  4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
204 Beiträge 10 Kommentatoren 42.1k Aufrufe 13 Beobachtet
    Fun fact:
    Den iobroker interessiert das aber nicht:
    echad@chet:/opt/iobroker $ sudo -u iobroker node cifs.js
    undefined
    Copy output from below
    /opt/iobroker/backups unmounted
    //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
    file test_pipeline_compressed_tar.tar.gz created
    file test_pipeline_compressed_tar.tar.gz done
    number of files in test_pipeline_compressed_tar.tar.gz: 0
    file test_pipeline_compressed_zlib.tar.gz created
    file test_pipeline_compressed_zlib.tar.gz done
    number of files in test_pipeline_compressed_zlib.tar.gz: 0
    file test_pipeline_uncompressed.tar created
    file test_pipeline_uncompressed.tar done
    number of files in test_pipeline_uncompressed.tar: 0
    listing of created files in /opt/iobroker/backups
    -rwxrwxrwx 1 root root 253952 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_uncompressed.tar
    -rwxrwxrwx 1 root root  16384 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
    -rwxrwxrwx 1 root root  16384 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
    End of output to copy
    F Online
    F Online
    fastfoot
    #185
    @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
    na da haben wirs!
    vi iob
    sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    abändern mit UV_USE_IO_URING=0 davor setzen
    stoppen und iob start. NICHT über den service
    • F fastfoot
      na da haben wirs!
      vi iob
      #186
      @fastfoot
      echad@chet:/opt/iobroker $ env | grep UV_USE
      UV_USE_IO_URING=0
      echad@chet:/opt/iobroker $ sudo -H -u iobroker env | grep UV_USE
      Der Schlingel!
      F 2 Antworten Letzte Antwort
        @fastfoot
        UV_USE_IO_URING=0
        Der Schlingel!
        F Online
        F Online
        fastfoot
        #187
        @thomas-braun mach mal noch den iob edit, das geht noch
        • F fastfoot
          #188
          @fastfoot
          #!/usr/bin/bash
          if (( $# == 1 )) && ([ "$1" = "start" ] || [ "$1" = "stop" ] || [ "$1" = "restart" ]); then
          sudo systemctl $1 iobroker
          elif [ "$1" = "fix" ]; then
          curl -sL https://iobroker.net/fix.sh | bash -
          elif [ "$1" = "nodejs-update" ]; then
          sudo -u iobroker curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh && bash /home/iobroker/.nodejs-update.sh $2
          elif [ "$1" = "diag" ]; then
            sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroke>
          else
          UV_USE_IO_URING=0
          fi
          Habs mit nano gemacht, auf vi hatte ich um die Uhrzeit keinen Bock mehr...
          F 1 Antwort Letzte Antwort
            @fastfoot
            UV_USE_IO_URING=0
            Der Schlingel!
            F Online
            F Online
            fastfoot
            #189
            @thomas-braun Nee, davor, so wie beim script, sonst haben wir denselben Sch......
              @fastfoot
              #!/usr/bin/bash
              else
              UV_USE_IO_URING=0
              fi
              F Online
              F Online
              fastfoot
              #190
              oder alternativ auf der Konsole
              su iobroker
              UV_USE_IO_URING=0 node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start
              • F fastfoot
                su iobroker
                #191
                @fastfoot
                Negativ, Backups sind Schrott.
                  @fastfoot
                  F Online
                  F Online
                  fastfoot
                  #192
                  @thomas-braun dann morgen, kann nicht mehr :-)
                    @fastfoot
                    F Online
                    F Online
                    fastfoot
                    #193
                    Bei mir im wsl kam dass ich keine environments setzen dürfe! im wsl darf ich nicht root sein, so wie es soll. Aber so gehts
                    UV_USE_IO_URING=0
                    sudo -H -u iobroker --preserve-env=UV_USE_IO_URING env | grep UV_
                    und so den Aufruf von iobroker im iob gestalten
                    • F fastfoot
                      UV_USE_IO_URING=0
                      #194
                      @fastfoot
                      #!/usr/bin/bash
                        sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroker
                      else
                      UV_USE_IO_URING=0 sudo -H -u iobroker --preserve-env=UV_USE_IO_URING node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                      fi
                      Aber:
                      echad@chet:/opt/iobroker $ iob nodejs-upgrade 20
                      sudo: sorry, you are not allowed to set the following environment variables: UV_USE_IO_URING
                        @fastfoot
                        #!/usr/bin/bash
                        else
                        fi
                        Aber:
                        F Online
                        F Online
                        fastfoot
                        #195
                        @thomas-braun es heisst nodejs-update, nicht upgrade!
                        mit dem preserve muss das setzen der env wieder in eine eigene zeile, export davor wäre gut, also
                        export UV_USE_IO_URING=0
                        sudo -H -u iobroker --preserve-env=UV_USE_IO_URING node opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                        Morgen dann 1 Stunde nachsitzen im home office, Thema:
                        Environments unter Linux Systemen richtig setzen(Selbststudium)
                        hab mir auch ne Stunde verordnet :-)
                        • F fastfoot
                          #196
                          @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                          Bei mir schon. Hab mir einen Alias gesetzt! :-)
                          Geht beides. Und nodejs-fix geht auch.
                          Joh... export...
                          Ich muss ins Bett...
                            Joh... export...
                            F Online
                            F Online
                            fastfoot
                            #197
                            @thomas-braun nene, in zeile 6 steht
                            elif [ "$1" = "nodejs-update" ]; then aber dort springt er nicht hin sondern in die modifizierte Zeile und dort meckert er dann :-)
                            morgen gehts weiter, das bringt nix mehr :-)
                            • F fastfoot
                              #198
                              @fastfoot
                              Jetzt mit export auch nix.
                              echad@chet:/opt/iobroker $ ls -lAh backups/ | grep 02_4
                              -rwxrwxrwx 1 root root  16K Oct 14 02:45 historyDB_2023_10_14-02_44_41_chet_backupiobroker.tar.gz
                              -rwxrwxrwx 1 root root  16K Oct 14 02:44 iobroker_2023_10_14-02_44_28_chet_backupiobroker.tar.gz
                              -rwxrwxrwx 1 root root  14K Oct 14 02:45 javascripts_2023_10_14-02_45_22_chet_backupiobroker.tar.gz
                              -rwxrwxrwx 1 root root  953 Oct 14 02:45 zigbee.0_2023_10_14-02_45_21_chet_backupiobroker.tar.gz
                              Dafür klemmt es weiter im Terminal:
                              echad@chet:/opt/iobroker $ iob status
                              Ich mag nicht mehr. Morgen zimmer ich da ein frisches Bookworm drauf, fertig.
                              • F fastfoot
                                ist ohne ENV.
                                traue deinem setup nicht :-) wenn du deinen iobroker startest (mit github backitup) und dann grep UV_USE log/*curr*|tail -2 ausführst solltest du 2 gleiche Einträge sehen, beide mit Wert 0. Sollte der erste undefined sein, dann setze mal bitte das env in deinen Systemeinstellungen. Immerhin hatte doch das Skript mit der env funktioniert, das muss dann auch im Backitup funktionieren. Und vergiss mal für kurze Zeit den History Teil und die anderen, die werden ja etwas anders erzeugt. Man wird sonst ganz durcheinander. Evtl. könnte @simatec dann ja die pipeline Methode aus dem Skript zum testen einbauen für die History wenn das normale Backup geklärt ist
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #199
                                Nein das geht nicht ... Backitup verwendet tar-fs und es wäre hier ein extrem tiefer Eingriff in den Adapter.
                                Vertiefe dich nicht so auf die ENV... Die war nur zu Testzwecken und ist produktiv nicht ratsam.
                                Deshalb wird sie in Node auch in den nächsten Versionen wieder entfernt.
                                Die Stabilität leidet unter dieser Option... Wir müssen an andern Stellen suchen.
                                Hier ist das Thema Nummer eins... Was passiert beim CIFS Mount auf der Fritte, bzw. was ist da anderes?? Die fritte ist aktuell das einzige mir bekannte NAS System, was diese Probleme verursacht.
                                Habe hier in der Testumgebung 3 verschiedene NAS mit CIFS laufen und auch bei mir gibt es nur mit der Fritte streß... Eventuell kann man auch mit den settings von smb was auf dem iobroker Host System testen...
                                Wir sollten weniger in Javascript suchen, sondern ermitteln, was bei der Fritte in Kombi mit CIFS anders ist
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                • simatecS simatec
                                  #200
                                  @simatec @fastfoot
                                  Mit zusätzlicher Mountoption cache=loose spuckt das V3-Skript nun aus:
                                  umount not possible
                                  //fritz.box/fritz.nas//Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
                                  number of files in test_pipeline_compressed_tar.tar.gz: 115
                                  number of files in test_pipeline_compressed_zlib.tar.gz: 115
                                  number of files in test_pipeline_uncompressed.tar: 115
                                  -rwxrwxrwx 1 root root 821248 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                                  -rwxrwxrwx 1 root root 155720 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                                  -rwxrwxrwx 1 root root 155720 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                                    @simatec @fastfoot
                                    umount not possible
                                    #201
                                    Mit der neuen Mount-Option cache=loose funktionieren Updates auch wieder auf dem zickigen Fritz!NAS:
                                    Das wird wohl mit nodejs@20 für die Verwender dann eine notwendige Einstellung werden, wenn sich da nichts mehr tun sollte bei nodejs.
                                    • L Offline
                                      legro
                                      schrieb am zuletzt editiert von legro
                                      #202
                                      Leider ist‘s bei mir nicht die Fritz!Box, die ein Backup von InfluxDB und Grafana verhindert. Bei mir sind die Backup-Dateien zu diesen beiden Programmen viel zu klein.
                                      Zuerst habe ich die Option cache=loose versucht. Die Dateien blieben zu klein. Anschließend habe ich das Backup nicht auf NAS gespeichert, sondern es lokal erstellen lassen. Die Backups blieben unverändert viel zu klein.
                                      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                                      • L legro
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #203
                                        @legro was sagt der Debuglog?
                                        L 1 Antwort Letzte Antwort
                                        • simatecS simatec
                                          legro
                                          #204
                                          @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                                          Danke, dass du dich meinem Problem annimmst.
                                          Die Protokollstufe habe ich auf debug eingestellt. Nun hoffe ich, dass du dies hier meinst ..
                                          ckitup.0
                                          2024-05-01 08:25:56.519	debug	[iobroker] exec: done
                                          backitup.0
                                          2024-05-01 08:25:56.217	debug	[iobroker/historyJSON] done
                                          backitup.0
                                          2024-05-01 08:25:56.217	debug	[iobroker/historyJSON] new history json values created
                                          backitup.0
                                          2024-05-01 08:25:55.999	debug	[iobroker/historyHTML] done
                                          backitup.0
                                          2024-05-01 08:25:55.903	debug	[iobroker/historyHTML] new history html values created
                                          backitup.0
                                          2024-05-01 08:25:55.595	debug	[iobroker/telegram] done
                                          backitup.0
                                          2024-05-01 08:25:55.591	debug	[iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                                          backitup.0
                                          2024-05-01 08:25:54.527	debug	[iobroker/clean] done
                                          backitup.0
                                          2024-05-01 08:25:54.526	debug	[iobroker/clean] No older backup files are deleted, because this backup was started manually
                                          backitup.0
                                          2024-05-01 08:25:53.174	debug	[iobroker/yahka] done
                                          backitup.0
                                          2024-05-01 08:25:53.173	debug	[iobroker/yahka] found yahka database: yahka.0
                                          backitup.0
                                          2024-05-01 08:25:53.019	debug	[iobroker/javascripts] done
                                          backitup.0
                                          2024-05-01 08:25:53.018	debug	[iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2024_05_01-08_25_52_Gro_backupiobroker.tar.gz
                                          backitup.0
                                          2024-05-01 08:25:53.018	debug	[iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                          backitup.0
                                          2024-05-01 08:25:53.003	debug	[iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                          backitup.0
                                          2024-05-01 08:25:52.604	debug	[iobroker/javascripts] found Script: ZeitplanHeizenNormal
                                          backitup.0
                                          2024-05-01 08:25:52.604	debug	[iobroker/javascripts] found Script: COP_GesamtEnergien_H&W_LastMonth
                                          backitup.0
                                          2024-05-01 08:25:52.603	debug	[iobroker/javascripts] found Script: COP_GesamtEnergien_H&W_CurrentMonth
                                          backitup.0
                                          2024-05-01 08:25:52.603	debug	[iobroker/javascripts] found Script: Zirkulation
                                          backitup.0
                                          2024-05-01 08:25:52.602	debug	[iobroker/javascripts] found Script: RollladenBlockly
                                          backitup.0
                                          2024-05-01 08:25:52.601	debug	[iobroker/javascripts] found Script: Sel_Liste_Test
                                          backitup.0
                                          2024-05-01 08:25:52.601	debug	[iobroker/javascripts] found Script: RollladenOOP_Bollig
                                          backitup.0
                                          2024-05-01 08:25:52.600	debug	[iobroker/javascripts] found Script: RollladenOOP
                                          backitup.0
                                          2024-05-01 08:25:52.600	debug	[iobroker/javascripts] found Script: RollladenSteuerung
                                          backitup.0
                                          2024-05-01 08:25:52.600	debug	[iobroker/javascripts] found Script: Set_Liste_Func_Test
                                          backitup.0
                                          2024-05-01 08:25:52.599	debug	[iobroker/javascripts] found Script: COP_Warmwasser_LastMonth
                                          backitup.0
                                          2024-05-01 08:25:52.599	debug	[iobroker/javascripts] found Script: COP_Heizen_LastMonth
                                          backitup.0
                                          2024-05-01 08:25:52.599	debug	[iobroker/javascripts] found Script: COP_Heizen_CurrentMonth
                                          backitup.0
                                          2024-05-01 08:25:52.598	debug	[iobroker/javascripts] found Script: COP_Warmwasser_CurrentMonth
                                          backitup.0
                                          2024-05-01 08:25:52.598	debug	[iobroker/javascripts] found Script: GesamtEnergien_H&W_CurrentMonth
                                          backitup.0
                                          2024-05-01 08:25:52.598	debug	[iobroker/javascripts] found Script: GesamtEnergie_H&W_LastMonth
                                          backitup.0
                                          2024-05-01 08:25:52.597	debug	[iobroker/javascripts] found Script: HeizungBasis
                                          backitup.0
                                          2024-05-01 08:25:52.597	debug	[iobroker/javascripts] found Script: Gruppen
                                          backitup.0
                                          2024-05-01 08:25:52.597	debug	[iobroker/javascripts] found Script: Set_Gruppe_01_In
                                          backitup.0
                                          2024-05-01 08:25:52.597	debug	[iobroker/javascripts] found Script: ZeitIntervalle
                                          backitup.0
                                          2024-05-01 08:25:52.596	debug	[iobroker/javascripts] found Script: ZeitTrigger
                                          backitup.0
                                          2024-05-01 08:25:52.596	debug	[iobroker/javascripts] found Script: Turmlampe_Helligkeit
                                          backitup.0
                                          2024-05-01 08:25:52.596	debug	[iobroker/javascripts] found Script: Eigenverbrauch
                                          backitup.0
                                          2024-05-01 08:25:52.595	debug	[iobroker/javascripts] found Script: V_Solar_Daten
                                          backitup.0
                                          2024-05-01 08:25:52.595	debug	[iobroker/javascripts] found Script: TestDatum
                                          backitup.0
                                          2024-05-01 08:25:52.594	debug	[iobroker/javascripts] found Script: MaxWerte
                                          backitup.0
                                          2024-05-01 08:25:52.593	debug	[iobroker/javascripts] found Script: Waschmaschine
                                          backitup.0
                                          2024-05-01 08:25:52.593	debug	[iobroker/javascripts] found Script: Spülmaschine
                                          backitup.0
                                          2024-05-01 08:25:52.592	debug	[iobroker/javascripts] found Script: ColorTemp_Wohnzimmer
                                          backitup.0
                                          2024-05-01 08:25:52.591	debug	[iobroker/javascripts] found Script: NEU_Wh_gesamtZählerAktualisieren
                                          backitup.0
                                          2024-05-01 08:25:52.590	debug	[iobroker/javascripts] found Script: NEU_InvertZustand
                                          backitup.0
                                          2024-05-01 08:25:52.589	debug	[iobroker/javascripts] found Script: NEU_Strom_SummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.589	debug	[iobroker/javascripts] found Script: KlingelSignalAusschalten
                                          backitup.0
                                          2024-05-01 08:25:52.588	debug	[iobroker/javascripts] found Script: KlingelAusTaster
                                          backitup.0
                                          2024-05-01 08:25:52.587	debug	[iobroker/javascripts] found Script: NEU_RegenSummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.587	debug	[iobroker/javascripts] found Script: NEU_GasSummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.585	debug	[iobroker/javascripts] found Script: MittlereTemperatur
                                          backitup.0
                                          2024-05-01 08:25:52.585	debug	[iobroker/javascripts] found Script: Test_GasSummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.584	debug	[iobroker/javascripts] found Script: TextPassage
                                          backitup.0
                                          2024-05-01 08:25:52.583	debug	[iobroker/javascripts] found Script: TestImport
                                          backitup.0
                                          2024-05-01 08:25:52.583	debug	[iobroker/javascripts] found Script: SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.582	debug	[iobroker/javascripts] found Script: SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.581	debug	[iobroker/javascripts] found Script: Send_Payload_Test
                                          backitup.0
                                          2024-05-01 08:25:52.580	debug	[iobroker/javascripts] found Script: AsgothianAn
                                          backitup.0
                                          2024-05-01 08:25:52.580	debug	[iobroker/javascripts] found Script: AsgothianAUS
                                          backitup.0
                                          2024-05-01 08:25:52.579	debug	[iobroker/javascripts] found Script: AlleSirenenAus
                                          backitup.0
                                          2024-05-01 08:25:52.579	debug	[iobroker/javascripts] found Script: AlleSireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.578	debug	[iobroker/javascripts] found Script: Fernsehabend_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.577	debug	[iobroker/javascripts] found Script: Fernsehabend_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.577	debug	[iobroker/javascripts] found Script: Esstischlampe_schalten
                                          backitup.0
                                          2024-05-01 08:25:52.576	debug	[iobroker/javascripts] found Script: EG_Rollläden_im_EG_schließen
                                          backitup.0
                                          2024-05-01 08:25:52.575	debug	[iobroker/javascripts] found Script: MonatWocheTag
                                          backitup.0
                                          2024-05-01 08:25:52.575	debug	[iobroker/javascripts] found Script: Schlafzimmerlampe
                                          backitup.0
                                          2024-05-01 08:25:52.574	debug	[iobroker/javascripts] found Script: OG_Rollläden_im_Turm_schließen
                                          backitup.0
                                          2024-05-01 08:25:52.573	debug	[iobroker/javascripts] found Script: Lampe_im_Turm
                                          backitup.0
                                          2024-05-01 08:25:52.572	debug	[iobroker/javascripts] found Script: WindstärkeMax
                                          backitup.0
                                          2024-05-01 08:25:52.572	debug	[iobroker/javascripts] found Script: RegenSummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.571	debug	[iobroker/javascripts] found Script: DruckTendenz
                                          backitup.0
                                          2024-05-01 08:25:52.570	debug	[iobroker/javascripts] found Script: Stehlampe_ein_aus
                                          backitup.0
                                          2024-05-01 08:25:52.569	debug	[iobroker/javascripts] found Script: I3-Rechts
                                          backitup.0
                                          2024-05-01 08:25:52.569	debug	[iobroker/javascripts] found Script: I3-Mitte
                                          backitup.0
                                          2024-05-01 08:25:52.568	debug	[iobroker/javascripts] found Script: I3-Links
                                          backitup.0
                                          2024-05-01 08:25:52.567	debug	[iobroker/javascripts] found Script: GaszählerVerwalten
                                          backitup.0
                                          2024-05-01 08:25:52.567	debug	[iobroker/javascripts] found Script: GasSummenTagWocheMonatJahr
                                          backitup.0
                                          2024-05-01 08:25:52.566	debug	[iobroker/javascripts] found Script: HaustürStatusSetzen
                                          backitup.0
                                          2024-05-01 08:25:52.565	debug	[iobroker/javascripts] found Script: Blinken_Test
                                          backitup.0
                                          2024-05-01 08:25:52.564	debug	[iobroker/javascripts] found Script: Offenes_Tor_melden
                                          backitup.0
                                          2024-05-01 08:25:52.564	debug	[iobroker/javascripts] found Script: Garagentor_nachts_schließen
                                          backitup.0
                                          2024-05-01 08:25:52.563	debug	[iobroker/javascripts] found Script: Garagenlicht_(manuell_am_Tor)
                                          backitup.0
                                          2024-05-01 08:25:52.562	debug	[iobroker/javascripts] found Script: Garagenlicht_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.562	debug	[iobroker/javascripts] found Script: GaragenTorSteuerung
                                          backitup.0
                                          2024-05-01 08:25:52.561	debug	[iobroker/javascripts] found Script: Treppenhauslampe_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.560	debug	[iobroker/javascripts] found Script: Treppenhaus_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.559	debug	[iobroker/javascripts] found Script: OGDiele_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.558	debug	[iobroker/javascripts] found Script: OGDiele_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.558	debug	[iobroker/javascripts] found Script: Kellertreppe_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.557	debug	[iobroker/javascripts] found Script: Innendielenleuchte_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.556	debug	[iobroker/javascripts] found Script: Innendiele_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.555	debug	[iobroker/javascripts] found Script: Eingangsdiele_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.555	debug	[iobroker/javascripts] found Script: Terrassenlampe_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.554	debug	[iobroker/javascripts] found Script: Terrassenlampe_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.553	debug	[iobroker/javascripts] found Script: TagesZeiten
                                          backitup.0
                                          2024-05-01 08:25:52.552	debug	[iobroker/javascripts] found Script: TagNacht
                                          backitup.0
                                          2024-05-01 08:25:52.552	debug	[iobroker/javascripts] found Script: Inverter
                                          backitup.0
                                          2024-05-01 08:25:52.551	debug	[iobroker/javascripts] found Script: Haustürlampe_(manuell)
                                          backitup.0
                                          2024-05-01 08:25:52.550	debug	[iobroker/javascripts] found Script: Haustürlampe_(automatisch)
                                          backitup.0
                                          2024-05-01 08:25:52.549	debug	[iobroker/javascripts] found Script: Garagentor_steuern
                                          backitup.0
                                          2024-05-01 08:25:52.548	debug	[iobroker/javascripts] found Script: Brunnen_schalten
                                          backitup.0
                                          2024-05-01 08:25:52.548	debug	[iobroker/javascripts] found Script: Bürobeleuchtung_schalten
                                          backitup.0
                                          2024-05-01 08:25:52.547	debug	[iobroker/javascripts] found Script: WindstärkeZurücksetzen
                                          backitup.0
                                          2024-05-01 08:25:52.546	debug	[iobroker/javascripts] found Script: Tageszeit_setzen
                                          backitup.0
                                          2024-05-01 08:25:52.545	debug	[iobroker/javascripts] found Script: OSRAM
                                          backitup.0
                                          2024-05-01 08:25:52.545	debug	[iobroker/javascripts] found Script: WZ_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.544	debug	[iobroker/javascripts] found Script: WZ_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.543	debug	[iobroker/javascripts] found Script: WK_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.543	debug	[iobroker/javascripts] found Script: WK_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.542	debug	[iobroker/javascripts] found Script: SZ_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.541	debug	[iobroker/javascripts] found Script: SZ_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.541	debug	[iobroker/javascripts] found Script: OG_Flur_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.540	debug	[iobroker/javascripts] found Script: OG_Flur_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.539	debug	[iobroker/javascripts] found Script: KF_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.538	debug	[iobroker/javascripts] found Script: KF_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.537	debug	[iobroker/javascripts] found Script: K2_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.536	debug	[iobroker/javascripts] found Script: K2_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.536	debug	[iobroker/javascripts] found Script: K1_SireneAus
                                          backitup.0
                                          2024-05-01 08:25:52.534	debug	[iobroker/javascripts] found Script: K1_SireneAn
                                          backitup.0
                                          2024-05-01 08:25:52.533	debug	[iobroker/javascripts] found Script: AußensireneAnAus
                                          backitup.0
                                          2024-05-01 08:25:52.528	debug	[iobroker/javascripts] found Script: RauchSensorMeldungen
                                          backitup.0
                                          2024-05-01 08:25:52.528	debug	[iobroker/javascripts] found Script: RauchAlarmSignalisieren
                                          backitup.0
                                          2024-05-01 08:25:52.526	debug	[iobroker/javascripts] found Script: OffeneFenster
                                          backitup.0
                                          2024-05-01 08:25:52.525	debug	[iobroker/javascripts] found Script: HüllschutzSensorMeldungen
                                          backitup.0
                                          2024-05-01 08:25:52.523	debug	[iobroker/javascripts] found Script: HüllschutzEinAusMitFB
                                          backitup.0
                                          2024-05-01 08:25:52.521	debug	[iobroker/javascripts] found Script: HüllschutzEinAusMelden
                                          backitup.0
                                          2024-05-01 08:25:52.519	debug	[iobroker/javascripts] found Script: HüllschutzAlarmAuslösen
                                          backitup.0
                                          2024-05-01 08:25:52.519	debug	[iobroker/javascripts] found Script: HeimZoneLeander
                                          backitup.0
                                          2024-05-01 08:25:52.518	debug	[iobroker/javascripts] found Script: HeimZoneGabi
                                          backitup.0
                                          2024-05-01 08:25:52.517	debug	[iobroker/javascripts] found Script: BatterieZustände
                                          backitup.0
                                          2024-05-01 08:25:52.516	debug	[iobroker/javascripts] found Script: AlleSirenenEin
                                          backitup.0
                                          2024-05-01 08:25:52.515	debug	[iobroker/javascripts] found Script: AlleSirenenAus
                                          backitup.0
                                          2024-05-01 08:25:52.513	debug	[iobroker/javascripts] found Script: AlleAlarmeZurücksetzen
                                          backitup.0
                                          2024-05-01 08:25:52.003	debug	[iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                          backitup.0
                                          2024-05-01 08:25:51.550	debug	[iobroker/grafana] done
                                          backitup.0
                                          2024-05-01 08:25:51.549	debug	[iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                          backitup.0
                                          2024-05-01 08:25:51.533	debug	[iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                          backitup.0
                                          2024-05-01 08:25:51.532	debug	[iobroker/grafana] Backup created: /opt/iobroker/backups/grafana_2024_05_01-08_25_46_Gro_backupiobroker.tar.gz
                                          backitup.0
                                          2024-05-01 08:25:46.417	debug	[iobroker/grafana] start Grafana backup compress ...
                                          backitup.0
                                          2024-05-01 08:25:46.409	debug	[iobroker/grafana] found Dashboard: schlafzimmer
                                          backitup.0
                                          2024-05-01 08:25:46.328	debug	[iobroker/grafana] found Dashboard: grid_pv
                                          backitup.0
                                          2024-05-01 08:25:46.324	debug	[iobroker/grafana] found Dashboard: gas-1d
                                          backitup.0
                                          2024-05-01 08:25:46.303	debug	[iobroker/grafana] found Dashboard: eigenquote
                                          backitup.0
                                          2024-05-01 08:25:46.155	debug	[iobroker/grafana] found Dashboard: benzinpreise
                                          backitup.0
                                          2024-05-01 08:25:46.145	debug	[iobroker/grafana] found Dashboard: jahresverbrauch
                                          backitup.0
                                          2024-05-01 08:25:46.127	debug	[iobroker/grafana] found Dashboard: luftfeuchtigkeit
                                          backitup.0
                                          2024-05-01 08:25:46.106	debug	[iobroker/grafana] found Dashboard: badezimmer
                                          backitup.0
                                          2024-05-01 08:25:46.096	debug	[iobroker/grafana] found Dashboard: pv-anlage
                                          backitup.0
                                          2024-05-01 08:25:45.956	debug	[iobroker/grafana] found Dashboard: gaswoche
                                          backitup.0
                                          2024-05-01 08:25:45.947	debug	[iobroker/grafana] found Dashboard: gas_30d
                                          backitup.0
                                          2024-05-01 08:25:45.937	debug	[iobroker/grafana] found Dashboard: solargrid
                                          backitup.0
                                          2024-05-01 08:25:45.772	debug	[iobroker/grafana] found Dashboard: gasverbrauch-30d-iobroker
                                          backitup.0
                                          2024-05-01 08:25:45.766	debug	[iobroker/grafana] found Dashboard: ertrag
                                          backitup.0
                                          2024-05-01 08:25:45.754	debug	[iobroker/grafana] found Dashboard: spulenandwaschen
                                          backitup.0
                                          2024-05-01 08:25:45.483	debug	[iobroker/grafana] found Dashboard: viessmann
                                          backitup.0
                                          2024-05-01 08:25:45.469	debug	[iobroker/grafana] found Dashboard: kinderzimmer
                                          backitup.0
                                          2024-05-01 08:25:45.344	debug	[iobroker/grafana] found Dashboard: aussentemperaturandluftfeuchtigkeit-24h
                                          backitup.0
                                          2024-05-01 08:25:45.140	debug	[iobroker/grafana] found Dashboard: strom_auswertung
                                          backitup.0
                                          2024-05-01 08:25:45.021	debug	[iobroker/grafana] found Dashboard: wetterdaten
                                          backitup.0
                                          2024-05-01 08:25:44.267	debug	[iobroker/grafana] found Dashboard: wohnzimmer
                                          backitup.0
                                          2024-05-01 08:25:43.138	debug	[iobroker/grafana] Grafana is available ... Status: 200
                                          backitup.0
                                          2024-05-01 08:25:43.027	debug	[iobroker/grafana] start Grafana request ...
                                          backitup.0
                                          2024-05-01 08:25:43.026	debug	[iobroker/grafana] Created datasource directory
                                          backitup.0
                                          2024-05-01 08:25:43.023	debug	[iobroker/grafana] Created dashboards_manually_restore directory
                                          backitup.0
                                          2024-05-01 08:25:43.020	debug	[iobroker/grafana] Created dashboard directory
                                          backitup.0
                                          2024-05-01 08:25:43.018	debug	[iobroker/grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                          backitup.0
                                          2024-05-01 08:25:43.015	debug	[iobroker/grafana] Start Grafana Backup ...
                                          backitup.0
                                          2024-05-01 08:25:42.712	debug	[iobroker/zigbee] done
                                          backitup.0
                                          2024-05-01 08:25:42.711	debug	[iobroker/zigbee] found zigbee database: zigbee.0
                                          backitup.0
                                          2024-05-01 08:25:41.807	debug	[iobroker/influxDB] done
                                          backitup.0
                                          2024-05-01 08:25:41.806	debug	[iobroker/influxDB] InfluxDB-Backup for is finish
                                          backitup.0
                                          2024-05-01 08:25:41.804	debug	[iobroker/influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_05_01-08_25_41_Gro_backupiobroker" successfully deleted
                                          backitup.0
                                          2024-05-01 08:25:41.789	debug	[iobroker/influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_05_01-08_25_41_Gro_backupiobroker"
                                          backitup.0
                                          2024-05-01 08:25:41.788	debug	[iobroker/influxDB] Backup created: /opt/iobroker/backups/influxDB_2024_05_01-08_25_41_Gro_backupiobroker.tar.gz
                                          backitup.0
                                          2024-05-01 08:25:41.655	debug	[iobroker/influxDB] InfluxDB Backup tmp directory created
                                          backitup.0
                                          2024-05-01 08:25:41.651	debug	[iobroker/influxDB] Start InfluxDB Backup ...
                                          backitup.0
                                          2024-05-01 08:25:41.648	debug	[iobroker/influxDB] InfluxDB-Backup started ...
                                          backitup.0
                                          2024-05-01 08:25:41.496	debug	[iobroker/iobroker] done
                                          backitup.0
                                          2024-05-01 08:25:40.412	debug	[iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
                                          backitup.0
                                          2024-05-01 08:25:40.408	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_05_01-08_25_28_Gro_backupiobroker.tar.gz
                                          backitup.0
                                          2024-05-01 08:25:36.301	debug	[iobroker/iobroker] host.raspiBullseye 20663 objects saved
                                          backitup.0
                                          2024-05-01 08:25:35.474	debug	[iobroker/iobroker] host.raspiBullseye 17187 states saved
                                          backitup.0
                                          2024-05-01 08:25:28.301	debug	Backup has started ...
                                          backitup.0
                                          2024-05-01 08:25:27.494	debug	The local storage check was completed successfully. On the host "raspiBullseye" are currently 102162 MB free space available!
                                          backitup.0
                                          2024-05-01 08:25:21.884	debug	The local storage check was completed successfully. On the host "raspiBullseye" are currently 102162 MB free space available!
                                          backitup.0
                                          2024-05-01 08:25:04.175	debug	No backup file was found
                                          backitup.0
                                          2024-05-01 08:25:04.139	debug	[ccu] 10 30 04 */4 * *
                                          backitup.0
                                          2024-05-01 08:25:04.116	info	[ccu] backup will be activated at 04:30 every 4 day(s)
                                          backitup.0
                                          2024-05-01 08:25:04.115	debug	[iobroker] 10 40 03 */1 * *
                                          backitup.0
                                          2024-05-01 08:25:03.993	info	[iobroker] backup will be activated at 03:40 every 1 day(s)
                                          backitup.0
                                          2024-05-01 08:25:03.963	debug	Backitup has recognized a linux system
                                          backitup.0
                                          2024-05-01 08:25:03.896	info	starting. Version 2.11.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.0, js-controller: 5.0.19
                                          backitup.0
                                          2024-05-01 08:25:02.944	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          backitup.0
                                          2024-05-01 08:25:02.837	debug	States connected to redis: 127.0.0.1:9000
                                          backitup.0
                                          2024-05-01 08:25:02.621	debug	States create User PubSub Client
                                          backitup.0
                                          2024-05-01 08:25:02.619	debug	States create System PubSub Client
                                          backitup.0
                                          2024-05-01 08:25:02.430	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                          backitup.0
                                          2024-05-01 08:25:02.282	debug	Objects connected to redis: 127.0.0.1:9001
                                          backitup.0
                                          2024-05-01 08:25:02.270	debug	Objects client initialize lua scripts
                                          backitup.0
                                          2024-05-01 08:25:02.078	debug	Objects create User PubSub Client
                                          backitup.0
                                          2024-05-01 08:25:02.076	debug	Objects create System PubSub Client
                                          backitup.0
                                          2024-05-01 08:25:02.073	debug	Objects client ready ... initialize now
                                          backitup.0
                                          2024-05-01 08:25:01.987	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          backitup.0
                                          2024-05-01 08:24:57.150	info	terminating
                                          backitup.0
                                          2024-05-01 08:24:56.649	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          backitup.0
                                          2024-05-01 08:24:56.648	debug	Plugin sentry destroyed
                                          backitup.0
                                          2024-05-01 08:24:56.646	info	terminating
                                          backitup.0
                                          2024-05-01 08:24:56.645	info	cleaned everything up...
                                          backitup.0
                                          2024-05-01 08:24:56.643	info	Got terminate signal TERMINATE_YOURSELF
                                          backitup.0
                                          2024-05-01 08:24:43.235	debug	The local storage check was completed successfully. On the host "raspiBullseye" are currently 102163 MB free space available!
                                          Die manuell erstellten Backups lieferten für Grafana und InfluxDB wiederum bloß Dateigrößen (ca. 16KB), wie sie meiner Ansicht nach wohl kaum stimmen können.
                                          Kann es sein, dass die Datenbank mit den sog. time series von InfluxDB gar nicht mit ins Backup aufgenommen wird, sondern bloß die Konfigurationsdaten des Adapters?
