  4. Web Interface nach Update nicht erreichbar
28 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • viper2033V viper2033
    Habe nodejs geupdatet leider kein Erfolg:
    code_text`
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: CT210
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.5.11-4-pve
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Thu 2024-01-18 16:00:19 CET
               Universal time: Thu 2024-01-18 15:00:19 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    test
    /home/test
    test adm sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
    Swap:           512M          0B        512M
    Total:          2.6G        575M        1.8G
             2048 M total memory
              576 M used memory
              641 M active memory
               74 M inactive memory
             1285 M free memory
                0 M buffer memory
              185 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
    /var:
    909M    /var/
    429M    /var/log
    388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
    344M    /var/cache
    Archived and active journals take up 387.6M in the file system.
    /opt/iobroker/backups:
    34M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    369M    /opt/iobroker/iobroker-data/
    319M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
    Temp directories causing npm8 problem: 1
    Some problems detected, please run iob fix
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
    npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
    npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
      system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
    + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
    + system.adapter.history.0                : history               : CT210                                    -  enabled
      system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
    + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
      system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
      system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
      system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
    + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
    + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
      system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "ebus"         : 3.2.4    , installed 3.2.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
    Adapter    "openknx"      : 0.6.3    , installed 0.6.3
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
    Objects and States
    Objects:        2394
    States:         1949
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://ftp.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
    tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
    udp6       0      0 :::111                  :::*                                0          91447178   1/init
    udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
    2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
    2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
    2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
    2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
    2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
    2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
    code_text
                            v.2023-10-10
               Chassis: container
        Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
    Swap:           512M          0B        512M
    Total:          2.6G        587M        1.6G
    Active iob-Instances:   12
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                2394
    States:                 1949
    Size of iob-Database:
    5.8M    /opt/iobroker/iobroker-data/objects.jsonl
    484K    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===```
    @viper2033 sagte in Web Interface nach Update nicht erreichbar:
    Das ist dein Problem.
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    viper2033V 1 Antwort Letzte Antwort
      cd /opt/iobroker
      viper2033V Offline
      viper2033V Offline
      viper2033
      @thomas-braun said in Web Interface nach Update nicht erreichbar:
      Es kommt folgende Meldung:
      code_textnpm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/diskusage
      npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
        npm ERR! errno -39
        @viper2033
        Dann
        iob stop
        iob fix
        cd /opt/iobroker
          @viper2033
          Dann
          iob stop
          iob fix
          cd /opt/iobroker
          viper2033V Offline
          viper2033V Offline
          viper2033
          Folgende Fehlermeldung:
          code_text
          pm WARN cleanup Failed to remove some directories [
          npm WARN cleanup   [
          npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
          npm WARN cleanup       errno: -39,
          npm WARN cleanup       code: 'ENOTEMPTY',
          npm WARN cleanup       syscall: 'rmdir',
          npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c node iobroker.js setup first
          npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
          npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
          npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
          npm ERR!
          npm ERR! SyntaxError: Invalid or unexpected token
          npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
          npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
          npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
          npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
          npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
          npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
          npm ERR!     at require (node:internal/modules/helpers:177:18)
          npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
          npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
          npm ERR!
          npm ERR! Node.js v18.19.0```
            code_text
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR!
            npm ERR!
        npm ERR!
            Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
              code_text
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ],
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ]
              npm WARN cleanup ]
              npm ERR! code 1
              npm ERR!
              npm ERR!
              wo bist du da?
              bitte immer alles komplett zeigen.
              Ein- und Ausgaben
                wo bist du da?
                Ein- und Ausgaben
                viper2033V Offline
                viper2033V Offline
                viper2033
                Jetzt zeigt er mir folgendes an nach eingabe von
                code_text
                npm ERR! errno -39
                  code_text
                  npm ERR! errno -39
                  @viper2033
                  Nochmal:
                  iob stop
                  iob fix
                  cd /opt/iobroker
                    code_text
                    npm ERR! errno -39
                    nach eingabe von
                    das sehe ich nicht!
                    bitte Prompt und Eingabebefehl zeigen!!
                      nach eingabe von
                      das sehe ich nicht!
                      viper2033V Offline
                      viper2033V Offline
                      viper2033
                      code_text
                      root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                      npm ERR! errno -39
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                        code_text
                        npm ERR! errno -39
                        root@CT210
                        War mir klar...
                        Auch im LXC wird NICHT als root herumgehampelt.
                          @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                          Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                            viper2033V Offline
                            viper2033V Offline
                            viper2033
                            Und wie mache ich jetzt weiter?
                              Fragt der super root...
                              Da niemand hier nachvollziehen kann was du da wann und wie kaputtgemacht hast:
                              Installier es neu.
                                Installier es neu.
                                viper2033V Offline
                                viper2033V Offline
                                viper2033
                                Gibt es keine andere Lösung außer neu installieren?
                                Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                  @viper2033
                                  Wenn du nicht weißt was du wann, warum mit welchen Rechten wo angepackt hast?
                                  Nö.
                                  Und die Neuinstallation dann direkt richtig machen...
                                    Meister MopperM Online
                                    Meister Mopper
                                    Glaub' mal nur, dass es viele hier gab (und leider weiterhin geben wird), die sich mit dem root-login oder sudo iob die Rechte verbogen haben (ich gehöre auch dazu).
                                    @Thomas-Braun ist tatsächlich unermüdlich, allen Sündern die Wahrheit notwendigerweise ins Gedächtnis einzuhämmern (vielen Dank übrigens dafür @Thomas-Braun) :
                                    Ohne eine frische Installation kannst du nicht sicher sein, dass alles sauber ist.
                                    Proxmox und HA ...
                                      viper2033V Offline
                                      viper2033V Offline
                                      viper2033
                                      @meister-mopper
                                      Ich habe jetzt meinen letzten Snapshot wieder installiert. Wie gehe ich jetzt weiter vor, einen neuen User erstellen?
