  4. QNAP NAS Container ioBroker js-controller und node update
68 Beiträge 7 Kommentatoren 9.5k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @holgercw
    ich habe so eine Vorahnung, das wieder No connection kommt ,
    dann diese Ausgabe hier posten :
    type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
    HolgerCW
    @glasfaser HIer nun die Ausgabe
    H GlasfaserG 2 Antworten Letzte Antwort
    • H HolgerCW
      HolgerCW
      @holgercw
      root@ioBroker:/opt/iobroker# iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-controller
        iobroker stop                                                stops the js-controller
        iobroker restart                                             Restarts js-controller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter
        iobroker install <adapter>                                   Installs a specified adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter from system
        iobroker del <adapter>.<instance>                            Remove adapter instance
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
      • H HolgerCW
        GlasfaserG Offline
        GlasfaserG Offline
        @holgercw
        Was machst du !
        Zuerst :
        @glasfaser sagte in QNAP NAS Container ioBroker js-controller und node update:
        @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
        Wenn ich dort was eingebe und enter drücke passiert nichts:
        Habe kein Qnap ... aber da bist du falsch , du hast da ein Button Terminal ...
        Aber im Grunde um dir zu helfen , brauchen wir keine Briefmarke , sondern ein richtige Ausgabe deines Systems :
        dazu dann einmal
        pkill -u iobroker
        iob fix
        danach den Container neu starten ,
        dann
        die Full Ausgabe von
        iob diag
        hier in Code-Tags </> posten
        sonst das :
        @holgercw
        H 1 Antwort Letzte Antwort
          @holgercw
          Was machst du !
          Zuerst :
          dazu dann einmal
          pkill -u iobroker
          iob fix
          dann
          iob diag
          sonst das :
          @holgercw
          HolgerCW
          @glasfaser Habe nun den Code eingegeben:
          root@ioBroker:/opt/iobroker# type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
          /usr/bin/nodejs
          v10.18.1
          /usr/bin/node
          v10.18.1
          /usr/bin/npm
          6.13.4
          /usr/bin/npx
          6.13.4
          nodejs:
            Installiert:           10.18.1-1nodesource1
            Installationskandidat: 10.18.1-1nodesource1
            Versionstabelle:
           *** 10.18.1-1nodesource1 100
          insgesamt 15M
          drwxrwxr-x 1 iobroker iobroker  12K Jan 13 18:09 backup-objects
          drwxrwxr-x 1 iobroker iobroker 4,0K Jan 13 16:19 files
          -rw-rwxr-- 1 iobroker iobroker 4,3K Jun  7  2021 iobroker.json
          -rw-r--r-- 1 iobroker iobroker    3 Jan 13 17:57 notifications.json
          -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json
          -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json.bak
          -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:21 states.json
          -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:20 states.json.bak
          3.2.16
          • H HolgerCW
            /usr/bin/nodejs
            v10.18.1
            /usr/bin/node
            v10.18.1
            /usr/bin/npm
            6.13.4
            /usr/bin/npx
            6.13.4
            nodejs:
              Versionstabelle:
            insgesamt 15M
            3.2.16
            HolgerCW
            schrieb am zuletzt editiert von HolgerCW
            Wusste eben nicht ob ich zwischen iob fix und iob diag in dem neuen Fenster bleiben soll bis er neu gestartet ist. Bin mit der Materie komplet nicht vertraut. Kannst Du mit den Daten nun was anfangen ?
            Vielleicht gibt es ja auch eine Möglichkeit das Image komplett neu zu installieren (Vorher backup und so) aber ohne das dann das Smarthome neu eingerichtet werden muss
            • H HolgerCW
              GlasfaserG Offline
              GlasfaserG Offline
              Ja ... , erstmal !
              Wie schon auf der Briefmarke zu erkennen , ist dein ioBroker / Container Stein Alt ... also nie gepflegt worden .
              Zeige mal :
              iob list instances
              iob list adapters
              H 3 Antworten Letzte Antwort
                Ja ... , erstmal !
                Zeige mal :
                iob list instances
                iob list adapters
                HolgerCW
                @glasfaser
                root@ioBroker:/opt/iobroker# iob list instances
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.ble.0                    : ble                   : ioBroker                                 -  enabled
                + system.adapter.daikin.0                 : daikin                : ioBroker                                 -  enabled
                + system.adapter.daikin.1                 : daikin                : ioBroker                                 -  enabled
                + system.adapter.daikin.2                 : daikin                : ioBroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
                + system.adapter.samsung.1                : samsung               : ioBroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 192.168.0.60, run as: admin
                + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
                + system.adapter.vr200.0                  : vr200                 : ioBroker                                 -  enabled
                + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                + instance is alive
                  Ja ... , erstmal !
                  Zeige mal :
                  iob list instances
                  iob list adapters
                  HolgerCW
                  @glasfaser
                  system.adapter.admin                   : admin          - v5.1.25
                  system.adapter.ble                     : ble            - v0.12.0
                  system.adapter.daikin                  : daikin         - v1.4.2
                  system.adapter.discovery               : discovery      - v2.7.3
                  system.adapter.fritzbox                : fritzbox       - v0.2.1
                  system.adapter.fullybrowser            : fullybrowser   - v2.0.10
                  system.adapter.hue                     : hue            - v3.7.1
                  system.adapter.info                    : info           - v1.9.8
                  system.adapter.lgtv-rs                 : lgtv-rs        - v0.1.1
                  system.adapter.lgtv11                  : lgtv11         - v1.0.5
                  system.adapter.mihome-vacuum           : mihome-vacuum  - v3.8.6
                  system.adapter.ping                    : ping           - v1.5.0
                  system.adapter.samsung                 : samsung        - v0.2.9
                  system.adapter.shelly                  : shelly         - v4.0.7
                  system.adapter.simple-api              : simple-api     - v2.6.1
                  system.adapter.tesla-motors            : tesla-motors   - v1.3.2
                  system.adapter.tr-064                  : tr-064         - v4.2.16
                  system.adapter.vr200                   : vr200          - v1.1.0
                  system.adapter.wled                    : wled           - v0.6.7
                    Ja ... , erstmal !
                    Zeige mal :
                    iob list instances
                    iob list adapters
                    HolgerCW
                    @glasfaser WUsste nie wie ich da ran gehen soll. Habe dann immer wieder aufgegeben. Hoffe jetzt geht es mal vorran
                    • H HolgerCW
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Das ganze Problem was ich jetzt sehe , ist das du kein Backup hast mit dem Backitup Adapter !
                      Oder wie machst du Backups !?
                        HolgerCW
                        @glasfaser Habe noch nie ein Backup gemacht. Soll ich den backitup adapter installieren auf dem iobroker. Bisher läuft ja auch leider alles, daher habe ich da ein wenig schiss. Ein Update des node und js wäre top wenn das einfach so ginge
                        • GlasfaserG Offline
                          GlasfaserG Offline
                          dann hast du immer Glück gehabt !
                          Ein Update des node
                          lohnt sich nicht , der Container ist UhrAlt !
                          Naja ..
                          Erstmal ein Backup machen !
                          Dann im alten Container den js-controller langsam hochziehen inkl Nodejs usw.
                          Dann ein Backup ,
                          dann einen neuen Container erstellen mit dem aktuelle Image dann dein Backup rein .
                            Ein Update des node
                            Naja ..
                            Dann ein Backup ,
                            HolgerCW
                            @glasfaser Alles klar. Nur wie mache ich ein Backup und wie mache ich danach die Updates. Bisher war das ja ohne Erfolg ?
                            • H HolgerCW
                              GlasfaserG Offline
                              GlasfaserG Offline
                              H 2 Antworten Letzte Antwort
                                HolgerCW
                                @glasfaser said in QNAP NAS Container ioBroker js-controller und node update:
                                Backitup
                                LEider keine Chance. Adapter nicht installierbar:1.jpg
                                Was nun ?
                                  HolgerCW
                                  @glasfaser Ich konnte ja auch jetzt nicht in der Console iobroker update machen
                                  Thomas BraunT HomoranH GlasfaserG 4 Antworten Letzte Antwort
                                  • H HolgerCW
                                    @holgercw
                                    iob stop
                                    iob fix
                                    iob nodejs-update
                                    Dann schauen ob der backitup-Adapter installierbar ist.
                                    Edith: Das ist ein Docker bei dir? Dann vergiss es, das geht da glaub ich nicht/anders.
                                    • H HolgerCW
                                      warum nicht?
                                      zeigen!
                                      wenn man 7 Jahre nichts updated gibt es die alten Repos gar nicht mehr.
                                      Hier trifft nach so langer Zeit wirklich zu:
                                      kein Backup - kein Mitleid!
                                      Du kannst noch versuchen nodejs hochzuziehen um den Controller und einige Adapter upzudaten.
                                      Aber da wirst du auch ggf. am Betriebssystem scheitern.
                                      Du darfst natürlich nicht versuchen die allerneuesten Versionen draufzuspielen.
                                      • H HolgerCW
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @holgercw
                                        Dann ziehen wir langsam hoch ...
                                        Erstmal
                                        pkill -u iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                                        Container danach neu starten .
                                        Bei
                                        nodejs: v10.18.1
                                        @Thomas-Braun kannst du nacher helfen... um erstmal nur auf 16 zu kommen für den alten Container !
                                        EDIT :
                                        Mähhh .. ab 4.0.24
                                        Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt.
                                        also erst Node-js
                                        Thomas BraunT H 2 Antworten Letzte Antwort
                                          @holgercw
                                          Erstmal
                                          pkill -u iobroker
                                          Bei
                                          nodejs: v10.18.1
                                          EDIT :
                                          Mähhh .. ab 4.0.24
                                          also erst Node-js
                                          Keine Ahnung. Ich kann nur apt... Geht das im Container?
