  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • viper2033V viper2033
    @thomas-braun said in Web Interface nach Update nicht erreichbar:
    sudo -H -u iobroker npm install iobroker.js-controller
    Es kommt folgende Meldung:
    code_textnpm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/diskusage
    npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
    @viper2033
    Dann
    iob stop
    iob fix
    cd /opt/iobroker
    viper2033V 1 Antwort Letzte Antwort
      @viper2033
      Dann
      iob stop
      iob fix
      cd /opt/iobroker
      viper2033V Offline
      viper2033V Offline
      viper2033
      Folgende Fehlermeldung:
      code_text
      pm WARN cleanup Failed to remove some directories [
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
      npm WARN cleanup       errno: -39,
      npm WARN cleanup       code: 'ENOTEMPTY',
      npm WARN cleanup       syscall: 'rmdir',
      npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
      npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
      npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      npm ERR!
      npm ERR! SyntaxError: Invalid or unexpected token
      npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
      npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
      npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
      npm ERR!     at require (node:internal/modules/helpers:177:18)
      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      npm ERR!
      npm ERR! Node.js v18.19.0```
        code_text
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR!
        npm ERR!
        @viper2033 sagte in Web Interface nach Update nicht erreichbar:
        npm ERR!
        Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
          code_text
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR!
          npm ERR!
          wo bist du da?
          bitte immer alles komplett zeigen.
          Ein- und Ausgaben
            wo bist du da?
            Ein- und Ausgaben
            viper2033V Offline
            viper2033V Offline
            viper2033
            Jetzt zeigt er mir folgendes an nach eingabe von
            code_text
            npm ERR! errno -39
              code_text
              npm ERR! errno -39
              @viper2033
              Nochmal:
              iob stop
              iob fix
              cd /opt/iobroker
                code_text
                npm ERR! errno -39
                nach eingabe von
                das sehe ich nicht!
                bitte Prompt und Eingabebefehl zeigen!!
                  nach eingabe von
                  das sehe ich nicht!
                  viper2033V Offline
                  viper2033V Offline
                  viper2033
                  code_text
                  root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                  npm ERR! errno -39
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                    code_text
                    npm ERR! errno -39
                    root@CT210
                    War mir klar...
                    Auch im LXC wird NICHT als root herumgehampelt.
                      @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                      Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                        viper2033V Offline
                        viper2033V Offline
                        viper2033
                        Und wie mache ich jetzt weiter?
                          Fragt der super root...
                          Da niemand hier nachvollziehen kann was du da wann und wie kaputtgemacht hast:
                          Installier es neu.
                            Installier es neu.
                            viper2033V Offline
                            viper2033V Offline
                            viper2033
                            Gibt es keine andere Lösung außer neu installieren?
                            Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                              @viper2033
                              Wenn du nicht weißt was du wann, warum mit welchen Rechten wo angepackt hast?
                              Nö.
                              Und die Neuinstallation dann direkt richtig machen...
                                Meister MopperM Online
                                Meister Mopper
                                Glaub' mal nur, dass es viele hier gab (und leider weiterhin geben wird), die sich mit dem root-login oder sudo iob die Rechte verbogen haben (ich gehöre auch dazu).
                                @Thomas-Braun ist tatsächlich unermüdlich, allen Sündern die Wahrheit notwendigerweise ins Gedächtnis einzuhämmern (vielen Dank übrigens dafür @Thomas-Braun) :
                                Ohne eine frische Installation kannst du nicht sicher sein, dass alles sauber ist.
                                Proxmox und HA ...
                                  viper2033V Offline
                                  viper2033V Offline
                                  viper2033
                                  @meister-mopper
                                  Ich habe jetzt meinen letzten Snapshot wieder installiert. Wie gehe ich jetzt weiter vor, einen neuen User erstellen?
