  4. Raspi-Firmware Update nach bookworm Update [gelöst]
51 Beiträge 4 Kommentatoren 15.3k Aufrufe 5 Beobachtet
  • mickymM mickym
    @Thomas-Braun
    Kannst Du mal schauen, ob Du in Deiner config.txt ganz unten diese Zeile hast?
    auto_initramfs=1
    @mickym
    echad@chet:~ $ cat /boot/firmware/config.txt
    # For more options and information see
    # http://rptl.io/configtxt
    # Some settings may impact device functionality. See link above for details
    kernel=vmlinuz
    initramfs initrd.img followkernel
    # Uncomment some or all of these to enable the optional hardware interfaces
    dtparam=i2c_arm=on
    #dtparam=i2s=on
    #dtparam=spi=on
    # Enable audio (loads snd_bcm2835)
    dtparam=audio=on
    # Additional overlays and parameters are documented
    # /boot/firmware/overlays/README
    # Automatically load overlays for detected cameras
    camera_auto_detect=1
    # Automatically load overlays for detected DSI displays
    display_auto_detect=1
    # Automatically load initramfs files, if found
    auto_initramfs=1
    # Enable DRM VC4 V3D driver
    dtoverlay=vc4-kms-v3d
    max_framebuffers=2
    # Don't have the firmware create an initial video= setting in cmdline.txt.
    # Use the kernel's default instead.
    disable_fw_kms_setup=1
    # Run in 64-bit mode
    arm_64bit=1
    # Disable compensation for displays with overscan
    disable_overscan=1
    # Run as fast as firmware / board allows
    arm_boost=1
    [cm4]
    # Enable host mode on the 2711 built-in XHCI USB controller.
    # This line should be removed if the legacy DWC2 controller is required
    # (e.g. for USB device mode) or if USB support is not required.
    otg_mode=1
    [all]
    enable_uart=1
    echad@chet:~ $
    • mickymM mickym
      @Thomas-Braun
      auto_initramfs=1
      @mickym
      Wobei die glaube ich wegen des Debian-Kernels bei mir verändert ist...
      Also vorsicht, was du da treibst...
        @mickym
        Viel Erfolg. Ich hatte das mal mit dem Vanilla-Debian-Kernel versucht, das ist in die Hose gegangen.
        mickymM Online
        mickymM Online
        mickym
        So hat alles geklappt - habe die config.txt nicht verändert.
        pi@mwhome:~ $ uname -a
        Linux mwhome 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27) aarch64 GNU/Linux
        Im boot Verzeichnis sind nun auch mehr Dateien:
        pi@mwhome:/boot $ ls -la
        insgesamt 29872
        drwxr-xr-x  3 root root     4096 13. Nov 22:35 .
        drwxr-xr-x 20 root root     4096 13. Nov 22:32 ..
        lrwxrwxrwx  1 root root       20 13. Nov 21:13 cmdline.txt -> firmware/cmdline.txt
        -rw-r--r--  1 root root   230383 27. Okt 16:31 config-6.1.0-rpi6-rpi-v8
        lrwxrwxrwx  1 root root       19 13. Nov 21:15 config.txt -> firmware/config.txt
        drwxr-xr-x  4 root root     3584  1. Jan 1970  firmware
        -rw-r--r--  1 root root 21598184 13. Nov 22:34 initrd.img-6.1.0-rpi6-rpi-v8
        lrwxrwxrwx  1 root root       17 13. Nov 21:14 overlays -> firmware/overlays
        -rw-r--r--  1 root root       83 27. Okt 16:31 System.map-6.1.0-rpi6-rpi-v8
        -rw-r--r--  1 root root  8729756 27. Okt 16:31 vmlinuz-6.1.0-rpi6-rpi-v8
        Für alle, für die das interessant sein mag hier - welche NEUEN Pakete mit diesem Kernel-Upgrade dazugekommen sind:
        pi@mwhome:/boot $ sudo apt install linux-image-rpi-v8 linux-headers-rpi-v8
        Die folgenden zusätzlichen Pakete werden installiert:
          apparmor firmware-linux-free linux-headers-6.1.0-rpi6-common-rpi linux-headers-6.1.0-rpi6-rpi-v8
          linux-image-6.1.0-rpi6-rpi-v8 linux-kbuild-6.1
        Vorgeschlagene Pakete:
          apparmor-profiles-extra apparmor-utils linux-doc-6.1 debian-kernel-handbook
        Die folgenden NEUEN Pakete werden installiert:
          linux-headers-rpi-v8 linux-image-6.1.0-rpi6-rpi-v8 linux-image-rpi-v8 linux-kbuild-6.1
        0 aktualisiert, 8 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 38,5 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 83,6 MB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] J
        Damit sollte ja nun alles wieder in Ordnung sein. :) - Hat bis jetzt immer noch eine Menge Zeit gespart - insbesondere da ein Neuaufbau eben schon aufwändiger ist. Auch wenn inzwischen das Backup mit Node-Red alles sichert.
        https://forum.iobroker.net/topic/57022/neuaufbau-kein-recovery-nodered-mit-backitup-möglich
        • mickymM mickym
          insgesamt 29872
          @mickym
          Wie groß ist deine /boot-Partition?
          Das neue Verfahren benötigt tendenziell mehr Platz für die ganzen Kernel. Die neue Vorgabe ist 512MB.
            @mickym
            mickymM Online
            mickymM Online
            mickym
            @thomas-braun sagte in Raspi-Firmware Update nach bookworm Update [gelöst]:
            @mickym
            lsblk
            NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
            sda           8:0    1 29,3G  0 disk /data
            mmcblk0     179:0    0 14,6G  0 disk
            ├─mmcblk0p1 179:1    0  256M  0 part /boot/firmware
            └─mmcblk0p2 179:2    0 14,1G  0 part /
            Na die 256 MB haben ausgereicht - vielleicht liegt das daran, dass für die anderen Hardware-Plattformen der Kernel eben nicht heruntergeladen wurde.
            Ich kann die Boot-partition aber auch vergrößern, wenn das mal notwendig werden sollte.
            Die ist aber nur zu 21% belegt - also eigentlich kein Handlungsbedarf
            • mickymM mickym
              @mickym
              lsblk
              @mickym sagte in Raspi-Firmware Update nach bookworm Update [gelöst]:
              Das ist aber schon nicht mehr so ganz trivial. Wie auch das, was bisher gemacht wurde.
              Weswegen bei diesem Release vom Raspberry OS halt die Empfehlung zu einer Neuinstallation geht.
                mickymM Online
                mickymM Online
                mickym
                @thomas-braun Gibt es noch technische Einwände? - Oder darf ich mich sonst freuen, ein aktuelles System zu haben? 🙄
                • mickymM mickym
                  Ich hab das selber noch nicht durchdrungen, an welchen Stellen da im einzelnen so deutlich umgebaut wurde. Kann sein, das es das jetzt war, kann aber auch sein, dass dir das bei anderer Gelegenheit aus dem Gleis springt.
                    mickymM Online
                    mickymM Online
                    mickym
                    Trotzdem danke ich Dir für Deine Hilfe - ich fühle mich erst mal wohl, so wie das System jetzt läuft. Der Neuaufbau läuft mir ja nicht davon, wenn es erforderlich sein sollte. 😁 🙂 🙂 🙂
                    @haus-automatisierung auch Dir vielen Dank für den Link:
                    https://gist.github.com/jauderho/6b7d42030e264a135450ecc0ba521bd8
                    Durch die Vorabeiten war ja "nur" noch das Kernelupdate erforderlich.☺
                    R 1 Antwort Letzte Antwort
                    • mickymM mickym
                      Rushmed
                      @mickym Supervielen Dank.
                      MIr hatte noch:
                      in deiner Anleitung gefehlt.
                      • R Rushmed
                        MIr hatte noch:
                        mickymM Online
                        mickymM Online
                        mickym
                        @rushmed Ja das war mein letzter Post. Ich habe das erste Posting ergänzt. Da das offiziell ja nicht empfohlen wird - ist hier alles "at your own risk. "
