  4. IObroker startet jeden Abend neu!
32 Beiträge 7 Kommentatoren 4.3k Aufrufe 6 Beobachtet
  • N norman
    meinst du so:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:56:24 up 14 days,  1:24,  2 users,  load average: 0.39, 0.52, 0.52
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-21 19:56:24 CET
               Universal time: Sun 2024-01-21 18:56:24 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.9G        1.4G        292M        225K        349M        569M
    Swap:           104M         21M         83M
    Total:          2.0G        1.4G        375M
             1848 M total memory
             1304 M used memory
              377 M active memory
             1060 M inactive memory
              278 M free memory
               21 M buffer memory
              311 M swap cache
               99 M total swap
               20 M used swap
               79 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  661M     0  661M   0% /dev
    tmpfs          tmpfs     185M  1.2M  184M   1% /run
    /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    956M    /var/
    490M    /var/log
    489M    /var/log/journal/646f283dbad041b98afadc09481d9d55
    202M    /var/cache
    Archived and active journals take up 488.8M in the file system.
    /opt/iobroker/backups:
    28M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    342M    /opt/iobroker/iobroker-data/
    223M    /opt/iobroker/iobroker-data/files
    76M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    41M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspi                                    -  enabled
      system.adapter.backitup.0               : backitup              : raspi                                    - disabled
    + system.adapter.evohome.0                : evohome               : raspi                                    -  enabled
      system.adapter.flot.0                   : flot                  : raspi                                    - disabled
    + system.adapter.growatt.0                : growatt               : raspi                                    -  enabled
    + system.adapter.history.0                : history               : raspi                                    -  enabled
    + system.adapter.hs100.0                  : hs100                 : raspi                                    -  enabled
      system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
      system.adapter.ical.1                   : ical                  : raspi                                    -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspi                                    - disabled
    + system.adapter.info.0                   : info                  : raspi                                    -  enabled
    + system.adapter.iot.0                    : iot                   : raspi                                    -  enabled
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspi                                    -  enabled
      system.adapter.mobile.0                 : mobile                : raspi                                    - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi                                    -  enabled, port: 1884, bind: 192.168.178.60
      system.adapter.openweathermap.0         : openweathermap        : raspi                                    -  enabled
    + system.adapter.ring.0                   : ring                  : raspi                                    -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi                                    -  enabled
      system.adapter.socketio.0               : socketio              : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tr-064.1                 : tr-064                : raspi                                    -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspi                                    - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    - disabled
      system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
      system.adapter.wallpanel.0              : wallpanel             : raspi                                    - disabled
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : raspi                                    - disabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
      system.adapter.ws.0                     : ws                    : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
    + instance is alive
    ioBroker-Repositories
    stabil        : http://download.iobroker.net/sources-dist.json
    Active repo(s): stabil
    Installed ioBroker-Instances
    Used repository: stabil
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "growatt"      : 3.2.1    , installed 3.2.1
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.9  [Updatable]
    Adapter    "vis-icontwo"  : 1.3.0    , installed 0.89.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.1  [Updatable]
    Adapter    "vis-justgage" : 2.1.0    , installed 1.0.2  [Updatable]
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.5  [Updatable]
    Objects and States
    Objects:        6083
    States:         16948
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 5
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15801      653/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        16411      627/redis-server 12
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12224465   533020/iobroker.js-
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12228465   534012/io.sonoff.0
    tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       12228375   533933/io.mqtt.0
    tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       12228376   533933/io.mqtt.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15803      653/sshd: /usr/sbin
    tcp6       0      0 ::1:6379                :::*                    LISTEN      106        16412      627/redis-server 12
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12232145   534743/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12226506   533038/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      412/avahi-daemon: r
    udp        0      0 0.0.0.0:37662           0.0.0.0:*                           104        13649      412/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        13648      412/avahi-daemon: r
    udp6       0      0 :::46445                :::*                                104        13650      412/avahi-daemon: r
    udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          16472      477/NetworkManager
    2024-01-21 19:44:49.088  - info: info.0 (534111) cpu Temp res = {"main":47.712,"cores":[],"max":47.712,"socket":[],"chipset":null}
    2024-01-21 19:44:49.312  - info: iot.0 (534161) Connection changed: connect "info_mediaevent24_de"
    2024-01-21 19:44:49.682  - info: info.0 (534111) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
    2024-01-21 19:44:50.424  - info: host.raspi instance system.adapter.ring.0 started with pid 534301
    2024-01-21 19:44:50.731  - info: lgtv.0 (534172) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 19:44:51.001  - info: lgtv.0 (534172) Ready. Configured WebOS TV IP: 192.168.178.56
    2024-01-21 19:44:55.048  - info: info.0 (534111) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
    2024-01-21 19:44:58.472  - info: host.raspi instance system.adapter.web.0 started with pid 534743
    2024-01-21 19:44:58.854  - info: vis.0 (534583) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 19:45:01.370  - info: vis.0 (534583) Terminated (NO_ERROR): Without reason
    2024-01-21 19:45:02.095  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
    2024-01-21 19:45:04.551  - info: ring.0 (534301) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 19:45:04.603  - info: ring.0 (534301) Initializing Api Client
    2024-01-21 19:45:05.483  - info: ring.0 (534301) Received new Refresh Token. Will use the new one until the token in config gets changed
    2024-01-21 19:45:06.926  - info: ring.0 (534301) Get sunset and sunrise
    2024-01-21 19:45:07.011  - info: ring.0 (534301) Daily sun parameter calculation scheduled for 00:00:25
    2024-01-21 19:45:16.762  - info: alexa2.0 (533309) Subscribing to states...
    2024-01-21 19:45:16.772  - info: alexa2.0 (533309) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
    2024-01-21 19:45:18.526  - info: alexa2.0 (533309) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-01-21 19:45:31.828  - info: alexa2.0 (533309) Initialization Done ...
    2024-01-21 19:46:31.428  - warn: sonoff.0 (534012) Client "" not connected
    2024-01-21 19:46:38.946  - warn: sonoff.0 (534012) Client "" not connected
    2024-01-21 19:47:24.048  - warn: sonoff.0 (534012) Client "" not connected
    2024-01-21 19:50:54.596  - warn: sonoff.0 (534012) Client "" not connected
    2024-01-21 19:54:14.031  - warn: sonoff.0 (534012) Client "" not connected
    @norman
    Hau die Updates rein.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    iob update
    iob upgrade all
    N 1 Antwort Letzte Antwort
      @norman
      sudo apt update
      sudo reboot
      iob update
      iob upgrade all
      N Offline
      N Offline
      norman
      Update nach deinen Kommandos durchgeschossen, bin mal gespannt wie er sich heute verhält.
      ich geb mal Rückmeldung.
      Soll ich zusätzlich nochmal den Fixer drüber schicken?
      • N norman
        N Offline
        N Offline
        norman
        So, nach anderthalb Tagen Testlauf kann ich nun sagen, is noch schlimmer wie vorher.
        Vorher startete nur IO neu, jetzt bleibt der ganze Raspi hängen und muss über Hard-Reset neu gestartet werden. :-(
        Und das sogar gestern 2x am Tag.
        Man muss doch irgendwie herausfinden können, woran das liegt :-( kann man nicht irgendwo gespeicherte Logs ziehen oder so??
        In der iob diag schreibt er auch irgendwas von "Error in NPM tree"
        Skript v.2023-10-10
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
         19:11:38 up 5 min,  2 users,  load average: 0.35, 0.68, 0.39
        CPU threads: 4
        Current issues:
                       Local time: Wed 2024-01-24 19:11:38 CET
                   Universal time: Wed 2024-01-24 18:11:38 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            1.9G        1.3G        347M        1.2M        334M        607M
        Swap:           104M          0B        104M
        Total:          2.0G        1.3G        452M
                 1848 M total memory
                 1268 M used memory
                 1282 M active memory
                  123 M inactive memory
                  330 M free memory
                   24 M buffer memory
                  294 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/mmcblk0p2 ext4       59G  4.8G   51G   9% /
        [Wed Jan 24 19:06:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:2A:EE:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7af47fd-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Jan 24 19:06:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Jan 24 19:06:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        /var:
        1.1G    /var/
        611M    /var/log
        609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
        203M    /var/cache
        Archived and active journals take up 608.8M in the file system.
        343M    /opt/iobroker/iobroker-data/
        224M    /opt/iobroker/iobroker-data/files
        42M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        6085
        States:         16953
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
        Pending Updates: 7
        tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       16654      906/io.mqtt.0
        tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       16655      906/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12210      996/io.sonoff.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16465      696/iobroker.js-con
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        13880      613/redis-server 12
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13837      652/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21580      1701/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12017      785/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13839      652/sshd: /usr/sbin
        tcp6       0      0 ::1:6379                :::*                    LISTEN      106        13881      613/redis-server 12
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13770      453/avahi-daemon: r
        udp        0      0 0.0.0.0:36397           0.0.0.0:*                           104        13772      453/avahi-daemon: r
        udp6       0      0 :::60534                :::*                                104        13773      453/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        13771      453/avahi-daemon: r
        udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          13959      539/NetworkManager
        2024-01-24 19:07:31.532  - info: info.0 (1087) cpu Temp res = {"main":53.069,"cores":[],"max":53.069,"socket":[],"chipset":null}
        2024-01-24 19:07:31.933  - info: info.0 (1087) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
        2024-01-24 19:07:32.682  - info: host.raspi instance system.adapter.lgtv.0 started with pid 1233
        2024-01-24 19:07:32.998  - info: iot.0 (1110) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
        2024-01-24 19:07:33.292  - info: iot.0 (1110) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2024-01-24 19:07:34.478  - info: iot.0 (1110) Connection changed: connect "info_mediaevent24_de"
        2024-01-24 19:07:36.233  - info: info.0 (1087) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
        2024-01-24 19:07:36.507  - info: lgtv.0 (1233) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
        2024-01-24 19:07:36.685  - info: host.raspi instance system.adapter.ring.0 started with pid 1508
        2024-01-24 19:07:36.746  - info: lgtv.0 (1233) Ready. Configured WebOS TV IP: 192.168.178.56
        2024-01-24 19:07:43.082  - info: vis.0 (1686) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2024-01-24 19:07:44.691  - info: host.raspi instance system.adapter.web.0 started with pid 1701
        2024-01-24 19:07:44.805  - info: vis.0 (1686) Terminated (NO_ERROR): Without reason
        2024-01-24 19:07:45.471  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
        2024-01-24 19:07:45.698  - info: ring.0 (1508) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
        2024-01-24 19:07:45.763  - info: ring.0 (1508) Initializing Api Client
        2024-01-24 19:07:46.476  - info: ring.0 (1508) Received new Refresh Token. Will use the new one until the token in config gets changed
        2024-01-24 19:07:48.002  - info: ring.0 (1508) Get sunset and sunrise
        2024-01-24 19:07:48.070  - info: ring.0 (1508) Daily sun parameter calculation scheduled for 00:00:37
        2024-01-24 19:07:54.417  - warn: sonoff.0 (996) Client "" not connected
        2024-01-24 19:07:54.517  - warn: sonoff.0 (996) Client "" not connected
        2024-01-24 19:08:10.184  - info: alexa2.0 (932) Subscribing to states...
        2024-01-24 19:08:10.191  - info: alexa2.0 (932) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
        2024-01-24 19:08:12.068  - info: alexa2.0 (932) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-01-24 19:08:25.834  - info: alexa2.0 (932) Initialization Done ...
        Im Summary, das danach automatisch erstellt wird sind auch rote Errors bei NPM:
                                v.2023-10-10
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           104M          0B        104M
                 1848 M total memory
                 1268 M used memory
                  330 M free memory
                   24 M buffer memory
                  294 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.1G    /var/
        611M    /var/log
        203M    /var/cache
        33M     /opt/iobroker/iobroker-data/files/iot.admin/stat Static hostname: raspi
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     7
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            1.9G        1.4G        165M        1.2M        436M        529M
        Swap:           104M          0B        104M
        Total:          2.0G        1.4G        270M
        Active iob-Instances:   19
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.12.0
        Objects type: jsonl
        States  type: redis
        Objects:                6085
        States:                 16953
        Size of iob-Database:
        68K     /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        pi@raspi:~ $ ======== Start marking the full check here =========
        -bash: ========: command not found
        pi@raspi:~ $
        pi@raspi:~ $ ```
        > Skript v.2023-10-10
        > *** BASE SYSTEM ***
        >        Icon name: computer
        > Operating System: Debian GNU/Linux 12 (bookworm)
        >     Architecture: arm64
        > Docker          : false
        > Kernel          : aarch64
        > Userland        : arm64
        > CPU threads: 4
        > Current issues:
        > No throttling issues detected.
        >                  RTC time: n/a
        >                 Time zone: Europe/Berlin (CET, +0100)
        > System clock synchronized: yes
        >               NTP service: active
        >           RTC in local TZ: no
        > pi
        > /home/pi
        > X-Server:       false
        > Desktop:
        > Terminal:       tty
        > *** MEMORY ***
        >                total        used        free      shared  buff/cache   available
        > Swap:           104M          0B        104M
        >          1848 M total memory
        >          1268 M used memory
        >           330 M free memory
        >            24 M buffer memory
        >           294 M swap cache
        >            99 M total swap
        >             0 M used swap
        >            99 M free swap
        > Raspberry only:
        > oom events: 0
        >   UNIT LOAD ACTIVE SUB DESCRIPTION
        > *** FILESYSTEM ***
        > Filesystem     Type      Size  Used Avail Use% Mounted on
        > Messages concerning ext4 filesystem in dmesg:
        -bash: Skript: command not found
        -bash: Abfall2024.ics: command not found
        -bash: Static: command not found
        -bash: Icon: command not found
        -bash: command substitution: line 7: syntax error near unexpected token `('
        -bash: command substitution: line 7: `Operating System: Debian GNU/Linux 12 (bookworm)'
        -bash: -/boot/firmware: No such file or directory
        pi@raspi:~ $
        pi@raspi:~ $ Files in neuralgic directories:
        -bash: Files: command not found
        pi@raspi:~ $
        pi@raspi:~ $ /var:
        -bash: /var:: No such file or directory
        pi@raspi:~ $ 1.1G    /var/
        -bash: 1.1G: command not found
        pi@raspi:~ $ 611M    /var/log
        -bash: 611M: command not found
        pi@raspi:~ $ 609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
        -bash: 609M: command not found
        pi@raspi:~ $ 203M    /var/cache
        -bash: 203M: command not found
        pi@raspi:~ $
        pi@raspi:~ $ Archived and active journals take up 608.8M in the file system.
        -bash: Archived: command not found
        pi@raspi:~ $
        pi@raspi:~ $ /opt/iobroker/backups:
        -bash: /opt/iobroker/backups:: No such file or directory
        pi@raspi:~ $ 28M     /opt/iobroker/backups/
        -bash: 28M: command not found
        pi@raspi:~ $
        pi@raspi:~ $ /opt/iobroker/iobroker-data:
        -bash: /opt/iobroker/iobroker-data:: No such file or directory
        pi@raspi:~ $ 343M    /opt/iobroker/iobroker-data/
        -bash: 343M: command not found
        pi@raspi:~ $ 224M    /opt/iobroker/iobroker-data/files
        -bash: 224M: command not found
        pi@raspi:~ $ 76M     /opt/iobroker/iobroker-data/backup-objects
        -bash: 76M: command not found
        pi@raspi:~ $ 67M     /opt/iobroker/iobroker-data/files/javascript.admin
        -bash: 67M: command not found
        pi@raspi:~ $ 48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        -bash: 48M: command not found
        pi@raspi:~ $
        pi@raspi:~ $ The five largest files in iobroker-data are:
        -bash: The: command not found
        pi@raspi:~ $ 42M     /opt/iobroker/iobroker-data/objects.jsonl
        -bash: 42M: command not found
        pi@raspi:~ $ 33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        -bash: 33M: command not found
        pi@raspi:~ $ 21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        -bash: 21M: command not found
        pi@raspi:~ $ 8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        -bash: 8.5M: command not found
        pi@raspi:~ $ 8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        -bash: 8.3M: command not found
        pi@raspi:~ $
        pi@raspi:~ $ USB-Devices by-id:
        -bash: USB-Devices: command not found
        pi@raspi:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        -bash: USB-Sticks: command not found
        pi@raspi:~ $
        pi@raspi:~ $ /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
        -bash: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00: Permission denied
        pi@raspi:~ $
        pi@raspi:~ $ *** NodeJS-Installation ***
        pi@raspi:~ $
        pi@raspi:~ $ /usr/bin/nodejs         v18.19.0
        node:internal/modules/cjs/loader:1137
          throw err;
        Error: Cannot find module '/home/pi/v18.19.0'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
            at Module._load (node:internal/modules/cjs/loader:975:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            at node:internal/main/run_main_module:28:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.19.0
        pi@raspi:~ $ /usr/bin/node           v18.19.0
          throw err;
          requireStack: []
        Node.js v18.19.0
        pi@raspi:~ $ /usr/bin/npm            10.2.3
        Unknown command: "10.2.3"
        To see a list of supported npm commands, run:
          npm help
        pi@raspi:~ $ /usr/bin/npx            10.2.3
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/10.2.3 - Not found
        npm ERR! 404
        npm ERR! 404  '10.2.3@*' is not in this registry.
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-24T18_14_59_263Z-debug-0.log
        pi@raspi:~ $ /usr/bin/corepack       0.22.0
        Unknown Syntax Error: Command not found; did you mean one of:
          0. corepack -h
          1. corepack -v
          2. corepack disable [--install-directory #0] ...
          3. corepack enable [--install-directory #0] ...
          4. corepack install <-g,--global> [--all] [--cache-only] ...
          5. corepack install
          6. corepack pack [--all] [--json] [-o,--output #0] ...
          7. corepack up
          8. corepack use <pattern>
          9. corepack hydrate [--activate] <fileName>
         10. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
        While running 0.22.0
        pi@raspi:~ $
        pi@raspi:~ $
        pi@raspi:~ $ nodejs:
        -bash: nodejs:: command not found
        pi@raspi:~ $   Installed: 18.19.0-1nodesource1
        -bash: Installed:: command not found
        pi@raspi:~ $   Candidate: 18.19.0-1nodesource1
        -bash: Candidate:: command not found
        pi@raspi:~ $   Version table:
        -bash: Version: command not found
        pi@raspi:~ $      18.19.0+dfsg-6~deb12u1 500
        -bash: 18.19.0+dfsg-6~deb12u1: command not found
        pi@raspi:~ $         500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        -bash: 500: command not found
        pi@raspi:~ $  *** 18.19.0-1nodesource1 1001
        pi@raspi:~ $         500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
        pi@raspi:~ $         100 /var/lib/dpkg/status
        -bash: 100: command not found
        pi@raspi:~ $      18.18.2-1nodesource1 1001
        -bash: 18.18.2-1nodesource1: command not found
        pi@raspi:~ $      18.18.1-1nodesource1 1001
        -bash: 18.18.1-1nodesource1: command not found
        pi@raspi:~ $      18.18.0-1nodesource1 1001
        -bash: 18.18.0-1nodesource1: command not found
        pi@raspi:~ $      18.17.1-1nodesource1 1001
        -bash: 18.17.1-1nodesource1: command not found
        pi@raspi:~ $      18.17.0-1nodesource1 1001
        -bash: 18.17.0-1nodesource1: command not found
              : raspi                                    - disabled
        + system.adapter.i-bash: 500: command not found
        pi@raspi:~ $      18.16.1-1nodesource1 1001
        -bash: 18.16.1-1nodesource1: command not found
        pi@raspi:~ $      18.16.0-1nodesource1 1001
        -bash: 18.16.0-1nodesource1: command not found
        pi@raspi:~ $      18.15.0-1nodesource1 1001
        -bash: 18.15.0-1nodesource1: command not found
        pi@raspi:~ $      18.14.2-1nodesource1 1001
        -bash: 18.14.2-1nodesource1: command not found
        pi@raspi:~ $      18.14.1-1nodesource1 1001
        -bash: 18.14.1-1nodesource1: command not found
        pi@raspi:~ $      18.14.0-1nodesource1 1001
        -bash: 18.14.0-1nodesource1: command not found
        pi@raspi:~ $      18.13.0+dfsg1-1 500
        -bash: 18.13.0+dfsg1-1: command not found
        pi@raspi:~ $         500 http://deb.debian.org/debian bookworm/main arm64 Packages
        pi@raspi:~ $      18.13.0-1nodesource1 1001
        -bash: 18.13.0-1nodesource1: command not found
        pi@raspi:~ $      18.12.0-1nodesource1 1001
        -bash: 18.12.0-1nodesource1: command not found
        pi@raspi:~ $      18.11.0-1nodesource1 1001
        -bash: 18.11.0-1nodesource1: command not found
        pi@raspi:~ $      18.10.0-1nodesource1 1001
        -bash: 18.10.0-1nodesource1: command not found
        pi@raspi:~ $      18.9.1-1nodesource1 1001
        -bash: 18.9.1-1nodesource1: command not found
        pi@raspi:~ $      18.9.0-1nodesource1 1001
        -bash: 18.9.0-1nodesource1: command not found
        pi@raspi:~ $      18.8.0-1nodesource1 1001
        -bash: 18.8.0-1nodesource1: command not found
        pi@raspi:~ $      18.7.0-1nodesource1 1001
        -bash: 18.7.0-1nodesource1: command not found
        pi@raspi:~ $      18.6.0-1nodesource1 1001
        -bash: 18.6.0-1nodesource1: command not found
        pi@raspi:~ $      18.5.0-1nodesource1 1001
        -bash: 18.5.0-1nodesource1: command not found
        pi@raspi:~ $      18.4.0-1nodesource1 1001
        -bash: 18.4.0-1nodesource1: command not found
        pi@raspi:~ $      18.3.0-1nodesource1 1001
        -bash: 18.3.0-1nodesource1: command not found
        pi@raspi:~ $      18.2.0-1nodesource1 1001
        -bash: 18.2.0-1nodesource1: command not found
        pi@raspi:~ $      18.1.0-1nodesource1 1001
        -bash: 18.1.0-1nodesource1: command not found
        pi@raspi:~ $      18.0.0-1nodesource1 1001
        -bash: 18.0.0-1nodesource1: command not found
        pi@raspi:~ $
        pi@raspi:~ $ Temp directories causing npm8 problem: 0
        -bash: Temp: command not found
        pi@raspi:~ $ No problems detected
        -bash: No: command not found
        pi@raspi:~ $
        pi@raspi:~ $ Errors in npm tree:
        -bash: Errors: command not found
        pi@raspi:~ $
        pi@raspi:~ $ *** ioBroker-Installation ***
        pi@raspi:~ $
        pi@raspi:~ $ ioBroker Status
        -bash: ioBroker: command not found
        pi@raspi:~ $ iobroker is running on this host.
        Objects type: jsonl
        States  type: redis
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + system.adapter.web.0                    : web       iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
          iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
          iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all native modules or path
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
          iobroker object                                              Object management  [aliases: o]
          iobroker state                                               State management  [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation  [aliases: id]
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
          iobroker plugin                                              Plugin management
          iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        pi@raspi:~ $
        Blickt da einer genau durch??
        • N norman
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           104M          0B        104M
                   1848 M total memory
                   1268 M used memory
                    330 M free memory
                     24 M buffer memory
                    294 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          611M    /var/log
          203M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6085
          States:         16953
          Pending Updates: 7
                                  v.2023-10-10
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           104M          0B        104M
                   1848 M total memory
                   1268 M used memory
                    330 M free memory
                     24 M buffer memory
                    294 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          611M    /var/log
          203M    /var/cache
                 Icon name: computer
              Architecture: arm64
          Kernel:                 aarch64
          Userland:               arm64
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
          MEMORY:
          Swap:           104M          0B        104M
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: redis
          Objects:                6085
          States:                 16953
          pi@raspi:~ $
          pi@raspi:~ $ ```
          > Skript v.2023-10-10
          > *** BASE SYSTEM ***
          >        Icon name: computer
          >     Architecture: arm64
          > Docker          : false
          > Kernel          : aarch64
          > Userland        : arm64
          > CPU threads: 4
          > Current issues:
          >                  RTC time: n/a
          >               NTP service: active
          >           RTC in local TZ: no
          > pi
          > /home/pi
          > X-Server:       false
          > Desktop:
          > Terminal:       tty
          > *** MEMORY ***
          > Swap:           104M          0B        104M
          >          1848 M total memory
          >          1268 M used memory
          >           330 M free memory
          >            24 M buffer memory
          >           294 M swap cache
          >            99 M total swap
          >             0 M used swap
          >            99 M free swap
          > Raspberry only:
          > oom events: 0
          > *** FILESYSTEM ***
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $ /var:
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
            throw err;
            requireStack: []
          Node.js v18.19.0
            throw err;
            requireStack: []
          Node.js v18.19.0
            npm help
          npm ERR! code E404
          npm ERR! 404
          npm ERR! 404
            0. corepack -h
            1. corepack -v
            5. corepack install
            7. corepack up
          pi@raspi:~ $
          pi@raspi:~ $
                : raspi                                    - disabled
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          pi@raspi:~ $
          Objects type: jsonl
          States  type: redis
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          Commands:
          Options:
          pi@raspi:~ $
          @norman sagte in IObroker startet jeden Abend neu!:
          Nein. Aber du hast auch irgendwas wirres in die Konsole geklatscht und das führt dann zu dem chaotischen Output.
          Also nochmal sauber die Ausgabe von iob diag bitte.
          -1
          • J Offline
            JohnnyBahama
            schrieb am zuletzt editiert von JohnnyBahama
            Bevor weiter rumprobiert wird, es ist derArbeitsspeicher. Der reicht nicht mehr. Mein System lief vorher auch Jahre, aber seit dem letztem Admin Update stürzte der immer wieder ab, auch wenn andere sagen das kann damit nichts zu tun haben.
            Neue Kiste mit mehr Arbeitsspeicher und läuft jetzt wieder seit 50 Tagen ohne Ausfälle.
            Kannst dir meinen Thread dazu anschauen, hat die gleichen Werte ausgeworfen
            https://forum.iobroker.net/topic/68713/gelöst-admin-adapter-restart-loop/3
            wendy2702W N 2 Antworten Letzte Antwort
            • J JohnnyBahama
              wendy2702W Online
              wendy2702W Online
              @johnnybahama das hat @Homoran schon im dritten Post geschrieben
              https://forum.iobroker.net/topic/72131/iobroker-startet-jeden-abend-neu/3#
                N Offline
                N Offline
                norman
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 09:29:50 up 14:23,  2 users,  load average: 0.13, 0.10, 0.09
                CPU threads: 4
                Current issues:
                               Local time: Thu 2024-01-25 09:29:50 CET
                           Universal time: Thu 2024-01-25 08:29:50 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            1.9G        1.7G        108M        229K        225M        262M
                Swap:           104M        7.6M         97M
                Total:          2.0G        1.7G        205M
                         1848 M total memory
                         1597 M used memory
                          976 M active memory
                          624 M inactive memory
                          103 M free memory
                            1 M buffer memory
                          213 M swap cache
                           99 M total swap
                            7 M used swap
                           92 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.1G    /var/
                627M    /var/log
                625M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                203M    /var/cache
                Archived and active journals take up 624.8M in the file system.
                345M    /opt/iobroker/iobroker-data/
                43M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                 Objects database error: read ECONNRESET
                 Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                Objects and States
                Objects:        6085
                States:         16776
                Pending Updates: 7
                tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       542361     26603/io.mqtt.0
                tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       542362     26603/io.mqtt.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       539776     26064/iobroker.js-c
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       539836     26082/io.admin.0
                2024-01-25 09:33:05.695  - info: javascript.0 (26128) Start javascript script.js.common.Waschmaschine_fertig_Ansage
                2024-01-25 09:33:05.703  - info: javascript.0 (26128) script.js.common.Waschmaschine_fertig_Ansage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                2024-01-25 09:33:05.778  - info: whatsapp-cmb.0 (26147) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v18.19.0, js-controller: 5.0.17
                2024-01-25 09:33:06.702  - info: host.raspi instance scheduled system.adapter.ical.1 0 3 * * *
                2024-01-25 09:33:06.718  - info: host.raspi instance system.adapter.ical.1 started with pid 26215
                2024-01-25 09:33:08.050  - info: ical.0 (26185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                2024-01-25 09:33:08.502  - info: ical.0 (26185) processing URL: Abfall /opt/iobroker/Abfall2024.ics
                2024-01-25 09:33:10.149  - info: ical.1 (26215) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                2024-01-25 09:33:10.250  - info: alexa2.0 (26157) Initialize all Device states ...
                2024-01-25 09:33:10.688  - info: host.raspi instance system.adapter.mqtt.0 started with pid 26603
                2024-01-25 09:33:10.898  - info: ical.1 (26215) processing URL: Frei https://calendar.google.com/calendar/ical/l8asmcgpumc56d3n6opmji52to%40group.calendar.google.com/public/basic.ics
                2024-01-25 09:33:12.112  - warn: ical.0 (26185) Error reading from URL "http://www.eventfabrik24.de/Abfall2023.ics": 404
                2024-01-25 09:33:12.119  - warn: ical.0 (26185) Error reading "http://www.eventfabrik24.de/Abfall2023.ics": Cannot read URL: "http://www.eventfabrik24.de/Abfall2023.ics"
                2024-01-25 09:33:14.677  - info: host.raspi instance scheduled system.adapter.openweathermap.0 0 23 * * *
                2024-01-25 09:33:14.692  - info: host.raspi instance system.adapter.openweathermap.0 started with pid 26625
                2024-01-25 09:33:16.006  - info: ical.1 (26215) Terminated (NO_ERROR): Without reason
                2024-01-25 09:33:16.687  - info: host.raspi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                2024-01-25 09:33:17.233  - info: ical.0 (26185) Terminated (NO_ERROR): Without reason
                2024-01-25 09:33:18.010  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                2024-01-25 09:33:18.790  - info: host.raspi instance system.adapter.rpi2.0 started with pid 27004
                2024-01-25 09:33:20.344  - info: openweathermap.0 (26625) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.0, js-controller: 5.0.17
                2024-01-25 09:33:22.289  - info: rpi2.0 (27004) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.19.0, js-controller: 5.0.17
                2024-01-25 09:33:22.678  - error: rpi2.0 (27004) No Value found for cpu_frequency
                2024-01-25 09:33:22.690  - info: host.raspi instance system.adapter.sonoff.0 started with pid 27052
                2024-01-25 09:33:26.745  - info: host.raspi instance system.adapter.tr-064.1 started with pid 27060
                iob diag has finished.
                Press any key for a summary
                • N norman
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M        7.6M         97M
                           1848 M total memory
                           1597 M used memory
                            976 M active memory
                            103 M free memory
                              1 M buffer memory
                            213 M swap cache
                             99 M total swap
                              7 M used swap
                             92 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.1G    /var/
                  627M    /var/log
                  203M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: redis
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        6085
                  States:         16776
                  Pending Updates: 7
                  *** MEMORY ***
                  Das wird zu wenig sein. Bei Lastspitzen knickt dir das weg.
                  • J JohnnyBahama
                    N Offline
                    N Offline
                    norman
                    @johnnybahama
                    nicht, dass ich dir nicht glauben will, will das nur etwas genauer verstehen. er kommt bei mir ja gar nicht über die 1500MB Speicherbedarf drüber bevor er abschmiert, da is ja eigentlich noch etwas Luft.....
                    Thomas BraunT J 2 Antworten Letzte Antwort
                    • N norman
                      @johnnybahama
                      @norman
                      Da sind noch 262MB verfügbar. So viel Luft ist da also nicht mehr.
                      Wenn jetzt ein Adapter sich mehr genehmigen muss (z. B. weil ein Backup läuft) hast du ein Problem.
                        @norman
                        N Offline
                        N Offline
                        norman
                        @thomas-braun said in IObroker startet jeden Abend neu!:
                        @norman
                        ja, knapp is es schon....aber es gibt doch noch mehr Leute hier, die IOb auf nem 2GBPi4 rennen haben.....
                        Oder ich hab zuviel Instanzen am laufen :-(
                        Also auf n Pi5 gehen??
                        Thomas BraunT HomoranH MartinPM Marc BergM 4 Antworten Letzte Antwort
                        • N norman
                          @norman
                          Die haben dann aber nicht wie du da 18 Instanzen laufen.
                          Man kann mit einem durchschnittlichen Bedarf von 80-100MB pro Instanz rechnen. Da bist du also alleine mit dem iobroker schon fast dicht. Und das Betriebssystem braucht ja auch noch was Luft zum atmen.
                          • N norman
                            @norman
                            muss kein pi5 sein, gibt auch pi4 mit 4 und 8 GB.
                            woher weisst du das?
                            Da wird wahrscheinlich intern schon Speicher freigeräumt indem Prozesse gestoppt werden.
                            ...bis dann lebenswichtige Prozesse dran glauben müssen.
                            • N norman
                              @norman
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              @norman said in IObroker startet jeden Abend neu!:
                              @norman
                              Ein Pi4 mit mehr Arbeitsspeicher, oder ein Mini-PC (NUC o.Ä.) wäre auch eine Option, wenn die IO-Pins des Pi nicht gebraucht werden....
                              Eine weitere Option wäre, ggfs die ioBroker Installation zu verschlanken. Adapter, die man probeweise installiert hat anhalten oder deinstallieren, Aufgaben an Slave-ioBroker auslagern usw... In aller Regel ist das aber keine Lösung, die dauerhaft funktioniert ...
                              Mein in der Signatur genanntes System kommt mit unter 10 Watt aus ... Tagesverbrauch ca 0,2 kWh ...
                              Mein Celeron 3000 ist aber ziemlich lahm (irgendwo zwischen Pi3 und Pi4), das System hat aber auch ohne RAM und SSD nur 69€ incl Gehäuse und Netzteil als "Refurbished" gekostet...
                              • N norman
                                @norman
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                Ich finde, du hättest schon noch ein wenig Optimierungspotential, um die Zeit bis zur neuen Hardware zu überbrücken. Den Info-Adapter würde ich wegwerfen und ob man bei DER Anzahl von States eine redis-DB betreiben muss? Ich weiß nicht ...
                                Wenn das Geld ein Thema ist und du mit der CPU Leistung zufrieden bist, warum nicht einen gebrauchten Pi4 mit 4 oder 8 GB RAM?
                                  N Offline
                                  N Offline
                                  norman
                                  @homoran said in IObroker startet jeden Abend neu!:
                                  Joa, stimmt schon, macht aber preislich ja schon kaum noch einen Unterschied, da kann man das gleich auf den 5er gehen.
                                  Oder hat der HW-technisch irgendwelche Nachteile beim IOB-Betrieb?
                                  HomoranH MartinPM 2 Antworten Letzte Antwort
                                  • N norman
                                    mal schnell bei einem Händler verglichen: bei 8GB 95 vs 79 Euro (Ohne Gewähr auf Vollständigkeit)
                                    außer dem höheren Stromverbrauch eher nicht.
                                    • N norman
                                      MartinPM Online
                                      MartinPM Online
                                      MartinP
                                      @norman Es wurde ja vorgeschlagen einen gebrauchten Pi4 zu versuchen, aber da habe ich schon gewisse Vorbehalte. Ein geschrotteter IO-Pin ist nicht schnell erkennbar, und ansonsten könnte der Pi dann bei ersten Tests unauffällig sein ....
                                        N Offline
                                        N Offline
                                        norman
                                        ja, bei Berrybase 93,90€ zu 79,90, bei 4GB Ram sind sogar knapp unter 10€ Preisunterschied
                                        • MartinPM MartinP
                                          N Offline
                                          N Offline
                                          norman
                                          @martinp said in IObroker startet jeden Abend neu!:
                                          Joa, hab eben auch mal kurz auf Kleinanzeigen geschaut, die sind ja z.T. teuerer als neue im Netz, die haben zum Teil echt seltsame Preisvorstellungen.
                                          okay, DANKE nochmals @all !
                                          Ich habe jetzt mal ein paar nicht so wichtige Instanzen bzw. Spielerein deaktiviert und schaue mal, ob er jetzt so stabiler läuft.
                                          Wenns so klappt, stell ich um ;-)
                                          Ich geb auf jeden Fall Rückmeldung!
