  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
  • NegaleinN Negalein
    @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
    Könnte sogar sein, dass danach iob diag funktioniert.
    hab den Controller auch gleich geupdatet.
    Jetzt funktioniert auch iob diag wieder.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 5.15.30-2-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     17:44:09 up  2:03,  2 users,  load average: 0.93, 2.52, 2.31
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Thu 2023-10-26 17:44:09 CEST
               Universal time: Thu 2023-10-26 15:44:09 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    nega
    /home/nega
    nega adm dialout sudo users iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             10G        387M        8.2G        0.0K        1.4G        9.7G
    Swap:           2.0G          0B        2.0G
    Total:           12G        387M         10G
            10048 M total memory
              388 M used memory
              845 M active memory
              623 M inactive memory
             8234 M free memory
                0 M buffer memory
             1425 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    * iobroker.service     loaded failed failed ioBroker Server
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4    45G   17G   26G  41% /
    10.0.1.21:/volume1/Backups       nfs4    14T   11T  3.7T  75% /opt/iobroker/backups
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G  148K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET                  SOURCE                           FSTYPE OPTIONS
    /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
    /var:
    2.6G    /var/
    2.1G    /var/log
    2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
    295M    /var/lib
    Archived and active journals take up 1.9G in the file system.
    /opt/iobroker/backups:
    599M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.7G    /opt/iobroker/iobroker-data/
    3.1G    /opt/iobroker/iobroker-data/history
    1.1G    /opt/iobroker/iobroker-data/files
    353M    /opt/iobroker/iobroker-data/files/vis.0
    327M    /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
    31M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.14
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   10
    Adapter State
      system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
      system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
      system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
      system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
      system.adapter.enigma2.1                : enigma2               : ioBroker                                 -  enabled
      system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
      system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
      system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
      system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
      system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
      system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
      system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
      system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
      system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
      system.adapter.mihome.0                 : mihome                : ioBroker                                 -  enabled, port: 9898, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
      system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
      system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
      system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
      system.adapter.philips-tv-android.0     : philips-tv-android    : ioBroker                                 - disabled
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      system.adapter.places.0                 : places                : ioBroker                                 - disabled
      system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
      system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
      system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 -  enabled, port: 8002
      system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
      system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
      system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "birthdays"    : 2.4.0    , installed 2.4.0
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.14   , installed 5.0.14
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.6
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mytime"       : 0.7.12   , installed 0.7.12
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "parser"       : 2.0.7    , installed 2.0.7
    Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 2.2.0    , installed 2.2.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "seq"          : 0.3.0    , installed 0.3.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "snmp"         : 3.1.0    , installed 3.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
    Adapter    "tractive-gps" : 0.1.2    , installed 0.1.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
    Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "xbox"         : 1.1.0    , installed 1.1.0
    Objects and States
    Objects:        52090
    States:         47239
    Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       378604442  13679/sshd: nega@pt
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          377972316  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          377973526  150/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          377975287  307/master
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        377974400  113/systemd-resolve
    tcp6       0      0 :::111                  :::*                    LISTEN      0          377972318  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          377973528  150/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          377975288  307/master
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       378604441  13679/sshd: nega@pt
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        377974399  113/systemd-resolve
    udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        377972518  100/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          377972317  1/init
    udp6       0      0 :::111                  :::*                                0          377972319  1/init
    2023-10-26 17:41:43.183  - warn: host.ioBroker instance system.adapter.nina.0 terminated due to SIGTERM
    2023-10-26 17:41:43.183  - info: host.ioBroker instance system.adapter.nina.0 terminated with code null ()
    2023-10-26 17:41:43.217  - warn: host.ioBroker instance system.adapter.parser.0 terminated due to SIGTERM
    2023-10-26 17:41:43.217  - info: host.ioBroker instance system.adapter.parser.0 terminated with code null ()
    2023-10-26 17:41:43.259  - warn: host.ioBroker instance system.adapter.pi-hole.0 terminated due to SIGTERM
    2023-10-26 17:41:43.259  - info: host.ioBroker instance system.adapter.pi-hole.0 terminated with code null ()
    2023-10-26 17:41:43.292  - warn: host.ioBroker instance system.adapter.proxmox.0 terminated due to SIGTERM
    2023-10-26 17:41:43.292  - info: host.ioBroker instance system.adapter.proxmox.0 terminated with code null ()
    2023-10-26 17:41:43.336  - warn: host.ioBroker instance system.adapter.rest-api.0 terminated due to SIGTERM
    2023-10-26 17:41:43.336  - info: host.ioBroker instance system.adapter.rest-api.0 terminated with code null ()
    2023-10-26 17:41:43.369  - warn: host.ioBroker instance system.adapter.samsung_tizen.0 terminated due to SIGTERM
    2023-10-26 17:41:43.369  - info: host.ioBroker instance system.adapter.samsung_tizen.0 terminated with code null ()
    2023-10-26 17:41:43.414  - warn: host.ioBroker instance system.adapter.telegram-menu.0 terminated due to SIGTERM
    2023-10-26 17:41:43.414  - info: host.ioBroker instance system.adapter.telegram-menu.0 terminated with code null ()
    2023-10-26 17:41:43.448  - warn: host.ioBroker instance system.adapter.trashschedule.0 terminated due to SIGTERM
    2023-10-26 17:41:43.448  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code null ()
    2023-10-26 17:41:43.497  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
    2023-10-26 17:41:43.497  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
    2023-10-26 17:41:43.530  - info: host.ioBroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2023-10-26 17:41:43.585  - info: host.ioBroker instance system.adapter.influxdb.1 terminated with code 0 (NO_ERROR)
    2023-10-26 17:41:43.623  - info: host.ioBroker instance system.adapter.influxdb.2 terminated with code 0 (NO_ERROR)
    2023-10-26 17:41:43.663  - info: host.ioBroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
    2023-10-26 17:41:43.711  - info: host.ioBroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2023-10-26 17:41:43.711  - info: host.ioBroker All instances are stopped.
    2023-10-26 17:41:43.807  - info: host.ioBroker terminated
    iob diag has finished.
    Press any key for a summary
    #539
    @negalein sagte in Test Adapter Linux Control v1.x.x:
    Das hatte ich vermutet.
      @negalein
      /dev/mapper/pve-vm--100--disk--0 ext4    20G   17G  1.6G  92% /
      da is nimmer viel Platz
      du hast da
      2.2G	/opt/iobroker/backups/
      dein Repo
      Get:1 https://deb.nodesource.com/node_16.x focal InRelease [4583 B]
      Get:2 https://deb.nodesource.com/node_18.x focal InRelease [4583 B]
      schon gemacht. ohne besserung.
      ich selbst hab keine Proxmox Steuerbefehle
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #540
      @crunchip sagte in Test Adapter Linux Control v1.x.x:
      wurde gerade vergrößert ;)
      @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
      Na dann stimmt etwas nicht, sollte 18.18.2 sein
      erledigt :)
      vllt mal die entsprechenden Datenpunkte löschen und neu hinzu fügen
      System ist nun 100% aktuell.
      DP gerade nochmal gelöscht.
      Brachte aber leider nichts.
      Ich bin ja nicht alleine mit dem Problem.
      https://github.com/Scrounger/ioBroker.linux-control/pull/57
      Leider bringt der Fork von ihm bei mir nichts neues.
      ° Fixer ---> iob fix
      Meister MopperM crunchipC 2 Antworten Letzte Antwort
        erledigt :)
        Meister MopperM Online
        Meister Mopper
        #541
        Dann lügt deine Signatur 😉
        Proxmox und HA ...
          erledigt :)
          crunchipC Abwesend
          crunchipC Abwesend
          #542
          Auch den Hinweis auf deine 2Gb backups gesehen?
          Machst du nicht extern backups?
          Dann dürfte in /opt/iobroker/backups eigentlich gar nichts liegen
          NegaleinN Thomas BraunT 2 Antworten Letzte Antwort
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #543
            Ja, eigentlich schon.
            Scheinen auch in der Syno auf.
            Lösch ich auf der Syno, sind sie auch in ioB weg.
            Hab das damals nach dem Tut. von Dutchman gemacht.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #544
              nö ;)
              da_WoodyD Meister MopperM 2 Antworten Letzte Antwort
                #545
                Das Dateisystem ist permanent eingehängt.
                  nö ;)
                  da_WoodyD Online
                  da_WoodyD Online
                  #546
                  @negalein immer der schummler. 🤠
                  Könntest aber noch iob diag einbauen... 🙄
                  • da_WoodyD da_Woody
                    #547
                    @da_woody
                    Meinst du mich? Ist in iob diag natürlich schon drin:
                    *** FILESYSTEM ***
                      @da_woody
                      *** FILESYSTEM ***
                      da_WoodyD Online
                      da_WoodyD Online
                      #548
                      @thomas-braun nope, meinte unser negalein! 😀
                        nö ;)
                        Meister Mopper
                        #549
                        nö 😉
                        Doch, hast du nicht Ubuntu 22.04 lts installiert? 😉
                        Proxmox und HA ...
                        • David G.D Online
                          David G.D Online
                          David G.
                          #550
                          Ich wollte eben mal AptUpgrade über den Adapter testen.
                          Irgendwie micheoes nicht.
                          sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                          • NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #551
                            @Scrounger
                            kannst du zu meinem Issue irgendwas sagen?
                            Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
                            Er sagt irgendwas von invalid Characters. Aber welche?
                            linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
                            linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                            linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
                            linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                            linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
                            linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
                            linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                            linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
                            linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
                            linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
                            linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
                            linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
                            linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
                            linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
                            linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
                            linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
                            Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
                            Aber warum? Ich hab nichts verändert an der Konfig.
                            Was kann ich machen?
                              @Scrounger
                              wendy2702W Online
                              wendy2702W Online
                              #552
                              Das hakt ja schon hier:
                              Gibt es den View noch?
                              Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
                              Wie sieht der aus?
                              Gibt es das Device/laufwerk noch?
                              • wendy2702W wendy2702
                                Wie sieht der aus?
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #553
                                @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
                                Nein, hat es auch nie gegeben.
                                10.0.1.201 = Proxmox
                                10.0.1.202:8082/vis/index.html#080_System = ioB und die View heißt 080_System
                                Gibt es das Device/laufwerk noch?>
                                root@proxmox:~# ls -l /dev/disk/by-id/
                                total 0
                                lrwxrwxrwx 1 root root  9 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390 -> ../../sda
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part1 -> ../../sda1
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part2 -> ../../sda2
                                lrwxrwxrwx 1 root root 10 Nov  6 05:06 ata-SanDisk_SDSSDH3_1T00_221348800390-part3 -> ../../sda3
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-root -> ../../dm-1
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-swap -> ../../dm-0
                                lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-name-pve-vm--100--disk--0 -> ../../dm-6
                                lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-name-pve-vm--101--disk--0 -> ../../dm-7
                                lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-name-pve-vm--102--disk--0 -> ../../dm-8
                                lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-name-pve-vm--103--disk--0 -> ../../dm-9
                                lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-name-pve-vm--104--disk--0 -> ../../dm-10
                                lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-name-pve-vm--105--disk--1 -> ../../dm-12
                                lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--106--disk--0 -> ../../dm-11
                                lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--107--disk--0 -> ../../dm-13
                                lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxM3dxrDM3dBYhNgI8mpPV3YmfHk75VT2CZ -> ../../dm-8
                                lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMEohxnWLY2pMegm2B06LWZhhOb4JtDLdQ -> ../../dm-6
                                lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMOiAaJ18km9GOxKBboaWrAGtoGCssq5sm -> ../../dm-12
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMUldB8S2CZaYIN2ywWiLNCdTYvUJEz4ot -> ../../dm-0
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMdti3rBZdxZYTN3oDHliWCdLGGomqi2xj -> ../../dm-1
                                lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMfdz28y3obse8csoHkDgVo2rTfBy8uJfJ -> ../../dm-9
                                lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMiOEhJ1hibDoUrRctAkyzN2exdG1ZcgxU -> ../../dm-13
                                lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMljq2p7vA13bd3yyKg19GNtsJ0RmMBuBi -> ../../dm-7
                                lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMqu8b9ffqSwzJpJJH3V1dSl2uQhw8p3UP -> ../../dm-11
                                lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMzv1OgYTuzbVrrzPLozpFivIdBr4F5xQv -> ../../dm-10
                                lrwxrwxrwx 1 root root 10 Nov  6 05:06 lvm-pv-uuid-gELFXe-CNIv-TyOf-EVPI-b8LY-bEn2-Pct9zA -> ../../sda3
                                lrwxrwxrwx 1 root root  9 Sep  7 13:58 wwn-0x5001b448b72fa263 -> ../../sda
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part1 -> ../../sda1
                                lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part2 -> ../../sda2
                                lrwxrwxrwx 1 root root 10 Nov  6 05:06 wwn-0x5001b448b72fa263-part3 -> ../../sda3
                                7.2-7
                                Meister MopperM crunchipC wendy2702W 3 Antworten Letzte Antwort
                                  total 0
                                  7.2-7
                                  Meister Mopper
                                  #554
                                  7.2-7
                                  Ich fahre die 8.x und habe mit dem Adapter keine Pobleme. Aber vielleicht gibt es ja jemanden, der mit 7.2-7 auch keine Probleme hat, dann könnte man das Problem mglw. eingrenzen.
                                  Proxmox und HA ...
                                    7.2-7
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #555
                                    komisch ist, dass vor JS-Controller 5 keine Probleme waren.
                                    Muss mir mal das Tut für das Update auf 8.x anschaun.
                                    Auf den ersten Blick sieht es sehr umfangreich aus. :(
                                      Meister Mopper
                                      schrieb am zuletzt editiert von Meister Mopper
                                      #556
                                      Es war nicht kompliziert und ich habe meine komplette HA-Umgebung binnen ca. einer Stunde auf 8.x gehoben. Läuft hier auch sehr stabil, keinerlei Ausfälle oder Störungen.
                                      Wenn du ein Backup des node hast, kannst du das ja zurückpfeifen.
                                      Proxmox und HA ...
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #557
                                        ich werde da zeitnah einen eigenen Thread erstellen (darf dich dann verlinken ;) ). Ein paar Fragen/Problemchen stehen schon auf der Liste.
                                        Wird hier sonst zu OT.
                                          total 0
                                          7.2-7
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #558
                                          @negalein proxmox root und sudo? 🤔
