  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
  • NegaleinN Negalein
    @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
    funktioniert bei dir? Oder knallt das auch ohne Abfragen durch?
    nega@ioBroker:/opt/iobroker$ iob nodejs-update
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    #537
    @negalein
    Vor dem nodejs-update ist ein
    iob fix
    durchzuführen.
    Könnte sogar sein, dass danach iob diag funktioniert.
      @negalein
      iob fix
      durchzuführen.
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #538
      hab den Controller auch gleich geupdatet.
      Jetzt funktioniert auch iob diag wieder.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 5.15.30-2-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       17:44:09 up  2:03,  2 users,  load average: 0.93, 2.52, 2.31
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Thu 2023-10-26 17:44:09 CEST
                 Universal time: Thu 2023-10-26 15:44:09 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      nega
      /home/nega
      nega adm dialout sudo users iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             10G        387M        8.2G        0.0K        1.4G        9.7G
      Swap:           2.0G          0B        2.0G
      Total:           12G        387M         10G
              10048 M total memory
                388 M used memory
                845 M active memory
                623 M inactive memory
               8234 M free memory
                  0 M buffer memory
               1425 M swap cache
               2048 M total swap
                  0 M used swap
               2048 M free swap
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      * iobroker.service     loaded failed failed ioBroker Server
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4    45G   17G   26G  41% /
      10.0.1.21:/volume1/Backups       nfs4    14T   11T  3.7T  75% /opt/iobroker/backups
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.2G  148K  3.2G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET                  SOURCE                           FSTYPE OPTIONS
      /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
      /var:
      2.6G    /var/
      2.1G    /var/log
      2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      295M    /var/lib
      Archived and active journals take up 1.9G in the file system.
      /opt/iobroker/backups:
      599M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      4.7G    /opt/iobroker/iobroker-data/
      3.1G    /opt/iobroker/iobroker-data/history
      1.1G    /opt/iobroker/iobroker-data/files
      353M    /opt/iobroker/iobroker-data/files/vis.0
      327M    /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
      31M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.14
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   10
      Adapter State
        system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
        system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
        system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
        system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
        system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
        system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
        system.adapter.enigma2.1                : enigma2               : ioBroker                                 -  enabled
        system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
        system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
        system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
        system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
        system.adapter.history.0                : history               : ioBroker                                 -  enabled
        system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
        system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
        system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
        system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
        system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
        system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
        system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
        system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
        system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
        system.adapter.mihome.0                 : mihome                : ioBroker                                 -  enabled, port: 9898, bind: 0.0.0.0
        system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
        system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
        system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
        system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
        system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
        system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
        system.adapter.philips-tv-android.0     : philips-tv-android    : ioBroker                                 - disabled
        system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        system.adapter.places.0                 : places                : ioBroker                                 - disabled
        system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
        system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
        system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
        system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 -  enabled, port: 8002
        system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
        system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
        system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
        system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
        system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
        system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
        system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
        system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Beta (latest)
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "birthdays"    : 2.4.0    , installed 2.4.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "device-watcher": 2.9.4   , installed 2.9.4
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.14   , installed 5.0.14
      Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linux-control": 1.1.5    , installed 1.1.6
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mytime"       : 0.7.12   , installed 0.7.12
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "parser"       : 2.0.7    , installed 2.0.7
      Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 2.2.0    , installed 2.2.0
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "seq"          : 0.3.0    , installed 0.3.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
      Adapter    "tractive-gps" : 0.1.2    , installed 0.1.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
      Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "xbox"         : 1.1.0    , installed 1.1.0
      Objects and States
      Objects:        52090
      States:         47239
      Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       378604442  13679/sshd: nega@pt
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          377972316  1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          377973526  150/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          377975287  307/master
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        377974400  113/systemd-resolve
      tcp6       0      0 :::111                  :::*                    LISTEN      0          377972318  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          377973528  150/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          377975288  307/master
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       378604441  13679/sshd: nega@pt
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        377974399  113/systemd-resolve
      udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        377972518  100/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          377972317  1/init
      udp6       0      0 :::111                  :::*                                0          377972319  1/init
      2023-10-26 17:41:43.183  - warn: host.ioBroker instance system.adapter.nina.0 terminated due to SIGTERM
      2023-10-26 17:41:43.183  - info: host.ioBroker instance system.adapter.nina.0 terminated with code null ()
      2023-10-26 17:41:43.217  - warn: host.ioBroker instance system.adapter.parser.0 terminated due to SIGTERM
      2023-10-26 17:41:43.217  - info: host.ioBroker instance system.adapter.parser.0 terminated with code null ()
      2023-10-26 17:41:43.259  - warn: host.ioBroker instance system.adapter.pi-hole.0 terminated due to SIGTERM
      2023-10-26 17:41:43.259  - info: host.ioBroker instance system.adapter.pi-hole.0 terminated with code null ()
      2023-10-26 17:41:43.292  - warn: host.ioBroker instance system.adapter.proxmox.0 terminated due to SIGTERM
      2023-10-26 17:41:43.292  - info: host.ioBroker instance system.adapter.proxmox.0 terminated with code null ()
      2023-10-26 17:41:43.336  - warn: host.ioBroker instance system.adapter.rest-api.0 terminated due to SIGTERM
      2023-10-26 17:41:43.336  - info: host.ioBroker instance system.adapter.rest-api.0 terminated with code null ()
      2023-10-26 17:41:43.369  - warn: host.ioBroker instance system.adapter.samsung_tizen.0 terminated due to SIGTERM
      2023-10-26 17:41:43.369  - info: host.ioBroker instance system.adapter.samsung_tizen.0 terminated with code null ()
      2023-10-26 17:41:43.414  - warn: host.ioBroker instance system.adapter.telegram-menu.0 terminated due to SIGTERM
      2023-10-26 17:41:43.414  - info: host.ioBroker instance system.adapter.telegram-menu.0 terminated with code null ()
      2023-10-26 17:41:43.448  - warn: host.ioBroker instance system.adapter.trashschedule.0 terminated due to SIGTERM
      2023-10-26 17:41:43.448  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code null ()
      2023-10-26 17:41:43.497  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
      2023-10-26 17:41:43.497  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
      2023-10-26 17:41:43.530  - info: host.ioBroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2023-10-26 17:41:43.585  - info: host.ioBroker instance system.adapter.influxdb.1 terminated with code 0 (NO_ERROR)
      2023-10-26 17:41:43.623  - info: host.ioBroker instance system.adapter.influxdb.2 terminated with code 0 (NO_ERROR)
      2023-10-26 17:41:43.663  - info: host.ioBroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
      2023-10-26 17:41:43.711  - info: host.ioBroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2023-10-26 17:41:43.711  - info: host.ioBroker All instances are stopped.
      2023-10-26 17:41:43.807  - info: host.ioBroker terminated
      iob diag has finished.
      Press any key for a summary
      ° Fixer ---> iob fix
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        nega
        /home/nega
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
        Total:           12G        387M         10G
                  388 M used memory
                  845 M active memory
                 8234 M free memory
                    0 M buffer memory
                 1425 M swap cache
                 2048 M total swap
                    0 M used swap
                 2048 M free swap
        *** FILESYSTEM ***
        /var:
        2.6G    /var/
        2.1G    /var/log
        295M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        52090
        States:         47239
        Pending Updates: 0
        #539
        @negalein sagte in Test Adapter Linux Control v1.x.x:
        Das hatte ich vermutet.
          @negalein
          /dev/mapper/pve-vm--100--disk--0 ext4    20G   17G  1.6G  92% /
          da is nimmer viel Platz
          du hast da
          2.2G	/opt/iobroker/backups/
          dein Repo
          Get:1 https://deb.nodesource.com/node_16.x focal InRelease [4583 B]
          Get:2 https://deb.nodesource.com/node_18.x focal InRelease [4583 B]
          schon gemacht. ohne besserung.
          ich selbst hab keine Proxmox Steuerbefehle
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #540
          @crunchip sagte in Test Adapter Linux Control v1.x.x:
          wurde gerade vergrößert ;)
          @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
          Na dann stimmt etwas nicht, sollte 18.18.2 sein
          erledigt :)
          vllt mal die entsprechenden Datenpunkte löschen und neu hinzu fügen
          System ist nun 100% aktuell.
          DP gerade nochmal gelöscht.
          Brachte aber leider nichts.
          Ich bin ja nicht alleine mit dem Problem.
          https://github.com/Scrounger/ioBroker.linux-control/pull/57
          Leider bringt der Fork von ihm bei mir nichts neues.
          Meister MopperM crunchipC 2 Antworten Letzte Antwort
            erledigt :)
            Meister MopperM Online
            Meister Mopper
            #541
            Dann lügt deine Signatur 😉
            Proxmox und HA ...
              erledigt :)
              crunchipC Abwesend
              crunchipC Abwesend
              #542
              Auch den Hinweis auf deine 2Gb backups gesehen?
              Machst du nicht extern backups?
              Dann dürfte in /opt/iobroker/backups eigentlich gar nichts liegen
              NegaleinN Thomas BraunT 2 Antworten Letzte Antwort
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #543
                Ja, eigentlich schon.
                Scheinen auch in der Syno auf.
                Lösch ich auf der Syno, sind sie auch in ioB weg.
                Hab das damals nach dem Tut. von Dutchman gemacht.
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #544
                  nö ;)
                  da_WoodyD Meister MopperM 2 Antworten Letzte Antwort
                    #545
                    Das Dateisystem ist permanent eingehängt.
                      nö ;)
                      da_WoodyD Online
                      da_WoodyD Online
                      #546
                      @negalein immer der schummler. 🤠
                      Könntest aber noch iob diag einbauen... 🙄
                      • da_WoodyD da_Woody
                        #547
                        @da_woody
                        Meinst du mich? Ist in iob diag natürlich schon drin:
                        *** FILESYSTEM ***
                          @da_woody
                          *** FILESYSTEM ***
                          da_WoodyD Online
                          da_WoodyD Online
                          #548
                          @thomas-braun nope, meinte unser negalein! 😀
                            nö ;)
                            Meister Mopper
                            #549
                            nö 😉
                            Doch, hast du nicht Ubuntu 22.04 lts installiert? 😉
                            Proxmox und HA ...
                            • David G.D Online
                              David G.D Online
                              David G.
                              #550
                              Ich wollte eben mal AptUpgrade über den Adapter testen.
                              Irgendwie micheoes nicht.
                              sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                              • NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #551
                                @Scrounger
                                kannst du zu meinem Issue irgendwas sagen?
                                Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
                                Er sagt irgendwas von invalid Characters. Aber welche?
                                linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
                                linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                                linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
                                linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                                linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
                                linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
                                linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
                                linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
                                linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
                                linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
                                linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
                                linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
                                linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
                                linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
                                linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
                                Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
                                Aber warum? Ich hab nichts verändert an der Konfig.
                                Was kann ich machen?
                                  @Scrounger
                                  wendy2702W Online
                                  wendy2702W Online
                                  #552
                                  Das hakt ja schon hier:
                                  Gibt es den View noch?
                                  Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
                                  Wie sieht der aus?
                                  Gibt es das Device/laufwerk noch?
                                  • wendy2702W wendy2702
                                    Wie sieht der aus?
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #553
                                    @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
                                    Nein, hat es auch nie gegeben.
                                    10.0.1.201 = Proxmox
                                    10.0.1.202:8082/vis/index.html#080_System = ioB und die View heißt 080_System
                                    Gibt es das Device/laufwerk noch?>
                                    root@proxmox:~# ls -l /dev/disk/by-id/
                                    total 0
                                    lrwxrwxrwx 1 root root  9 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390 -> ../../sda
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part1 -> ../../sda1
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part2 -> ../../sda2
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:06 ata-SanDisk_SDSSDH3_1T00_221348800390-part3 -> ../../sda3
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-root -> ../../dm-1
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-swap -> ../../dm-0
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-name-pve-vm--100--disk--0 -> ../../dm-6
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-name-pve-vm--101--disk--0 -> ../../dm-7
                                    lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-name-pve-vm--102--disk--0 -> ../../dm-8
                                    lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-name-pve-vm--103--disk--0 -> ../../dm-9
                                    lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-name-pve-vm--104--disk--0 -> ../../dm-10
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-name-pve-vm--105--disk--1 -> ../../dm-12
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--106--disk--0 -> ../../dm-11
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--107--disk--0 -> ../../dm-13
                                    lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxM3dxrDM3dBYhNgI8mpPV3YmfHk75VT2CZ -> ../../dm-8
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMEohxnWLY2pMegm2B06LWZhhOb4JtDLdQ -> ../../dm-6
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMOiAaJ18km9GOxKBboaWrAGtoGCssq5sm -> ../../dm-12
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMUldB8S2CZaYIN2ywWiLNCdTYvUJEz4ot -> ../../dm-0
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMdti3rBZdxZYTN3oDHliWCdLGGomqi2xj -> ../../dm-1
                                    lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMfdz28y3obse8csoHkDgVo2rTfBy8uJfJ -> ../../dm-9
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMiOEhJ1hibDoUrRctAkyzN2exdG1ZcgxU -> ../../dm-13
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMljq2p7vA13bd3yyKg19GNtsJ0RmMBuBi -> ../../dm-7
                                    lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMqu8b9ffqSwzJpJJH3V1dSl2uQhw8p3UP -> ../../dm-11
                                    lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMzv1OgYTuzbVrrzPLozpFivIdBr4F5xQv -> ../../dm-10
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:06 lvm-pv-uuid-gELFXe-CNIv-TyOf-EVPI-b8LY-bEn2-Pct9zA -> ../../sda3
                                    lrwxrwxrwx 1 root root  9 Sep  7 13:58 wwn-0x5001b448b72fa263 -> ../../sda
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part1 -> ../../sda1
                                    lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part2 -> ../../sda2
                                    lrwxrwxrwx 1 root root 10 Nov  6 05:06 wwn-0x5001b448b72fa263-part3 -> ../../sda3
                                    7.2-7
                                    Meister MopperM crunchipC wendy2702W 3 Antworten Letzte Antwort
                                      total 0
                                      7.2-7
                                      Meister Mopper
                                      #554
                                      7.2-7
                                      Ich fahre die 8.x und habe mit dem Adapter keine Pobleme. Aber vielleicht gibt es ja jemanden, der mit 7.2-7 auch keine Probleme hat, dann könnte man das Problem mglw. eingrenzen.
                                      Proxmox und HA ...
                                        7.2-7
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #555
                                        komisch ist, dass vor JS-Controller 5 keine Probleme waren.
                                        Muss mir mal das Tut für das Update auf 8.x anschaun.
                                        Auf den ersten Blick sieht es sehr umfangreich aus. :(
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          #556
                                          Es war nicht kompliziert und ich habe meine komplette HA-Umgebung binnen ca. einer Stunde auf 8.x gehoben. Läuft hier auch sehr stabil, keinerlei Ausfälle oder Störungen.
                                          Wenn du ein Backup des node hast, kannst du das ja zurückpfeifen.
                                          Proxmox und HA ...
