  4. iob node fix - Skript
198 Beiträge 34 Kommentatoren 73.4k Aufrufe 37 Beobachtet
    @bastler sagte in iob node fix - Skript:
    Kann ich das auch mit deinem node fix - Skript klären?
    Dafür ist es (unter anderem) da.
    bastler
    #158
    Danke, hat geklappt!
    		     v.2023-06-20
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm
            Machine ID: 00d6058392fa44d3b60e2dcfbf39a290
               Boot ID: ab4aea8acd5c4141a66953e96c6126d8
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-25-amd64
          Architecture: x86-64
    Installation: 		kvm
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
    			/usr/bin/node 		v18.18.0
    			/usr/bin/npm 		9.8.1
    			/usr/bin/npx 		9.8.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             12G        124M         11G        0.0K        1.2G         11G
    Swap:           974M          0B        974M
    Total:           13G        124M         12G
    Active iob-Instances: 	1
    ioBroker Core: 		js-controller 		5.0.12
    			admin 			6.10.1
    ioBroker Status: 	iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		18629
    States: 		15864
    Size of iob-Database:
    22M	/opt/iobroker/iobroker-data/objects.jsonl
    9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
    9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    54M	/opt/iobroker/iobroker-data/states.jsonl
    4.6M	/opt/iobroker/iobroker-data/states.json.migrated
    4.6M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    • B bastler
      		     v.2023-06-20
                 Chassis: vm
          Virtualization: kvm
      Installation: 		kvm
      Kernel: 		x86_64
      Userland: 		amd64
      User-ID: 		1000
      X-Server: 		false
      			/usr/bin/npm 		9.8.1
      			/usr/bin/npx 		9.8.1
      MEMORY:
      Swap:           974M          0B        974M
      Total:           13G        124M         12G
      			admin 			6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects: 		18629
      States: 		15864
      #159
      So soll es sein.
        Hinweis vorab: Wenn das Skript ausgeführt wurde und sein Werk getan hat, funktionieren Updates innerhalb der nodejs-Version wieder wie gehabt über
        sudo apt update
        sudo apt full-upgrade
        Erneutes ausführen des Skriptes bei einem gewöhnlichen Update ist nicht notwendig!
        __
        BETA-TESTING
        (Nachdem das Skript jetzt auch offiziell Teil vom ioBroker in Form des Kommandos iob nodejs-update geworden ist wird hier im Thread an Beta-Versionen gewerkelt. Mit den üblichen Gefahren. Es kann hier Code in jeglicher Form und Lauffähigkeit vorgefunden werden. Bitte hier nur 'todesmutige' Tester mit Backup für den Fall der Fälle. )
        Ich habe mich ja lange dagegen ausgesprochen, so grundlegende Dinge wie die Installation von nodejs über windige 'Toolz' machen zu lassen. Aber sei es wie es ist, hier ist ein Skript, das verfummelte nodejs-Installationen wieder weitgehend gerade ziehen sollte und auch das aktuelle Repository für nodejs in der Version von nodesource inkl. der Schlüssel usw. installiert.
        Flugs heruntergeladen und ausgeführt per
        curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
        chmod 744 iob_node_update
        ./iob_node_update
        Optional kann man dem Skript auch einen nodejs-Zweig mit geben, dann wird die letzte Version aus diesem Zweig installiert.
        ./iob_node_update XX
        Wobei der Zweig natürlich existent sein muss. Zur Zeit ist also XX = 18 , 20 oder 22 möglich.
        Noch ein Hinweis: Gegebenenfalls (wenn z. B. mehrere verschachtelte Fehler vorliegen) das Skript nochmal laufen lassen. Wenn alles senkrecht ist sieht die Meldung am Ende so aus:
        Nothing to do, your installation is using the correct paths.
        Nothing to do, your installed version is the recommended one.
        Also 2x 'nothing to do'.
        (2x aber nur, wenn die Empfehlung aus dem iobroker herausgelesen werden konnte. Das funktioniert aber nicht immer, für Multihost-Setups z.B. nur für das Hauptsystem)
        Meinungen? Anregungen? Wünsche?
        Wer da tiefer einsteigen möchte und vielleicht selber kochen möchte:
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        DasBo1975D Offline
        DasBo1975D Offline
        DasBo1975
        #160
        Vielen Dank, hat funktioniert
        • Entwickler des Adapters PoolControl / BertinSoft-Sprachassistent
        • Einfach macht aus einem Problem keine Lösung
        • universelle Gerätedatenstruktur mit kontextueller Funktionszuordnung. Oder einfach gesagt: Jedes Gerät spricht dieselbe Sprache - nur nicht jedes sagt alles!
          sudo apt update
          __
          BETA-TESTING
          ./iob_node_update
          bergjetB Offline
          bergjetB Offline
          bergjet
          #161
          @thomas-braun Danke für diese super Möglichkeit, dem Laien ein beschwerdefreies Update zu ermöglichen.
          homee, ioBroker, iMac, iPhone, Sonos, Alaxa
            So soll es sein.
            bastler
            #162
            Moin, habe seit dem Update jetzt eine Fehlermeldung. Kann die damit zusammen hängen? Hast du einen Hinweis für mich, wie ich den Fehler behoben bekomme?
            Danke und Gruß
            DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
            • B bastler
              Danke und Gruß
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #163
              eine Fehlermeldung.
              und die ist geheim ? ;)
              Lehrling seit 1975 !!!
              • B bastler
                Danke und Gruß
                #164
                Nein. Wie auch? Du solltest die geheime Fehlermeldung vielleicht bekannt machen.
                • DJMarc75D DJMarc75
                  eine Fehlermeldung.
                  bastler
                  #165
                  @djmarc75
                  Sorry hier ist der Screenshot:
                  • B bastler
                    @djmarc75
                    #166
                    @bastler
                    Nein, hat nichts mit einem sauber durchgeführten Update zu tun.
                      @bastler
                      ticaki
                      #167
                      Danke für das Skript hat mir die Sucherei, wie ich von 18.17.x auf 18.18.0 komme erspart 👍
                      Spenden
                      • T ticaki
                        #168
                        Ganz neu:
                        Man kann dem Skript jetzt eine Major-Version von nodejs mit geben und dann wird die letzte Version aus diesem Zweig installiert. Siehe erstes Posting für Details.
                        • MichaelFM Online
                          MichaelFM Online
                          MichaelF
                          #169
                          Hi, funktioniert der Script auch bei raspberry 64 bit Systemen. Oder ist hier noch was zu beachten ?
                          Grüsse
                          • MichaelFM MichaelF
                            Grüsse
                            #170
                            @michaelf
                            Funktioniert auf allen aktuellen Systemen, die dpkg/apt verwenden. Also, ja, auch auf einem 64bit-RaspberryOS.
                            MichaelFM 1 Antwort Letzte Antwort
                              @michaelf
                              MichaelFM Online
                              MichaelFM Online
                              MichaelF
                              schrieb am zuletzt editiert von MichaelF
                              #171
                              @thomas-braun said in iob node fix - Skript:
                              @michaelf
                              Danke für die schnelle Antwort. Allerdings ist es ein Multihost, sorry eben vergessen mit dazu zu schreiben. Der Master ist ein normales RaspberryOS, der host der 64bit.
                              Grüsse
                                @michaelf
                                Grüsse
                                #172
                                @michaelf
                                Egal. Auf dem Slave wird ledigich nicht die Meldung 'Nothing to do' 2x ausgegeben sondern nur einmal. Wenn aber die aktuelle nodejs 18.18.0 gemeldet wird ist alles i.O.
                                  @michaelf
                                  MichaelFM Online
                                  MichaelFM Online
                                  MichaelF
                                  #173
                                  @michaelf
                                  Danke für die info.
                                    @michaelf
                                    Danke für die info.
                                    #174
                                    @michaelf
                                    Stand aber im Eröffnungspost auch schon drin...
                                    JoJo58J 1 Antwort Letzte Antwort
                                      SuFra
                                      #175
                                      Super Script, Update von 18.17.x auf 18.18.0 ohne Probleme.
                                      System: Proxmox, ioBrocker im LXC.
                                      Vielen Dank für deine Arbeit Thomas 👍
                                      HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
                                      LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
                                      VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
                                        @michaelf
                                        JoJo58J Online
                                        JoJo58J Online
                                        JoJo58
                                        #176
                                        @thomas-braun Guten Morgen, ich habe aktuell Probleme mit meinem Javascript Adapter und wollte daher nodejs aktualisieren. Ich habe eine VM unter Proxmox mit der aktuellen Debian 12 bookworm am laufen. Installiert ist nodejs v18.171 und ich wollte auf 18.18 gehen. Da es nicht nach der Anleitung hier aus dem Forum funktionierte, habe ich recherchiert und dein Script gefunden. Nach dem Start kommt noch die Meldung das ich Geduld haben soll und das war es leider auch. Nach 1,5 Stunden habe ich das Script abgebrochen.
                                        ioBroker nodejs fixer 2023-10-07
                                        Recommended nodejs-version is: 18.18.0
                                        Checking your installation now. Please be patient!
                                        Your current setup is:
                                        /usr/bin/nodejs         v18.17.1
                                        /usr/bin/node           v18.17.1
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        /usr/bin/corepack       0.18.0
                                        We found these nodejs versions available for installation:
                                        nodejs:
                                          Installed: 18.17.1-deb-1nodesource1
                                          Candidate: 18.17.1-deb-1nodesource1
                                          Version table:
                                         *** 18.17.1-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                                             18.13.0+dfsg1-1 500
                                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                        Nothing to do - Your installation is using the correct paths.
                                        You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                                        Press <y> to continue or any other key to quit
                                        Trying to fix your installation now. Please be patient.
                                        Noch eine Idee was ich machen kann?
                                        Gruß Johannes
                                        Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
                                        Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
                                        Einfach ein tolles Hobby :-)
                                        • JoJo58J JoJo58
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Gruß Johannes
                                          #177
                                          @jojo58 sagte in iob node fix - Skript:
                                          Das ist ein interessantes Verhalten. Sollte eigentlich nicht vorkommen.
                                          sudo apt update
                                          sagt?
