  4. QNAP NAS Container ioBroker js-controller und node update
68 Beiträge 7 Kommentatoren 9.5k Aufrufe 4 Beobachtet
  • H HolgerCW
    @glasfaser HIer nun die Ausgabe
    HolgerCW
    @holgercw
    root@ioBroker:/opt/iobroker# iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    • H HolgerCW
      GlasfaserG Offline
      GlasfaserG Offline
      @holgercw
      Was machst du !
      Zuerst :
      @glasfaser sagte in QNAP NAS Container ioBroker js-controller und node update:
      @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
      Wenn ich dort was eingebe und enter drücke passiert nichts:
      Habe kein Qnap ... aber da bist du falsch , du hast da ein Button Terminal ...
      Aber im Grunde um dir zu helfen , brauchen wir keine Briefmarke , sondern ein richtige Ausgabe deines Systems :
      dazu dann einmal
      pkill -u iobroker
      iob fix
      danach den Container neu starten ,
      dann
      die Full Ausgabe von
      iob diag
      hier in Code-Tags </> posten
      sonst das :
      @holgercw
      ich habe so eine Vorahnung, das wieder No connection kommt ,
      dann diese Ausgabe hier posten :
      type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
      H 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @holgercw
        Was machst du !
        Zuerst :
        dazu dann einmal
        pkill -u iobroker
        iob fix
        dann
        iob diag
        sonst das :
        @holgercw
        HolgerCW
        @glasfaser Habe nun den Code eingegeben:
        root@ioBroker:/opt/iobroker# type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
        /usr/bin/nodejs
        v10.18.1
        /usr/bin/node
        v10.18.1
        /usr/bin/npm
        6.13.4
        /usr/bin/npx
        6.13.4
        nodejs:
          Installiert:           10.18.1-1nodesource1
          Installationskandidat: 10.18.1-1nodesource1
          Versionstabelle:
         *** 10.18.1-1nodesource1 100
        insgesamt 15M
        drwxrwxr-x 1 iobroker iobroker  12K Jan 13 18:09 backup-objects
        drwxrwxr-x 1 iobroker iobroker 4,0K Jan 13 16:19 files
        -rw-rwxr-- 1 iobroker iobroker 4,3K Jun  7  2021 iobroker.json
        -rw-r--r-- 1 iobroker iobroker    3 Jan 13 17:57 notifications.json
        -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json
        -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json.bak
        -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:21 states.json
        -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:20 states.json.bak
        3.2.16
        • H HolgerCW
          /usr/bin/nodejs
          v10.18.1
          /usr/bin/node
          v10.18.1
          /usr/bin/npm
          6.13.4
          /usr/bin/npx
          6.13.4
          nodejs:
            Versionstabelle:
          insgesamt 15M
          3.2.16
          HolgerCW
          schrieb am zuletzt editiert von HolgerCW
          Wusste eben nicht ob ich zwischen iob fix und iob diag in dem neuen Fenster bleiben soll bis er neu gestartet ist. Bin mit der Materie komplet nicht vertraut. Kannst Du mit den Daten nun was anfangen ?
          Vielleicht gibt es ja auch eine Möglichkeit das Image komplett neu zu installieren (Vorher backup und so) aber ohne das dann das Smarthome neu eingerichtet werden muss
          • H HolgerCW
            GlasfaserG Offline
            GlasfaserG Offline
            Ja ... , erstmal !
            Wie schon auf der Briefmarke zu erkennen , ist dein ioBroker / Container Stein Alt ... also nie gepflegt worden .
            Zeige mal :
            iob list instances
            iob list adapters
            H 3 Antworten Letzte Antwort
              Ja ... , erstmal !
              Zeige mal :
              iob list instances
              iob list adapters
              HolgerCW
              @glasfaser
              root@ioBroker:/opt/iobroker# iob list instances
              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.ble.0                    : ble                   : ioBroker                                 -  enabled
              + system.adapter.daikin.0                 : daikin                : ioBroker                                 -  enabled
              + system.adapter.daikin.1                 : daikin                : ioBroker                                 -  enabled
              + system.adapter.daikin.2                 : daikin                : ioBroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
              + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
              + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
              + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
              + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
              + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
              + system.adapter.samsung.1                : samsung               : ioBroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 192.168.0.60, run as: admin
              + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
              + system.adapter.vr200.0                  : vr200                 : ioBroker                                 -  enabled
              + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
              + instance is alive
                Ja ... , erstmal !
                Zeige mal :
                iob list instances
                iob list adapters
                HolgerCW
                @glasfaser
                system.adapter.admin                   : admin          - v5.1.25
                system.adapter.ble                     : ble            - v0.12.0
                system.adapter.daikin                  : daikin         - v1.4.2
                system.adapter.discovery               : discovery      - v2.7.3
                system.adapter.fritzbox                : fritzbox       - v0.2.1
                system.adapter.fullybrowser            : fullybrowser   - v2.0.10
                system.adapter.hue                     : hue            - v3.7.1
                system.adapter.info                    : info           - v1.9.8
                system.adapter.lgtv-rs                 : lgtv-rs        - v0.1.1
                system.adapter.lgtv11                  : lgtv11         - v1.0.5
                system.adapter.mihome-vacuum           : mihome-vacuum  - v3.8.6
                system.adapter.ping                    : ping           - v1.5.0
                system.adapter.samsung                 : samsung        - v0.2.9
                system.adapter.shelly                  : shelly         - v4.0.7
                system.adapter.simple-api              : simple-api     - v2.6.1
                system.adapter.tesla-motors            : tesla-motors   - v1.3.2
                system.adapter.tr-064                  : tr-064         - v4.2.16
                system.adapter.vr200                   : vr200          - v1.1.0
                system.adapter.wled                    : wled           - v0.6.7
                  Ja ... , erstmal !
                  Zeige mal :
                  iob list instances
                  iob list adapters
                  HolgerCW
                  @glasfaser WUsste nie wie ich da ran gehen soll. Habe dann immer wieder aufgegeben. Hoffe jetzt geht es mal vorran
                  • H HolgerCW
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Das ganze Problem was ich jetzt sehe , ist das du kein Backup hast mit dem Backitup Adapter !
                    Oder wie machst du Backups !?
                      HolgerCW
                      @glasfaser Habe noch nie ein Backup gemacht. Soll ich den backitup adapter installieren auf dem iobroker. Bisher läuft ja auch leider alles, daher habe ich da ein wenig schiss. Ein Update des node und js wäre top wenn das einfach so ginge
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        dann hast du immer Glück gehabt !
                        Ein Update des node
                        lohnt sich nicht , der Container ist UhrAlt !
                        Naja ..
                        Erstmal ein Backup machen !
                        Dann im alten Container den js-controller langsam hochziehen inkl Nodejs usw.
                        Dann ein Backup ,
                        dann einen neuen Container erstellen mit dem aktuelle Image dann dein Backup rein .
                          Ein Update des node
                          Naja ..
                          Dann ein Backup ,
                          HolgerCW
                          @glasfaser Alles klar. Nur wie mache ich ein Backup und wie mache ich danach die Updates. Bisher war das ja ohne Erfolg ?
                          • H HolgerCW
                            GlasfaserG Offline
                            GlasfaserG Offline
                            H 2 Antworten Letzte Antwort
                              HolgerCW
                              @glasfaser said in QNAP NAS Container ioBroker js-controller und node update:
                              Backitup
                              LEider keine Chance. Adapter nicht installierbar:1.jpg
                              Was nun ?
                                HolgerCW
                                @glasfaser Ich konnte ja auch jetzt nicht in der Console iobroker update machen
                                Thomas BraunT HomoranH GlasfaserG 4 Antworten Letzte Antwort
                                • H HolgerCW
                                  @holgercw
                                  iob stop
                                  iob fix
                                  iob nodejs-update
                                  Dann schauen ob der backitup-Adapter installierbar ist.
                                  Edith: Das ist ein Docker bei dir? Dann vergiss es, das geht da glaub ich nicht/anders.
                                  • H HolgerCW
                                    warum nicht?
                                    zeigen!
                                    wenn man 7 Jahre nichts updated gibt es die alten Repos gar nicht mehr.
                                    Hier trifft nach so langer Zeit wirklich zu:
                                    kein Backup - kein Mitleid!
                                    Du kannst noch versuchen nodejs hochzuziehen um den Controller und einige Adapter upzudaten.
                                    Aber da wirst du auch ggf. am Betriebssystem scheitern.
                                    Du darfst natürlich nicht versuchen die allerneuesten Versionen draufzuspielen.
                                    • H HolgerCW
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @holgercw
                                      Dann ziehen wir langsam hoch ...
                                      Erstmal
                                      pkill -u iobroker
                                      sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                                      Container danach neu starten .
                                      Bei
                                      nodejs: v10.18.1
                                      @Thomas-Braun kannst du nacher helfen... um erstmal nur auf 16 zu kommen für den alten Container !
                                      EDIT :
                                      Mähhh .. ab 4.0.24
                                      Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt.
                                      also erst Node-js
                                      Thomas BraunT H 2 Antworten Letzte Antwort
                                        @holgercw
                                        Erstmal
                                        pkill -u iobroker
                                        Bei
                                        nodejs: v10.18.1
                                        EDIT :
                                        Mähhh .. ab 4.0.24
                                        also erst Node-js
                                        Keine Ahnung. Ich kann nur apt... Geht das im Container?
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Ja , geht !
