  4. Iobroker lässt sich nicht mehr starten.
80 Beiträge 7 Kommentatoren 8.8k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @michael_schotthoefer
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    Michael_Schotthoefer
    @glasfaser
    das kam dabei raus.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! node:internal/modules/cjs/loader:1137
    npm ERR! throw err;
    npm ERR! ^
    npm ERR!
    npm ERR! Error: Cannot find module 'tar'
    npm ERR! Require stack:
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    npm ERR! at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
    npm ERR! at Module._load (node:internal/modules/cjs/loader:975:27)
    npm ERR! at Module.require (node:internal/modules/cjs/loader:1225:19)
    npm ERR! at require (node:internal/modules/helpers:177:18)
    npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
    npm ERR! at Module._compile (node:internal/modules/cjs/loader:1356:14)
    npm ERR! at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    npm ERR! at Module.load (node:internal/modules/cjs/loader:1197:32)
    npm ERR! at Module._load (node:internal/modules/cjs/loader:1013:12)
    npm ERR! at Module.require (node:internal/modules/cjs/loader:1225:19) {
    npm ERR! code: 'MODULE_NOT_FOUND',
    npm ERR! requireStack: [
    npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
    npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
    npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    npm ERR! ]
    npm ERR! }
    npm ERR!
    npm ERR! Node.js v18.19.0
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-17T19_59_00_782Z-debug-0.log
    danke schonmal.
      @michael_schotthoefer sagte in Iobroker lässt sich nicht mehr starten.:
      Kernel : aarch64
      Userland : armhf
      Mix aus 32 und 64Bit. Installier das Betriebssystem NEU und sortenrein.
      Dann im neuen System deine Backups einspielen, fertig.
      hi thomas.
      heißt sd-karte formatieren und alles neu aufspielen?
      • M Michael_Schotthoefer
        hi thomas.
        Ich würde es auf eine konsistente und aktuelle Basis setzen.
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        M 2 Antworten Letzte Antwort
          dann werde ich das morgen mal angehen.
          ich werde berichten.
          danke schonmal.
            gibt es eine möglichkeit iobroker ein backup zu ziehen über putty?
            habe backitup laufen gehabt aber habe nicht gemerkt das es schon länger nicht mehr sichert. habe über filezilla jetzt mal das ganze iobroker gesichert auf dem nas.
            reicht das?
              reicht das?
              iobroker backup
              Datei liegt dann in /opt/iobroker/backups
              Wobei ich mir halt auch anschauen würde, warum dein Backitup nicht funktioniert. Insgesamt scheint mir deine Kiste leicht zu hinken...
                Kernel : aarch64
                Userland : armhf
                wenn ich es richtig sehe benötige ich 64bit oder?
                  iobroker backup
                  das hatte ich schon probiert.
                  geht leider nicht da anscheinend alles zerschossen ist.
                    Ja, wissen wir.
                      @glasfaser
                      das kam dabei raus.
                      npm ERR! code 1
                      npm ERR! throw err;
                      npm ERR! ^
                      npm ERR!
                      npm ERR! ]
                      npm ERR! }
                      npm ERR!
                      danke schonmal.
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Kannst du etwas testen :
                      iob stop
                      iob fix
                      iob nodejs-update
                      iob setup first
                      sudo reboot
                        Hi. Ich habe das Problem das mein Iobroker nicht mehr startet. Ich konnte schon feststellen das nodejs nicht richtig installiert war und konnte es fixen. Leider komme ich nun nicht mehr weiter.
                        Kann mir jemand noch helfen?
                        Anbei die Iobroker diag.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                           Static hostname: raspberrypi
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : armhf
                        Systemuptime and Load:
                         19:48:29 up 14 min,  1 user,  load average: 0.39, 0.50, 0.52
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Wed 2024-01-17 19:48:29 GMT
                                   Universal time: Wed 2024-01-17 19:48:29 UTC
                                         RTC time: n/a
                                        Time zone: Europe/London (GMT, +0000)
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            7.8G        231M        6.8G        1.0M        796M        7.5G
                        Swap:            99M          0B         99M
                        Total:          7.9G        231M        6.9G
                                 7812 M total memory
                                  231 M used memory
                                  421 M active memory
                                  411 M inactive memory
                                 6784 M free memory
                                   96 M buffer memory
                                  699 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                          UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                        * grafana-server.service loaded failed failed Grafana instance
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G   16G   13G  56% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                        [Wed Jan 17 19:34:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:E1:AA:91 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad490bbd-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Wed Jan 17 19:34:01 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Wed Jan 17 19:34:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Wed Jan 17 19:34:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        7.7G    /var/
                        5.8G    /var/log
                        2.9G    /var/log/journal/2c760f47d5f741e395b4738f4f48cd7d
                        1.4G    /var/lib
                        Archived and active journals take up 2.8G in the file system.
                        /opt/iobroker/backups:
                        257M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        1.7G    /opt/iobroker/iobroker-data/
                        926M    /opt/iobroker/iobroker-data/files
                        507M    /opt/iobroker/iobroker-data/history
                        136M    /opt/iobroker/iobroker-data/backup-objects
                        112M    /opt/iobroker/iobroker-data/files/vis-2-beta
                        94M     /opt/iobroker/iobroker-data/states.jsonl
                        46M     /opt/iobroker/iobroker-data/objects.jsonl
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                        USB-Devices by-id:
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.19.0
                        /usr/bin/node           v18.19.0
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                         *** 18.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u4 500
                        No problems detected
                        Errors in npm tree:
                        npm ERR! code ELSPROBLEMS
                        npm ERR! extraneous: bufferutil@ /opt/iobroker/node_modules/bufferutil
                        npm ERR! extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
                        npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                        npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-17T19_48_37_592Z-debug-0.log
                        *** ioBroker-Installation ***
                        ioBroker Status
                          throw err;
                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                            at node:internal/main/run_main_module:28:49 {
                          requireStack: []
                        Node.js v18.19.0
                        Core adapters versions
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        js-controller:
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        admin:
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        javascript:
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-17T19_48_40_428Z-debug-0.log
                        Adapters from github:   0
                        Adapter State
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        ioBroker-Repositories
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Installed ioBroker-Instances
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Objects and States
                        Objects:        0
                        States:         0
                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                        E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      111        14743      703/asterisk
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14559      521/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15797      709/influxd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14569      521/sshd: /usr/sbin
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        3998       709/influxd
                        udp        0      0 0.0.0.0:5060            0.0.0.0:*                           111        14755      703/asterisk
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14476      392/avahi-daemon: r
                        udp        0      0 0.0.0.0:43427           0.0.0.0:*                           111        15744      703/asterisk
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15481      702/dhcpcd
                        udp        0      0 0.0.0.0:41192           0.0.0.0:*                           108        14478      392/avahi-daemon: r
                        udp        0      0 0.0.0.0:4569            0.0.0.0:*                           111        14756      703/asterisk
                        udp6       0      0 :::5353                 :::*                                108        14477      392/avahi-daemon: r
                        udp6       0      0 :::52261                :::*                                108        14479      392/avahi-daemon: r
                        udp6       0      0 :::48892                :::*                                111        15745      703/asterisk
                        udp6       0      0 :::546                  :::*                                0          15493      702/dhcpcd
                        2024-01-17 09:35:29.341  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.342  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.343  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.344  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.345  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.347  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.348  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.349  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.352  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.353  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.354  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.355  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.356  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.357  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.358  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.359  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.360  - warn: myvbus.0 (2404) get state error: DB closed
                        2024-01-17 09:35:29.423  - error: upnp.0 (2300) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2024-01-17 09:35:33.763  - error: history.0 (1038) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        iob diag has finished.
                        Copy text starting here:
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               armhf
                        Timezone:               Europe/London (GMT, +0000)
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     0
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                /usr/bin/npm            10.2.3
                                                /usr/bin/npx            10.2.3
                        Recommended versions are nodejs  and npm
                        MEMORY:
                        Mem:            7.8G        233M        6.8G        1.0M        761M        7.5G
                        Swap:            99M          0B         99M
                        Total:          7.9G        233M        6.9G
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Active iob-Instances:   0
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        ioBroker Core:          js-controller
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                                                admin
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        ioBroker Status:
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Objects:                0
                        States:                 0
                        Size of iob-Database:
                        === Mark text until here for copying ===
                        Danke schonmal für eure Hilfe.
                        Michael
                        GlasfaserG Offline
                        GlasfaserG Offline
                        readonly on device
                        Hast du den Netz-Stecker gezogen !?
                          iob stop
                          iob fix
                          iob nodejs-update
                          iob setup first
                          sudo reboot
                          @glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
                          iob stop
                          iob fix
                          iob nodejs-update
                          iob setup first
                          sudo reboot
                          habe es getestet. das kam dabei raus.
                           ioBroker nodejs updater 2023-10-13
                          No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                          Your current setup is:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          We found these nodejs versions available for installation:
                          nodejs:
                            Version table:
                          Nothing to do - Your installation is using the correct paths.
                          You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
                          Press <y> to continue or any other key to quit
                          Trying to update your installation now. Please be patient.
                          Waiting for ioBroker to shut down - Give me a minute...
                          *** These repos are active on your system:
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Get:3 https://packages.grafana.com/enterprise/deb stable InRelease [5984 B]
                          Err:3 https://packages.grafana.com/enterprise/deb stable InRelease
                          Ign:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                          Err:5 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                            404  Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443]
                          Reading package lists... Done
                          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                          N: See apt-secure(8) manpage for repository creation and user configuration details.
                          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                          Package: nodejs
                          Pin: origin deb.nodesource.com
                          Pin-Priority: 1001
                          *** These repos are active after the adjustments:
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Ign:5 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                          Err:6 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                          Installing the recommended nodejs version now!
                          Exact recommended version unknown, installing a fallback!
                          dpkg: warning: downgrading nodejs from 18.19.0-1nodesource1 to 18.0.0-1nodesource1
                          (Reading database ... 67384 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                          Detected old npm client, removing...
                          Unpacking nodejs (18.0.0-1nodesource1) over (18.19.0-1nodesource1) ...
                          Setting up nodejs (18.0.0-1nodesource1) ...
                          Processing triggers for man-db (2.9.4-2) ...
                          Updating fallback to latest nodejs v18 release
                          (Reading database ... 67647 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.19.0-1nodesource1_armhf.deb ...
                          Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
                          Setting up nodejs (18.19.0-1nodesource1) ...
                          v18.19.0 has been installed! You are using the latest version now!
                          Installing the recommended nodejs version!
                          We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                          *** RESTARTING ioBroker NOW! ***
                           Please refresh or restart your browser in a few moments.
                          pi@raspberrypi:~ $ iob setup first
                            throw err;
                            requireStack: []
                          Node.js v18.19.0
                          danke für die vielen hilfen von euch.
                            iob stop
                            iob fix
                            iob nodejs-update
                            iob setup first
                            sudo reboot
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Package: nodejs
                            Pin-Priority: 1001
                              throw err;
                              requireStack: []
                            Node.js v18.19.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            der letzte Befehl war
                            sudo reboot
                            und jetzt
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install iobroker.js-controller@5.0.17
                              sudo reboot
                              und jetzt
                              cd /opt/iobroker
                              sudo reboot
                              und jetzt
                              cd /opt/iobroker
                              hat leider nicht funktioniert.
                                sudo reboot
                                und jetzt
                                cd /opt/iobroker
                                crunchipC Offline
                                crunchipC Offline
                                Warum? MELDUNGEN?
                                B 2 Antworten Letzte Antwort
                                  Warum? MELDUNGEN?
                                  Borkenkäfer
                                  @crunchip
                                  hallo
                                  hänge mich hier mal rein da ich gleichen Fehlermeldungen habe
                                  nach reboot und dem install iobroker.js-controller@5.0.17 komt
                                  npm ERR! invalid Version
                                  < cd /opt/iobroker
                                  ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@5.0.17
                                  npm ERR! Invalid Version:
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T17_03_13_632Z-debug-0.log>
                                    Warum? MELDUNGEN?
                                    Borkenkäfer
                                    @crunchip
                                    iob diag ergibt folgende Status
                                    sorry das ich das so reinkopiere, kenn die andere Vorgehensweise leider nicht
                                    Node.js v18.19.0
                                    ioBroker Status:
                                    throw err;
                                    requireStack: []
                                    Node.js v18.19.0
                                    Objects: 0
                                    States: 0
                                    5.8M /opt/iobroker/iobroker-data/objects.jsonl
                                    420K /opt/iobroker/iobroker-data/states.jsonl
                                    GlasfaserG B 2 Antworten Letzte Antwort
                                    • B Borkenkäfer
                                      @crunchip
                                      hallo
                                      < cd /opt/iobroker
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
                                      Dann zeige erst
                                      die Full Ausgabe von
                                      iob diag
                                      so ... bringt das nicht !
                                      Ausgabe in Code-Tags </>
                                      • B Borkenkäfer
                                        @crunchip
                                        Node.js v18.19.0
                                        ioBroker Status:
                                        throw err;
                                        requireStack: []
                                        Node.js v18.19.0
                                        Objects: 0
                                        States: 0
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Hier ...
                                        sehr gut erklärt !
                                        • B Borkenkäfer
                                          @crunchip
                                          Node.js v18.19.0
                                          ioBroker Status:
                                          throw err;
                                          requireStack: []
                                          Node.js v18.19.0
                                          Objects: 0
                                          States: 0
                                          Borkenkäfer
                                          @borkenkäfer
                                          und iob update/upgrade/ upgrade self
                                          gibt die Meldung raus
