  4. IObroker funktioniert seit einer Woche nicht mehr
23 Beiträge 4 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • Marc BergM Marc Berg
    @photographix sagte in IObroker funktioniert seit einer Woche nicht mehr:
    Vielleicht hat ja jemand eine Idee.
    Bitte das Docker Log komplett posten. Insbesondere im Kopf stehe ein paar relevante Infos.
    Die Zeitzone im Container passt nicht.
    photographix
    @marc-berg
    -------------------------     2023-12-01 14:06:51      -------------------------
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                aarch64                      -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v9.0.1                       -----
    -----                    build:               2023-11-22T05:46:43+00:00    -----
    -----                    node:                v18.18.2                     -----
    -----                    npm:                 9.8.1                        -----
    -----                        Environment Variables                         -----
    -----                    PACKAGES:            nano                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                    USBDEVICES:          /dev/ttyUSB0                 -----
    -----                   Step 1 of 5: Preparing container                   -----
    Updating Linux packages on first run... Done.
    PACKAGES is set. Installing the following additional Linux packages: nano
    nano is not installed. Installing... Done.
    Registering maintenance script as command... Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Checking Database connection... Done.
    Hostname in ioBroker matches the hostname of this container.
    No action required.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    USBDEVICES is set.
    Setting permissions for "/dev/ttyUSB0"... Done.
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
    host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.1" for host "iobroker"
    host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
    host.iobroker check instance "system.adapter.whatsapp-cmb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.whatsapp-cmb.1" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rega.0" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.0" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.1" for host "iobroker"
    host.iobroker check instance "system.adapter.hm-rpc.2" for host "iobroker"
    host.iobroker check instance "system.adapter.mihome-vacuum.0" for host "iobroker"
    host.iobroker check instance "system.adapter.openweathermap.0" for host "iobroker"
    host.iobroker check instance "system.adapter.ping.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tr-064.0" for host "iobroker"
    host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
    host.iobroker check instance "system.adapter.daswetter.0" for host "iobroker"
    host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
    host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
    host.iobroker check instance "system.adapter.energiefluss-erweitert.0" for host "iobroker"
    host.iobroker check instance "system.adapter.fullcalendar.0" for host "iobroker"
    host.iobroker check instance "system.adapter.info.0" for host "iobroker"
    host.iobroker check instance "system.adapter.iot.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jeelink.0" for host "iobroker"
    host.iobroker check instance "system.adapter.lovelace.0" for host "iobroker"
    host.iobroker check instance "system.adapter.material.0" for host "iobroker"
    host.iobroker check instance "system.adapter.nina.0" for host "iobroker"
    host.iobroker check instance "system.adapter.rflink.0" for host "iobroker"
    host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker"
    host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
    host.iobroker check instance "system.adapter.socketio.0" for host "iobroker"
    host.iobroker check instance "system.adapter.statistics.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tankerkoenig.0" for host "iobroker"
    host.iobroker check instance "system.adapter.text2command.0" for host "iobroker"
    host.iobroker check instance "system.adapter.tradfri.0" for host "iobroker"
    host.iobroker check instance "system.adapter.valloxmv.0" for host "iobroker"
    host.iobroker check instance "system.adapter.viessmannapi.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-bars.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-fancyswitch.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-google-fonts.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-material-webfont.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-materialdesign.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-metro.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-players.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis-weather.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web-speedy.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web.0" for host "iobroker"
    host.iobroker check instance "system.adapter.wiffi-wz.0" for host "iobroker"
    Cannot get NPM version: timeout
    Send diag info: {"uuid":"628fab6a-6228-357a-2ff5-17ee90fe0903","language":"de","country":"Germany","hosts":[{"version":"5.0.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.19.0","arch":"arm64","docker":true,"adapters":{"admin":{"version":"6.12.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.7","platform":"Javascript/Node.js"},"cloud":{"version":"4.4.1","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.10","platform":"Javascript/Node.js"},"devices":{"version":"1.1.5","platform":"Javascript/Node.js"},"discovery":{"version":"4.2.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js"},"energiefluss-erweitert":{"version":"0.0.2-alpha.20","platform":"Javascript/Node.js"},"fullcalendar":{"version":"2.2.6","platform":"Javascript/Node.js"},"hm-rega":{"version":"4.0.0","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.19","platform":"Javascript/Node.js"},"hmm":{"version":"1.0.1","platform":"Javascript/Node.js"},"icons-material-svg":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"info":{"version":"2.0.0","platform":"Javascript/Node.js"},"iot":{"version":"2.0.11","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.6","platform":"Javascript/Node.js"},"jeelink":{"version":"1.2.3","platform":"Javascript/Node.js"},"lovelace":{"version":"3.0.1","platform":"Javascript/Node.js"},"material":{"version":"1.3.1","platform":"Javascript/Node.js"},"mihome-vacuum":{"version":"4.1.0","platform":"Javascript/Node.js"},"mikrotik":{"version":"1.0.16","platform":"Javascript/Node.js"},"minuvis":{"version":"2.2.0","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.4.5","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.2.3","platform":"Javascript/Node.js"},"ping":{"version":"1.6.2","platform":"Javascript/Node.js"},"rflink":{"version":"2.1.6","platform":"Javascript/Node.js"},"shelly":{"version":"6.6.1","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"snips":{"version":"1.5.0","platform":"Javascript/Node.js"},"snmp":{"version":"3.1.0","platform":"Javascript/Node.js"},"socketio":{"version":"6.6.0","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.8-alpha.0","platform":"Javascript/Node.js"},"statistics":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"3.3.7","platform":"Javascript/Node.js"},"telegram":{"version":"2.0.1","platform":"Javascript/Node.js"},"terminal":{"version":"0.2.1","platform":"Javascript/Node.js"},"text2command":{"version":"3.0.2","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.18","platform":"Javascript/Node.js"},"tradfri":{"version":"3.1.3","platform":"Javascript/Node.js"},"valloxmv":{"version":"1.2.0","platform":"Javascript/Node.js"},"viessmannapi":{"version":"2.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.16","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.4.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"vis-material-webfont":{"version":"0.0.3","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.7","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-players":{"version":"0.1.6","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.5.6","platform":"Javascript/Node.js"},"web":{"version":"6.1.10","platform":"Javascript/Node.js"},"web-speedy":{"version":"0.2.0","platform":"Javascript/Node.js"},"whatsapp-cmb":{"version":"0.2.3","platform":"Javascript/Node.js"},"wiffi-wz":{"version":"2.2.1","platform":"Javascript/Node.js"},"ws":{"version":"2.5.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":56,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3990155264,"ostype":"Linux","vis":64}
    Cannot send diag info: timeout of 4000ms exceeded
    /bin/sh: 1: hcitool: not found
    ioBroker in Docker auf Raspberry PI 4 / 4GB
    CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
    • P photographix
      @marc-berg
      No action required.
      USBDEVICES is set.
      Marc BergM Online
      Marc BergM Online
      Marc Berg
      @photographix
      Mich verwundert etwas (0.0.0.0):
      States database error: connect ECONNREFUSED 0.0.0.0:9000
      Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      Mach mal im Container
      iob setup custom
      und zeig mal die Ausgabe
      P 1 Antwort Letzte Antwort
        @photographix
        iob setup custom
        photographix
        @marc-berg sagte in IObroker funktioniert seit einer Woche nicht mehr:
        iob setup custom
        root@iobroker:/opt/iobroker# iob setup custom
        Current configuration:
        - Objects database:
          - Type: jsonl
          - Host/Unix Socket: 0.0.0.0
          - Port: 9001
        - States database:
          - Type: jsonl
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        - Host name: iobroker
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
        • P photographix
          iob setup custom
          - Objects database:
            - Type: jsonl
            - Port: 9001
          - States database:
            - Type: jsonl
            - Port: 9000
          Marc BergM Online
          Marc BergM Online
          Marc Berg
          @photographix
          stell da mal "127.0.0.1" statt "0.0.0.0" ein.
          OliverIOO P 2 Antworten Letzte Antwort
            @photographix
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @marc-berg
            @photographix
            bei docker lieber die bereitgestellten environment variablen verwenden.
            dann sind die parameter entweder durch den aufruf oder im docker-compose für später dokumentiert.
            alles was auf kommandozeile ausgeführt wird, ist beim nächsten re-create wieder weg
            https://github.com/buanet/ioBroker.docker/blob/main/docs/README_docker_hub_iobroker.md#configure-iobroker-application
            allerdings sollte der standard schon bei 127.0.0.1 sein.
            evtl pfuschelt da die alte konfiguration da mit rein?
            Meine Adapter und Widgets
            Links im Profil
              @photographix
              photographix
              127.0.0.1
              - Objects database:
                - Type: jsonl
                - Host/Unix Socket: 127.0.0.1
                - Port: 9001
              - States database:
                - Type: jsonl
                - Port: 9000
              iobroker startet neu
              • OliverIOO OliverIO
                @marc-berg
                @photographix
                photographix
                @oliverio
                ist alles im yaml ;-)
                • P photographix
                  @oliverio
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @photographix
                  also docker-compose
                  docker-compose ist in yaml
                  Links im Profil
                    @photographix
                    also docker-compose
                    photographix
                    @oliverio
                    genau
                    • P photographix
                      127.0.0.1
                      - Objects database:
                        - Type: jsonl
                        - Port: 9001
                      - States database:
                        - Type: jsonl
                        - Port: 9000
                      photographix
                      @photographix
                      also iob diag hängt sich heute auch schon wieder weg.
                      *** iob diag is starting up, please wait ***
                      Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
                          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      ich habe aber weder Multihost noch redis in Nutzung
                      Marc BergM crunchipC 2 Antworten Letzte Antwort
                      • P photographix
                        @photographix
                        Marc BergM Online
                        Marc BergM Online
                        Marc Berg
                        Keine Idee mehr. Da scheint etwas mehr nicht rund zu laufen. Ich würde einen frischen Container aufsetzen, Backup einspielen, fertig.
                          photographix
                          schrieb am zuletzt editiert von photographix
                          @marc-berg
                          wie kann ich das Backup innerhalb des Containers zurückspielen. (iob backup restore?) die GUI geht ja nicht.
                          Mit "Frischen Container aufsetzen" meinst du auch das Data Volume löschen?
                          • P photographix
                            @marc-berg
                            Marc BergM Online
                            Marc BergM Online
                            Marc Berg
                            In einem frischen Container würde die Gui wieder gehen :-)
                            Ja, so würde ich das machen. Das gesamte Verzeichis löschen und nur die Backup-Datei reinlegen. Diese wird dann beim ersten Start in /backups verschoben. Danach des Restore per Gui oder
                            iob m restore
                            starten.
                            • P photographix
                              @photographix
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @photographix redis bezieht sich wohl eher auf die interne iobroker redis Datenbank
                              • P Offline
                                photographix
                                @marc-berg
                                Hallo es hat etwas gedauert. Ich habe auf einem zweiten Raspberry, die iobroker.yml gestartet und in einem Leeren Container das Backup zurückgespielt. Leider hängt er sich wieder nach Zeit X mit dem selben Fehler weg :-/
                                Weiterhin kommt auch wieder TimeOut in der Webgui.
