  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
    @viper2033
    Das ist nicht die vollständige Ausgabe der Langfassung von iob diag.
    Und es steht nicht in CodeTags...
    viper2033V Offline
    viper2033V Offline
    viper2033
    code_text
    *** BASE SYSTEM ***
       Static hostname: CT210
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.5.11-4-pve
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     13:38:19 up  5:00,  1 user,  load average: 0.39, 0.25, 0.20
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Thu 2024-01-18 13:38:19 UTC
               Universal time: Thu 2024-01-18 13:38:19 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    test
    /home/test
    test sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.0G        714M        860M        0.0K        472M        1.3G
    Swap:           512M          0B        512M
    Total:          2.6G        714M        1.4G
             2048 M total memory
              714 M used memory
              776 M active memory
              294 M inactive memory
              860 M free memory
                0 M buffer memory
              472 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  59% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
    /var:
    898M    /var/
    418M    /var/log
    380M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
    344M    /var/cache
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    34M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    366M    /opt/iobroker/iobroker-data/
    319M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.3.0
    /usr/bin/npx            10.3.0
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
      system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
    + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
    + system.adapter.history.0                : history               : CT210                                    -  enabled
      system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
    + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
      system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
      system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
      system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
    + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
    + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
      system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "ebus"         : 3.2.4    , installed 3.2.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
    Adapter    "openknx"      : 0.6.3    , installed 0.6.3
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
    Objects and States
    Objects:        2394
    States:         1947
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org bullseye-security InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       90927369   5239/io.hm-rpc.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          90845716   314/master
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        90846217   95/systemd-resolved
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       90926356   5140/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          90845300   1/init
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       90926339   5140/iobroker.js-co
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        90846211   95/systemd-resolved
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       90926936   5305/io.web.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       90926644   5210/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          90845483   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          90845302   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          90845717   314/master
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        90846214   95/systemd-resolved
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        90846216   95/systemd-resolved
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          90843085   85/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          90845301   1/init
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        90846210   95/systemd-resolved
    udp6       0      0 :::111                  :::*                                0          90845303   1/init
    udp6       0      0 :::5355                 :::*                                104        90846213   95/systemd-resolved
    2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
    2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 13:38:43.958  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:38:43.958  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
    2024-01-18 13:38:46.471  - info: host.CT210 instance system.adapter.admin.0 started with pid 27872
    2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
    2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
    2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 13:38:46.645  - error: host.CT210 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 13:38:46.645  - info: host.CT210 Restart adapter system.adapter.admin.0 because enabled
    v.2023-10-10
               Chassis: container
        Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC (UTC, +0000)
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.3.0
                            /usr/bin/npx            10.3.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            2.0G        726M        848M        0.0K        472M        1.3G
    Swap:           512M          0B        512M
    Total:          2.6G        726M        1.4G
    Active iob-Instances:   12
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                2394
    States:                 1947
    Size of iob-Database:
    9.7M    /opt/iobroker/iobroker-data/objects.jsonl
    844K    /opt/iobroker/iobroker-data/states.jsonl
    =================== END OF SUMMARY ====================```
    • viper2033V viper2033
      code_text
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      test
      /home/test
      test sudo iobroker
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           512M          0B        512M
               2048 M total memory
                714 M used memory
                776 M active memory
                860 M free memory
                  0 M buffer memory
                472 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      898M    /var/
      418M    /var/log
      344M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.3.0
      /usr/bin/npx            10.3.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2394
      States:         1947
      Pending Updates: 0
      v.2023-10-10
                 Chassis: container
          Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
                              /usr/bin/npm            10.3.0
                              /usr/bin/npx            10.3.0
      MEMORY:
      Swap:           512M          0B        512M
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                2394
      States:                 1947
      @viper2033 sagte in Web Interface nach Update nicht erreichbar:
      Falsche Zeitzone. Stell das auf deine Zeitzone um.
      Boot Target: graphical.target
      Stell das auf multi-user.target um.
      sudo systemctl set-default multi-user.target
      Setz den user test in die Gruppe adm rein.
      sudo usermod -a -G adm test
      Veraltet, bring das auf den aktuellen Stand.
      iob update
      iob stop
      iob upgrade self
      iob start
      iob start admin
      viper2033V 1 Antwort Letzte Antwort
        iob update
        iob stop
        iob upgrade self
        iob start
        iob start admin
        viper2033V Offline
        viper2033V Offline
        viper2033
        @thomas-braun said in Web Interface nach Update nicht erreichbar:
        iob start admin
        Habe ich alles gemacht, funktioniert leider nicht :-(.
          iob start admin
          Dann nochmal
          iob diag
          Diesmal bitte besser lesbar inkl. der CodeTags.
            iob start admin
            @viper2033
            Sehe ich gerade erst:
            /usr/bin/npm            10.3.0
            /usr/bin/npx            10.3.0
            Das ist nicht die Version, die mit nodejs 18.19.0 gebündelt kommt. Von Hand irgendwas gefummelt? Muss ja...
            sudo apt install --reinstall nodejs
              @viper2033
              /usr/bin/npm            10.3.0
              /usr/bin/npx            10.3.0
              viper2033V Offline
              viper2033V Offline
              viper2033
              Habe nodejs geupdatet leider kein Erfolg:
              code_text`
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: container
                  Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
              CPU threads: 2
                             Local time: Thu 2024-01-18 16:00:19 CET
                         Universal time: Thu 2024-01-18 15:00:19 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              test
              /home/test
              test adm sudo iobroker
              X-Server:       false
              Desktop:
              Terminal:
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
              Swap:           512M          0B        512M
              Total:          2.6G        575M        1.8G
                       2048 M total memory
                        576 M used memory
                        641 M active memory
                         74 M inactive memory
                       1285 M free memory
                          0 M buffer memory
                        185 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              *** FILESYSTEM ***
              /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
              /var:
              909M    /var/
              429M    /var/log
              388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
              344M    /var/cache
              Archived and active journals take up 387.6M in the file system.
              369M    /opt/iobroker/iobroker-data/
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Temp directories causing npm8 problem: 1
              Some problems detected, please run iob fix
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
              npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
              npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2394
              States:         1949
              Hit:1 http://security.debian.org bullseye-security InRelease
              Hit:2 http://ftp.debian.org/debian bullseye InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
              tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
              tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
              tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
              tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
              udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
              udp6       0      0 :::111                  :::*                                0          91447178   1/init
              udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
              2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
              2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
              2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
              2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
              2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
              2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
              2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
              2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
              code_text
                                      v.2023-10-10
                         Chassis: container
                  Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               amd64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1001
              X-Server:               false
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              MEMORY:
              Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
              Swap:           512M          0B        512M
              Total:          2.6G        587M        1.6G
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                2394
              States:                 1949
              5.8M    /opt/iobroker/iobroker-data/objects.jsonl
              484K    /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===```
                code_text`
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 2
                                 RTC time: n/a
                          RTC in local TZ: no
                test
                /home/test
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:           512M          0B        512M
                         2048 M total memory
                          576 M used memory
                          641 M active memory
                         1285 M free memory
                            0 M buffer memory
                          185 M swap cache
                          512 M total swap
                            0 M used swap
                          512 M free swap
                *** FILESYSTEM ***
                /var:
                909M    /var/
                429M    /var/log
                344M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2394
                States:         1949
                Pending Updates: 0
                code_text
                                        v.2023-10-10
                           Chassis: container
                    Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                1001
                X-Server:               false
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                MEMORY:
                Swap:           512M          0B        512M
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                2394
                States:                 1949
                Das ist dein Problem.
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  cd /opt/iobroker
                  viper2033V Offline
                  viper2033V Offline
                  viper2033
                  Es kommt folgende Meldung:
                  code_textnpm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/diskusage
                  npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
                    npm ERR! errno -39
                    @viper2033
                    Dann
                    iob stop
                    iob fix
                    cd /opt/iobroker
                      @viper2033
                      Dann
                      iob stop
                      iob fix
                      cd /opt/iobroker
                      viper2033V Offline
                      viper2033V Offline
                      viper2033
                      Folgende Fehlermeldung:
                      code_text
                      pm WARN cleanup Failed to remove some directories [
                      npm WARN cleanup   [
                      npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
                      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
                      npm WARN cleanup       errno: -39,
                      npm WARN cleanup       code: 'ENOTEMPTY',
                      npm WARN cleanup       syscall: 'rmdir',
                      npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
                      npm WARN cleanup     }
                      npm WARN cleanup   ],
                      npm WARN cleanup   [
                      npm WARN cleanup     }
                      npm WARN cleanup   ]
                      npm WARN cleanup ]
                      npm ERR! code 1
                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! command failed
                      npm ERR! command sh -c node iobroker.js setup first
                      npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                      npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
                      npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                      npm ERR!
                      npm ERR! SyntaxError: Invalid or unexpected token
                      npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
                      npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                      npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                      npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                      npm ERR!     at require (node:internal/modules/helpers:177:18)
                      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
                      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                      npm ERR!
                      npm ERR! Node.js v18.19.0```
                        code_text
                        npm WARN cleanup   [
                        npm WARN cleanup     }
                        npm WARN cleanup   ],
                        npm WARN cleanup   [
                        npm WARN cleanup     }
                        npm WARN cleanup   ]
                        npm WARN cleanup ]
                        npm ERR! code 1
                        npm ERR!
                        npm ERR!
        npm ERR!
                        Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
                          code_text
                          npm WARN cleanup   [
                          npm WARN cleanup     }
                          npm WARN cleanup   ],
                          npm WARN cleanup   [
                          npm WARN cleanup     }
                          npm WARN cleanup   ]
                          npm WARN cleanup ]
                          npm ERR! code 1
                          npm ERR!
                          npm ERR!
                          wo bist du da?
                          bitte immer alles komplett zeigen.
                          Ein- und Ausgaben
                            wo bist du da?
                            Ein- und Ausgaben
                            viper2033V Offline
                            viper2033V Offline
                            viper2033
                            Jetzt zeigt er mir folgendes an nach eingabe von
                            code_text
                            npm ERR! errno -39
                              code_text
                              npm ERR! errno -39
                              @viper2033
                              Nochmal:
                              iob stop
                              iob fix
                              cd /opt/iobroker
                                code_text
                                npm ERR! errno -39
                                nach eingabe von
                                das sehe ich nicht!
                                bitte Prompt und Eingabebefehl zeigen!!
                                  nach eingabe von
                                  das sehe ich nicht!
                                  viper2033V Offline
                                  viper2033V Offline
                                  viper2033
                                  code_text
                                  root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                                  npm ERR! errno -39
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                                    code_text
                                    npm ERR! errno -39
                                    root@CT210
                                    War mir klar...
                                    Auch im LXC wird NICHT als root herumgehampelt.
                                      @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                                      Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                                        viper2033V Offline
                                        viper2033V Offline
                                        viper2033
                                        Und wie mache ich jetzt weiter?
                                          Fragt der super root...
                                          Da niemand hier nachvollziehen kann was du da wann und wie kaputtgemacht hast:
                                          Installier es neu.
