  4. Sayit Adapter- Probleme nach Update
51 Beiträge 10 Kommentatoren 9.9k Aufrufe 6 Beobachtet
    @do5tj80 sagte in Sayit Adapter- Probleme nach Update:
    This system needs to be REBOOTED!
    Mach das...
    Zuvor
    iob nodejs-update
    do5tj80
    thuebner@iobroker:~$ iob nodejs-update
    iobroker nodejs-update [<major-version>]
    Upgrade the Node.JS installation to the current LTS
    Options:
      --help  Show help  [boolean]
    mehr kommt da nicht.
    • D do5tj80
      Options:
      @do5tj80
      iob stop
      iob fix
      iob nodejs-update
      Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
        @do5tj80
        iob stop
        iob fix
        iob nodejs-update
        do5tj80
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-26-amd64
              Architecture: x86-64
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sun 2023-11-26 18:49:14 CET
                   Universal time: Sun 2023-11-26 17:49:14 UTC
                         RTC time: Sun 2023-11-26 17:49:15
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        thuebner
        /home/thuebner
        thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
        Swap:            11G          0B         11G
        Total:           16G        3.7G         12G
                 4921 M total memory
                 3693 M used memory
                  159 M active memory
                 3645 M inactive memory
                  816 M free memory
                   50 M buffer memory
                  359 M swap cache
                11215 M total swap
                    0 M used swap
                11215 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                    Type      Size  Used Avail Use% Mounted on
        udev                          devtmpfs  2.4G     0  2.4G   0% /dev
        tmpfs                         tmpfs     493M  540K  492M   1% /run
        /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
        tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
        tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/vda1                     ext2      470M   86M  360M  20% /boot
        tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
        [sudo] password for thuebner:
        [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
        [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
        [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
        TARGET  SOURCE                        FSTYPE OPTIONS
        /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
        `-/boot /dev/vda1                     ext2   rw,relatime
        /var:
        2.8G    /var/
        2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
        2.2G    /var/log
        382M    /var/cache
        Archived and active journals take up 32.0M in the file system.
        /opt/iobroker/backups:
        101M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        754M    /opt/iobroker/iobroker-data/
        557M    /opt/iobroker/iobroker-data/files
        133M    /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/vis-2-beta
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        46M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             10.24.0~dfsg-1~deb10u1 500
                500 http://ftp.de.debian.org/debian buster/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   5
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
        + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
        + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
        + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
          system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
        + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
        + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "km200"        : 2.0.3    , installed 2.0.3
        Adapter    "knx"          : 2.0.23   , installed 2.0.23
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
        Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "s7"           : 1.3.15   , installed 1.3.15
        Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
        Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
        Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "wled"         : 0.7.1    , installed 0.7.1
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        54381
        States:         44412
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 https://repos.influxdata.com/debian stable InRelease
        Hit:3 http://ftp.de.debian.org/debian buster InRelease
        Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
        Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
        tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
        tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
        tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
        tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
        tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
        tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
        udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
        udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
        udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
        udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
        udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
        udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
        udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
        udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
        udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
        udp6       0      0 :::111                  :::*                                0          11448      1/init
        2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
        2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
        2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
        2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
        2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
        2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
        2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
        2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
        2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
        2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
        2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
        2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
        2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
        iob diag has finished.
        • D do5tj80
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          thuebner
          /home/thuebner
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            11G          0B         11G
          Total:           16G        3.7G         12G
                   4921 M total memory
                   3693 M used memory
                    159 M active memory
                    816 M free memory
                     50 M buffer memory
                    359 M swap cache
                  11215 M total swap
                      0 M used swap
                  11215 M free swap
          *** FILESYSTEM ***
          /var:
          2.8G    /var/
          2.2G    /var/log
          382M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        54381
          States:         44412
          Pending Updates: 0
          @do5tj80
          Der Eintrag
          muss raus.
          Und setz den User auch noch in die Gruppe 'adm'.
            @do5tj80
            Der Eintrag
            muss raus.
            do5tj80
            @thomas-braun said in Sayit Adapter- Probleme nach Update:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
             19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
            CPU threads: 4
                           Local time: Sun 2023-11-26 19:08:23 CET
                       Universal time: Sun 2023-11-26 18:08:23 UTC
                             RTC time: Sun 2023-11-26 18:08:24
                          NTP service: active
                      RTC in local TZ: no
            thuebner
            /home/thuebner
            thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            4.9G        4.0G        502M        0.0K        464M        746M
            Swap:            11G        308M         10G
            Total:           16G        4.3G         11G
                     4921 M total memory
                     3954 M used memory
                      475 M active memory
                     3651 M inactive memory
                      502 M free memory
                       29 M buffer memory
                      434 M swap cache
                    11215 M total swap
                      308 M used swap
                    10907 M free swap
            *** FILESYSTEM ***
            tmpfs                         tmpfs     493M  560K  492M   1% /run
            /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
            /var:
            2.8G    /var/
            2.2G    /var/log
            382M    /var/cache
            Archived and active journals take up 2.1G in the file system.
            767M    /opt/iobroker/iobroker-data/
            59M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        54381
            States:         44373
            Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
            Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Pending Updates: 0
            2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
            2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
            2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
            2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
            2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
            2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
            2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
            2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
            2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
            2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
            2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
            2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
            2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
            2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
            2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
            2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
            2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
            2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
            2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
            2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
            2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
            in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
            • D do5tj80
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              thuebner
              /home/thuebner
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            11G        308M         10G
              Total:           16G        4.3G         11G
                       4921 M total memory
                       3954 M used memory
                        475 M active memory
                        502 M free memory
                         29 M buffer memory
                        434 M swap cache
                      11215 M total swap
                        308 M used swap
                      10907 M free swap
              *** FILESYSTEM ***
              /var:
              2.8G    /var/
              2.2G    /var/log
              382M    /var/cache
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        54381
              States:         44373
              Pending Updates: 0
              @do5tj80
              Dann würde ich den Arbeitsspeicher anders verteilen.
              11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                @do5tj80
                do5tj80
                schrieb am zuletzt editiert von do5tj80
                Ok das schaue ich mir an.
                Aber generel erst mal Danke , das du so viele Tip's gibst.
                F 1 Antwort Letzte Antwort
                • D do5tj80
                  fvp
                  Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                  Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                  sayit.0
                  	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                  sayit.0
                  	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                  sayit.0
                  	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                  Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                  • F fvp
                    sayit.0
                    sayit.0
                    sayit.0
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @fvp
                    Sende erst das mp3
                    und nach x Sek. dann den Text.
                    Dies funktioniert.
                    Danke.
                    • F Offline
                      fvp
                      @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                      • F fvp
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @fvp sagte in Sayit Adapter- Probleme nach Update:
                        Man muss halt auch mal die Hilfe der Adapter lesen.
                        Bringt manchmal Erleuchtung.
                        Denn da steht alles was du gerade suchst.
                        Danke.
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          per js so:
                          setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                          setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                          Danke.
                          F D 3 Antworten Letzte Antwort
                          • bahnuhrB bahnuhr
                            per js so:
                            fvp
                            @bahnuhr
                            Erstmal vielen Dank für den Code.
                            Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                            In der Hilfe steht hier
                            sayit.N.tts.text: Phrase to be spoken.
                            Hast du den Ankündigungston im Adapter abgeschaltet ?
                            Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                            • bahnuhrB bahnuhr
                              per js so:
                              fvp
                              @bahnuhr
                              Ich habe deinen Tipp gerade ausprobiert.
                              Als Workaround kann man das so machen.
                              Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                      // place as first the announcement mp3
                                      tasks.push({
                                          text: announce,
                                          language,
                                          volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                          ts: task.ts,
                                          testOptions
                                      // and then text
                                      tasks.push(task);
                              • F fvp
                                @bahnuhr
                                        tasks.push({
                                            text: announce,
                                            language,
                                            ts: task.ts,
                                            testOptions
                                        // and then text
                                        tasks.push(task);
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @fvp
                                Dein Script sagt jetzt aber absolut nix mit sayit.
                                Danke.
                                • bahnuhrB bahnuhr
                                  @fvp
                                  fvp
                                  @bahnuhr
                                  Das ist nicht von mir.
                                  Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                                  • F fvp
                                    @bahnuhr
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Uns was willst du jetzt damit ?
                                    mal kritisch von mir:
                                    Du weißt nicht wie man eine mp3 sendet.
                                    und dann beschäftigst du dich mit der main.js
                                    Passt m.E. nicht zusammen.
                                    Aber einen workflow von mir hast du ja jetzt.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      fvp
                                      @bahnuhr
                                      Ich möchte damit sagen: das von dir gezeigte Vorgehen, für das ich dankbar bin , geht daran vorbei wie der Adapter eigentlich konzipiert ist.
                                      Zu deiner Kritik.
                                      Du sendest ja keine MP3 sondern übergibst dem Adapter den Pfad zur Datei. Sorry das ich nicht wusste das der Adapter das unterstützt und das du dies mit senden meinst. Das heißt doch aber nicht das ich mich mit dem Thema nicht beschäftigt habe !?🤔
                                      Mal kritisch von mir:
                                      Warum eigentlich dieser "scharfe" Ton und kein konstruktives Zusammenarbeiten ? ✌
                                      • F fvp
                                        @bahnuhr
                                        Zu deiner Kritik.
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        "scharfe" Ton
                                        War kein scharfer Ton.
                                        Ganz im Gegenteil; habe dir sogar eine Script Vorlage frei Haus geliefert.
                                        Aber ich habe dir am Anfang geschrieben du sollst du Hilfe lesen.
                                        Was du nicht gemacht hast.
                                        Und dann aber die main.js durchwühlen.
                                        Und dies finde ich halt falsch.
                                        Aber da du anscheinend empfinglich bist, bin ich jetzt raus.
                                        keine Hilfe mehr von mir.
                                        Schönen Abend dir.
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          "scharfe" Ton
                                          Schönen Abend dir.
                                          fvp
                                          Schade aber vielen Dank für deine Mühe @bahnuhr
