  4. Sayit Adapter- Probleme nach Update
51 Beiträge 10 Kommentatoren 9.9k Aufrufe 6 Beobachtet
  • D do5tj80
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-16-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:29:23 up 7 days,  3:46,  1 user,  load average: 0.75, 0.84, 0.89
    CPU threads: 4
    This system needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 18:29:23 CET
               Universal time: Sun 2023-11-26 17:29:23 UTC
                     RTC time: Sun 2023-11-26 17:29:24
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    thuebner
    /home/thuebner
    thuebner cdrom floppy audio dip video plugdev netdev
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.9G        4.1G        357M        0.0K        492M        601M
    Swap:            11G        1.7G        9.5G
    Total:           16G        5.8G        9.8G
             4933 M total memory
             4082 M used memory
             2900 M active memory
             1305 M inactive memory
              357 M free memory
              102 M buffer memory
              390 M swap cache
            11215 M total swap
             1727 M used swap
             9488 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                    Type      Size  Used Avail Use% Mounted on
    udev                          devtmpfs  2.4G     0  2.4G   0% /dev
    tmpfs                         tmpfs     494M  572K  493M   1% /run
    /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
    tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
    tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/vda1                     ext2      470M   86M  360M  20% /boot
    tmpfs                         tmpfs     494M     0  494M   0% /run/user/0
    [sudo] password for thuebner:
    Sorry, user thuebner is not allowed to execute '/usr/bin/dmesg -T' as root on iobroker.huebner.local.
    TARGET  SOURCE                        FSTYPE OPTIONS
    /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
    `-/boot /dev/vda1                     ext2   rw,relatime
    /var:
    Sorry, user thuebner is not allowed to execute '/usr/bin/du -h /var/' as root on iobroker.huebner.local.
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    101M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    772M    /opt/iobroker/iobroker-data/
    557M    /opt/iobroker/iobroker-data/files
    133M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/vis-2-beta
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
    *** NodeJS-Installation ***
    ./diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    ./diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
    npm ERR!     /home/thuebner/.npm/_logs/2023-11-26T17_29_31_386Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   5
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
    + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
    + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
    + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
      system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "knx"          : 2.0.23   , installed 2.0.23
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "s7"           : 1.3.15   , installed 1.3.15
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        54381
    States:         44373
    Sorry, user thuebner is not allowed to execute '/usr/bin/apt-get update' as root on iobroker.huebner.local.
    Pending Updates: 0
    *** Listening Ports ***
    Sorry, user thuebner is not allowed to execute '/usr/bin/netstat -tulpen' as root on iobroker.huebner.local.
    2023-11-26 18:30:06.044  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:00:00.000Z","datetype":"date-time","end":"2023-10-24T16:00:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"do5tj80@gmail.com"},"val":"mailto:do5tj80@gmail.com"},"uid":"f79t37oti7bdm0js41njjjgbic@google.com","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.ann@googlemail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.ann@googlemail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/xyu-para-npo","created":"2023-10-23T04:49:38.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/xyu-para-npo\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-23T04:49:40.000Z","location":"Festplatz Gelenau, Ernst-Grohmann-Straße, 09423 Gelenau/Erzgeb., Deutschland","sequence":"0","status":"CONFIRMED","summary":"Altpapiersammlung","transparency":"OPAQUE","method":"PUBLISH"}
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Altpapiersammlung; start:Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Altpapiersammlung at Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:30:00.000Z","datetype":"date-time","end":"2023-10-24T16:30:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"huebner.justus.paul@gmail.com"},"val":"mailto:huebner.justus.paul@gmail.com"},"uid":"A1E9AD76-8D6D-45B2-A4B7-D22ABDCB3D61","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/cdk-spjy-ptp","created":"2023-09-26T14:47:05.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/cdk-spjy-ptp\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-24T01:42:18.000Z","sequence":"1","status":"CONFIRMED","summary":"Bibo Gelenau","transparency":"OPAQUE","APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","method":"PUBLISH"}
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Bibo Gelenau; start:Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit)
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Bibo Gelenau at Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
    2023-11-26 18:30:06.045  - debug: ical.4 (291961) displaying dates because of callback
    2023-11-26 18:30:06.046  - debug: ical.4 (291961) Dates array (data.table): [{"date":"Day After Tomorrow 15:15-16:45","event":"Pippisport","_class":"ical_Tischdienst Justus ical_dayafter","_date":"2023-11-28T14:15:00.000Z","_end":"2023-11-28T15:45:00.000Z","_IDID":"1spa6nra1auon528393aj0gk9n@google.com","_allDay":false,"_private":false,"_rule":" ","location":"Ringerhalle","_calName":"Tischdienst Justus","_calColor":"#186804","_object":{"type":"VEVENT","params":[],"start":"2023-11-28T14:15:00.000Z","datetype":"date-time","end":"2023-11-28T15:45:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","uid":"1spa6nra1auon528393aj0gk9n@google.com","created":"2023-09-28T15:35:00.000Z","lastmodified":"2023-09-28T15:35:00.000Z","location":"Ringerhalle","sequence":"0","status":"CONFIRMED","summary":"Pippisport","transparency":"OPAQUE","method":"PUBLISH"}},{"date":"In 4 days 16:30-17:30","event":"Reiten","_class":"ical_Tischdienst Clara ical_4days","_date":"2023-11-30T15:30:00.000Z","_end":"2023-11-30T16:30:00.000Z","_IDID":"1uksojk6m1bp444avbrev14dgg@google.com","_allDay":false,"_private":false,"_rule":" rrule ","location":"Scharfensteiner Str. 24, 09430 Drebach","_calName":"Tischdienst Clara","_calColor":"#e307ff","_object":{"type":"VEVENT","params":[],"start":"2023-11-30T15:30:00.000Z","datetype":"date-time","end":"2023-11-30T16:30:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Berlin","dtstart":"2023-09-07T14:30:00.000Z","freq":2,"byweekday":[{"weekday":3}]},"options":{"freq":2,"dtstart":"2023-09-07T14:30:00.000Z","interval":1,"wkst":0,"count":null,"until":null,"tzid":"Europe/Berlin","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[3],"bynweekday":null,"byhour":[14],"byminute":[30],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-11-26T17:30:05.000Z","uid":"1uksojk6m1bp444avbrev14dgg@google.com","created":"2023-09-08T09:18:39.000Z","lastmodified":"2023-09-08T09:18:39.000Z","location":"Scharfensteiner Str. 24, 09430 Drebach","sequence":"0","status":"CONFIRMED","summary":"Reiten","transparency":"OPAQUE","method":"PUBLISH"}}]
    2023-11-26 18:30:06.137  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
    2023-11-26 18:30:06.138  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
    2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
    2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 today Tischdienst = false, state = false
    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 now Tischdienst = false, state = false
    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 later Tischdienst = false, state = false
    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 1 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 2 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 3 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 4 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 5 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 6 null Tischdienst = false, state = false
    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 7 null Tischdienst = false, state = false
    2023-11-26 18:30:09.348  - info: ical.3 (291984) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    iob diag has finished.
    @do5tj80 sagte in Sayit Adapter- Probleme nach Update:
    Mach das...
    Zuvor
    iob nodejs-update
      Mach das...
      Zuvor
      iob nodejs-update
      do5tj80
      thuebner@iobroker:~$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
        --help  Show help  [boolean]
      mehr kommt da nicht.
      • D do5tj80
        Options:
        @do5tj80
        iob stop
        iob fix
        iob nodejs-update
        Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
          @do5tj80
          iob stop
          iob fix
          iob nodejs-update
          do5tj80
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
                      Kernel: Linux 5.10.0-26-amd64
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
          CPU threads: 4
                         Local time: Sun 2023-11-26 18:49:14 CET
                     Universal time: Sun 2023-11-26 17:49:14 UTC
                           RTC time: Sun 2023-11-26 17:49:15
                        NTP service: active
                    RTC in local TZ: no
          thuebner
          /home/thuebner
          thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
          Swap:            11G          0B         11G
          Total:           16G        3.7G         12G
                   4921 M total memory
                   3693 M used memory
                    159 M active memory
                   3645 M inactive memory
                    816 M free memory
                     50 M buffer memory
                    359 M swap cache
                  11215 M total swap
                      0 M used swap
                  11215 M free swap
          *** FILESYSTEM ***
          tmpfs                         tmpfs     493M  540K  492M   1% /run
          tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
          [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
          [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
          [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
          [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
          /var:
          2.8G    /var/
          2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
          2.2G    /var/log
          382M    /var/cache
          Archived and active journals take up 32.0M in the file system.
          754M    /opt/iobroker/iobroker-data/
          46M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        54381
          States:         44412
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 https://repos.influxdata.com/debian stable InRelease
          Hit:3 http://ftp.de.debian.org/debian buster InRelease
          Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
          Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists... Done
          Pending Updates: 0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
          tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
          tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
          tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
          tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
          tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
          tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
          udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
          udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
          udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
          udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
          udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
          udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
          udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
          udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
          udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
          udp6       0      0 :::111                  :::*                                0          11448      1/init
          2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
          2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
          2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
          2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
          2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
          2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
          2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
          2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
          2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          • D do5tj80
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            thuebner
            /home/thuebner
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            11G          0B         11G
            Total:           16G        3.7G         12G
                     4921 M total memory
                     3693 M used memory
                      159 M active memory
                      816 M free memory
                       50 M buffer memory
                      359 M swap cache
                    11215 M total swap
                        0 M used swap
                    11215 M free swap
            *** FILESYSTEM ***
            /var:
            2.8G    /var/
            2.2G    /var/log
            382M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        54381
            States:         44412
            Pending Updates: 0
            @do5tj80
            Der Eintrag
            muss raus.
            Und setz den User auch noch in die Gruppe 'adm'.
              @do5tj80
              Der Eintrag
              muss raus.
              do5tj80
              @thomas-braun said in Sayit Adapter- Probleme nach Update:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
              CPU threads: 4
                             Local time: Sun 2023-11-26 19:08:23 CET
                         Universal time: Sun 2023-11-26 18:08:23 UTC
                               RTC time: Sun 2023-11-26 18:08:24
                            NTP service: active
                        RTC in local TZ: no
              thuebner
              /home/thuebner
              thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.9G        4.0G        502M        0.0K        464M        746M
              Swap:            11G        308M         10G
              Total:           16G        4.3G         11G
                       4921 M total memory
                       3954 M used memory
                        475 M active memory
                       3651 M inactive memory
                        502 M free memory
                         29 M buffer memory
                        434 M swap cache
                      11215 M total swap
                        308 M used swap
                      10907 M free swap
              *** FILESYSTEM ***
              tmpfs                         tmpfs     493M  560K  492M   1% /run
              /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
              /var:
              2.8G    /var/
              2.2G    /var/log
              382M    /var/cache
              Archived and active journals take up 2.1G in the file system.
              767M    /opt/iobroker/iobroker-data/
              59M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        54381
              States:         44373
              Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
              Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 0
              2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
              2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
              2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
              2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
              2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
              2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
              2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
              2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
              2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
              2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
              2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
              2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
              • D do5tj80
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                              NTP service: active
                          RTC in local TZ: no
                thuebner
                /home/thuebner
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            11G        308M         10G
                Total:           16G        4.3G         11G
                         4921 M total memory
                         3954 M used memory
                          475 M active memory
                          502 M free memory
                           29 M buffer memory
                          434 M swap cache
                        11215 M total swap
                          308 M used swap
                        10907 M free swap
                *** FILESYSTEM ***
                /var:
                2.8G    /var/
                2.2G    /var/log
                382M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        54381
                States:         44373
                Pending Updates: 0
                @do5tj80
                Dann würde ich den Arbeitsspeicher anders verteilen.
                11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                  @do5tj80
                  do5tj80
                  schrieb am zuletzt editiert von do5tj80
                  Ok das schaue ich mir an.
                  Aber generel erst mal Danke , das du so viele Tip's gibst.
                  F 1 Antwort Letzte Antwort
                  • D do5tj80
                    fvp
                    Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                    Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                    sayit.0
                    	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                    sayit.0
                    	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                    sayit.0
                    	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                    Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                    • F fvp
                      sayit.0
                      sayit.0
                      sayit.0
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @fvp
                      Sende erst das mp3
                      und nach x Sek. dann den Text.
                      Dies funktioniert.
                      Danke.
                      • F Offline
                        fvp
                        @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                        • F fvp
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @fvp sagte in Sayit Adapter- Probleme nach Update:
                          Man muss halt auch mal die Hilfe der Adapter lesen.
                          Bringt manchmal Erleuchtung.
                          Denn da steht alles was du gerade suchst.
                          Danke.
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            per js so:
                            setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                            setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                            Danke.
                            F D 3 Antworten Letzte Antwort
                            • bahnuhrB bahnuhr
                              per js so:
                              fvp
                              @bahnuhr
                              Erstmal vielen Dank für den Code.
                              Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                              In der Hilfe steht hier
                              sayit.N.tts.text: Phrase to be spoken.
                              Hast du den Ankündigungston im Adapter abgeschaltet ?
                              Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                              • bahnuhrB bahnuhr
                                per js so:
                                fvp
                                @bahnuhr
                                Ich habe deinen Tipp gerade ausprobiert.
                                Als Workaround kann man das so machen.
                                Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                        // place as first the announcement mp3
                                        tasks.push({
                                            text: announce,
                                            language,
                                            volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                            ts: task.ts,
                                            testOptions
                                        // and then text
                                        tasks.push(task);
                                • F fvp
                                  @bahnuhr
                                          tasks.push({
                                              text: announce,
                                              language,
                                              ts: task.ts,
                                              testOptions
                                          // and then text
                                          tasks.push(task);
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  @fvp
                                  Dein Script sagt jetzt aber absolut nix mit sayit.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    @fvp
                                    fvp
                                    @bahnuhr
                                    Das ist nicht von mir.
                                    Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                                    • F fvp
                                      @bahnuhr
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Uns was willst du jetzt damit ?
                                      mal kritisch von mir:
                                      Du weißt nicht wie man eine mp3 sendet.
                                      und dann beschäftigst du dich mit der main.js
                                      Passt m.E. nicht zusammen.
                                      Aber einen workflow von mir hast du ja jetzt.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        fvp
                                        @bahnuhr
                                        Ich möchte damit sagen: das von dir gezeigte Vorgehen, für das ich dankbar bin , geht daran vorbei wie der Adapter eigentlich konzipiert ist.
                                        Zu deiner Kritik.
                                        Du sendest ja keine MP3 sondern übergibst dem Adapter den Pfad zur Datei. Sorry das ich nicht wusste das der Adapter das unterstützt und das du dies mit senden meinst. Das heißt doch aber nicht das ich mich mit dem Thema nicht beschäftigt habe !?🤔
                                        Mal kritisch von mir:
                                        Warum eigentlich dieser "scharfe" Ton und kein konstruktives Zusammenarbeiten ? ✌
                                        • F fvp
                                          @bahnuhr
                                          Zu deiner Kritik.
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          "scharfe" Ton
                                          War kein scharfer Ton.
                                          Ganz im Gegenteil; habe dir sogar eine Script Vorlage frei Haus geliefert.
                                          Aber ich habe dir am Anfang geschrieben du sollst du Hilfe lesen.
                                          Was du nicht gemacht hast.
                                          Und dann aber die main.js durchwühlen.
                                          Und dies finde ich halt falsch.
                                          Aber da du anscheinend empfinglich bist, bin ich jetzt raus.
                                          keine Hilfe mehr von mir.
                                          Schönen Abend dir.
                                          Danke.
