  4. Keine Verbindung mehr zu iobroker
32 Beiträge 5 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • O obstbauer
    ich weiß der Desktop läuft noch, ich werde das ändern, wenn alles wieder stabil läuft
    Skript v.2023-10-25
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     22:23:36 up  7:48,  2 users,  load average: 1.76, 1.51, 1.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-12-27 22:23:36 CET
               Universal time: Wed 2023-12-27 21:23:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.8G        1.0G        365M         65M        2.4G        2.6G
    Swap:            99M          0B         99M
    Total:          3.9G        1.0G        465M
             3794 M total memory
             1024 M used memory
             1589 M active memory
             1563 M inactive memory
              368 M free memory
                7 M buffer memory
             2393 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   18G   39G  31% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  7.8M  1.9G   1% /dev/shm
    tmpfs          tmpfs     759M  1.3M  758M   1% /run
    /dev/sda1      ext4      3.7T  2.8T  772G  79% /mount/toshiba_1
    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     380M   28K  380M   1% /run/user/1000
    [Wed Dec 27 14:35:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A8:66:23 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=33928f17-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Dec 27 14:35:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Dec 27 14:35:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Dec 27 14:35:22 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [Wed Dec 27 14:35:24 2023] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
    [Wed Dec 27 14:35:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236870
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236868
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236864
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236869
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236867
    [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236865
    [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): error count since last fsck: 2616
    [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): initial error at time 1679237384: ext4_lookup:1840: inode 232962
    [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): last error at time 1703684179: ext4_lookup:1839: inode 232962
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE         OPTIONS
    /                            /dev/mmcblk0p2 ext4           rw,noatime
    |-/dev                       devtmpfs       devtmpfs       rw,relatime,size=1678472k,nr_inodes=419618,mode=755
    | |-/dev/shm                 tmpfs          tmpfs          rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts         rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue         rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc           rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs         rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs          rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2        rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore         pstore         rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf            rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs        debugfs        rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs        tracefs        rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config       configfs       configfs       rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections fusectl        fusectl        rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs          rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs          rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs     rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs          rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
    |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fus rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/mount/toshiba_1           /dev/sda1      ext4           rw,relatime
    `-/boot                      /dev/mmcblk0p1 vfat           rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remoun
    /var:
    6.9G	/var/
    5.2G	/var/log
    4.0G	/var/log/journal/8c1e10bfe3864fdca0aaa920fec2e173
    1.1G	/var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    3.2G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G	/opt/iobroker/iobroker-data/
    153M	/opt/iobroker/iobroker-data/files
    62M	/opt/iobroker/iobroker-data/history
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    35M	/opt/iobroker/iobroker-data/backup-objects
    1.6G	/opt/iobroker/iobroker-data/objects.jsonl
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Single_Serial_558E108164-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.20.2
    /usr/bin/node 		v16.20.2
    /usr/bin/npm 		8.19.4
    /usr/bin/npx 		8.19.4
    /usr/bin/corepack 	0.17.0
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.12.0
    javascript: 	7.0.3
    Adapters from github: 	0
    Adapter State
    No connection to databases possible ...
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects: 	1
    States: 	1
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://archive.raspbian.org/raspbian buster InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Get:7 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
    Hit:8 https://repos.influxdata.com/debian stable InRelease
    Hit:9 https://repos.influxdata.com/debian bullseye InRelease
    Hit:10 http://weewx.com/apt/python3 buster InRelease
    Fetched 4586 B in 5s (842 B/s)
    Reading package lists... Done
    N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
    N: Skipping acquire of configured file 'contrib/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
    N: Skipping acquire of configured file 'non-free/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
    Pending Updates: 0
    *** Listening Ports ***
    Netid            State             Recv-Q            Send-Q                         Local Address:Port                          Peer Address:Port            Process
    udp              UNCONN            0                 0                                    0.0.0.0:631                                0.0.0.0:*                users:(("cups-browsed",pid=735,fd=7))
    udp              UNCONN            0                 0                                    0.0.0.0:5353                               0.0.0.0:*                users:(("avahi-daemon",pid=440,fd=12))
    udp              UNCONN            0                 0                                    0.0.0.0:34224                              0.0.0.0:*                users:(("avahi-daemon",pid=440,fd=14))
    udp              UNCONN            0                 0                                    0.0.0.0:68                                 0.0.0.0:*                users:(("dhcpcd",pid=508,fd=13))
    udp              UNCONN            0                 0                                          *:546                                      *:*                users:(("dhcpcd",pid=508,fd=16))
    udp              UNCONN            0                 0                                          *:5353                                     *:*                users:(("avahi-daemon",pid=440,fd=13))
    udp              UNCONN            0                 0                                          *:39262                                    *:*                users:(("avahi-daemon",pid=440,fd=15))
    tcp              LISTEN            0                 511                                  0.0.0.0:80                                 0.0.0.0:*                users:(("nginx",pid=757,fd=6),("nginx",pid=756,fd=6),("nginx",pid=755,fd=6),("nginx",pid=754,fd=6),("nginx",pid=753,fd=6))
    tcp              LISTEN            0                 128                                127.0.0.1:631                                0.0.0.0:*                users:(("cupsd",pid=591,fd=7))
    tcp              LISTEN            0                 128                                  0.0.0.0:22                                 0.0.0.0:*                users:(("sshd",pid=646,fd=3))
    tcp              LISTEN            0                 1024                                 0.0.0.0:2812                               0.0.0.0:*                users:(("monit",pid=566,fd=5))
    tcp              LISTEN            0                 4096                               127.0.0.1:8088                               0.0.0.0:*                users:(("influxd",pid=603,fd=3))
    tcp              LISTEN            0                 80                                 127.0.0.1:3306                               0.0.0.0:*                users:(("mariadbd",pid=732,fd=21))
    tcp              LISTEN            0                 5                                    0.0.0.0:5900                               0.0.0.0:*                users:(("vncserver-x11-c",pid=636,fd=12))
    tcp              LISTEN            0                 511                                     [::]:80                                    [::]:*                users:(("nginx",pid=757,fd=7),("nginx",pid=756,fd=7),("nginx",pid=755,fd=7),("nginx",pid=754,fd=7),("nginx",pid=753,fd=7))
    tcp              LISTEN            0                 128                                     [::]:22                                    [::]:*                users:(("sshd",pid=646,fd=4))
    tcp              LISTEN            0                 1024                                    [::]:2812                                  [::]:*                users:(("monit",pid=566,fd=6))
    tcp              LISTEN            0                 4096                                       *:3000                                     *:*                users:(("grafana",pid=1238,fd=9))
    tcp              LISTEN            0                 2                                      [::1]:3350                                  [::]:*                users:(("xrdp-sesman",pid=641,fd=11))
    tcp              LISTEN            0                 128                                    [::1]:631                                   [::]:*                users:(("cupsd",pid=591,fd=6))
    tcp              LISTEN            0                 2                                          *:3389                                     *:*                users:(("xrdp",pid=733,fd=11))
    tcp              LISTEN            0                 511                                        *:8080                                     *:*                users:(("node /home/Shin",pid=1217,fd=21))
    tcp              LISTEN            0                 4096                                       *:8086                                     *:*                users:(("influxd",pid=603,fd=29))
    tcp              LISTEN            0                 5                                       [::]:5900                                  [::]:*                users:(("vncserver-x11-c",pid=636,fd=11))
    2023-12-27 22:24:52.282  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-27 22:24:52.283  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
    2023-12-27 22:24:52.284  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
    2023-12-27 22:25:22.310  - error: host.raspberrypi No connection to databases possible, restart
    2023-12-27 22:25:22.324  - info: host.raspberrypi iobroker _restart
    2023-12-27 22:25:27.732  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2023-12-27 22:25:27.738  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-27 22:25:27.739  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
    2023-12-27 22:25:27.740  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
    2023-12-27 22:25:57.766  - error: host.raspberrypi No connection to databases possible, restart
    2023-12-27 22:25:57.783  - info: host.raspberrypi iobroker _restart
    2023-12-27 22:26:03.868  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2023-12-27 22:26:03.880  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-27 22:26:03.882  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
    2023-12-27 22:26:03.884  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
    2023-12-27 22:26:06.035  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    2023-12-27 22:26:10.857  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2023-12-27 22:26:10.868  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-27 22:26:10.869  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
    2023-12-27 22:26:10.871  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
    2023-12-27 22:26:13.043  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    2023-12-27 22:26:17.742  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2023-12-27 22:26:17.752  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-27 22:26:17.754  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
    2023-12-27 22:26:17.756  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
    GlasfaserG Offline
    GlasfaserG Offline
    @obstbauer sagte in Keine Verbindung mehr zu iobroker:
    der ist aber schon sehr alt .. und auch vom letzten Stand "4.0.24" auch nicht aktuell
    Neu ist JS 5
    dazu aber erst ein Backup machen zur Sicherheit dann
    iob stop
    iob update
    iob upgrade self
    iob start
    /usr/bin/npm 8.19.4
    /usr/bin/npx 8.19.4
    Auch sehr alt .
    dazu :
    iob nodejs-update
    • O obstbauer
      @glasfaser super klasse, es geht wieder, vielen Dank!
      Kann mir noch jemand fürs Verständis erklären wie das passieren konnte (wie gesagt es gab einen Stromausfall) ? Und woher weiß ich dass die 1.6 GB zu groß sind ?
      GlasfaserG Offline
      GlasfaserG Offline
      Das liegt erstmal am Stromausfall von dir ... Daten wurden noch nicht weggeschrieben und du hast noch die alte 4.0.23 dort wurde es noch nicht damit abgefangen !
      • GlasfaserG Offline
        GlasfaserG Offline
        diesen Fehler scheine ich zu haben:
        Dazu gibt es einen Thread
        siehe hier :
        https://forum.iobroker.net/topic/53378/server-cannot-start-inmem-objects-on-port-9001
        Klar ...funktioniert es wieder ...
        ein bekannter Fehler ( Stromausfall ) ;)
        O 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          siehe hier :
          O Offline
          O Offline
          obstbauer
          @glasfaser ich versuche die updates jetzt durchzuführen, Sicherung ist erstellt
          weitere Verständnisfrage: Werden diese Versionen nicht mit aktualisiert wenn ich das System aktualisiere mit sudo apt upgrade oder is das durch meine grafana key fehler einfach zu lange nicht mehr gemacht worden ?
          • O obstbauer
            GlasfaserG Offline
            GlasfaserG Offline
            nein nur dein
              nein nur dein
              O Offline
              O Offline
              obstbauer
              @glasfaser also muss ich in Zukunft selbst immer von Hand diese updates machen und schauen, dass alles aktuell ist?
              • O obstbauer
                GlasfaserG Offline
                GlasfaserG Offline
                @obstbauer
                ja , Node per Konsole
                und ab JS 5 ist jetzt neu per Admin WebUI ein update zu machen ... wie halt auch die Adapter
                  @obstbauer
                  O Offline
                  O Offline
                  obstbauer
                  @glasfaser Hallo,
                  ich habe mal wieder nach aktuellen Updates geschaut
                  Was meinst du genau? Wo kann ich das im Admin WebUI finden ? Konnte da nix finden wie bei den Adaptern...
                  • O obstbauer
                    @glasfaser Hallo,
                    HomoranH Offline
                    HomoranH Offline
                    @obstbauer welche controller Version hast du?
                    • O obstbauer
                      @glasfaser Hallo,
                      @obstbauer
                      Raspbian GNU/Linux 10
                      ist tot, muss durch v12 ersetzt werden. Neuinstallation der 64Bit-Lite-Version.
                      • O Offline
                        O Offline
                        obstbauer
                        @homoran Admin 6.13.15
                        Ich habe release 11 bullseye
                        node v18.19.0
                        • O obstbauer
                          node v18.19.0
                          HomoranH Offline
                          HomoranH Offline
                          @obstbauer fehlt nur noch die gefragte Version des js-controllers.
                          • O Offline
                            O Offline
                            obstbauer
                            Node.js: v18.19.0
                            NPM: 10.2.3
                            js-controller 5.0.17
                            • O obstbauer
                              Node.js: v18.19.0
                              NPM: 10.2.3
                              HomoranH Offline
                              HomoranH Offline
                              danke!
                              damit sollte es gehen.
                              Der Button dafür sollte wie bisher unter hosts zu finden sein
