  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. OpenDTU-onBattery
OpenDTU-onBattery
victron ve direktpylontechopendtushellys
94 Beiträge 23 Kommentatoren 46.0k Aufrufe 20 Beobachtet
  • P PV Bastler
    @ralla66
    Screenshots von Tasmota
    Danke für die Unterstützung!
    Ralla66R Offline
    Ralla66R Offline
    Ralla66
    @pv-bastler
    bitte von der Konsole, du hast das script hochgeladen :-)
    P 1 Antwort Letzte Antwort
    • Ralla66R Ralla66
      @pv-bastler
      PV Bastler
      @ralla66
      Sory!
      15:13:24.556 RSL: STATE = {"Time":"2023-12-13T15:13:24","Uptime":"0T22:20:09","UptimeSec":80409,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:13:24.562 RSL: SENSOR = {"Time":"2023-12-13T15:13:24","":{"power":294,"counter_pos":800.90,"counter_neg":94.14}}
      15:18:24.560 RSL: STATE = {"Time":"2023-12-13T15:18:24","Uptime":"0T22:25:09","UptimeSec":80709,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:18:24.565 RSL: SENSOR = {"Time":"2023-12-13T15:18:24","":{"power":2325,"counter_pos":801.02,"counter_neg":94.14}}
      15:23:24.582 RSL: STATE = {"Time":"2023-12-13T15:23:24","Uptime":"0T22:30:09","UptimeSec":81009,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-34,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:23:24.588 RSL: SENSOR = {"Time":"2023-12-13T15:23:24","":{"power":2268,"counter_pos":801.21,"counter_neg":94.14}}
      15:28:24.591 RSL: STATE = {"Time":"2023-12-13T15:28:24","Uptime":"0T22:35:09","UptimeSec":81309,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:28:24.597 RSL: SENSOR = {"Time":"2023-12-13T15:28:24","":{"power":2056,"counter_pos":801.39,"counter_neg":94.14}}
      15:33:24.580 RSL: STATE = {"Time":"2023-12-13T15:33:24","Uptime":"0T22:40:09","UptimeSec":81609,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:33:24.585 RSL: SENSOR = {"Time":"2023-12-13T15:33:24","":{"power":2049,"counter_pos":801.57,"counter_neg":94.14}}
      15:38:24.581 RSL: STATE = {"Time":"2023-12-13T15:38:24","Uptime":"0T22:45:09","UptimeSec":81909,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:38:24.586 RSL: SENSOR = {"Time":"2023-12-13T15:38:24","":{"power":2076,"counter_pos":801.75,"counter_neg":94.14}}
      15:43:24.961 RSL: STATE = {"Time":"2023-12-13T15:43:24","Uptime":"0T22:50:09","UptimeSec":82209,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:43:24.967 RSL: SENSOR = {"Time":"2023-12-13T15:43:24","":{"power":2303,"counter_pos":801.93,"counter_neg":94.14}}
      15:48:24.583 RSL: STATE = {"Time":"2023-12-13T15:48:24","Uptime":"0T22:55:09","UptimeSec":82509,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-34,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:48:24.588 RSL: SENSOR = {"Time":"2023-12-13T15:48:24","":{"power":339,"counter_pos":801.98,"counter_neg":94.14}}
      15:53:24.577 RSL: STATE = {"Time":"2023-12-13T15:53:24","Uptime":"0T23:00:09","UptimeSec":82809,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
      15:53:24.583 RSL: SENSOR = {"Time":"2023-12-13T15:53:24","":{"power":243,"counter_pos":802.01,"counter_neg":94.14}}
      Ralla66R 1 Antwort Letzte Antwort
      • P PV Bastler
        @ralla66
        Sory!
        Ralla66R Offline
        Ralla66R Offline
        Ralla66
        @pv-bastler
        Telemetrieperiode in Tasmota steht auf 10 ?
        Mqtt hast du eingerichtet in Tasmota ?
        • Ralla66R Ralla66
          @pv-bastler
          PV Bastler
          @ralla66
          Nein, habe sonst nichts eingerichtet.
          Außer Script.
          • P PV Bastler
            @ralla66
            Außer Script.
            Ralla66R Offline
            Ralla66R Offline
            Ralla66
            @pv-bastler
            teste mal im Browser :
            http:// deine Tasmota IP /cm?cmnd=Status%2010
            dann sollte sowas erscheinen ->
            • Ralla66R Ralla66
              @pv-bastler
              PV Bastler
              @ralla66
              Muss warscheinlich mttq einrichten. Bei der Eingabe http://192.168.178.62 /cm?cmnd=Status%2010 kommt nichts raus.
              Telemetrieperiode hab ich geändert von 300 auf 10
              • P PV Bastler
                @ralla66
                Ralla66R Offline
                Ralla66R Offline
                Ralla66
                @pv-bastler
                ok richte mal Mqtt und Sonoff Adapter ein.
                Bei -> http:// deine Tasmota IP /cm?cmnd=Status%2010 achte auf http://
                moderne Browser machen da gerne automatisch https raus
                • Ralla66R Ralla66
                  @pv-bastler
                  Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  @ralla66
                  so als Tipp, Port 1886 oder 1887 nehmen da der Mqtt Adapter default 1883 hat
                  3 Haken setzen
                  zum testen nimm einfache Paßworte, 1234 oder so, keine Sonderzeichen.
                  rebooten Adapter und Esp nach den Eingaben
                  • Ralla66R Ralla66
                    @ralla66
                    3 Haken setzen
                    PV Bastler
                    @ralla66
                    Das mit https hattest du recht.
                    Jetzt kommt sowas: {"StatusSNS":{"Time":"2023-12-13T17:33:53","":{"power":1127,"counter_pos":804.78,"counter_neg":94.14}}}
                    Leider kann ich mit sonoff überhaupt nichts anfangen. Ich dachte es wird außer Tasmota Ir und OpenDTU on Battery keine weitere Hardware benötigt. Ist sonoff Software? Werde mich später noch "schlau" googeln.
                    • P PV Bastler
                      @ralla66
                      Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      @pv-bastler sagte in OpenDTU-onBattery:
                      schwierig da bei dir nur "," steht ,sonst wäre das etwa so
                      JSON bei dir:
                      StatusSNS/ ??? /power
                      bild war falsch
                      • Ralla66R Ralla66
                        JSON bei dir:
                        bild war falsch
                        Ralla66R Offline
                        Ralla66R Offline
                        Ralla66
                        @ralla66
                        mein script
                        >D
                        >B
                        =>sensor53 r
                        >M 1
                        +1,3,s,0,9600,MT175
                        1,77070100000000ff@#
                        schreibe mal in deinem script hinter 9600, Test hin. ( ist bei mir MT175 )
                        Also +1,3,s,0,9600,Test
                        dann teste noch einmal im Browser, dann sollte statt "," dort Test stehen
                        Dann wäre dein JSON
                        StatusSNS/Test/power
                        Dann sollte das kommen:
                        {"StatusSNS":{"Time":"2023-12-13T17:33:53"Test"":{"power":1127,"counter_pos":804.78,"counter_neg":94.14}}}
                        • Ralla66R Ralla66
                          @ralla66
                          mein script
                          >D
                          >B
                          =>sensor53 r
                          >M 1
                          +1,3,s,0,9600,MT175
                          Dann wäre dein JSON
                          PV Bastler
                          @ralla66
                          Du bist der Beste. Genau so gemacht und jetzt funktioniert es!
                          • P PV Bastler
                            @ralla66
                            Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            @pv-bastler
                            für die Nachwelt noch ein Bild des Json in OpenDtu on Battery damit es andere leichter haben.
                            • Ralla66R Ralla66
                              @pv-bastler
                              PV Bastler
                              @ralla66
                              Bei mir bleibt die Http Anfrage wird gesendet unverändert.
                              Leistung/Netz ändert sich nur bei Aktualisierung der Seite, ist das so normal?
                              Ralla66R P 2 Antworten Letzte Antwort
                              • P PV Bastler
                                @ralla66
                                Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                @pv-bastler
                                schau mal oben im Beitrag am 4 Nov 12:47
                                hatte http und JSON unter Phase 1 eingetragen
                                • P PV Bastler
                                  @ralla66
                                  PV Bastler
                                  @pv-bastler said in OpenDTU-onBattery:
                                  @ralla66
                                  Alles läuft wie geschmiert. War mein Fehler.
                                  Danke nochmal!
                                  • P PV Bastler
                                    @ralla66
                                    Danke nochmal!
                                    Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    @pv-bastler
                                    Prima, Top
                                    WebrangerW 1 Antwort Letzte Antwort
                                    • Ralla66R Ralla66
                                      @pv-bastler
                                      Prima, Top
                                      WebrangerW Offline
                                      WebrangerW Offline
                                      Webranger
                                      Kann ich irgendwie den Wert von meinem Discovergy Zähler in die openDTU onbattery schicken?
                                      Sollte doch auch gehen oder? Habe den wert ja in den Objekten stehen.
                                      Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                                      • WebrangerW Webranger
                                        WebrangerW Offline
                                        WebrangerW Offline
                                        Webranger
                                        schrieb am zuletzt editiert von Webranger
                                        Hab die Lösung gefunden.
                                        evtl. hilft es jemanden.
                                        Hab jetzt das nächste Problem das mir wenn ich "Dynamic Power limiter" aktiviere mir dann von OpenDTU der Wechselrichter ausgestellt wird.
                                        • Ralla66R Ralla66
                                          @ralla66
                                          Status :
                                          Antenne nrf24l01+ wird empfangen
                                          Zähler Tasmota eingebunden
                                          Büld
                                          nun weitere Tests mit Vitron VE Direkt mit dem Solar MPPT 100/20 Laderegler
                                          aus der Doku:
                                          Battery support: Read the voltage from Victron MPPT charge controller or from the Hoymiles DC inputs and starts/stops the power producing based on configurable voltage thresholds
                                          W Offline
                                          W Offline
                                          wolfmensch
                                          @ralla66
                                          Habe alles nach Deiner Anleitung gemacht. Leider noch nicht geklappt, kannst Du mir evtl. weiterhelfen?
                                          Hier meine Tasmota Daten:
                                          {"StatusSNS":{"Time":"2024-01-30T22:57:20","EFR":{"Power":207,"Total":19053.3992,"Voltage":234.8,"Current":0.38,"Supply":0.0000}}}
                                          Habe ganz anständig dieses ins OpenDTU onBattery eingetragen:
                                          StatusSNS/EFR/Power
                                          Vielen Dank
