  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 514.7k Aufrufe 93 Beobachtet
  • B Buster
    so besser ;-)
    habe den adapter neu gestartet ......
    2024-05-31 14:08:16.859  - info: host.iobroker instance system.adapter.deyeidc.0 started with pid 17583
    2024-05-31 14:08:18.734  - debug: deyeidc.0 (17583) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-05-31 14:08:18.791  - debug: deyeidc.0 (17583) Objects client ready ... initialize now
    2024-05-31 14:08:18.794  - debug: deyeidc.0 (17583) Objects create System PubSub Client
    2024-05-31 14:08:18.796  - debug: deyeidc.0 (17583) Objects create User PubSub Client
    2024-05-31 14:08:18.863  - debug: deyeidc.0 (17583) Objects client initialize lua scripts
    2024-05-31 14:08:18.874  - debug: deyeidc.0 (17583) Objects connected to redis: 127.0.0.1:9001
    2024-05-31 14:08:18.879  - silly: deyeidc.0 (17583) redis psubscribe cfg.o.system.user.*
    2024-05-31 14:08:18.920  - silly: deyeidc.0 (17583) redis psubscribe cfg.o.enum.*
    2024-05-31 14:08:18.923  - silly: deyeidc.0 (17583) objectDB connected
    2024-05-31 14:08:18.927  - debug: deyeidc.0 (17583) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-05-31 14:08:18.953  - debug: deyeidc.0 (17583) States create System PubSub Client
    2024-05-31 14:08:18.955  - debug: deyeidc.0 (17583) States create User PubSub Client
    2024-05-31 14:08:19.039  - debug: deyeidc.0 (17583) States connected to redis: 127.0.0.1:9000
    2024-05-31 14:08:19.040  - silly: deyeidc.0 (17583) statesDB connected
    2024-05-31 14:08:19.283  - info: deyeidc.0 (17583) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.deyeidc, node: v18.19.0, js-controller: 5.0.17
    2024-05-31 14:08:19.317  - debug: deyeidc.0 (17583) IP address [192.168.0.44] seems to be valid.
    2024-05-31 14:08:19.318  - info: deyeidc.0 (17583) Retrieving data from the inverter will be done every 60 seconds
    2024-05-31 14:08:19.319  - debug: deyeidc.0 (17583) checkUserData is ready
    2024-05-31 14:08:19.320  - debug: deyeidc.0 (17583) try to connect . . .
    2024-05-31 14:08:19.355  - debug: deyeidc.0 (17583) Connected to server
    2024-05-31 14:08:19.361  - silly: deyeidc.0 (17583) States system redis pmessage system.adapter.deyeidc.0.logLevel/system.adapter.deyeidc.0.logLevel:{"val":"silly","ack":true,"ts":1717157299326,"q":0,"from":"system.adapter.deyeidc.0","lc":1717149942276}
    2024-05-31 14:08:29.516  - debug: deyeidc.0 (17583) Connection timeout
    2024-05-31 14:08:29.517  - debug: deyeidc.0 (17583) Connection closed/destroyed
    2024-05-31 14:08:29.519  - debug: deyeidc.0 (17583) Connection closed
    2024-05
    #874
    @buster
    iob nodejs-update 20
    Und der Wechselrichter wohnt unter 192.168.0.44?
    Irgendwie scheint der Adapter da nicht an Land zu kommen.
    Edit: Typos
      @buster
      Edit: Typos
      Buster
      #875
      jepp der wohnt da ..... kann auch darauf zugreifen und die Konfigoberfläche aufrufen
      ich mach mal das update.....
        Buster
        #876
        Update gemacht.... verhält sich aber immer noch gleich ...
        Schließt die Verbindung nach timeout.....
        ? Rene55R 2 Antworten Letzte Antwort
        • B Buster
          #877
          @buster
          hast du auch die richtige Seriennummer ( des Datenloggers, nicht vom Wechselrichter! ) eingetragen, und den richtigen Port ? (8899 wenn unveraendert)
            @buster
            Buster
            #878
            @ilovegym
            danke für den Hinweis ...... kaum macht man es richtig....schon geht's .
            War natürlich die falsche SN Nummer ;-)
            Danke für Eure Hilfe !!!!
            LG Buster
            • B Buster
              Rene55R Online
              Rene55R Online
              Rene55
              #879
              @buster Danke an @ilovegym und @Thomas-Braun, ich hätte das mit der Seriennummer auch stark vermutet.
              Übrigens, dass die Verbindung nach dem Abrufen der Datenblöcke wieder geschlossen wird ist so richtig - außer, du hast ein externes Relais angeschlossen. Dann bleibt die Verbindung offen, weil das Relais soviel quasselt.
              ChendaC 1 Antwort Letzte Antwort
              -1
              • Rene55R Rene55
                ChendaC Offline
                ChendaC Offline
                Chenda
                #880
                @rene55
                Ich konnte IP und SN von einem deye WR eingeben und die Verbindung klappte auf Anhieb. kann ich mehrere deye Wechselrichter auslesen und wenn ja wie funktioniert das? Ich sehe nur Felder für ein Gerät.
                • ChendaC Chenda
                  @rene55
                  #881
                  @chenda
                  fuer jeden Wechselrichter eine Instanz anlegen, und dort die IP des Wechselrichters und die Seriennummers des Datenloggers eintragen.
                  Funktioniert hier mit 5 Wechselrichtern einwandfrei.
                    @chenda
                    ChendaC Offline
                    ChendaC Offline
                    Chenda
                    #882
                    @ilovegym
                    Danke für die schnelle Antwort.
                    Wie lege ich eine zweite Instanz an?
                    • ChendaC Chenda
                      @ilovegym
                      #883
                      @chenda
                      Im Tab Adapter bei demjenigen auf das + klicken..
                        @chenda
                        ChendaC Offline
                        ChendaC Offline
                        Chenda
                        #884
                        @ilovegym
                          kptkip
                          #885
                          Gibt es eine Möglichkeit, in der admin-Oberfläche die jeweiligen json-Dateien von github zu importieren? Oder müssen die von Hand eingepflegt werden?
                          • K kptkip
                            Rene55R Online
                            Rene55R Online
                            Rene55
                            #886
                            @kptkip Dazu kann man die gewünschte .json über den linken Pfeil importieren. Danach natürlich IP-Adresse und Seriennummer neu eintragen._Einstellungen_importieren.png
                            • NashraN Offline
                              NashraN Offline
                              Nashra
                              Most Active Forum Testing
                              #887
                              Hey @Rene55 , wollte die json exportieren, aber das geht nicht d.h. ich klick auf den Button aber nichts passiert.
                              Wo wird diese Datei abgelegt?
                              Gruß Ralf
                              • NashraN Nashra
                                Rene55R Online
                                Rene55R Online
                                Rene55
                                #888
                                @nashra Von woher wolltest du was exportieren?
                                Aus dem Adapter? Dann liegt das .json so wie es im Browser eingestellt ist - meist unter 'Downloads'.
                                • Rene55R Rene55
                                  NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  #889
                                  @rene55 sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                  @Rene55 das ist schon klar, aber es passiert nichts wenn ich auf den Button klicke.
                                  Habe es jetzt bei einigen anderen Adaptern versucht, klappt nicht. Hat also nichts mit
                                  deinem zu tun, sondern scheint ein generelles Problem zu sein.
                                  Gruß Ralf
                                  • NashraN Nashra
                                    #890
                                    @nashra sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                    welche Versionen Controller und admin?
                                      NashraN Offline
                                      NashraN Offline
                                      Nashra
                                      schrieb am zuletzt editiert von Nashra
                                      #891
                                      ups verklickt..
                                      admin 6.13.16
                                      controller 5.0.19
                                      Gruß Ralf
                                      • NashraN Nashra
                                        ups verklickt..
                                        admin 6.13.16
                                        controller 5.0.19
                                        #892
                                          NashraN Offline
                                          NashraN Offline
                                          Nashra
                                          #893
                                          @homoran sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                          admin 6.13.16
                                          controller 5.0.19
                                          Gruß Ralf
