  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
    @viper2033 sagte in Web Interface nach Update nicht erreichbar:
    js-controller: 4.0.23
    Das ist dein Problem.
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    viper2033V Offline
    viper2033V Offline
    viper2033
    @thomas-braun said in Web Interface nach Update nicht erreichbar:
    Es kommt folgende Meldung:
    code_textnpm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/diskusage
    npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
    • viper2033V viper2033
      npm ERR! errno -39
      @viper2033
      Dann
      iob stop
      iob fix
      cd /opt/iobroker
      viper2033V 1 Antwort Letzte Antwort
        @viper2033
        Dann
        iob stop
        iob fix
        cd /opt/iobroker
        viper2033V Offline
        viper2033V Offline
        viper2033
        Folgende Fehlermeldung:
        code_text
        pm WARN cleanup Failed to remove some directories [
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
        npm WARN cleanup       errno: -39,
        npm WARN cleanup       code: 'ENOTEMPTY',
        npm WARN cleanup       syscall: 'rmdir',
        npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
        npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
        npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
        npm ERR!
        npm ERR! SyntaxError: Invalid or unexpected token
        npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
        npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
        npm ERR!     at require (node:internal/modules/helpers:177:18)
        npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        npm ERR!
        npm ERR! Node.js v18.19.0```
          code_text
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR!
          npm ERR!
        npm ERR!
          Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
            code_text
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR!
            npm ERR!
            wo bist du da?
            bitte immer alles komplett zeigen.
            Ein- und Ausgaben
              wo bist du da?
              Ein- und Ausgaben
              viper2033V Offline
              viper2033V Offline
              viper2033
              Jetzt zeigt er mir folgendes an nach eingabe von
              code_text
              npm ERR! errno -39
                code_text
                npm ERR! errno -39
                @viper2033
                Nochmal:
                iob stop
                iob fix
                cd /opt/iobroker
                  code_text
                  npm ERR! errno -39
                  nach eingabe von
                  das sehe ich nicht!
                  bitte Prompt und Eingabebefehl zeigen!!
                    nach eingabe von
                    das sehe ich nicht!
                    viper2033V Offline
                    viper2033V Offline
                    viper2033
                    code_text
                    root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                    npm ERR! errno -39
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                      code_text
                      npm ERR! errno -39
                      root@CT210
                      War mir klar...
                      Auch im LXC wird NICHT als root herumgehampelt.
                        @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                        Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                          viper2033V Offline
                          viper2033V Offline
                          viper2033
                          Und wie mache ich jetzt weiter?
                            Fragt der super root...
                            Da niemand hier nachvollziehen kann was du da wann und wie kaputtgemacht hast:
                            Installier es neu.
                              Installier es neu.
                              viper2033V Offline
                              viper2033V Offline
                              viper2033
                              Gibt es keine andere Lösung außer neu installieren?
                              Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                @viper2033
                                Wenn du nicht weißt was du wann, warum mit welchen Rechten wo angepackt hast?
                                Nö.
                                Und die Neuinstallation dann direkt richtig machen...
                                  Meister MopperM Online
                                  Meister Mopper
                                  Glaub' mal nur, dass es viele hier gab (und leider weiterhin geben wird), die sich mit dem root-login oder sudo iob die Rechte verbogen haben (ich gehöre auch dazu).
                                  @Thomas-Braun ist tatsächlich unermüdlich, allen Sündern die Wahrheit notwendigerweise ins Gedächtnis einzuhämmern (vielen Dank übrigens dafür @Thomas-Braun) :
                                  Ohne eine frische Installation kannst du nicht sicher sein, dass alles sauber ist.
                                  Proxmox und HA ...
                                    viper2033V Offline
                                    viper2033V Offline
                                    viper2033
                                    @meister-mopper
                                    Ich habe jetzt meinen letzten Snapshot wieder installiert. Wie gehe ich jetzt weiter vor, einen neuen User erstellen?
