  4. Sayit Adapter- Probleme nach Update
51 Beiträge 10 Kommentatoren 9.9k Aufrufe 6 Beobachtet
    @do5tj80
    iob stop
    iob fix
    iob nodejs-update
    Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
    do5tj80
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 18:49:14 CET
               Universal time: Sun 2023-11-26 17:49:14 UTC
                     RTC time: Sun 2023-11-26 17:49:15
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    thuebner
    /home/thuebner
    thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
    Swap:            11G          0B         11G
    Total:           16G        3.7G         12G
             4921 M total memory
             3693 M used memory
              159 M active memory
             3645 M inactive memory
              816 M free memory
               50 M buffer memory
              359 M swap cache
            11215 M total swap
                0 M used swap
            11215 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                    Type      Size  Used Avail Use% Mounted on
    udev                          devtmpfs  2.4G     0  2.4G   0% /dev
    tmpfs                         tmpfs     493M  540K  492M   1% /run
    /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
    tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
    tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/vda1                     ext2      470M   86M  360M  20% /boot
    tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
    [sudo] password for thuebner:
    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
    TARGET  SOURCE                        FSTYPE OPTIONS
    /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
    `-/boot /dev/vda1                     ext2   rw,relatime
    /var:
    2.8G    /var/
    2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
    2.2G    /var/log
    382M    /var/cache
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    101M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    754M    /opt/iobroker/iobroker-data/
    557M    /opt/iobroker/iobroker-data/files
    133M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/vis-2-beta
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   5
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
    + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
    + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
      system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "knx"          : 2.0.23   , installed 2.0.23
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "s7"           : 1.3.15   , installed 1.3.15
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        54381
    States:         44412
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://ftp.de.debian.org/debian buster InRelease
    Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
    Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
    tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
    tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
    tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
    tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
    tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
    tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
    udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
    udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
    udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
    udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
    udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
    udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
    udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
    udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
    udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
    udp6       0      0 :::111                  :::*                                0          11448      1/init
    2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
    2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
    2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
    2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
    2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
    2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
    2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
    2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
    2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
    2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
    2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
    2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
    2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
    iob diag has finished.
    • D do5tj80
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      thuebner
      /home/thuebner
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            11G          0B         11G
      Total:           16G        3.7G         12G
               4921 M total memory
               3693 M used memory
                159 M active memory
                816 M free memory
                 50 M buffer memory
                359 M swap cache
              11215 M total swap
                  0 M used swap
              11215 M free swap
      *** FILESYSTEM ***
      /var:
      2.8G    /var/
      2.2G    /var/log
      382M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        54381
      States:         44412
      Pending Updates: 0
      @do5tj80
      Der Eintrag
      muss raus.
      Und setz den User auch noch in die Gruppe 'adm'.
        @do5tj80
        Der Eintrag
        muss raus.
        do5tj80
        @thomas-braun said in Sayit Adapter- Probleme nach Update:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
         19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
        CPU threads: 4
                       Local time: Sun 2023-11-26 19:08:23 CET
                   Universal time: Sun 2023-11-26 18:08:23 UTC
                         RTC time: Sun 2023-11-26 18:08:24
                      NTP service: active
                  RTC in local TZ: no
        thuebner
        /home/thuebner
        thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.9G        4.0G        502M        0.0K        464M        746M
        Swap:            11G        308M         10G
        Total:           16G        4.3G         11G
                 4921 M total memory
                 3954 M used memory
                  475 M active memory
                 3651 M inactive memory
                  502 M free memory
                   29 M buffer memory
                  434 M swap cache
                11215 M total swap
                  308 M used swap
                10907 M free swap
        *** FILESYSTEM ***
        tmpfs                         tmpfs     493M  560K  492M   1% /run
        /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
        /var:
        2.8G    /var/
        2.2G    /var/log
        382M    /var/cache
        Archived and active journals take up 2.1G in the file system.
        767M    /opt/iobroker/iobroker-data/
        59M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        54381
        States:         44373
        Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
        Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Pending Updates: 0
        2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
        2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
        2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
        2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
        2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
        2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
        2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
        2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
        2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
        2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
        2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
        2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
        2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
        2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
        2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
        2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
        2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
        2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
        2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
        2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
        2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
        in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
        • D do5tj80
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          thuebner
          /home/thuebner
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            11G        308M         10G
          Total:           16G        4.3G         11G
                   4921 M total memory
                   3954 M used memory
                    475 M active memory
                    502 M free memory
                     29 M buffer memory
                    434 M swap cache
                  11215 M total swap
                    308 M used swap
                  10907 M free swap
          *** FILESYSTEM ***
          /var:
          2.8G    /var/
          2.2G    /var/log
          382M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        54381
          States:         44373
          Pending Updates: 0
          @do5tj80
          Dann würde ich den Arbeitsspeicher anders verteilen.
          11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
            @do5tj80
            do5tj80
            schrieb am zuletzt editiert von do5tj80
            Ok das schaue ich mir an.
            Aber generel erst mal Danke , das du so viele Tip's gibst.
            F 1 Antwort Letzte Antwort
            • D do5tj80
              fvp
              Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
              Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
              sayit.0
              	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
              sayit.0
              	2023-12-12 12:02:29.016	info	Upload announce mp3 files
              sayit.0
              	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
              Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
              • F fvp
                sayit.0
                sayit.0
                sayit.0
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @fvp
                Sende erst das mp3
                und nach x Sek. dann den Text.
                Dies funktioniert.
                Danke.
                • F Offline
                  fvp
                  @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                  • F fvp
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @fvp sagte in Sayit Adapter- Probleme nach Update:
                    Man muss halt auch mal die Hilfe der Adapter lesen.
                    Bringt manchmal Erleuchtung.
                    Denn da steht alles was du gerade suchst.
                    Danke.
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      per js so:
                      setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                      setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                      Danke.
                      F D 3 Antworten Letzte Antwort
                      • bahnuhrB bahnuhr
                        per js so:
                        fvp
                        @bahnuhr
                        Erstmal vielen Dank für den Code.
                        Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                        In der Hilfe steht hier
                        sayit.N.tts.text: Phrase to be spoken.
                        Hast du den Ankündigungston im Adapter abgeschaltet ?
                        Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                        • bahnuhrB bahnuhr
                          per js so:
                          fvp
                          @bahnuhr
                          Ich habe deinen Tipp gerade ausprobiert.
                          Als Workaround kann man das so machen.
                          Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                  // place as first the announcement mp3
                                  tasks.push({
                                      text: announce,
                                      language,
                                      volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                      ts: task.ts,
                                      testOptions
                                  // and then text
                                  tasks.push(task);
                          • F fvp
                            @bahnuhr
                                    tasks.push({
                                        text: announce,
                                        language,
                                        ts: task.ts,
                                        testOptions
                                    // and then text
                                    tasks.push(task);
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @fvp
                            Dein Script sagt jetzt aber absolut nix mit sayit.
                            Danke.
                            • bahnuhrB bahnuhr
                              @fvp
                              fvp
                              @bahnuhr
                              Das ist nicht von mir.
                              Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                              • F fvp
                                @bahnuhr
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Uns was willst du jetzt damit ?
                                mal kritisch von mir:
                                Du weißt nicht wie man eine mp3 sendet.
                                und dann beschäftigst du dich mit der main.js
                                Passt m.E. nicht zusammen.
                                Aber einen workflow von mir hast du ja jetzt.
                                Danke.
                                • bahnuhrB bahnuhr
                                  fvp
                                  @bahnuhr
                                  Ich möchte damit sagen: das von dir gezeigte Vorgehen, für das ich dankbar bin , geht daran vorbei wie der Adapter eigentlich konzipiert ist.
                                  Zu deiner Kritik.
                                  Du sendest ja keine MP3 sondern übergibst dem Adapter den Pfad zur Datei. Sorry das ich nicht wusste das der Adapter das unterstützt und das du dies mit senden meinst. Das heißt doch aber nicht das ich mich mit dem Thema nicht beschäftigt habe !?🤔
                                  Mal kritisch von mir:
                                  Warum eigentlich dieser "scharfe" Ton und kein konstruktives Zusammenarbeiten ? ✌
                                  • F fvp
                                    @bahnuhr
                                    Zu deiner Kritik.
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    "scharfe" Ton
                                    War kein scharfer Ton.
                                    Ganz im Gegenteil; habe dir sogar eine Script Vorlage frei Haus geliefert.
                                    Aber ich habe dir am Anfang geschrieben du sollst du Hilfe lesen.
                                    Was du nicht gemacht hast.
                                    Und dann aber die main.js durchwühlen.
                                    Und dies finde ich halt falsch.
                                    Aber da du anscheinend empfinglich bist, bin ich jetzt raus.
                                    keine Hilfe mehr von mir.
                                    Schönen Abend dir.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      "scharfe" Ton
                                      Schönen Abend dir.
                                      fvp
                                      Schade aber vielen Dank für deine Mühe @bahnuhr
                                      • F fvp
                                        fvp
                                        Ich habe mir mal ein paar Logger-Ausgaben im Adapter erstellt und folgendes festgestellt:
                                            let announce = testOptions && testOptions.announce !== undefined ? testOptions.announce : adapter.config.announce;
                                            adapter.log.info(`announce : ${announce}`);
                                            const annoTimeout = parseInt(testOptions && testOptions.annoTimeout !== undefined ? testOptions.annoTimeout : adapter.config.annoTimeout, 10);
                                            const task = {text, language, volume, onlyCache, ts: Date.now(), combined, testOptions};
                                            // announce  = '/opt/iobroker/iobroker-data/files/sayit.0/tts.userfiles/gong.mp3'
                                            // If more time than 15 seconds till last text, add announcement
                                            if (!onlyCache && announce && !tasks.length && (!lastSay || (Date.now() - lastSay > annoTimeout * 1000))) {
                                        In Zeile 1 scheint 'announce' keinen Wert von der Adapter.config.announce zu erhalten. Dementsprechend ist das If in Zeile 8 nicht erfüllt. Dies wäre dann weiter dafür zuständig den Ankündigungston in die Queue zu bringen.
                                        Wenn ich mit Zeile 6 "nachhelfe" funktioniert der Ankündigungston wie erwartet und ohne den Tipp von bahnuhr.
                                        Damit vermute ich das der fileSelector keinen Wert liefert. Der sieht ja auch merkwürdig aus:
                                        Muss mich jetzt erst mal weiter einlesen ob bzw. wie ich das weiter debuggen kann.
                                        • F fvp
                                          maxpd
                                          schrieb am zuletzt editiert von maxpd
                                          deleteddd
                                          maxpd
