  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    apollon77A
267 Beiträge 8 Kommentatoren 75.7k Aufrufe 8 Beobachtet
  • G Gismoh
    @thomas-braun said in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
    whoami && sudo whoami
    idash
    root
    G
    G
    Gismoh
    #92
    idash@ioBrokerVM:/opt/iobroker/node_modules$ ls
    abab                            is-potential-custom-element-name
    @abandonware                    is-primitive
    abbrev                          is-regex
    accepts                         is-shared-array-buffer
    acme-http-01-standalone         is-stream
    acorn                           isstream
    acorn-globals                   is-string
    acorn-walk                      is-symbol
    after                           is-typed-array
    agent-base                      is-typedarray
    ajv                             is-weakref
    @alcalzone                      joi
    alcalzone-shared                jose
    alexa-cookie2                   jsbi
    alexa-remote2                   jsbn
    ansi-colors                     jsdom
    ansi-regex                      jshashes
    ansi-styles                     json2iob
    anymatch                        jsonata
    @apollon                        json-bigint
    aproba                          json-buffer
    archiver                        jsonc-parser
    archiver-utils                  jsonfile
    are-we-there-yet                json-schema
    array-buffer-byte-length        json-schema-traverse
    arraybuffer.prototype.slice     json-stringify-safe
    arraybuffer.slice               jsonwebtoken
    array-flatten                   jsprim
    array.prototype.findindex       js-sdsl
    asn1                            jszip
    assert-plus                     jwa
    async                           jws
    asynckit                        keypairs
    async-limiter                   keyv
    autobind-decorator              kuler
    available-typed-arrays          layerr
    aws4                            lazystream
    aws-crt                         le-acme-core
    aws-iot-device-sdk              le-challenge-fs
    aws-iot-device-sdk-v2           @leichtgewicht
    @aws-sdk                        le-sni-auto
    aws-sign2                       leven
    axios                           lie
    b4a                             loadavg-windows
    backo2                          localforage
    backoff                         locate-path
    balanced-match                  lodash
    base-64                         lodash.assign
    base64-arraybuffer              lodash.defaults
    base64id                        lodash.difference
    base64-js                       lodash.flatten
    bcrypt-pbkdf                    lodash.includes
    bignumber.js                    lodash.isarguments
    binary-extensions               lodash.isboolean
    bindings                        lodash.isinteger
    bl                              lodash.isnumber
    blob                            lodash.isplainobject
    bluebird                        lodash.isstring
    body-parser                     lodash.once
    boolbase                        lodash.union
    bottleneck                      logform
    brace-expansion                 loglevel
    braces                          long
    browser-request                 long-timeout
    buffer                          lowercase-keys
    buffer-crc32                    lru-cache
    buffer-equal-constant-time      lru_map
    buffer-from                     ltx
    bufferhelper                    luxon
    buffer-shims                    lzma
    busboy                          make-dir
    @buttercup                      @mapbox
    byte-length                     map-stream
    bytes                           md5
    cacheable-lookup                md5.js
    cacheable-request               mdns-discovery
    call-bind                       media-typer
    callsite                        merge-descriptors
    camelcase                       merge-stream
    canvas                          meross-cloud
    capitalize                      methods
    caseless                        micromatch
    cert-info                       @microsoft
    chalk                           mime
    charenc                         mime-db
    cheerio                         mime-types
    cheerio-select                  mimic-fn
    chokidar                        mimic-response
    chownr                          minimatch
    ci-info                         minimist
    cli                             minipass
    cliff                           minizlib
    cliui                           mkdirp
    cluster-key-slot                mkdirp-classic
    coap                            mock-require
    coap-packet                     module-not-found-error
    coffeescript                    moment
    color                           mqtt
    color-convert                   mqtt-connection
    color-name                      mqtt-packet
    @colors                         ms
    colors                          mute-stream
    colorspace                      nan
    color-string                    napi-build-utils
    color-support                   nearest-color
    combined-stream                 negotiator
    commist                         nested-property
    component-bind                  netmask
    component-emitter               node-abi
    component-inherit               node-addon-api
    compress-commons                node-arp
    compressible                    node-ble
    compression                     node-domexception
    compress-json                   node.extend
    concat-map                      node-fetch
    concat-stream                   node-forge
    connect-flash                   node-gyp-build
    console-control-strings         node-hue-api
    content-disposition             node-inspect
    content-type                    node-machine-id
    cookie                          node-mndp
    cookie-parser                   node-persist
    cookie-signature                node-rest-client
    core-util-is                    node-schedule
    crc-32                          node-ssdp
    crc32-stream                    node-telegram-bot-api
    cron                            node-wol
    cron-parser                     node-xmpp-client
    cross-spawn                     node-xmpp-core
    crypt                           node-xmpp-tls-connect
    crypto                          nopt
    crypto-js                       normalize-path
    css-select                      normalize-url
    cssstyle                        @nornagon
    css-what                        npmlog
    cycle                           npm-run-path
    @dabh                           nth-check
    daemonize2                      number-allocator
    daikin-controller-cloud         nwsapi
    dashdash                        oauth-sign
    @datalust                       object-assign
    data-uri-to-buffer              object.assign
    data-urls                       object-hash
    dbus-next                       object-inspect
    debug                           object-keys
    decache                         oidc-token-hash
    decamelize                      once
    decimal.js                      onedrive-api
    decompress-response             one-time
    deep-clone                      onetime
    deep-extend                     on-finished
    defer-to-connect                on-headers
    define-data-property            openid-client
    define-properties               options
    delayed-stream                  pako
    delegates                       parse5
    denque                          parse5-htmlparser2-tree-adapter
    depd                            parseqs
    destroy                         parseuri
    detect-libc                     parseurl
    dgram                           passport
    dijkstrajs                      passport-local
    diskusage                       passport-strategy
    dns-packet                      path-exists
    dns-socket                      path-is-absolute
    domelementtype                  path-key
    domexception                    path-parse
    domhandler                      path-posix
    dom-serializer                  path-to-regexp
    domutils                        pause
    dropbox-v2-api                  pause-stream
    duplexer                        p-cancelable
    duplexify                       performance-now
    ecc-jsbn                        p-finally
    ecdsa-sig-formatter             picocolors
    echarts                         picomatch
    eckles                          pidusage
    ecovacs-deebot                  ping
    ee-first                        pkginfo
    emoji-regex                     p-limit
    enabled                         p-locate
    encodeurl                       p-map
    encode-utf8                     pngjs
    end-of-stream                   p-queue
    engine.io                       prebuild-install
    engine.io-client                process
    engine.io-parser                process-nextick-args
    enquirer                        promisify-child-process
    entities                        prompt
    es6-promise                     proxy-addr
    es-abstract                     proxy-from-env
    esbuild                         proxyquire
    escalade                        psl
    escape-html                     p-timeout
    escodegen                       p-try
    @esm2cjs                        pump
    esprima                         punycode
    es-set-tostringtag              pushover-notifications
    es-shim-unscopables             q
    es-to-primitive                 qbox
    estraverse                      qrcode
    esutils                         qr-image
    etag                            qs
    eventemitter3                   querystring
    eventsource                     querystringify
    event-stream                    queue-tick
    execa                           quick-lru
    expand-template                 random-bytes
    express                         range-parser
    express-fileupload              rasha
    express-session                 raw-body
    extend                          rc
    extsprintf                      read
    eyes                            readable-stream
    fast-deep-equal                 readdir-glob
    fast-fifo                       readdirp
    fast-json-stable-stringify      readline
    fastseries                      readline-sync
    fast-xml-parser                 reconnect-core
    fecha                           redirect-https
    fetch-blob                      redis-commands
    file-stream-rotator             redis-errors
    file-type                       redis-parser
    file-uri-to-path                regexp.prototype.flags
    fill-keys                       reinterval
    fill-range                      remove-trailing-separator
    finalhandler                    request
    find-up                         request-promise
    fn.name                         request-promise-core
    follow-redirects                request-promise-native
    for-each                        require-directory
    forever-agent                   require-main-filename
    form-data                       requires-port
    form-data-encoder               resolve
    formdata-polyfill               resolve-alpn
    forwarded                       respjs
    fresh                           responselike
    from                            retry
    fs-constants                    revalidator
    fs-extra                        rfdc
    fs-minipass                     rimraf
    fs.realpath                     @root
    ftp                             rrule
    function-bind                   rrweb-cssom
    function.prototype.name         rsa-compat
    functions-have-names            safe-array-concat
    futoin-hkdf                     safe-buffer
    gauge                           safer-buffer
    gaxios                          safe-regex-test
    gcp-metadata                    safe-replace
    get-caller-file                 safe-stable-stringify
    get-intrinsic                   sax
    getpass                         saxes
    get-ssl-certificate             semaphore
    get-stream                      semver
    get-symbol-description          send
    github-from-package             @sentry
    glob                            @sentry-internal
    globalthis                      seq-logging
    globalyzer                      @serialport
    glob-parent                     serialport
    globrex                         serve-static
    glossy                          set-blocking
    @googleapis                     set-function-length
    googleapis-common               set-function-name
    google-auth-library             setimmediate
    gopd                            setprototypeof
    got                             set-value
    graceful-fs                     sharp
    @greenlock                      shebang-command
    greenlock                       shebang-regex
    greenlock-express               shelly-iot
    greenlock-manager-fs            side-channel
    greenlock-store-fs              @sideway
    gtoken                          signal-exit
    @hapi                           simple-concat
    @harmonyhub                     simple-get
    harmonyhubws                    simple-oauth2
    har-schema                      simple-swizzle
    har-validator                   simple-xmpp
    has-bigints                     @sindresorhus
    has-binary2                     socket.io
    has-cors                        socket.io-adapter
    has-flag                        socket.io-client
    hash-base                       socket.io-parser
    hasown                          socksv5
    has-property-descriptors        sorted-array-functions
    has-proto                       source-map
    has-symbols                     source-map-support
    has-tostringtag                 split
    has-unicode                     split2
    he                              sshpk
    help-me                         stack-trace
    hexy                            standard-as-callback
    homebridge-plugin-wrapper       statuses
    hot-patcher                     stealthy-require
    html-encoding-sniffer           stream-combiner
    htmlparser2                     streamsearch
    http2-wrapper                   stream-shift
    http-cache-semantics            streamx
    http-errors                     string-argv
    http-mitm-proxy                 string_decoder
    http-proxy                      string.prototype.trim
    http-proxy-agent                string.prototype.trimend
    http-proxy-middleware           string.prototype.trimstart
    http-proxy-response-rewrite     string-width
    https                           strip-ansi
    http-signature                  strip-final-newline
    https-proxy-agent               strip-json-comments
    @httptoolkit                    strnum
    hue-push-client                 suncalc2
    human-signals                   supports-color
    iconv-lite                      supports-preserve-symlinks-flag
    ieee754                         symbol-tree
    immediate                       systeminformation
    indexof                         @szmarczak
    inflight                        tar
    influx                          tar-fs
    @influxdata                     tar-stream
    inherits                        tcp-ping
    ini                             text-hex
    internal-slot                   through
    @iobroker                       through2
    iobroker.admin                  tibber-api
    iobroker.alarm                  tiny-glob
    iobroker.alexa2                 to-array
    iobroker.backitup               toidentifier
    iobroker.daikin-cloud           @tootallnate
    iobroker.daswetter              to-regex-range
    iobroker.deconz                 tough-cookie
    iobroker.device-reminder        tr46
    iobroker.discovery              treemap-js
    iobroker.ecovacs-deebot         triple-beam
    iobroker.fb-checkpresence       tslib
    iobroker.fiat                   tunnel-agent
    iobroker.flot                   tweetnacl
    iobroker.fullybrowser           typedarray
    iobroker.go-e                   typed-array-buffer
    iobroker.ham                    typed-array-byte-length
    iobroker.harmony                typed-array-byte-offset
    iobroker.hue                    typed-array-length
    iobroker.hue-extended           type-is
    iobroker.icons-mfd-svg          @types
    iobroker.influxdb               typescript
    iobroker.info                   uid-safe
    iobroker.iot                    ultron
    iobroker.javascript             unbox-primitive
    iobroker.js-controller          undici-types
    iobroker-jsonexplorer           uniqid
    iobroker.meross                 universalify
    iobroker.mihome-vacuum          unix-dgram
    iobroker.mobile                 unpipe
    iobroker.openweathermap         uri-js
    iobroker.pi-hole                url-join
    iobroker.pushover               url-parse
    iobroker.pvforecast             url-template
    iobroker.radar2                 ursa-optional
    iobroker.shelly                 usb
    iobroker.simple-api             util-deprecate
    iobroker.smartcontrol           utils-merge
    iobroker.socketio               uuid
    iobroker.sonoff                 vary
    iobroker.tado                   verror
    iobroker.telegram               virtual-tsc
    iobroker.tibberlink             w3c-xmlserializer
    iobroker.type-detector          wake_on_lan
    iobroker.vis-hqwidgets          weak-daemon
    iobroker.vis-jqui-mfd           webdav
    iobroker.vis-material-advanced  webidl-conversions
    iobroker.vis-metro              websocket-stream
    iobroker.vis-timeandweather     web-streams-polyfill
    iobroker.weatherunderground     whatwg-encoding
    iobroker.web                    whatwg-mimetype
    iobroker.worx                   whatwg-url
    iobroker.ws                     which
    iobroker.ws.server              which-boxed-primitive
    ioredis                         which-module
    ip                              which-typed-array
    ipaddr.js                       wide-align
    ip-regex                        winston
    is                              winston-daily-rotate-file
    isarray                         winston-seq-updated
    is-array-buffer                 winston-syslog
    is-arrayish                     winston-transport
    is-bigint                       wrap-ansi
    is-binary-path                  wrappy
    is-boolean-object               ws
    is-buffer                       xml2js
    is-callable                     xml2json-light
    is-core-module                  xmlbuilder
    is-date-object                  xmlchars
    is-empty-object                 @xmldom
    isexe                           xmlhttprequest-ssl
    is-extglob                      xml-name-validator
    is-fullwidth-code-point         @xmpp
    is-glob                         xregexp
    is-ip                           xtend
    is-negative-zero                y18n
    is-number                       yallist
    is-number-object                yargs
    is-object                       yargs-parser
    isobject                        yeast
    isomorphic-ws                   zip-stream
    is-plain-obj                    zlib
    is-plain-object                 zrender
    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
    • G Gismoh
      Nun kommt aber immer noch bei :
      sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
      Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
      Thomas BraunT
      Thomas BraunT
      #93
      @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
      sudo nano
      Du sollst nicht ohne Not jetzt vor jeden Befehl sudo setzen. Das wird nur unter besonderen Umständen benötigt. Für Aktionen in /opt/iobroker werden keine root-Rechte benötigt (in einer gesunden Installation).
      Das Verzeichnis gibt es auf meiner Machine auch nicht.
      sudo nano /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
      funktioniert?
      G 1 Antwort Letzte Antwort
        sudo nano
        funktioniert?
        G
        G
        Gismoh
        #94
        ja, dies funktioniert ;)
        • G Gismoh
          Thomas BraunT
          Thomas BraunT
          #95
          @gismoh
          Dann schau da mal nach dem Eintrag, den crunchip oben genannt hat.
          Ich vermute aber, der ist da so gar nicht mehr drin.
          In meiner Version steht da nämlich:
              if os.path.exists(build_file_path):
                  build_file_contents = open(build_file_path, encoding='utf-8').read()
              else:
                  raise GypError(f"{build_file_path} not found (cwd: {os.getcwd()})")
              build_file_data = None
          G crunchipC 2 Antworten Letzte Antwort
            @gismoh
                else:
            G
            G
            Gismoh
            #96
            kann man auch den inhalt der Datei in die Zwischenablage holen, um besser danach suchen zu können?
            • G Gismoh
              Thomas BraunT
              Thomas BraunT
              #97
              Mit Strg-W sucht man in nano
                G
                G
                Gismoh
                #98
                denke, das ist es?
                def LoadOneBuildFile(build_file_path, data, aux_data, includes, is_target, chec>
                    if build_file_path in data:
                        return data[build_file_path]
                    else:
                    try:
                        if check:
                            build_file_data = CheckedEval(build_file_contents)
                • G Gismoh
                  denke, das ist es?
                      else:
                      try:
                          if check:
                  Thomas BraunT
                  Thomas BraunT
                  #99
                  @gismoh
                  Zeile 228 müsste das sein.
                    @gismoh
                    G
                    G
                    Gismoh
                    schrieb am zuletzt editiert von Gismoh
                    #100
                    Zeilennummern sehe ich nicht, aber ist es nicht das, was ich oben gepostet habe?
                    • G Gismoh
                      Thomas BraunT
                      Thomas BraunT
                      #101
                      @gismoh
                      Strg-C zeigt die aktuelle Zeile.
                      Aber das passt wohl bei dir dann.
                        @gismoh
                        G
                        G
                        Gismoh
                        #102
                        Merci - ist dann aber wohl kein gutes Zeichen, weil ich immer noch nicht den ble zum laufen bekomme nach Backitup rückspielung. 😰
                        • G Gismoh
                          Thomas BraunT
                          Thomas BraunT
                          #103
                          @gismoh
                          iob stop
                          iob fix
                          cd /home/iobroker
                          sudo -u iobroker npm cache clear --force
                          cd
                          iobroker upgrade ble@0.13.4
                            @gismoh
                                else:
                            crunchipC
                            crunchipC
                            Developer Global Moderator Most Active Forum Testing
                            #104
                            @thomas-braun sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                            in der einen ja, ich hab da beide
                            und die Fehlermeldung spuckt ja auch aus
                            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                            npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                            npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                            npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                              @gismoh
                              iob stop
                              iob fix
                              cd /home/iobroker
                              cd
                              G
                              G
                              Gismoh
                              #105
                              idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
                              npm WARN using --force Recommended protections disabled.
                              npm ERR! code ENOTEMPTY
                              npm ERR! syscall rmdir
                              npm ERR! path /home/iobroker/.npm/_cacache
                              npm ERR! errno -39
                              npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
                              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T22_45_40_333Z-debug-0.log
                              denke, es sollte anders aussehen?
                              • G Gismoh
                                npm ERR! errno -39
                                Thomas BraunT
                                Thomas BraunT
                                #106
                                @gismoh
                                Ja, das sollte so aussehen:
                                echad@chet:/home/iobroker $ sudo -u iobroker npm cache clear --force
                                ls -lah /home/iobroker/.npm/_cacache
                                sagt?
                                  @gismoh
                                  sagt?
                                  G
                                  G
                                  Gismoh
                                  #107
                                  idash@ioBrokerVM:/home/iobroker$ ls -lah /home/iobroker/.npm/_cacache
                                  insgesamt 12K
                                  drwxr-xr-x 3 iobroker iobroker 4,0K  8. Nov 23:45 .
                                  drwxr-xr-x 7 iobroker iobroker 4,0K  8. Nov 22:10 ..
                                  drwxr-xr-x 2 iobroker iobroker 4,0K  8. Nov 23:45 tmp
                                  • G Gismoh
                                    insgesamt 12K
                                    Thomas BraunT
                                    Thomas BraunT
                                    #108
                                    rm -rf /home/iobroker/.npm/_cacache/tmp
                                      G
                                      G
                                      Gismoh
                                      #109
                                      rm: das Entfernen von '/home/iobroker/.npm/_cacache/tmp/d411385f' ist nicht möglich: Keine Berechtigung
                                      • G Gismoh
                                        Thomas BraunT
                                        Thomas BraunT
                                        #110
                                        @gismoh
                                        sudo -u iobroker rm -rf /home/iobroker/.npm/_cacache/tmp
                                          @gismoh
                                          G
                                          G
                                          Gismoh
                                          #111
                                          idash@ioBrokerVM:/home/iobroker$ cd
                                          idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4
                                          Adapter "ble"            is not installed.
                                          84.0k
