  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    Da passiert gar nichts. Da springt der cursor nur in die nächste Zeile
    @airframe75
    sudo systemctl stop iobroker
    iob stop
    iob fix
    iob diag
    A 2 Antworten Letzte Antwort
      @airframe75
      iob stop
      iob fix
      iob diag
      Airframe75
      iob dia ging noch immer nicht, aber iob fix ging
      iobroker@iobroker:~ $ sudo systemctl stop iobroker
      iobroker@iobroker:~ $ iob stop
      iobroker@iobroker:~ $ iob fix
      library: loaded
      Library version=2024-01-04
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Err:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
      Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Err:2 http://security.debian.org/debian-security bullseye-security InRelease
        Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
      Get:3 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Err:3 http://deb.debian.org/debian bullseye InRelease
      Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Err:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
      Err:6 https://repos.influxdata.com/debian bullseye InRelease
        Error writing to file - write (28: No space left on device) [IP: 2600:9000:2057:5a00:11:fe8d:7d40:93a1 443]
      Err:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
      Reading package lists... Error!
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
      W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2600:9000:2057:5a00:11:fe8d:7d40:93a1 443]
      W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
      W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      E: Write error - write (28: No space left on device)
      E: IO Error saving source cache
      E: The package lists or status file could not be parsed or opened.
          Checking ioBroker user and directory permissions (2/5)
      [sudo] password for iobroker:
      usermod: /etc/passwd.3522: No space left on device
      usermod: cannot lock /etc/passwd; try again later.
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      npm ERR! code ENOSPC
      npm ERR! syscall write
      npm ERR! errno -28
      npm ERR! nospc ENOSPC: no space left on device, write
      npm ERR! nospc There appears to be insufficient space on your system to finish.
      npm ERR! nospc Clear up some disk space and try again.
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-25T11_08_30_818Z-debug-0.log
      main: line 14: [: -lt: unary operator expected
      npm ERR! errno -28
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-25T11_08_31_650Z-debug-0.log
          Checking autostart (5/5)
      Enabling autostart...
      Failed to enable unit: Unit file /lib/systemd/system/iobroker.service is masked.
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      iobroker@iobroker:~ $ iob diag
      • A Airframe75
        library: loaded
        Done.
        npm ERR! errno -28
        npm ERR! errno -28
        Autostart enabled!
        @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
        Der Datenträger ist rappelvoll.
        Schau per
        sudo ncdu /
        wo die dicken Hunde liegen.
          @airframe75
          iob stop
          iob fix
          iob diag
          Airframe75
          Na, da steht "no space left on device". Das wird wohl das Problem sein.
          Ich habe Daten gelogged, kann ich die über die Shell löschen? Damit sollte es ja eventuell wieder gehen.
            Schau per
            sudo ncdu /
            Airframe75
            cdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help                                                          --- / ------------------------------------------------------------------------------------------------------------------   25.4 GiB [##########] /var        1.6 GiB [          ] /usr
                1.3 GiB [          ] /opt
              750.3 MiB [          ] /home
               75.5 MiB [          ] /run
               30.6 MiB [          ] /boot
                3.8 MiB [          ] /etc
               28.0 KiB [          ] /tmp
               20.0 KiB [          ] /root
            e  16.0 KiB [          ] /lost+found
            e   4.0 KiB [          ] /srv
            e   4.0 KiB [          ] /mnt
            e   4.0 KiB [          ] /media
                0.0   B [          ] /sys
            .   0.0   B [          ] /proc
                0.0   B [          ] /dev
            @   0.0   B [          ]  sbin
            @   0.0   B [          ]  lib
            @   0.0   B [          ]  bin
            • A Airframe75
                  1.3 GiB [          ] /opt
                750.3 MiB [          ] /home
                 75.5 MiB [          ] /run
                 30.6 MiB [          ] /boot
                  3.8 MiB [          ] /etc
                 28.0 KiB [          ] /tmp
                 20.0 KiB [          ] /root
              e   4.0 KiB [          ] /srv
              e   4.0 KiB [          ] /mnt
                  0.0   B [          ] /sys
              .   0.0   B [          ] /proc
                  0.0   B [          ] /dev
              @   0.0   B [          ]  sbin
              @   0.0   B [          ]  lib
              @   0.0   B [          ]  bin
              @airframe75
              Weiter durchhangeln. Das dürfte aber in /var eines der logs sein.
                @airframe75
                Airframe75
                Wie weiter durchhangeln? Was soll ich machen. Ich habe keine Ahnung von Linux. Ich habe das Tutorial von Matthias Kleine besucht und alles nachgemacht.
                • A Airframe75
                  @airframe75
                  Mit 'Linux' hat das nix zu tun...
                    @airframe75
                    Airframe75
                    So habe mit ">" weitergeklickt und 22,6 GB influx db Daten gefunden
                    --- /var/lib/influxdb/engine ------------------------------------------------------------------------------------------- /..
                    22.6 GiB [##########] /data 35.9 MiB [ ] /wal
                    e 4.0 KiB [ ] /replicationq
                    Kann ich das gewissenlos löschen und wenn ja wie?
                    • A Airframe75
                      Nein, da sollte die Datenbank ordentlich gezähmt werden.
                      Nie einfach irgendwas löschen.
                      Ich hab aber keinen Plan von influx. Vielleicht @Marc-Berg
                        Airframe75
                        Vielen Dank für die Indentifizierung des Problems.
                        Sollte ich Marc Berg einzeln anschreiben oder ist das durch das Taggen automatisch passiert?
                        • W Online
                          W Online
                          Wildbill
                          @airframe75 Durch das Taggen bekommt er einen Hinweis, wenn er sich im Forum einloggt. Alternativ auch eine E-Mail, dass er erwähnt wurde, wenn er es so eingestellt hat.
                          Gruss, Jürgen
                            Airframe75
                            Ich habe das Problem mit dem fehlenden Speiecherplatz mit Marc gelöst und InfluxDB2 komplett deistalliert. Aber ich habe noch immer keinen Zugriff auf den ioBroker. Es ist immer noch die gleiche Fehlermeldung?
                            Ich habe auch nochmal iob dia ausprobiert, aber keine Reaktion / Feedback vom System
                            • A Airframe75
                              wendy2702W Offline
                              wendy2702W Offline
                              @airframe75 hast du diese Schritte ausgeführt
                              https://forum.iobroker.net/post/1132900
                              • wendy2702W wendy2702
                                Airframe75
                                schrieb am zuletzt editiert von Airframe75
                                @wendy2702 @thomas-braun
                                Ja, diese drei habe ich durchgeführt, aber nichts wird mir angezeigt
                                Am Ende habe ich auch noch ein Reboot durchgeführt, aber erreichen kann ich den ioBroker immer noch nicht.
                                • A Airframe75
                                  @airframe75
                                  df -h
                                  sagt?
                                    @airframe75
                                    df -h
                                    sagt?
                                    Airframe75
                                    iobroker@iobroker:~ $ df -h
                                    Filesystem      Size  Used Avail Use% Mounted on
                                    /dev/root        29G  6.4G   22G  23% /
                                    devtmpfs        1.7G     0  1.7G   0% /dev
                                    tmpfs           1.9G     0  1.9G   0% /dev/shm
                                    tmpfs           759M  1.1M  758M   1% /run
                                    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                    /dev/mmcblk0p1  255M   31M  225M  13% /boot
                                    tmpfs           380M     0  380M   0% /run/user/1000
                                    Ich habe auch nochmal sudo ncdu / gemacht und da stehen ganz andere Werte
                                    ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help                                                          --- / ------------------------------------------------------------------------------------------------------------------    2.9 GiB [##########] /var        1.5 GiB [#####     ] /usr
                                        1.3 GiB [####      ] /opt
                                      750.3 MiB [##        ] /home
                                       30.6 MiB [          ] /boot
                                        3.8 MiB [          ] /etc
                                        1.1 MiB [          ] /run
                                       48.0 KiB [          ] /tmp
                                       20.0 KiB [          ] /root
                                    e   4.0 KiB [          ] /srv
                                    e   4.0 KiB [          ] /mnt
                                        0.0   B [          ] /sys
                                    .   0.0   B [          ] /proc
                                        0.0   B [          ] /dev
                                    @   0.0   B [          ]  sbin
                                    @   0.0   B [          ]  lib
                                    @   0.0   B [          ]  bin
                                      @airframe75
                                      df -h
                                      sagt?
                                      Airframe75
                                      Kann es auch eventuell damit was zu tun, das die WLAN Verbindung nicht funktioniert? Ich kann zwar per Powershell auf den Resberry Pi zugreifen. Ich sehe aber nicht in der FritzBox, dass das Gerät online ist.
                                      CodierknechtC wendy2702W 2 Antworten Letzte Antwort
                                      • A Airframe75
                                        CodierknechtC Offline
                                        Codierknecht
                                        @airframe75
                                        Wenn Dein WLAN nicht in Ordnung wäre, könntest Du gar nicht auf den Pi zugreifen.
                                        Dass Du es kannst zeigt, dass das OK ist.
                                        Die Fritte zeigt da auch gerne mal Mist an.
                                        HmIP|ZigBee|Tasmota|Unifi
                                        Zabbix Certified Specialist
                                        • A Airframe75
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          @airframe75 wenn du mit powershell auf den Pi kommst ist der auch irgendwie im Netzwerk.
                                          Ich würde aber eh empfehlen den per Kabel anzuschließen.
