- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- Iobroker lässt sich nicht mehr starten.
Hi. Ich habe das Problem das mein Iobroker nicht mehr startet. Ich konnte schon feststellen das nodejs nicht richtig installiert war und konnte es fixen. Leider komme ich nun nicht mehr weiter.
Kann mir jemand noch helfen?Anbei die Iobroker diag.
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 19:48:29 up 14 min, 1 user, load average: 0.39, 0.50, 0.52 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Wed 2024-01-17 19:48:29 GMT Universal time: Wed 2024-01-17 19:48:29 UTC RTC time: n/a Time zone: Europe/London (GMT, +0000) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 231M 6.8G 1.0M 796M 7.5G Swap: 99M 0B 99M Total: 7.9G 231M 6.9G 7812 M total memory 231 M used memory 421 M active memory 411 M inactive memory 6784 M free memory 96 M buffer memory 699 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * grafana-server.service loaded failed failed Grafana instance LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 16G 13G 56% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.2M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Jan 17 19:34:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:E1:AA:91 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=ad490bbd-02 rootfstype=ext4 fsck.repair=yes rootwait [Wed Jan 17 19:34:01 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Wed Jan 17 19:34:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Wed Jan 17 19:34:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 7.7G /var/ 5.8G /var/log 2.9G /var/log/journal/2c760f47d5f741e395b4738f4f48cd7d 2.9G /var/log/journal 1.4G /var/lib Archived and active journals take up 2.8G in the file system. /opt/iobroker/backups: 257M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.7G /opt/iobroker/iobroker-data/ 926M /opt/iobroker/iobroker-data/files 507M /opt/iobroker/iobroker-data/history 136M /opt/iobroker/iobroker-data/backup-objects 112M /opt/iobroker/iobroker-data/files/vis-2-beta The five largest files in iobroker-data are: 94M /opt/iobroker/iobroker-data/states.jsonl 46M /opt/iobroker/iobroker-data/objects.jsonl 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: bufferutil@ /opt/iobroker/node_modules/bufferutil npm ERR! extraneous: diskusage@ /opt/iobroker/node_modules/diskusage npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0 npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-17T19_48_37_592Z-debug-0.log *** ioBroker-Installation *** ioBroker Status node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Core adapters versions node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 js-controller: node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 admin: node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 javascript: npm ERR! code ELSPROBLEMS npm ERR! extraneous: bufferutil@ /opt/iobroker/node_modules/bufferutil npm ERR! extraneous: diskusage@ /opt/iobroker/node_modules/diskusage npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0 npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0 npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-17T19_48_40_428Z-debug-0.log Adapters from github: 0 Adapter State node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Enabled adapters with bindings node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 ioBroker-Repositories node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Installed ioBroker-Instances node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Objects and States Please stand by - This may take a while Objects: 0 States: 0 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 111 14743 703/asterisk tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14559 521/sshd: /usr/sbin tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 15797 709/influxd tcp6 0 0 :::22 :::* LISTEN 0 14569 521/sshd: /usr/sbin tcp6 0 0 :::8086 :::* LISTEN 999 3998 709/influxd udp 0 0 0.0.0.0:5060 0.0.0.0:* 111 14755 703/asterisk udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14476 392/avahi-daemon: r udp 0 0 0.0.0.0:43427 0.0.0.0:* 111 15744 703/asterisk udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15481 702/dhcpcd udp 0 0 0.0.0.0:41192 0.0.0.0:* 108 14478 392/avahi-daemon: r udp 0 0 0.0.0.0:4569 0.0.0.0:* 111 14756 703/asterisk udp6 0 0 :::5353 :::* 108 14477 392/avahi-daemon: r udp6 0 0 :::52261 :::* 108 14479 392/avahi-daemon: r udp6 0 0 :::48892 :::* 111 15745 703/asterisk udp6 0 0 :::546 :::* 0 15493 702/dhcpcd *** Log File - Last 25 Lines *** 2024-01-17 09:35:29.341 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.342 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.343 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.344 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.345 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.347 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.347 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.348 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.348 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.349 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.352 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.353 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.354 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.355 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.355 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.356 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.356 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.357 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.358 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.359 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.359 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.360 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.360 - warn: myvbus.0 (2404) get state error: DB closed 2024-01-17 09:35:29.423 - error: upnp.0 (2300) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2024-01-17 09:35:33.763 - error: history.0 (1038) Objects database error: connect ECONNREFUSED 127.0.0.1:9001============ Mark until here for C&P =============
iob diag has finished.
Copy text starting here:======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: armhf Timezone: Europe/London (GMT, +0000) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 233M 6.8G 1.0M 761M 7.5G Swap: 99M 0B 99M Total: 7.9G 233M 6.9G node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Active iob-Instances: 0 node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 ioBroker Core: js-controller node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 admin node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 ioBroker Status: Status admin and web instance: node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 Objects: 0 States: 0 Size of iob-Database: 46M /opt/iobroker/iobroker-data/objects.jsonl 94M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ======================= Mark text until here for copying ===
Danke schonmal für eure Hilfe.
Michaelcd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controllerSynology 918+ 16GB - ioBroker in Docker v9 , VISO auf Trekstor Primebook C13 13,3" , Hikvision Domkameras mit Surveillance Station .. CCU RaspberryMatic in Synology VM .. Zigbee CC2538+CC2592 .. Sonoff .. KNX .. Modbus ..
Michael@michael_schotthoefer sagte in Iobroker lässt sich nicht mehr starten.:
Kernel : aarch64
Userland : armhfMix aus 32 und 64Bit. Installier das Betriebssystem NEU und sortenrein.
Dann im neuen System deine Backups einspielen, fertig.Linux-Werkzeugkasten:
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
Time zone: Europe/London (GMT, +0000)Vermutlich auch falsch.
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller@glasfaser
das kam dabei raus.
npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm ERR! code 1
npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
npm ERR! command failed
npm ERR! command sh -c node iobroker.js setup first
npm ERR! node:internal/modules/cjs/loader:1137
npm ERR! throw err;
npm ERR! ^
npm ERR!
npm ERR! Error: Cannot find module 'tar'
npm ERR! Require stack:
npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
npm ERR! at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
npm ERR! at Module._load (node:internal/modules/cjs/loader:975:27)
npm ERR! at Module.require (node:internal/modules/cjs/loader:1225:19)
npm ERR! at require (node:internal/modules/helpers:177:18)
npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
npm ERR! at Module._compile (node:internal/modules/cjs/loader:1356:14)
npm ERR! at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
npm ERR! at Module.load (node:internal/modules/cjs/loader:1197:32)
npm ERR! at Module._load (node:internal/modules/cjs/loader:1013:12)
npm ERR! at Module.require (node:internal/modules/cjs/loader:1225:19) {
npm ERR! code: 'MODULE_NOT_FOUND',
npm ERR! requireStack: [
npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
npm ERR! ]
npm ERR! }
npm ERR!
npm ERR! Node.js v18.19.0npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-17T19_59_00_782Z-debug-0.log
danke schonmal.
Kernel : aarch64
Dann im neuen System deine Backups einspielen, fertig.@thomas-braun
hi thomas.
heißt sd-karte formatieren und alles neu aufspielen? -
hi thomas.
heißt sd-karte formatieren und alles neu aufspielen?@michael_schotthoefer sagte in Iobroker lässt sich nicht mehr starten.:
Ich würde es auf eine konsistente und aktuelle Basis setzen.
https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
dann werde ich das morgen mal angehen.
ich werde berichten.danke schonmal.
gibt es eine möglichkeit iobroker ein backup zu ziehen über putty?
habe backitup laufen gehabt aber habe nicht gemerkt das es schon länger nicht mehr sichert. habe über filezilla jetzt mal das ganze iobroker gesichert auf dem nas.
reicht das? -
reicht das?@michael_schotthoefer sagte in Iobroker lässt sich nicht mehr starten.:
iobroker backupDatei liegt dann in /opt/iobroker/backups
Wobei ich mir halt auch anschauen würde, warum dein Backitup nicht funktioniert. Insgesamt scheint mir deine Kiste leicht zu hinken...Linux-Werkzeugkasten:
Kernel : aarch64
wenn ich es richtig sehe benötige ich 64bit oder? -
Wobei ich mir halt auch anschauen würde, warum dein Backitup nicht funktioniert. Insgesamt scheint mir deine Kiste leicht zu hinken...@thomas-braun
das hatte ich schon probiert.
geht leider nicht da anscheinend alles zerschossen ist. -
geht leider nicht da anscheinend alles zerschossen ist.@michael_schotthoefer sagte in Iobroker lässt sich nicht mehr starten.:
Ja, wissen wir.
@glasfaser
das kam dabei raus.
npm ERR! code 1
npm ERR! throw err;
npm ERR! ^
npm ERR!
npm ERR! ]
npm ERR! }
npm ERR!
danke schonmal.
Kannst du etwas testen :
iob stop iob fix iob nodejs-update iob setup first sudo rebootSynology 918+ 16GB - ioBroker in Docker v9 , VISO auf Trekstor Primebook C13 13,3" , Hikvision Domkameras mit Surveillance Station .. CCU RaspberryMatic in Synology VM .. Zigbee CC2538+CC2592 .. Sonoff .. KNX .. Modbus ..
readonly on device
Hast du den Netz-Stecker gezogen !?
iob stop iob fix iob nodejs-update iob setup first sudo reboot@glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
iob stop iob fix iob nodejs-update iob setup first sudo reboothabe es getestet. das kam dabei raus.
ioBroker nodejs updater 2023-10-13 No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree. Your current setup is: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 We found these nodejs versions available for installation: nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Nothing to do - Your installation is using the correct paths. You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree? Press <y> to continue or any other key to quit Trying to update your installation now. Please be patient. Waiting for ioBroker to shut down - Give me a minute... ############################################################ *** These repos are active on your system: Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Get:3 https://packages.grafana.com/enterprise/deb stable InRelease [5984 B] Err:3 https://packages.grafana.com/enterprise/deb stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 Ign:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease Err:5 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release 404 Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443] Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 *** Installing ca-certificates, curl and gnupg, just in case they are missing. *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main Package: nodejs Pin: origin deb.nodesource.com Pin-Priority: 1001 *** These repos are active after the adjustments: Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Get:3 https://packages.grafana.com/enterprise/deb stable InRelease [5984 B] Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Err:3 https://packages.grafana.com/enterprise/deb stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 Ign:5 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease Err:6 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release 404 Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443] Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 Installing the recommended nodejs version now! Exact recommended version unknown, installing a fallback! dpkg: warning: downgrading nodejs from 18.19.0-1nodesource1 to 18.0.0-1nodesource1 (Reading database ... 67384 files and directories currently installed.) Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ... Detected old npm client, removing... Unpacking nodejs (18.0.0-1nodesource1) over (18.19.0-1nodesource1) ... Setting up nodejs (18.0.0-1nodesource1) ... Processing triggers for man-db (2.9.4-2) ... Updating fallback to latest nodejs v18 release W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 (Reading database ... 67647 files and directories currently installed.) Preparing to unpack .../nodejs_18.19.0-1nodesource1_armhf.deb ... Detected old npm client, removing... Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ... Setting up nodejs (18.19.0-1nodesource1) ... Processing triggers for man-db (2.9.4-2) ... v18.19.0 has been installed! You are using the latest version now! Installing the recommended nodejs version! W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2 We tried our best to update or fix your nodejs. Please run iob diag again to verify. *** RESTARTING ioBroker NOW! *** Please refresh or restart your browser in a few moments. pi@raspberrypi:~ $ iob setup first node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0danke für die vielen hilfen von euch.
der letzte Befehl war
sudo rebootund jetzt
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller@5.0.17Synology 918+ 16GB - ioBroker in Docker v9 , VISO auf Trekstor Primebook C13 13,3" , Hikvision Domkameras mit Surveillance Station .. CCU RaspberryMatic in Synology VM .. Zigbee CC2538+CC2592 .. Sonoff .. KNX .. Modbus ..
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller@5.0.17@glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller@5.0.17hat leider nicht funktioniert.
Warum? MELDUNGEN?
Warum? MELDUNGEN?
@crunchip
hallo
hänge mich hier mal rein da ich gleichen Fehlermeldungen habe
nach reboot und dem install iobroker.js-controller@5.0.17 komt
npm ERR! invalid Version
< cd /opt/iobroker
ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@5.0.17
npm ERR! Invalid Version:npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T17_03_13_632Z-debug-0.log>
Warum? MELDUNGEN?
@crunchip
iob diag ergibt folgende Statussorry das ich das so reinkopiere, kenn die andere Vorgehensweise leider nicht
Node.js v18.19.0
ioBroker Status:Status admin and web instance:
throw err;
^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
requireStack: []
}Node.js v18.19.0
Objects: 0
States: 0Size of iob-Database:
5.8M /opt/iobroker/iobroker-data/objects.jsonl
420K /opt/iobroker/iobroker-data/states.jsonl
