  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
    @viper2033
    iob diag
    sagt?
    viper2033V Offline
    viper2033V Offline
    viper2033
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]: Node.js v18.19.0
    2024-01-18 13:13:15.309  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:13:15.309  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
    2024-01-18 13:13:24.362  - info: host.CT210 instance system.adapter.iot.0 started with pid 25033
    2024-01-18 13:13:25.155  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:2:17)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 13:13:25.156  - error: host.CT210 instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:13:25.156  - info: host.CT210 Restart adapter system.adapter.iot.0 because enabled
    • viper2033V viper2033
      @viper2033
      Das ist nicht die vollständige Ausgabe der Langfassung von iob diag.
      Und es steht nicht in CodeTags...
      viper2033V 1 Antwort Letzte Antwort
        @viper2033
        viper2033V Offline
        viper2033V Offline
        viper2033
        code_text
        *** BASE SYSTEM ***
           Static hostname: CT210
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.5.11-4-pve
              Architecture: x86-64
        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         13:38:19 up  5:00,  1 user,  load average: 0.39, 0.25, 0.20
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Thu 2024-01-18 13:38:19 UTC
                   Universal time: Thu 2024-01-18 13:38:19 UTC
                         RTC time: n/a
                        Time zone: Etc/UTC (UTC, +0000)
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        test
        /home/test
        test sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            2.0G        714M        860M        0.0K        472M        1.3G
        Swap:           512M          0B        512M
        Total:          2.6G        714M        1.4G
                 2048 M total memory
                  714 M used memory
                  776 M active memory
                  294 M inactive memory
                  860 M free memory
                    0 M buffer memory
                  472 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        *** FAILED SERVICES ***
          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
        * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
        3 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  59% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
        /var:
        898M    /var/
        418M    /var/log
        380M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
        344M    /var/cache
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        34M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        366M    /opt/iobroker/iobroker-data/
        319M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.3.0
        /usr/bin/npx            10.3.0
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org bullseye-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.23
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
        + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
        + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
          system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
        + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
        + system.adapter.history.0                : history               : CT210                                    -  enabled
          system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
        + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
          system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
        + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
          system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
          system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
          system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
        + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
        + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
          system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "ebus"         : 3.2.4    , installed 3.2.4
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
        Adapter    "openknx"      : 0.6.3    , installed 0.6.3
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
        Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
        Objects and States
        Objects:        2394
        States:         1947
        Hit:1 http://ftp.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org bullseye-security InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       90927369   5239/io.hm-rpc.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          90845716   314/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        90846217   95/systemd-resolved
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       90926356   5140/iobroker.js-co
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          90845300   1/init
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       90926339   5140/iobroker.js-co
        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        90846211   95/systemd-resolved
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       90926936   5305/io.web.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       90926644   5210/io.sonos.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          90845483   1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          90845302   1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          90845717   314/master
        tcp6       0      0 :::5355                 :::*                    LISTEN      104        90846214   95/systemd-resolved
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        90846216   95/systemd-resolved
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          90843085   85/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          90845301   1/init
        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        90846210   95/systemd-resolved
        udp6       0      0 :::111                  :::*                                0          90845303   1/init
        udp6       0      0 :::5355                 :::*                                104        90846213   95/systemd-resolved
        2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
        2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
        2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
        2024-01-18 13:38:43.958  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-18 13:38:43.958  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
        2024-01-18 13:38:46.471  - info: host.CT210 instance system.adapter.admin.0 started with pid 27872
        2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
        2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
        2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
        2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
        2024-01-18 13:38:46.645  - error: host.CT210 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-18 13:38:46.645  - info: host.CT210 Restart adapter system.adapter.admin.0 because enabled
        v.2023-10-10
                   Chassis: container
            Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC (UTC, +0000)
        User-ID:                1001
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.3.0
                                /usr/bin/npx            10.3.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:            2.0G        726M        848M        0.0K        472M        1.3G
        Swap:           512M          0B        512M
        Total:          2.6G        726M        1.4G
        Active iob-Instances:   12
        ioBroker Core:          js-controller           4.0.23
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                2394
        States:                 1947
        Size of iob-Database:
        9.7M    /opt/iobroker/iobroker-data/objects.jsonl
        844K    /opt/iobroker/iobroker-data/states.jsonl
        =================== END OF SUMMARY ====================```
          code_text
          *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          test
          /home/test
          test sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           512M          0B        512M
                   2048 M total memory
                    714 M used memory
                    776 M active memory
                    860 M free memory
                      0 M buffer memory
                    472 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          *** FILESYSTEM ***
          /var:
          898M    /var/
          418M    /var/log
          344M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.3.0
          /usr/bin/npx            10.3.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2394
          States:         1947
          Pending Updates: 0
          v.2023-10-10
                     Chassis: container
              Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1001
          X-Server:               false
                                  /usr/bin/npm            10.3.0
                                  /usr/bin/npx            10.3.0
          MEMORY:
          Swap:           512M          0B        512M
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                2394
          States:                 1947
          @viper2033 sagte in Web Interface nach Update nicht erreichbar:
          Falsche Zeitzone. Stell das auf deine Zeitzone um.
          Boot Target: graphical.target
          Stell das auf multi-user.target um.
          sudo systemctl set-default multi-user.target
          Setz den user test in die Gruppe adm rein.
          sudo usermod -a -G adm test
          Veraltet, bring das auf den aktuellen Stand.
          iob update
          iob stop
          iob upgrade self
          iob start
          iob start admin
            iob update
            iob stop
            iob upgrade self
            iob start
            iob start admin
            viper2033V Offline
            viper2033V Offline
            viper2033
            @thomas-braun said in Web Interface nach Update nicht erreichbar:
            iob start admin
            Habe ich alles gemacht, funktioniert leider nicht :-(.
              iob start admin
              Dann nochmal
              iob diag
              Diesmal bitte besser lesbar inkl. der CodeTags.
                iob start admin
                @viper2033
                Sehe ich gerade erst:
                /usr/bin/npm            10.3.0
                /usr/bin/npx            10.3.0
                Das ist nicht die Version, die mit nodejs 18.19.0 gebündelt kommt. Von Hand irgendwas gefummelt? Muss ja...
                sudo apt install --reinstall nodejs
                  @viper2033
                  /usr/bin/npm            10.3.0
                  /usr/bin/npx            10.3.0
                  viper2033V Offline
                  viper2033V Offline
                  viper2033
                  Habe nodejs geupdatet leider kein Erfolg:
                  code_text`
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
                  CPU threads: 2
                                 Local time: Thu 2024-01-18 16:00:19 CET
                             Universal time: Thu 2024-01-18 15:00:19 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  test
                  /home/test
                  test adm sudo iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
                  Swap:           512M          0B        512M
                  Total:          2.6G        575M        1.8G
                           2048 M total memory
                            576 M used memory
                            641 M active memory
                             74 M inactive memory
                           1285 M free memory
                              0 M buffer memory
                            185 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
                  /var:
                  909M    /var/
                  429M    /var/log
                  388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
                  344M    /var/cache
                  Archived and active journals take up 387.6M in the file system.
                  369M    /opt/iobroker/iobroker-data/
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Temp directories causing npm8 problem: 1
                  Some problems detected, please run iob fix
                  Errors in npm tree:
                  npm ERR! code ELSPROBLEMS
                  npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                  npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
                  npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        2394
                  States:         1949
                  Hit:1 http://security.debian.org bullseye-security InRelease
                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
                  tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
                  tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
                  tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
                  udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
                  udp6       0      0 :::111                  :::*                                0          91447178   1/init
                  udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
                  2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
                  2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                  2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                  2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
                  2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                  2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                  2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                  2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
                  2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
                  2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
                  code_text
                                          v.2023-10-10
                             Chassis: container
                      Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               amd64
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1001
                  X-Server:               false
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                  MEMORY:
                  Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
                  Swap:           512M          0B        512M
                  Total:          2.6G        587M        1.6G
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2394
                  States:                 1949
                  5.8M    /opt/iobroker/iobroker-data/objects.jsonl
                  484K    /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===```
                    code_text`
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 2
                                     RTC time: n/a
                              RTC in local TZ: no
                    test
                    /home/test
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           512M          0B        512M
                             2048 M total memory
                              576 M used memory
                              641 M active memory
                             1285 M free memory
                                0 M buffer memory
                              185 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    /var:
                    909M    /var/
                    429M    /var/log
                    344M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2394
                    States:         1949
                    Pending Updates: 0
                    code_text
                                            v.2023-10-10
                               Chassis: container
                        Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               amd64
                    User-ID:                1001
                    X-Server:               false
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    MEMORY:
                    Swap:           512M          0B        512M
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2394
                    States:                 1949
                    Das ist dein Problem.
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                      cd /opt/iobroker
                      viper2033V Offline
                      viper2033V Offline
                      viper2033
                      Es kommt folgende Meldung:
                      code_textnpm ERR! code ENOTEMPTY
                      npm ERR! syscall rename
                      npm ERR! path /opt/iobroker/node_modules/diskusage
                      npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
                        npm ERR! errno -39
                        @viper2033
                        Dann
                        iob stop
                        iob fix
                        cd /opt/iobroker
                          @viper2033
                          Dann
                          iob stop
                          iob fix
                          cd /opt/iobroker
                          viper2033V Offline
                          viper2033V Offline
                          viper2033
                          Folgende Fehlermeldung:
                          code_text
                          pm WARN cleanup Failed to remove some directories [
                          npm WARN cleanup   [
                          npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
                          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
                          npm WARN cleanup       errno: -39,
                          npm WARN cleanup       code: 'ENOTEMPTY',
                          npm WARN cleanup       syscall: 'rmdir',
                          npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
                          npm WARN cleanup     }
                          npm WARN cleanup   ],
                          npm WARN cleanup   [
                          npm WARN cleanup     }
                          npm WARN cleanup   ]
                          npm WARN cleanup ]
                          npm ERR! code 1
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR! command failed
                          npm ERR! command sh -c node iobroker.js setup first
                          npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                          npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
                          npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                          npm ERR!
                          npm ERR! SyntaxError: Invalid or unexpected token
                          npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
                          npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                          npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                          npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                          npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                          npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                          npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                          npm ERR!     at require (node:internal/modules/helpers:177:18)
                          npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
                          npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                          npm ERR!
                          npm ERR! Node.js v18.19.0```
                            code_text
                            npm WARN cleanup   [
                            npm WARN cleanup     }
                            npm WARN cleanup   ],
                            npm WARN cleanup   [
                            npm WARN cleanup     }
                            npm WARN cleanup   ]
                            npm WARN cleanup ]
                            npm ERR! code 1
                            npm ERR!
                            npm ERR!
        npm ERR!
                            Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
                              code_text
                              npm WARN cleanup   [
                              npm WARN cleanup     }
                              npm WARN cleanup   ],
                              npm WARN cleanup   [
                              npm WARN cleanup     }
                              npm WARN cleanup   ]
                              npm WARN cleanup ]
                              npm ERR! code 1
                              npm ERR!
                              npm ERR!
                              wo bist du da?
                              bitte immer alles komplett zeigen.
                              Ein- und Ausgaben
                                wo bist du da?
                                Ein- und Ausgaben
                                viper2033V Offline
                                viper2033V Offline
                                viper2033
                                Jetzt zeigt er mir folgendes an nach eingabe von
                                code_text
                                npm ERR! errno -39
                                  code_text
                                  npm ERR! errno -39
                                  @viper2033
                                  Nochmal:
                                  iob stop
                                  iob fix
                                  cd /opt/iobroker
                                    code_text
                                    npm ERR! errno -39
                                    nach eingabe von
                                    das sehe ich nicht!
                                    bitte Prompt und Eingabebefehl zeigen!!
                                      nach eingabe von
                                      das sehe ich nicht!
                                      viper2033V Offline
                                      viper2033V Offline
                                      viper2033
                                      code_text
                                      root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                                      npm ERR! errno -39
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                                        code_text
                                        npm ERR! errno -39
                                        root@CT210
                                        War mir klar...
                                        Auch im LXC wird NICHT als root herumgehampelt.
                                          @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                                          Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
