  4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
204 Beiträge 10 Kommentatoren 42.1k Aufrufe 13 Beobachtet
  • F fastfoot
    @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
    @fastfoot
    Ich hab jetzt die Kiste komplett gebootet, damit /etc/environment definitiv gesourct wird.
    Backups kaputt.
    da hab ich noch was, aber nach dem Schlafen :-)
    #183
    @fastfoot
    Aber die ENV wird jetzt systemweit berücksichtigt:
    echad@chet:/opt/iobroker $ node cifs.js
    Copy output from below
    /opt/iobroker/backups unmounted
    //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
    file test_pipeline_compressed_tar.tar.gz created
    file test_pipeline_compressed_tar.tar.gz done
    number of files in test_pipeline_compressed_tar.tar.gz: 115
    file test_pipeline_compressed_zlib.tar.gz created
    file test_pipeline_compressed_zlib.tar.gz done
    number of files in test_pipeline_compressed_zlib.tar.gz: 115
    file test_pipeline_uncompressed.tar created
    file test_pipeline_uncompressed.tar done
    number of files in test_pipeline_uncompressed.tar: 115
    listing of created files in /opt/iobroker/backups
    -rwxrwxrwx 1 root root 821248 Oct 14 01:15 /opt/iobroker/backups/test_pipeline_uncompressed.tar
    -rwxrwxrwx 1 root root 154609 Oct 14 01:15 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
    -rwxrwxrwx 1 root root 154609 Oct 14 01:15 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
      @fastfoot
      #184
      Fun fact:
      Den iobroker interessiert das aber nicht:
      echad@chet:/opt/iobroker $ sudo -u iobroker node cifs.js
      undefined
      number of files in test_pipeline_compressed_tar.tar.gz: 0
      number of files in test_pipeline_compressed_zlib.tar.gz: 0
      number of files in test_pipeline_uncompressed.tar: 0
      -rwxrwxrwx 1 root root 253952 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_uncompressed.tar
      -rwxrwxrwx 1 root root  16384 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
      -rwxrwxrwx 1 root root  16384 Oct 14 01:17 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
      End of output to copy
      F 1 Antwort Letzte Antwort
        Fun fact:
        undefined
        F Online
        F Online
        fastfoot
        #185
        na da haben wirs!
        vi iob
        sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
        abändern mit UV_USE_IO_URING=0 davor setzen
        stoppen und iob start. NICHT über den service
        • F fastfoot
          na da haben wirs!
          vi iob
          #186
          @fastfoot
          echad@chet:/opt/iobroker $ env | grep UV_USE
          UV_USE_IO_URING=0
          echad@chet:/opt/iobroker $ sudo -H -u iobroker env | grep UV_USE
          Der Schlingel!
          F 2 Antworten Letzte Antwort
            @fastfoot
            UV_USE_IO_URING=0
            Der Schlingel!
            F Online
            F Online
            fastfoot
            #187
            @thomas-braun mach mal noch den iob edit, das geht noch
            • F fastfoot
              #188
              @fastfoot
              #!/usr/bin/bash
              if (( $# == 1 )) && ([ "$1" = "start" ] || [ "$1" = "stop" ] || [ "$1" = "restart" ]); then
              sudo systemctl $1 iobroker
              elif [ "$1" = "fix" ]; then
              curl -sL https://iobroker.net/fix.sh | bash -
              elif [ "$1" = "nodejs-update" ]; then
              sudo -u iobroker curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh && bash /home/iobroker/.nodejs-update.sh $2
              elif [ "$1" = "diag" ]; then
                sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroke>
              else
              UV_USE_IO_URING=0
              fi
              Habs mit nano gemacht, auf vi hatte ich um die Uhrzeit keinen Bock mehr...
                @fastfoot
                UV_USE_IO_URING=0
                Der Schlingel!
                F Online
                F Online
                fastfoot
                #189
                @thomas-braun Nee, davor, so wie beim script, sonst haben wir denselben Sch......
                  @fastfoot
                  #!/usr/bin/bash
                  else
                  UV_USE_IO_URING=0
                  fi
                  F Online
                  F Online
                  fastfoot
                  #190
                  oder alternativ auf der Konsole
                  su iobroker
                  UV_USE_IO_URING=0 node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start
                  • F fastfoot
                    su iobroker
                    #191
                    @fastfoot
                    Negativ, Backups sind Schrott.
                      @fastfoot
                      F Online
                      F Online
                      fastfoot
                      #192
                      @thomas-braun dann morgen, kann nicht mehr :-)
                        @fastfoot
                        F Online
                        F Online
                        fastfoot
                        #193
                        Bei mir im wsl kam dass ich keine environments setzen dürfe! im wsl darf ich nicht root sein, so wie es soll. Aber so gehts
                        UV_USE_IO_URING=0
                        sudo -H -u iobroker --preserve-env=UV_USE_IO_URING env | grep UV_
                        und so den Aufruf von iobroker im iob gestalten
                        • F fastfoot
                          UV_USE_IO_URING=0
                          #194
                          @fastfoot
                          #!/usr/bin/bash
                            sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroker
                          else
                          UV_USE_IO_URING=0 sudo -H -u iobroker --preserve-env=UV_USE_IO_URING node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                          fi
                          Aber:
                          echad@chet:/opt/iobroker $ iob nodejs-upgrade 20
                          sudo: sorry, you are not allowed to set the following environment variables: UV_USE_IO_URING
                            @fastfoot
                            #!/usr/bin/bash
                            else
                            fi
                            Aber:
                            F Online
                            F Online
                            fastfoot
                            #195
                            @thomas-braun es heisst nodejs-update, nicht upgrade!
                            mit dem preserve muss das setzen der env wieder in eine eigene zeile, export davor wäre gut, also
                            export UV_USE_IO_URING=0
                            sudo -H -u iobroker --preserve-env=UV_USE_IO_URING node opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                            Morgen dann 1 Stunde nachsitzen im home office, Thema:
                            Environments unter Linux Systemen richtig setzen(Selbststudium)
                            hab mir auch ne Stunde verordnet :-)
                            • F fastfoot
                              #196
                              @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                              Bei mir schon. Hab mir einen Alias gesetzt! :-)
                              Geht beides. Und nodejs-fix geht auch.
                              Joh... export...
                              Ich muss ins Bett...
                                Joh... export...
                                F Online
                                F Online
                                fastfoot
                                #197
                                @thomas-braun nene, in zeile 6 steht
                                elif [ "$1" = "nodejs-update" ]; then aber dort springt er nicht hin sondern in die modifizierte Zeile und dort meckert er dann :-)
                                morgen gehts weiter, das bringt nix mehr :-)
                                • F fastfoot
                                  #198
                                  @fastfoot
                                  Jetzt mit export auch nix.
                                  echad@chet:/opt/iobroker $ ls -lAh backups/ | grep 02_4
                                  -rwxrwxrwx 1 root root  16K Oct 14 02:45 historyDB_2023_10_14-02_44_41_chet_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 root root  16K Oct 14 02:44 iobroker_2023_10_14-02_44_28_chet_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 root root  14K Oct 14 02:45 javascripts_2023_10_14-02_45_22_chet_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 root root  953 Oct 14 02:45 zigbee.0_2023_10_14-02_45_21_chet_backupiobroker.tar.gz
                                  Dafür klemmt es weiter im Terminal:
                                  echad@chet:/opt/iobroker $ iob status
                                  Ich mag nicht mehr. Morgen zimmer ich da ein frisches Bookworm drauf, fertig.
                                  • F fastfoot
                                    ist ohne ENV.
                                    traue deinem setup nicht :-) wenn du deinen iobroker startest (mit github backitup) und dann grep UV_USE log/*curr*|tail -2 ausführst solltest du 2 gleiche Einträge sehen, beide mit Wert 0. Sollte der erste undefined sein, dann setze mal bitte das env in deinen Systemeinstellungen. Immerhin hatte doch das Skript mit der env funktioniert, das muss dann auch im Backitup funktionieren. Und vergiss mal für kurze Zeit den History Teil und die anderen, die werden ja etwas anders erzeugt. Man wird sonst ganz durcheinander. Evtl. könnte @simatec dann ja die pipeline Methode aus dem Skript zum testen einbauen für die History wenn das normale Backup geklärt ist
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #199
                                    Nein das geht nicht ... Backitup verwendet tar-fs und es wäre hier ein extrem tiefer Eingriff in den Adapter.
                                    Vertiefe dich nicht so auf die ENV... Die war nur zu Testzwecken und ist produktiv nicht ratsam.
                                    Deshalb wird sie in Node auch in den nächsten Versionen wieder entfernt.
                                    Die Stabilität leidet unter dieser Option... Wir müssen an andern Stellen suchen.
                                    Hier ist das Thema Nummer eins... Was passiert beim CIFS Mount auf der Fritte, bzw. was ist da anderes?? Die fritte ist aktuell das einzige mir bekannte NAS System, was diese Probleme verursacht.
                                    Habe hier in der Testumgebung 3 verschiedene NAS mit CIFS laufen und auch bei mir gibt es nur mit der Fritte streß... Eventuell kann man auch mit den settings von smb was auf dem iobroker Host System testen...
                                    Wir sollten weniger in Javascript suchen, sondern ermitteln, was bei der Fritte in Kombi mit CIFS anders ist
                                    • Besuche meine Github Seite
                                    • HowTo Restore ioBroker
                                    • simatecS simatec
                                      #200
                                      @simatec @fastfoot
                                      Mit zusätzlicher Mountoption cache=loose spuckt das V3-Skript nun aus:
                                      umount not possible
                                      //fritz.box/fritz.nas//Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
                                      -rwxrwxrwx 1 root root 821248 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_uncompressed.tar
                                      -rwxrwxrwx 1 root root 155720 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_compressed_zlib.tar.gz
                                      -rwxrwxrwx 1 root root 155720 Oct 31 03:10 /opt/iobroker/backups/test_pipeline_compressed_tar.tar.gz
                                        @simatec @fastfoot
                                        umount not possible
                                        #201
                                        Mit der neuen Mount-Option cache=loose funktionieren Updates auch wieder auf dem zickigen Fritz!NAS:
                                        Das wird wohl mit nodejs@20 für die Verwender dann eine notwendige Einstellung werden, wenn sich da nichts mehr tun sollte bei nodejs.
                                        • L Offline
                                          legro
                                          schrieb am zuletzt editiert von legro
                                          #202
                                          Leider ist‘s bei mir nicht die Fritz!Box, die ein Backup von InfluxDB und Grafana verhindert. Bei mir sind die Backup-Dateien zu diesen beiden Programmen viel zu klein.
                                          Zuerst habe ich die Option cache=loose versucht. Die Dateien blieben zu klein. Anschließend habe ich das Backup nicht auf NAS gespeichert, sondern es lokal erstellen lassen. Die Backups blieben unverändert viel zu klein.
                                          Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
