  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • viper2033V viper2033
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]: Node.js v18.19.0
    2024-01-18 13:13:15.309  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:13:15.309  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
    2024-01-18 13:13:24.362  - info: host.CT210 instance system.adapter.iot.0 started with pid 25033
    2024-01-18 13:13:25.155  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:2:17)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 13:13:25.156  - error: host.CT210 instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:13:25.156  - info: host.CT210 Restart adapter system.adapter.iot.0 because enabled
    @viper2033
    Das ist nicht die vollständige Ausgabe der Langfassung von iob diag.
    Und es steht nicht in CodeTags...
    viper2033V 1 Antwort Letzte Antwort
      @viper2033
      viper2033V Offline
      viper2033V Offline
      viper2033
      code_text
      *** BASE SYSTEM ***
         Static hostname: CT210
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.5.11-4-pve
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       13:38:19 up  5:00,  1 user,  load average: 0.39, 0.25, 0.20
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Thu 2024-01-18 13:38:19 UTC
                 Universal time: Thu 2024-01-18 13:38:19 UTC
                       RTC time: n/a
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      test
      /home/test
      test sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            2.0G        714M        860M        0.0K        472M        1.3G
      Swap:           512M          0B        512M
      Total:          2.6G        714M        1.4G
               2048 M total memory
                714 M used memory
                776 M active memory
                294 M inactive memory
                860 M free memory
                  0 M buffer memory
                472 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  59% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
      /var:
      898M    /var/
      418M    /var/log
      380M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
      344M    /var/cache
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      366M    /opt/iobroker/iobroker-data/
      319M    /opt/iobroker/iobroker-data/files
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.3.0
      /usr/bin/npx            10.3.0
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.23
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
      + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
      + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
        system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
      + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
      + system.adapter.history.0                : history               : CT210                                    -  enabled
        system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
      + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
        system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
      + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
        system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
        system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
        system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
      + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
      + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
        system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "ebus"         : 3.2.4    , installed 3.2.4
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
      Adapter    "openknx"      : 0.6.3    , installed 0.6.3
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
      Objects and States
      Objects:        2394
      States:         1947
      Hit:1 http://ftp.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org bullseye-security InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       90927369   5239/io.hm-rpc.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          90845716   314/master
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        90846217   95/systemd-resolved
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       90926356   5140/iobroker.js-co
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          90845300   1/init
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       90926339   5140/iobroker.js-co
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        90846211   95/systemd-resolved
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       90926936   5305/io.web.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       90926644   5210/io.sonos.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          90845483   1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          90845302   1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          90845717   314/master
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        90846214   95/systemd-resolved
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        90846216   95/systemd-resolved
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          90843085   85/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          90845301   1/init
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        90846210   95/systemd-resolved
      udp6       0      0 :::111                  :::*                                0          90845303   1/init
      udp6       0      0 :::5355                 :::*                                104        90846213   95/systemd-resolved
      2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
      2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
      2024-01-18 13:38:43.958  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-18 13:38:43.958  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
      2024-01-18 13:38:46.471  - info: host.CT210 instance system.adapter.admin.0 started with pid 27872
      2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
      2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
      2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
      2024-01-18 13:38:46.645  - error: host.CT210 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-18 13:38:46.645  - info: host.CT210 Restart adapter system.adapter.admin.0 because enabled
      v.2023-10-10
                 Chassis: container
          Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC (UTC, +0000)
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.3.0
                              /usr/bin/npx            10.3.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            2.0G        726M        848M        0.0K        472M        1.3G
      Swap:           512M          0B        512M
      Total:          2.6G        726M        1.4G
      Active iob-Instances:   12
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                2394
      States:                 1947
      Size of iob-Database:
      9.7M    /opt/iobroker/iobroker-data/objects.jsonl
      844K    /opt/iobroker/iobroker-data/states.jsonl
      =================== END OF SUMMARY ====================```
        code_text
        *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        test
        /home/test
        test sudo iobroker
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           512M          0B        512M
                 2048 M total memory
                  714 M used memory
                  776 M active memory
                  860 M free memory
                    0 M buffer memory
                  472 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        *** FILESYSTEM ***
        /var:
        898M    /var/
        418M    /var/log
        344M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.3.0
        /usr/bin/npx            10.3.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2394
        States:         1947
        Pending Updates: 0
        v.2023-10-10
                   Chassis: container
            Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            10.3.0
                                /usr/bin/npx            10.3.0
        MEMORY:
        Swap:           512M          0B        512M
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                2394
        States:                 1947
        @viper2033 sagte in Web Interface nach Update nicht erreichbar:
        Falsche Zeitzone. Stell das auf deine Zeitzone um.
        Boot Target: graphical.target
        Stell das auf multi-user.target um.
        sudo systemctl set-default multi-user.target
        Setz den user test in die Gruppe adm rein.
        sudo usermod -a -G adm test
        Veraltet, bring das auf den aktuellen Stand.
        iob update
        iob stop
        iob upgrade self
        iob start
        iob start admin
          iob update
          iob stop
          iob upgrade self
          iob start
          iob start admin
          viper2033V Offline
          viper2033V Offline
          viper2033
          @thomas-braun said in Web Interface nach Update nicht erreichbar:
          iob start admin
          Habe ich alles gemacht, funktioniert leider nicht :-(.
            iob start admin
            Dann nochmal
            iob diag
            Diesmal bitte besser lesbar inkl. der CodeTags.
              iob start admin
              @viper2033
              Sehe ich gerade erst:
              /usr/bin/npm            10.3.0
              /usr/bin/npx            10.3.0
              Das ist nicht die Version, die mit nodejs 18.19.0 gebündelt kommt. Von Hand irgendwas gefummelt? Muss ja...
              sudo apt install --reinstall nodejs
                @viper2033
                /usr/bin/npm            10.3.0
                /usr/bin/npx            10.3.0
                viper2033V Offline
                viper2033V Offline
                viper2033
                Habe nodejs geupdatet leider kein Erfolg:
                code_text`
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                 16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
                CPU threads: 2
                               Local time: Thu 2024-01-18 16:00:19 CET
                           Universal time: Thu 2024-01-18 15:00:19 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                test
                /home/test
                test adm sudo iobroker
                X-Server:       false
                Desktop:
                Terminal:
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
                Swap:           512M          0B        512M
                Total:          2.6G        575M        1.8G
                         2048 M total memory
                          576 M used memory
                          641 M active memory
                           74 M inactive memory
                         1285 M free memory
                            0 M buffer memory
                          185 M swap cache
                          512 M total swap
                            0 M used swap
                          512 M free swap
                *** FILESYSTEM ***
                /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
                /var:
                909M    /var/
                429M    /var/log
                388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
                344M    /var/cache
                Archived and active journals take up 387.6M in the file system.
                369M    /opt/iobroker/iobroker-data/
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Temp directories causing npm8 problem: 1
                Some problems detected, please run iob fix
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
                npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2394
                States:         1949
                Hit:1 http://security.debian.org bullseye-security InRelease
                Hit:2 http://ftp.debian.org/debian bullseye InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
                tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
                tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
                tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
                tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
                udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
                udp6       0      0 :::111                  :::*                                0          91447178   1/init
                udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
                2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
                2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
                2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
                2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
                2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
                code_text
                                        v.2023-10-10
                           Chassis: container
                    Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1001
                X-Server:               false
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                MEMORY:
                Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
                Swap:           512M          0B        512M
                Total:          2.6G        587M        1.6G
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                2394
                States:                 1949
                5.8M    /opt/iobroker/iobroker-data/objects.jsonl
                484K    /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===```
                  code_text`
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                  CPU threads: 2
                                   RTC time: n/a
                            RTC in local TZ: no
                  test
                  /home/test
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           512M          0B        512M
                           2048 M total memory
                            576 M used memory
                            641 M active memory
                           1285 M free memory
                              0 M buffer memory
                            185 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  *** FILESYSTEM ***
                  /var:
                  909M    /var/
                  429M    /var/log
                  344M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        2394
                  States:         1949
                  Pending Updates: 0
                  code_text
                                          v.2023-10-10
                             Chassis: container
                      Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               amd64
                  User-ID:                1001
                  X-Server:               false
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                  MEMORY:
                  Swap:           512M          0B        512M
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2394
                  States:                 1949
                  Das ist dein Problem.
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                    cd /opt/iobroker
                    viper2033V Offline
                    viper2033V Offline
                    viper2033
                    Es kommt folgende Meldung:
                    code_textnpm ERR! code ENOTEMPTY
                    npm ERR! syscall rename
                    npm ERR! path /opt/iobroker/node_modules/diskusage
                    npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
                    npm ERR! errno -39
                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
                      npm ERR! errno -39
                      @viper2033
                      Dann
                      iob stop
                      iob fix
                      cd /opt/iobroker
                        @viper2033
                        Dann
                        iob stop
                        iob fix
                        cd /opt/iobroker
                        viper2033V Offline
                        viper2033V Offline
                        viper2033
                        Folgende Fehlermeldung:
                        code_text
                        pm WARN cleanup Failed to remove some directories [
                        npm WARN cleanup   [
                        npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
                        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
                        npm WARN cleanup       errno: -39,
                        npm WARN cleanup       code: 'ENOTEMPTY',
                        npm WARN cleanup       syscall: 'rmdir',
                        npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
                        npm WARN cleanup     }
                        npm WARN cleanup   ],
                        npm WARN cleanup   [
                        npm WARN cleanup     }
                        npm WARN cleanup   ]
                        npm WARN cleanup ]
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                        npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
                        npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                        npm ERR!
                        npm ERR! SyntaxError: Invalid or unexpected token
                        npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
                        npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                        npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                        npm ERR!     at require (node:internal/modules/helpers:177:18)
                        npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
                        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                        npm ERR!
                        npm ERR! Node.js v18.19.0```
                          code_text
                          npm WARN cleanup   [
                          npm WARN cleanup     }
                          npm WARN cleanup   ],
                          npm WARN cleanup   [
                          npm WARN cleanup     }
                          npm WARN cleanup   ]
                          npm WARN cleanup ]
                          npm ERR! code 1
                          npm ERR!
                          npm ERR!
        npm ERR!
                          Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
                            code_text
                            npm WARN cleanup   [
                            npm WARN cleanup     }
                            npm WARN cleanup   ],
                            npm WARN cleanup   [
                            npm WARN cleanup     }
                            npm WARN cleanup   ]
                            npm WARN cleanup ]
                            npm ERR! code 1
                            npm ERR!
                            npm ERR!
                            wo bist du da?
                            bitte immer alles komplett zeigen.
                            Ein- und Ausgaben
                              wo bist du da?
                              Ein- und Ausgaben
                              viper2033V Offline
                              viper2033V Offline
                              viper2033
                              Jetzt zeigt er mir folgendes an nach eingabe von
                              code_text
                              npm ERR! errno -39
                                code_text
                                npm ERR! errno -39
                                @viper2033
                                Nochmal:
                                iob stop
                                iob fix
                                cd /opt/iobroker
                                  code_text
                                  npm ERR! errno -39
                                  nach eingabe von
                                  das sehe ich nicht!
                                  bitte Prompt und Eingabebefehl zeigen!!
                                    nach eingabe von
                                    das sehe ich nicht!
                                    viper2033V Offline
                                    viper2033V Offline
                                    viper2033
                                    code_text
                                    root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                                    npm ERR! errno -39
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                                      code_text
                                      npm ERR! errno -39
                                      root@CT210
                                      War mir klar...
                                      Auch im LXC wird NICHT als root herumgehampelt.
                                        @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                                        Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                                          viper2033V Offline
                                          viper2033V Offline
                                          viper2033
                                          Und wie mache ich jetzt weiter?
