  4. IObroker funktioniert seit einer Woche nicht mehr
23 Beiträge 4 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • P photographix
    @marc-berg
    -------------------------     2023-12-01 14:06:51      -------------------------
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                aarch64                      -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v9.0.1                       -----
    -----                    build:               2023-11-22T05:46:43+00:00    -----
    -----                    node:                v18.18.2                     -----
    -----                    npm:                 9.8.1                        -----
    -----                        Environment Variables                         -----
    -----                    PACKAGES:            nano                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                    USBDEVICES:          /dev/ttyUSB0                 -----
    -----                   Step 1 of 5: Preparing container                   -----
    Updating Linux packages on first run... Done.
    PACKAGES is set. Installing the following additional Linux packages: nano
    nano is not installed. Installing... Done.
    Registering maintenance script as command... Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Checking Database connection... Done.
    Hostname in ioBroker matches the hostname of this container.
    No action required.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    USBDEVICES is set.
    Setting permissions for "/dev/ttyUSB0"... Done.
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
    host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.1" for host "iobroker"
    host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
    host.iobroker check instance "system.adapter.whatsapp-cmb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.whatsapp-cmb.1" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rega.0" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.0" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.1" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.2" for host "iobroker"
    host.iobroker check instance "system.adapter.mihome-vacuum.0" for host "iobroker"
    host.iobroker check instance "system.adapter.openweathermap.0" for host "iobroker"
    host.iobroker check instance "system.adapter.ping.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tr-064.0" for host "iobroker"
    host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
    host.iobroker check instance "system.adapter.daswetter.0" for host "iobroker"
    host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
    host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
    host.iobroker check instance "system.adapter.energiefluss-erweitert.0" for host "iobroker"
    host.iobroker check instance "system.adapter.fullcalendar.0" for host "iobroker"
    host.iobroker check instance "system.adapter.info.0" for host "iobroker"
    host.iobroker check instance "system.adapter.iot.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jeelink.0" for host "iobroker"
    host.iobroker check instance "system.adapter.lovelace.0" for host "iobroker"
    host.iobroker check instance "system.adapter.material.0" for host "iobroker"
    host.iobroker check instance "system.adapter.nina.0" for host "iobroker"
    host.iobroker check instance "system.adapter.rflink.0" for host "iobroker"
    host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker"
    host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
    host.iobroker check instance "system.adapter.socketio.0" for host "iobroker"
    host.iobroker check instance "system.adapter.statistics.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tankerkoenig.0" for host "iobroker"
    host.iobroker check instance "system.adapter.text2command.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tradfri.0" for host "iobroker"
    host.iobroker check instance "system.adapter.valloxmv.0" for host "iobroker"
    host.iobroker check instance "system.adapter.viessmannapi.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-bars.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-fancyswitch.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-google-fonts.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-material-webfont.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-materialdesign.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-metro.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-players.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-weather.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web-speedy.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web.0" for host "iobroker"
    host.iobroker check instance "system.adapter.wiffi-wz.0" for host "iobroker"
    Cannot get NPM version: timeout
    Send diag info: {"uuid":"628fab6a-6228-357a-2ff5-17ee90fe0903","language":"de","country":"Germany","hosts":[{"version":"5.0.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.19.0","arch":"arm64","docker":true,"adapters":{"admin":{"version":"6.12.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.7","platform":"Javascript/Node.js"},"cloud":{"version":"4.4.1","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.10","platform":"Javascript/Node.js"},"devices":{"version":"1.1.5","platform":"Javascript/Node.js"},"discovery":{"version":"4.2.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js"},"energiefluss-erweitert":{"version":"0.0.2-alpha.20","platform":"Javascript/Node.js"},"fullcalendar":{"version":"2.2.6","platform":"Javascript/Node.js"},"hm-rega":{"version":"4.0.0","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.19","platform":"Javascript/Node.js"},"hmm":{"version":"1.0.1","platform":"Javascript/Node.js"},"icons-material-svg":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"info":{"version":"2.0.0","platform":"Javascript/Node.js"},"iot":{"version":"2.0.11","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.6","platform":"Javascript/Node.js"},"jeelink":{"version":"1.2.3","platform":"Javascript/Node.js"},"lovelace":{"version":"3.0.1","platform":"Javascript/Node.js"},"material":{"version":"1.3.1","platform":"Javascript/Node.js"},"mihome-vacuum":{"version":"4.1.0","platform":"Javascript/Node.js"},"mikrotik":{"version":"1.0.16","platform":"Javascript/Node.js"},"minuvis":{"version":"2.2.0","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.4.5","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.2.3","platform":"Javascript/Node.js"},"ping":{"version":"1.6.2","platform":"Javascript/Node.js"},"rflink":{"version":"2.1.6","platform":"Javascript/Node.js"},"shelly":{"version":"6.6.1","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"snips":{"version":"1.5.0","platform":"Javascript/Node.js"},"snmp":{"version":"3.1.0","platform":"Javascript/Node.js"},"socketio":{"version":"6.6.0","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.8-alpha.0","platform":"Javascript/Node.js"},"statistics":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"3.3.7","platform":"Javascript/Node.js"},"telegram":{"version":"2.0.1","platform":"Javascript/Node.js"},"terminal":{"version":"0.2.1","platform":"Javascript/Node.js"},"text2command":{"version":"3.0.2","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.18","platform":"Javascript/Node.js"},"tradfri":{"version":"3.1.3","platform":"Javascript/Node.js"},"valloxmv":{"version":"1.2.0","platform":"Javascript/Node.js"},"viessmannapi":{"version":"2.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.16","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.4.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"vis-material-webfont":{"version":"0.0.3","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.7","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-players":{"version":"0.1.6","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.5.6","platform":"Javascript/Node.js"},"web":{"version":"6.1.10","platform":"Javascript/Node.js"},"web-speedy":{"version":"0.2.0","platform":"Javascript/Node.js"},"whatsapp-cmb":{"version":"0.2.3","platform":"Javascript/Node.js"},"wiffi-wz":{"version":"2.2.1","platform":"Javascript/Node.js"},"ws":{"version":"2.5.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":56,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3990155264,"ostype":"Linux","vis":64}
    Cannot send diag info: timeout of 4000ms exceeded
    /bin/sh: 1: hcitool: not found
    Marc BergM Online
    Marc BergM Online
    Marc Berg
    @photographix
    Mich verwundert etwas (0.0.0.0):
    States database error: connect ECONNREFUSED 0.0.0.0:9000
    Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    Mach mal im Container
    iob setup custom
    und zeig mal die Ausgabe
    P 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      @photographix
      iob setup custom
      photographix
      @marc-berg sagte in IObroker funktioniert seit einer Woche nicht mehr:
      iob setup custom
      root@iobroker:/opt/iobroker# iob setup custom
      Current configuration:
      - Objects database:
        - Type: jsonl
        - Host/Unix Socket: 0.0.0.0
        - Port: 9001
      - States database:
        - Type: jsonl
        - Port: 9000
      - Data Directory: ../../iobroker-data/
      - Host name: iobroker
      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
      ioBroker in Docker auf Raspberry PI 4 / 4GB
      CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
      • P photographix
        iob setup custom
        - Objects database:
          - Type: jsonl
          - Port: 9001
        - States database:
          - Type: jsonl
          - Port: 9000
        Marc BergM Online
        Marc BergM Online
        Marc Berg
        @photographix
        stell da mal "127.0.0.1" statt "0.0.0.0" ein.
        OliverIOO P 2 Antworten Letzte Antwort
          @photographix
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @marc-berg
          @photographix
          bei docker lieber die bereitgestellten environment variablen verwenden.
          dann sind die parameter entweder durch den aufruf oder im docker-compose für später dokumentiert.
          alles was auf kommandozeile ausgeführt wird, ist beim nächsten re-create wieder weg
          https://github.com/buanet/ioBroker.docker/blob/main/docs/README_docker_hub_iobroker.md#configure-iobroker-application
          allerdings sollte der standard schon bei 127.0.0.1 sein.
          evtl pfuschelt da die alte konfiguration da mit rein?
          Meine Adapter und Widgets
          Links im Profil
            @photographix
            photographix
            127.0.0.1
            - Objects database:
              - Type: jsonl
              - Host/Unix Socket: 127.0.0.1
              - Port: 9001
            - States database:
              - Type: jsonl
              - Port: 9000
            iobroker startet neu
            • OliverIOO OliverIO
              @marc-berg
              @photographix
              photographix
              @oliverio
              ist alles im yaml ;-)
              • P photographix
                @oliverio
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @photographix
                also docker-compose
                docker-compose ist in yaml
                Links im Profil
                  @photographix
                  also docker-compose
                  photographix
                  @oliverio
                  genau
                  • P photographix
                    127.0.0.1
                    - Objects database:
                      - Type: jsonl
                      - Port: 9001
                    - States database:
                      - Type: jsonl
                      - Port: 9000
                    photographix
                    @photographix
                    also iob diag hängt sich heute auch schon wieder weg.
                    *** iob diag is starting up, please wait ***
                    Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
                        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                    ich habe aber weder Multihost noch redis in Nutzung
                    Marc BergM crunchipC 2 Antworten Letzte Antwort
                    • P photographix
                      @photographix
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      @photographix sagte in IObroker funktioniert seit einer Woche nicht mehr:
                      Keine Idee mehr. Da scheint etwas mehr nicht rund zu laufen. Ich würde einen frischen Container aufsetzen, Backup einspielen, fertig.
                        photographix
                        schrieb am zuletzt editiert von photographix
                        @marc-berg
                        wie kann ich das Backup innerhalb des Containers zurückspielen. (iob backup restore?) die GUI geht ja nicht.
                        Mit "Frischen Container aufsetzen" meinst du auch das Data Volume löschen?
                        • P photographix
                          @marc-berg
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          In einem frischen Container würde die Gui wieder gehen :-)
                          Ja, so würde ich das machen. Das gesamte Verzeichis löschen und nur die Backup-Datei reinlegen. Diese wird dann beim ersten Start in /backups verschoben. Danach des Restore per Gui oder
                          iob m restore
                          starten.
                          • P photographix
                            @photographix
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @photographix redis bezieht sich wohl eher auf die interne iobroker redis Datenbank
                            • P Offline
                              photographix
                              @marc-berg
                              Hallo es hat etwas gedauert. Ich habe auf einem zweiten Raspberry, die iobroker.yml gestartet und in einem Leeren Container das Backup zurückgespielt. Leider hängt er sich wieder nach Zeit X mit dem selben Fehler weg :-/
                              Weiterhin kommt auch wieder TimeOut in der Webgui.
