument, this is to prevent DDoS attacks
                          Developer relevant optimizations and fixes
                          • (foxriver76) fixed crash case if an malformed object was defined in ioPack instanceObjects
                          • (foxriver76) if getState is called on a non-existing or non-linked alias we return null like for all other non-existing states
                          • (foxriver76/bluefox) multiple improvements on type level
                          Wir wünschen allen viel Spaß mit dem neuen Controller!
                          Moritz
                          fAz3rs adventuresF
                          fAz3rs adventuresF
                          fAz3rs adventures
                          #74
                          @foxriver76
                          Servus,
                          Ich wollte meinen IoBroker wieder auf neuesten Stand bringen und scheitere aber an dem js-controller Update.
                          Node.js und NPM updaten klappt, ebenso wie alle Adapter Updates.
                          Liegt auch alles (aus meiner Sicht) korrekt ab
                          nodejs liegt in /usr/bin
                          node liegt in /usr/bin
                          npm liegt in /usr/bin
                          führe ich das Update über die iob Oberfläche in Hosts aus bekomme ich folgende Rückmeldung:
                          36 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
                          537 verbose pkgid iobroker.js-controller@6.0.9
                          538 error code 1
                          539 error path /opt/iobroker/node_modules/iobroker.js-controller
                          540 error command failed
                          541 error command sh -c node iobroker.js setup first
                          542 error file:///opt/iobroker/node_modules/axios/lib/helpers/parseHeaders.js:1
                          542 error   },
                          542 error   ^
                          542 error
                          542 error SyntaxError: Unexpected token '}'
                          542 error     at ModuleLoader.moduleStrategy (node:internal/modules/esm/translators:169:18)
                          542 error     at callTranslator (node:internal/modules/esm/loader:272:14)
                          542 error     at ModuleLoader.moduleProvider (node:internal/modules/esm/loader:278:30)
                          542 error
                          542 error Node.js v20.16.0
                          543 silly unfinished npm timer reify 1722633029717
                          544 silly unfinished npm timer reify:build 1722633047822
                          545 silly unfinished npm timer build 1722633047827
                          546 silly unfinished npm timer build:deps 1722633047827
                          547 silly unfinished npm timer build:run:install 1722633049025
                          548 silly unfinished npm timer build:run:install:node_modules/iobroker.js-controller 1722633049025
                          549 verbose cwd /opt/iobroker
                          550 verbose os Linux 6.1.21-v8+
                          551 verbose node v20.16.0
                          552 verbose npm  v10.8.1
                          553 verbose exit 1
                          554 verbose code 1
                          Auch über
                          iobroker stop
                          iobroker update
                          iobroker fix bzw ( - curl -sLf https://iobroker.net/install.sh | bash -)
                          iobroker upgrade self
                          iobroker start
                          erfolglos
                          Dann habe ich es über npm install iobroker.js-controller@6.0.9 versucht mit folgendem Ergebnis
                          1236 error code EACCES
                          1237 error syscall open
                          1238 error path /home/pi/package.json
                          1239 error errno -13
                          1240 error Error: EACCES: permission denied, open '/home/pi/package.json'
                          1240 error     at async open (node:internal/fs/promises:639:25)
                          1240 error     at async writeFile (node:internal/fs/promises:1219:14)
                          1240 error     at async PackageJson.save (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:255:14)
                          1240 error     at async [saveIdealTree] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1512:9)
                          1240 error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)
                          1240 error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
                          1240 error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                          1240 error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
                          1240 error   errno: -13,
                          1240 error   code: 'EACCES',
                          1240 error   syscall: 'open',
                          1240 error   path: '/home/pi/package.json'
                          1240 error }
                          1241 error
                          1241 error The operation was rejected by your operating system.
                          1241 error It is likely you do not have the permissions to access this file as the current user
                          1241 error
                          1241 error If you believe this might be a permissions issue, please double-check the
                          1241 error permissions of the file and its containing directories, or try running
                          1241 error the command again as root/Administrator.
                          1242 silly unfinished npm timer reify 1722634042338
                          1243 silly unfinished npm timer reify:save 1722634104770
                          1244 verbose cwd /home/pi
                          1245 verbose os Linux 6.1.21-v8+
                          1246 verbose node v20.16.0
                          1247 verbose npm  v10.8.1
                          Das ist wohl ein anderer Pfad der entweder korrekt oder falsch ist (jaaa es ist nur gefährliches Halbwissen am start.. ich lerne beim tun)
                          Kann mir jemand für dumme sagen was mein Fehler ist?
                          Grüßle Timo
                          • fAz3rs adventuresF fAz3rs adventures
                            @foxriver76
                            Servus,
                            538 error code 1
                            542 error   },
                            542 error   ^
                            542 error
                            542 error
                            553 verbose exit 1
                            554 verbose code 1
                            Auch über
                            iobroker stop
                            iobroker update
                            iobroker start
                            erfolglos
                            1240 error }
                            1241 error
                            1241 error
                            Grüßle Timo
                            Thomas BraunT
                            Thomas BraunT
                            #75
                            @faz3rs-adventures sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                            Du stehst für solche Aktionen via npm im falschen Verzeichnis.
                            Versuch es erstmal so:
                            iob update
                            iob stop
                            iob upgrade all -y
                            iob upgrade self
                            iob start
                            fAz3rs adventuresF 1 Antwort Letzte Antwort
                              iob update
                              iob stop
                              iob upgrade all -y
                              iob upgrade self
                              iob start
                              fAz3rs adventuresF
                              fAz3rs adventuresF
                              fAz3rs adventures
                              #76
                              Moinmoin
                              danke schonmal für die Antwort
                              nach dem
                              iob upgrade all -y
                              kommt All adapters are up to date
                              beim
                              iob upgrade self
                              passiert folgendes
                              Update js-controller from @5.0.19 to @6.0.9
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.8.1
                              Installing iobroker.js-controller@6.0.9... (System call)
                              es läuft jedoch nicht fertig durch
                                Moinmoin
                                nach dem
                                iob upgrade all -y
                                beim
                                iob upgrade self
                                passiert folgendes
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 10.8.1
                                Thomas BraunT
                                Thomas BraunT
                                #77
                                @faz3rs-adventures
                                Bitte immer vollständige Ein- wie Ausgabezeilen posten.
                                Damit man sowas wie 'falsches Verzeichnis' auch sieht.
                                Keine Screenshots!
                                  @faz3rs-adventures
                                  Keine Screenshots!
                                  fAz3rs adventuresF
                                  fAz3rs adventuresF
                                  fAz3rs adventures
                                  #78
                                  pi@raspberrypi:~ $ iob update
                                  Adapter    "acme"         : 0.1.2    , installed 0.1.2
                                  Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                  Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
                                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                  Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                  Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                  Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
                                  Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
                                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                                  Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                                  Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                  Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                                  Adapter    "residents"    : 0.1.1    , installed 0.1.1
                                  Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "welcome"      : 0.3.0    , installed 0.3.0
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                  Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                                  pi@raspberrypi:~ $ iob stop
                                  pi@raspberrypi:~ $ iob upgrade all -y
                                  pi@raspberrypi:~ $ iob upgrade self
                                  Stopped Objects DB
                                  Stopped States DB
                                  NPM version: 10.8.1
                                  pi@raspberrypi:~ $
                                  das steht in der console
                                    Moinmoin
                                    nach dem
                                    iob upgrade all -y
                                    beim
                                    iob upgrade self
                                    passiert folgendes
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.8.1
                                    Thomas BraunT
                                    Thomas BraunT
                                    #79
                                    @faz3rs-adventures
                                    Sondern?
                                      @faz3rs-adventures
                                      Sondern?
                                      fAz3rs adventuresF
                                      fAz3rs adventuresF
                                      fAz3rs adventures
                                      #80
                                      Es passiert nichts weiter
                                      Es kommt eine neue eingabe Zeile in der ich Iobroker wieder starten könnte
                                      Thomas BraunT E 2 Antworten Letzte Antwort
                                        Thomas BraunT
                                        Thomas BraunT
                                        #81
                                        @faz3rs-adventures
                                        Gib mal die Langfassung von
                                        iob diag
                                        zum Besten.
                                          @faz3rs-adventures
                                          iob diag
                                          zum Besten.
                                          fAz3rs adventuresF
                                          fAz3rs adventuresF
                                          fAz3rs adventures
                                          #82
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                             Static hostname: raspberrypi
                                                   Icon name: computer
                                            Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 6.1.21-v8+
                                                Architecture: arm64
                                          Model           : Raspberry Pi 4 Model B Rev 1.4
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 32 bit
                                           00:02:36 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                                         Local time: Sat 2024-08-03 00:02:37 CEST
                                                     Universal time: Fri 2024-08-02 22:02:37 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Server: true
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            7.8G        2.4G        746M         35M        4.7G        5.3G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        2.4G        846M
                                          Active iob-Instances:   27
                                                   7812 M total memory
                                                   2396 M used memory
                                                   2627 M active memory
                                                   3853 M inactive memory
                                                    746 M free memory
                                                    376 M buffer memory
                                                   4293 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          top - 00:02:37 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
                                          Tasks: 219 total,   2 running, 217 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 27.0 us,  4.1 sy,  0.0 ni, 68.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   7812.3 total,    746.0 free,   2396.6 used,   4669.8 buff/cache
                                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5258.5 avail Mem
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       30G   20G  8.7G  70% /
                                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                          /dev/mmcblk0p1 vfat      255M   53M  203M  21% /boot
                                          tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
                                          [Mon May 13 18:23:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.                              macaddr=DC:A6:32:CB:CB:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb8f5eed-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ign                              ore-serial-consoles
                                          [Mon May 13 18:23:18 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Mon May 13 18:23:18 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Mon May 13 18:23:21 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          [Fri Aug  2 23:29:26 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 166: bad block bitmap checksum
                                          [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700736 at logical offset 0 with max blocks 135 with error 74
                                          [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
                                          [Fri Aug  2 23:29:29 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 165: bad block bitmap checksum
                                          [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700840 at logical offset 0 with max blocks 175 with error 74
                                          [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
                                          [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm logrotate: bg 164: bad block bitmap checksum
                                          [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2) in ext4_mb_clear_bb:6077: Filesystem failed CRC
                                          /                            /dev/mmcblk0p2 ext4            rw,noatime
                                          |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=3735680k,nr_inodes=933920,mode=755
                                          |-/proc                      proc           proc            rw,relatime
                                          | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                          |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
                                          | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
                                          |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                          `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          4.1G    /var/
                                          2.4G    /var/cache
                                          2.3G    /var/cache/apt/archives
                                          2.3G    /var/cache/apt
                                          1.5G    /var/log/journal/a9d90c753d4c4e98916aa8f9a3f582f2
                                          Archived and active journals take up 1.4G in the file system.
                                          126M    /opt/iobroker/backups/
                                          951M    /opt/iobroker/iobroker-data/files
                                          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                          23M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          HINT:
                                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                          /dev/serial/by-path/platform-fd500000.pcie-pci-0000
                                          /usr/bin/nodejs         v20.16.0
                                          /usr/bin/node           v20.16.0
                                          /usr/bin/npm            10.8.1
                                          /usr/bin/npx            10.8.1
                                          /usr/bin/corepack       0.28.2
                                          nodejs:
                                            Installed: 20.16.0-1nodesource1
                                            Candidate: 20.16.0-1nodesource1
                                            Version table:
                                           *** 20.16.0-1nodesource1 600
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                               20.15.1-1nodesource1 600
                                               20.15.0-1nodesource1 600
                                               20.14.0-1nodesource1 600
                                               20.13.1-1nodesource1 600
                                               20.13.0-1nodesource1 600
                                               20.12.2-1nodesource1 600
                                               20.12.1-1nodesource1 600
                                               20.12.0-1nodesource1 600
                                               20.11.1-1nodesource1 600
                                               20.11.0-1nodesource1 600
                                               20.10.0-1nodesource1 600
                                               20.9.0-1nodesource1 600
                                               20.8.1-1nodesource1 600
                                               20.8.0-1nodesource1 600
                                               20.7.0-1nodesource1 600
                                               20.6.1-1nodesource1 600
                                               20.6.0-1nodesource1 600
                                               20.5.1-1nodesource1 600
                                               20.5.0-1nodesource1 600
                                               20.4.0-1nodesource1 600
                                               20.3.1-1nodesource1 600
                                               20.3.0-1nodesource1 600
                                               20.2.0-1nodesource1 600
                                               20.1.0-1nodesource1 600
                                               20.0.0-1nodesource1 600
                                               12.22.12~dfsg-1~deb11u4 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          js-controller:  5.0.19
                                          admin:          7.0.22
                                          javascript:     8.7.6
                                          nodejs modules from github:     3
                                          +-- iobroker.bring@1.8.4 (git+ssh://git@github.com/foxriver76/ioBroker.bring.git#85ba3e11a521d5660aa3018d12e7e083f181ad8b)
                                          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                          +-- iobroker.todoist2@0.9.1 (git+ssh://git@github.com/rde-master/ioBroker.todoist2.git#531241af9356c641158a3cb63e3bd45a1d11a8d8)
                                          Adapter State
                                            system.adapter.acme.0                   : acme                  : raspberrypi                              - disabled, port: 8092, bind: 192.168.178.60
                                            system.adapter.adguard.0                : adguard               : raspberrypi                              - disabled
                                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                          + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
                                          + system.adapter.bring.1                  : bring                 : raspberrypi                              -  enabled
                                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                          + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                          + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
                                          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                            system.adapter.iwg-vpn.0                : iwg-vpn               : raspberrypi                              - disabled
                                          + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
                                            system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 8000
                                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 192.168.178.60
                                          + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                                          + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
                                          + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
                                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                            system.adapter.residents.0              : residents             : raspberrypi                              - disabled
                                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.synochat.0               : synochat              : raspberrypi                              - disabled
                                            system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5001
                                            system.adapter.tapo.0                   : tapo                  : raspberrypi                              - disabled
                                            system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
                                            system.adapter.todoist2.0               : todoist2              : raspberrypi                              - disabled
                                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                            system.adapter.welcome.0                : welcome               : raspberrypi                              - disabled, port: 80, bind: 0.0.0.0, run as: admin
                                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                            system.adapter.wiobrowser.0             : wiobrowser            : raspberrypi                              - disabled, port: 5000
                                          + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                                            system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
                                          + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0
                                            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
                                          + instance is alive
                                          Objects and States
                                          Objects:        6774
                                          States:         5215
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:45989           0.0.0.0:*               LISTEN      1001       55153121   29571/io.yahka.2
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15381      580/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55151380   29218/node-red
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55149882   29112/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55149877   29112/iobroker.js-c
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          55154847   30024/cupsd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15383      580/sshd: /usr/sbin
                                          tcp6       0      0 :::4369                 :::*                    LISTEN      0          14541      1/systemd
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          55154846   30024/cupsd
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55152105   29537/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       55151228   29130/io.admin.0
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       55152999   29556/io.ws.0
                                          tcp6       0      0 :::8091                 :::*                    LISTEN      1001       55150427   29499/io.lovelace.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16409      475/dhcpcd
                                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          55156844   30028/cups-browsed
                                          udp        0      0 0.0.0.0:41644           0.0.0.0:*                           1001       55151762   29277/io.openknx.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       55152225   29593/io.esphome.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12255      370/avahi-daemon: r
                                          udp        0      0 0.0.0.0:35438           0.0.0.0:*                           108        12257      370/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        12256      370/avahi-daemon: r
                                          udp6       0      0 :::36482                :::*                                108        12258      370/avahi-daemon: r
                                          2024-08-03 00:00:00.080  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 29931
                                          2024-08-03 00:00:03.501  - info: dwd.0 (29931) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.16.0, js-controller: 5.0.19
                                          2024-08-03 00:00:04.123  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 29947
                                          2024-08-03 00:00:05.493  - info: dwd.0 (29931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2024-08-03 00:00:06.041  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-08-03 00:00:08.090  - info: ical.0 (29947) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.16.0, js-controller: 5.0.19
                                          2024-08-03 00:00:09.385  - info: ical.0 (29947) processing URL: Gmail Privat https://calendar.google.com/calendar/ical/liersch52%40gmail.com/private-30a9b22ce901d314b7678a6a5cecd14f/basic.ics
                                          2024-08-03 00:00:31.904  - info: ical.0 (29947) processing URL: Gmail Geschäft https://calendar.google.com/calendar/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics
                                          2024-08-03 00:00:51.143  - info: ical.0 (29947) Set events.2.Geschäft to true
                                          2024-08-03 00:00:52.421  - info: ical.0 (29947) Set events.0.today.Geschäft to false
                                          2024-08-03 00:00:52.432  - info: ical.0 (29947) Set events.0.now.Geschäft to false
                                          2024-08-03 00:00:52.444  - info: ical.0 (29947) Set events.7.Geschäft to false
                                          2024-08-03 00:00:57.512  - info: ical.0 (29947) Terminated (NO_ERROR): Without reason
                                          2024-08-03 00:00:58.106  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                          iob diag has finished.
                                          Press any key for a summary
                                          pi@raspberrypi:~ $
                                          pi@raspberrypi:~ $
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 32 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                          ^Cb diag has finished.l here for C&P =============instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)r/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics:1.0-port0n
                                          pi@raspberrypi:~ $
                                          84.1k
