  4. Sayit Adapter- Probleme nach Update
51 Beiträge 10 Kommentatoren 9.9k Aufrufe 6 Beobachtet
  • D do5tj80
    @thomas-braun said in Sayit Adapter- Probleme nach Update:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 19:08:23 CET
               Universal time: Sun 2023-11-26 18:08:23 UTC
                     RTC time: Sun 2023-11-26 18:08:24
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    thuebner
    /home/thuebner
    thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.9G        4.0G        502M        0.0K        464M        746M
    Swap:            11G        308M         10G
    Total:           16G        4.3G         11G
             4921 M total memory
             3954 M used memory
              475 M active memory
             3651 M inactive memory
              502 M free memory
               29 M buffer memory
              434 M swap cache
            11215 M total swap
              308 M used swap
            10907 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                    Type      Size  Used Avail Use% Mounted on
    udev                          devtmpfs  2.4G     0  2.4G   0% /dev
    tmpfs                         tmpfs     493M  560K  492M   1% /run
    /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
    tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
    tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/vda1                     ext2      470M   86M  360M  20% /boot
    tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
    [sudo] password for thuebner:
    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
    TARGET  SOURCE                        FSTYPE OPTIONS
    /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
    `-/boot /dev/vda1                     ext2   rw,relatime
    /var:
    2.8G    /var/
    2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
    2.2G    /var/log
    382M    /var/cache
    Archived and active journals take up 2.1G in the file system.
    /opt/iobroker/backups:
    101M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    767M    /opt/iobroker/iobroker-data/
    557M    /opt/iobroker/iobroker-data/files
    133M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/vis-2-beta
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    59M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   5
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
    + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
    + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
      system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "knx"          : 2.0.23   , installed 2.0.23
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "s7"           : 1.3.15   , installed 1.3.15
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        54381
    States:         44373
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
    Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
    tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
    tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
    tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
    tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
    tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
    tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
    udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
    udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
    udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
    udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
    udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
    udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
    udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
    udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
    udp6       0      0 :::111                  :::*                                0          11448      1/init
    2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
    2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
    2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
    2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
    2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
    2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
    2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
    2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
    2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
    2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
    2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
    2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
    2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
    2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
    2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
    2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
    2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
    2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
    2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
    2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
    2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
    iob diag has finished.
    in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
    @do5tj80
    Dann würde ich den Arbeitsspeicher anders verteilen.
    11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
      @do5tj80
      do5tj80
      schrieb am zuletzt editiert von do5tj80
      Ok das schaue ich mir an.
      Aber generel erst mal Danke , das du so viele Tip's gibst.
      F 1 Antwort Letzte Antwort
      • D do5tj80
        fvp
        Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
        Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
        sayit.0
        	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        sayit.0
        	2023-12-12 12:02:29.016	info	Upload announce mp3 files
        sayit.0
        	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
        Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
        • F fvp
          sayit.0
          sayit.0
          sayit.0
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @fvp
          Sende erst das mp3
          und nach x Sek. dann den Text.
          Dies funktioniert.
          Danke.
          • F Offline
            fvp
            @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
            • F fvp
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @fvp sagte in Sayit Adapter- Probleme nach Update:
              Man muss halt auch mal die Hilfe der Adapter lesen.
              Bringt manchmal Erleuchtung.
              Denn da steht alles was du gerade suchst.
              Danke.
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                per js so:
                setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                Danke.
                F D 3 Antworten Letzte Antwort
                • bahnuhrB bahnuhr
                  per js so:
                  fvp
                  @bahnuhr
                  Erstmal vielen Dank für den Code.
                  Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                  In der Hilfe steht hier
                  sayit.N.tts.text: Phrase to be spoken.
                  Hast du den Ankündigungston im Adapter abgeschaltet ?
                  Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                  • bahnuhrB bahnuhr
                    per js so:
                    fvp
                    @bahnuhr
                    Ich habe deinen Tipp gerade ausprobiert.
                    Als Workaround kann man das so machen.
                    Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                            // place as first the announcement mp3
                            tasks.push({
                                text: announce,
                                language,
                                volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                ts: task.ts,
                                testOptions
                            // and then text
                            tasks.push(task);
                    • F fvp
                      @bahnuhr
                              tasks.push({
                                  text: announce,
                                  language,
                                  ts: task.ts,
                                  testOptions
                              // and then text
                              tasks.push(task);
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @fvp
                      Dein Script sagt jetzt aber absolut nix mit sayit.
                      Danke.
                      • bahnuhrB bahnuhr
                        @fvp
                        fvp
                        @bahnuhr
                        Das ist nicht von mir.
                        Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                        • F fvp
                          @bahnuhr
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          Uns was willst du jetzt damit ?
                          mal kritisch von mir:
                          Du weißt nicht wie man eine mp3 sendet.
                          und dann beschäftigst du dich mit der main.js
                          Passt m.E. nicht zusammen.
                          Aber einen workflow von mir hast du ja jetzt.
                          Danke.
                          • bahnuhrB bahnuhr
                            fvp
                            @bahnuhr
                            Ich möchte damit sagen: das von dir gezeigte Vorgehen, für das ich dankbar bin , geht daran vorbei wie der Adapter eigentlich konzipiert ist.
                            Zu deiner Kritik.
                            Du sendest ja keine MP3 sondern übergibst dem Adapter den Pfad zur Datei. Sorry das ich nicht wusste das der Adapter das unterstützt und das du dies mit senden meinst. Das heißt doch aber nicht das ich mich mit dem Thema nicht beschäftigt habe !?🤔
                            Mal kritisch von mir:
                            Warum eigentlich dieser "scharfe" Ton und kein konstruktives Zusammenarbeiten ? ✌
                            • F fvp
                              @bahnuhr
                              Zu deiner Kritik.
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              "scharfe" Ton
                              War kein scharfer Ton.
                              Ganz im Gegenteil; habe dir sogar eine Script Vorlage frei Haus geliefert.
                              Aber ich habe dir am Anfang geschrieben du sollst du Hilfe lesen.
                              Was du nicht gemacht hast.
                              Und dann aber die main.js durchwühlen.
                              Und dies finde ich halt falsch.
                              Aber da du anscheinend empfinglich bist, bin ich jetzt raus.
                              keine Hilfe mehr von mir.
                              Schönen Abend dir.
                              Danke.
                              • bahnuhrB bahnuhr
                                "scharfe" Ton
                                Schönen Abend dir.
                                fvp
                                Schade aber vielen Dank für deine Mühe @bahnuhr
                                • F fvp
                                  fvp
                                  Ich habe mir mal ein paar Logger-Ausgaben im Adapter erstellt und folgendes festgestellt:
                                      let announce = testOptions && testOptions.announce !== undefined ? testOptions.announce : adapter.config.announce;
                                      adapter.log.info(`announce : ${announce}`);
                                      const annoTimeout = parseInt(testOptions && testOptions.annoTimeout !== undefined ? testOptions.annoTimeout : adapter.config.annoTimeout, 10);
                                      const task = {text, language, volume, onlyCache, ts: Date.now(), combined, testOptions};
                                      // announce  = '/opt/iobroker/iobroker-data/files/sayit.0/tts.userfiles/gong.mp3'
                                      // If more time than 15 seconds till last text, add announcement
                                      if (!onlyCache && announce && !tasks.length && (!lastSay || (Date.now() - lastSay > annoTimeout * 1000))) {
                                  In Zeile 1 scheint 'announce' keinen Wert von der Adapter.config.announce zu erhalten. Dementsprechend ist das If in Zeile 8 nicht erfüllt. Dies wäre dann weiter dafür zuständig den Ankündigungston in die Queue zu bringen.
                                  Wenn ich mit Zeile 6 "nachhelfe" funktioniert der Ankündigungston wie erwartet und ohne den Tipp von bahnuhr.
                                  Damit vermute ich das der fileSelector keinen Wert liefert. Der sieht ja auch merkwürdig aus:
                                  Muss mich jetzt erst mal weiter einlesen ob bzw. wie ich das weiter debuggen kann.
                                  • F fvp
                                    maxpd
                                    schrieb am zuletzt editiert von maxpd
                                    deleteddd
                                    maxpd
                                    • F Offline
                                      fvp
                                      Leider hänge ich immer noch an dem fileSelector. Im Dev-Server funktioniert das eigentlich gut. Am Testsystem aber nicht.
                                      Ich habe den Adapter ganz leicht modifiziert so das ich statt dem fileSelector ein Eingabefeld verwende.
                                      Damit funktioniert dann auch die Ankündigung wie vorgesehen.
                                      • bahnuhrB bahnuhr
                                        per js so:
                                        drapo
                                        @bahnuhr sagte in Sayit Adapter- Probleme nach Update:
                                        vielen dank für diesen Ansatz der hat mir gerade sehr weitergeholfen und ist um ehrlich zu sein die einzige methode die wirklich funktioniert mit sayit und meinem sonos system.
                                        da ich alle meine Skripte als Blockly am Laufen hab, wie würde das aussehen ein file zu übergeben? weisst du das allenfalls?
                                        • D drapo
                                          drapo
                                          schrieb am zuletzt editiert von drapo
                                          @drapo @drapo so gehts mittels blockly
