  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    iob dia ging noch immer nicht, aber iob fix ging
    iobroker@iobroker:~ $ sudo systemctl stop iobroker
    iobroker@iobroker:~ $ iob stop
    iobroker@iobroker:~ $ iob fix
    library: loaded
    Library version=2024-01-04
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Err:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
    Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Err:2 http://security.debian.org/debian-security bullseye-security InRelease
      Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
    Get:3 http://deb.debian.org/debian bullseye InRelease [116 kB]
    Err:3 http://deb.debian.org/debian bullseye InRelease
    Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Err:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
    Err:6 https://repos.influxdata.com/debian bullseye InRelease
      Error writing to file - write (28: No space left on device) [IP: 2600:9000:2057:5a00:11:fe8d:7d40:93a1 443]
    Err:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
    Reading package lists... Error!
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
    W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:8d::644 80]
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2600:9000:2057:5a00:11:fe8d:7d40:93a1 443]
    W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    E: Write error - write (28: No space left on device)
    E: IO Error saving source cache
    E: The package lists or status file could not be parsed or opened.
        Checking ioBroker user and directory permissions (2/5)
    [sudo] password for iobroker:
    usermod: /etc/passwd.3522: No space left on device
    usermod: cannot lock /etc/passwd; try again later.
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npm ERR! code ENOSPC
    npm ERR! syscall write
    npm ERR! errno -28
    npm ERR! nospc ENOSPC: no space left on device, write
    npm ERR! nospc There appears to be insufficient space on your system to finish.
    npm ERR! nospc Clear up some disk space and try again.
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-25T11_08_30_818Z-debug-0.log
    main: line 14: [: -lt: unary operator expected
    npm ERR! errno -28
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-25T11_08_31_650Z-debug-0.log
        Checking autostart (5/5)
    Enabling autostart...
    Failed to enable unit: Unit file /lib/systemd/system/iobroker.service is masked.
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    iobroker@iobroker:~ $ iob diag
    @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
    Der Datenträger ist rappelvoll.
    Schau per
    sudo ncdu /
    wo die dicken Hunde liegen.
      @airframe75
      iob stop
      iob fix
      iob diag
      Airframe75
      Na, da steht "no space left on device". Das wird wohl das Problem sein.
      Ich habe Daten gelogged, kann ich die über die Shell löschen? Damit sollte es ja eventuell wieder gehen.
        Schau per
        sudo ncdu /
        Airframe75
        cdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help                                                          --- / ------------------------------------------------------------------------------------------------------------------   25.4 GiB [##########] /var        1.6 GiB [          ] /usr
            1.3 GiB [          ] /opt
          750.3 MiB [          ] /home
           75.5 MiB [          ] /run
           30.6 MiB [          ] /boot
            3.8 MiB [          ] /etc
           28.0 KiB [          ] /tmp
           20.0 KiB [          ] /root
        e  16.0 KiB [          ] /lost+found
        e   4.0 KiB [          ] /srv
        e   4.0 KiB [          ] /mnt
        e   4.0 KiB [          ] /media
            0.0   B [          ] /sys
        .   0.0   B [          ] /proc
            0.0   B [          ] /dev
        @   0.0   B [          ]  sbin
        @   0.0   B [          ]  lib
        @   0.0   B [          ]  bin
        • A Airframe75
              1.3 GiB [          ] /opt
            750.3 MiB [          ] /home
             75.5 MiB [          ] /run
             30.6 MiB [          ] /boot
              3.8 MiB [          ] /etc
             28.0 KiB [          ] /tmp
             20.0 KiB [          ] /root
          e   4.0 KiB [          ] /srv
          e   4.0 KiB [          ] /mnt
              0.0   B [          ] /sys
          .   0.0   B [          ] /proc
              0.0   B [          ] /dev
          @   0.0   B [          ]  sbin
          @   0.0   B [          ]  lib
          @   0.0   B [          ]  bin
          @airframe75
          Weiter durchhangeln. Das dürfte aber in /var eines der logs sein.
          A 2 Antworten Letzte Antwort
            @airframe75
            Airframe75
            Wie weiter durchhangeln? Was soll ich machen. Ich habe keine Ahnung von Linux. Ich habe das Tutorial von Matthias Kleine besucht und alles nachgemacht.
            • A Airframe75
              @airframe75
              Mit 'Linux' hat das nix zu tun...
                @airframe75
                Airframe75
                So habe mit ">" weitergeklickt und 22,6 GB influx db Daten gefunden
                --- /var/lib/influxdb/engine ------------------------------------------------------------------------------------------- /..
                22.6 GiB [##########] /data 35.9 MiB [ ] /wal
                e 4.0 KiB [ ] /replicationq
                Kann ich das gewissenlos löschen und wenn ja wie?
                • A Airframe75
                  Nein, da sollte die Datenbank ordentlich gezähmt werden.
                  Nie einfach irgendwas löschen.
                  Ich hab aber keinen Plan von influx. Vielleicht @Marc-Berg
                    Airframe75
                    Vielen Dank für die Indentifizierung des Problems.
                    Sollte ich Marc Berg einzeln anschreiben oder ist das durch das Taggen automatisch passiert?
                    • W Online
                      W Online
                      Wildbill
                      @airframe75 Durch das Taggen bekommt er einen Hinweis, wenn er sich im Forum einloggt. Alternativ auch eine E-Mail, dass er erwähnt wurde, wenn er es so eingestellt hat.
                      Gruss, Jürgen
                        Airframe75
                        Ich habe das Problem mit dem fehlenden Speiecherplatz mit Marc gelöst und InfluxDB2 komplett deistalliert. Aber ich habe noch immer keinen Zugriff auf den ioBroker. Es ist immer noch die gleiche Fehlermeldung?
                        Ich habe auch nochmal iob dia ausprobiert, aber keine Reaktion / Feedback vom System
                        • A Airframe75
                          wendy2702W Offline
                          wendy2702W Offline
                          @airframe75 hast du diese Schritte ausgeführt
                          https://forum.iobroker.net/post/1132900
                          • wendy2702W wendy2702
                            Airframe75
                            schrieb am zuletzt editiert von Airframe75
                            @wendy2702 @thomas-braun
                            Ja, diese drei habe ich durchgeführt, aber nichts wird mir angezeigt
                            Am Ende habe ich auch noch ein Reboot durchgeführt, aber erreichen kann ich den ioBroker immer noch nicht.
                            • A Airframe75
                              @airframe75
                              df -h
                              sagt?
                                @airframe75
                                df -h
                                sagt?
                                Airframe75
                                iobroker@iobroker:~ $ df -h
                                Filesystem      Size  Used Avail Use% Mounted on
                                /dev/root        29G  6.4G   22G  23% /
                                devtmpfs        1.7G     0  1.7G   0% /dev
                                tmpfs           1.9G     0  1.9G   0% /dev/shm
                                tmpfs           759M  1.1M  758M   1% /run
                                tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                /dev/mmcblk0p1  255M   31M  225M  13% /boot
                                tmpfs           380M     0  380M   0% /run/user/1000
                                Ich habe auch nochmal sudo ncdu / gemacht und da stehen ganz andere Werte
                                ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help                                                          --- / ------------------------------------------------------------------------------------------------------------------    2.9 GiB [##########] /var        1.5 GiB [#####     ] /usr
                                    1.3 GiB [####      ] /opt
                                  750.3 MiB [##        ] /home
                                   30.6 MiB [          ] /boot
                                    3.8 MiB [          ] /etc
                                    1.1 MiB [          ] /run
                                   48.0 KiB [          ] /tmp
                                   20.0 KiB [          ] /root
                                e   4.0 KiB [          ] /srv
                                e   4.0 KiB [          ] /mnt
                                    0.0   B [          ] /sys
                                .   0.0   B [          ] /proc
                                    0.0   B [          ] /dev
                                @   0.0   B [          ]  sbin
                                @   0.0   B [          ]  lib
                                @   0.0   B [          ]  bin
                                  @airframe75
                                  df -h
                                  sagt?
                                  Airframe75
                                  Kann es auch eventuell damit was zu tun, das die WLAN Verbindung nicht funktioniert? Ich kann zwar per Powershell auf den Resberry Pi zugreifen. Ich sehe aber nicht in der FritzBox, dass das Gerät online ist.
                                  CodierknechtC wendy2702W 2 Antworten Letzte Antwort
                                  • A Airframe75
                                    CodierknechtC Offline
                                    Codierknecht
                                    @airframe75
                                    Wenn Dein WLAN nicht in Ordnung wäre, könntest Du gar nicht auf den Pi zugreifen.
                                    Dass Du es kannst zeigt, dass das OK ist.
                                    Die Fritte zeigt da auch gerne mal Mist an.
                                    HmIP|ZigBee|Tasmota|Unifi
                                    Zabbix Certified Specialist
                                    • A Airframe75
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      @airframe75 wenn du mit powershell auf den Pi kommst ist der auch irgendwie im Netzwerk.
                                      Ich würde aber eh empfehlen den per Kabel anzuschließen.
                                        Airframe75
                                        @wendy2702
                                        Muss man das umstellen oder kann ich das einfach umstecken?
                                        • A Airframe75
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          @airframe75 Kabel dran und neu starten. Wenn an den Netzwerk Einstellungen im Pi nichts geändert wurde war es zumindest früher so das Kabel immer zuerst verwendet wurde. Sonst einfach die WLAN Einstellungen löschen.
                                          Meister MopperM A 2 Antworten Letzte Antwort
