  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • Palm_ManiacP Offline
    Palm_Maniac
    #1164
    Eben ist es doch wieder passiert, ohne das ich was geschraubt habe.
    awtrix-light.0
    2023-08-17 10:24:10.976	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:24:06.162	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:57.768	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:54.207	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:53.024	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:51.771	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:42.396	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:39.876	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:33.913	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:27.982	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:25.548	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    awtrix-light.0
    2023-08-17 10:23:20.789	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
    Das Interface der Ulanzi ist erreichbar. Es ist natürlich möglich, dass sich das Problem von selbst wieder gelöst hat, da seit 10:24Uhr keine neue Meldung mehr aufgelaufen ist. Leider hab ich es vorhin erst entdeckt und bis dahin schien es wohl wieder zu laufen.
    Ich hätte da noch etwas. Ich lasse unter anderem auch den Diesel-Preis unserer Lieblingstankstelle durchlaufen und wollte dazu noch den Preisverlauf anzeigen lassen. Leider wird mir da nur eine Flatline angezeigt, weil wahrscheinlich der abgebildete Zeitraum zu kurz ist. Was ich da bräuchte, wäre eine Darstellung von 6-12 Stunden. Läßt sich da was machen? Ich habe leider nichts gefunden, wo ich den Zeitraum für die Darstellung verändern könnte.
    arteckA haus-automatisierungH 2 Antworten Letzte Antwort
    • Palm_ManiacP Palm_Maniac
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      awtrix-light.0
      arteckA Offline
      arteckA Offline
      arteck
      #1165
      @palm_maniac wie oft werden die daten von der PV app geändert ???
      bestimmt in sekunden takt..
      Palm_ManiacP 1 Antwort Letzte Antwort
      • arteckA arteck
        Palm_Maniac
        #1166
        @arteck Ja, aber ich habe im Adapter 3 Sekunden eingestellt. So genau muß es da nicht sein.
          arteckA Offline
          arteckA Offline
          arteck
          #1167
          @palm_maniac das klappt nicht... du musst immer die antwortzeit der Dose berücksichtigen...
          ich bin dazu übergegangen die Daten alle 1 min zu senden..
          es scheint als ob de Dose das nicht so schnell verarbeiten kann
          • arteckA arteck
            Palm_Maniac
            #1168
            @arteck Es lief aber alles durch, seit gestern bis heute morgen und vor dem Firmware-Update sogar über mehrere Tage mit dieser Konfig.
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              awtrix-light.0
              haus-automatisierungH Offline
              #1169
              @palm_maniac sagte in Test Adapter Awtrix-Light:
              Die Frage ist ja auch, warum Du alle paar Sekunden die Sichtbarkeit einer App ändern möchtest.
              📚 Meine Dokumentation
                Palm_Maniac
                #1170
                @haus-automatisierung Die Apps schalten im 7-10 Sekunden Abstand durch, also doch wie das System selbst. Oder was meinst du?
                  #1171
                  @palm_maniac Laut Log wird der Datenpunkt apps.pv.visible ständig neu geschrieben.
                    Palm_Maniac
                    #1172
                    @haus-automatisierung Ah, das ist mein erster Versuch die PV-Anzeige bei 0W abzuschalten. Da muß ich nochmal optimierend ran.
                      #1173
                      Das kannst Du direkt auf der Custom App festlegen in den Instanzeinstellungen.
                      EDIT: Sorry, das geht in der Produktivversion ja noch gar nicht - habe das mit meinem Entwicklungsstand verwechselt
                      Palm_ManiacP K 2 Antworten Letzte Antwort
                        Palm_Maniac
                        #1174
                        @haus-automatisierung Deshalb hab ich nix gefunden und schon gedacht, ich bin blöd und blind. ;)
                        • C Offline
                          calliou1234
                          #1175
                          Gtuen Abend Zusammen,
                          sehr toller Adapter, vielen Dank dafür.
                          Versuche gerande ein paar Daten meiner PV Anlage anzuzeigen.
                          Leider zeigt die Ulanzi nix an.
                          Im log steht:
                          [initCustomApps] State value of custom app "pvleistung" (javascript.0.PV.PVLeistung) is not acknowledged (ack: false) - waiting for new value
                          Jemand ne Idee?
                          Thomas
                          :mrgreen:
                          • C calliou1234
                            Im log steht:
                            Jemand ne Idee?
                            Thomas
                            #1176
                            @calliou1234 sagte in Test Adapter Awtrix-Light:
                            Jemand ne Idee?
                            Es werden nur bestätigte Werte übermittelt.
                            • H Offline
                              Heinz2100
                              #1177
                              Hallo, erst einmal vielen Dank für den tollen Adapter. Gibt es die Möglichkeit die Icons einer App per Skript zu ändern? Ich denke da an Mondphasen, Wettericons oder auch Speicher-/Ladezustände des PV-Speichers. Tausend Dank
                              • FreunderNachtF Offline
                                FreunderNacht
                                #1178
                                Hallo Mathias,
                                es geht um folgende Einstellmöglichkeit im Adapter:
                                Nach der Beschreibung unter dem Eingabefeld vermute ich mal, daß ich hier eine Zeit definieren kann, nach der der Adapter die Werte für die Apps abfragt.
                                Ich habe diesen auf 10 Sekunden gestellt, trotzdem habe ich den Eindruck, daß die Werte in kürzeren Intervallen an die Ulanzia geschickt werden.
                                Ich bekomme von meinem Senec Speicher in kürzeren Intervallen neue Werte und ich vermute stark, daß diese auch direkt weiter gegeben werden.
                                Ich schaue mir das ganze aber nochmal im Debug Log an.
                                Habe ich aber die Funktionen dieser Einstellung richtig interpretiert?
                                Intel NUC mit Proxmox
                                IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                                Influx DB
                                Grafana
                                PiHole
                                PiVPN
                                • H Heinz2100
                                  Kelzith
                                  #1179
                                  @heinz2100 Ich würde für jeden Zustand eine eigene App mit Icon erstellen und mit einem Script steuern welche angezeigt wird.
                                  H 1 Antwort Letzte Antwort
                                    FreunderNacht
                                    #1180
                                    mal eine Frage in die Runde.
                                    Ich habe aktuell bei mir 6 Apps mit einer Anzeigedauer von je 2 Sekunden am laufen.
                                    Wie sieht es bei euch aus?
                                    Influx DB
                                    Grafana
                                    PiHole
                                    PiVPN
                                    • K Kelzith
                                      Heinz2100
                                      #1181
                                      @kelzith So habe ich das auch verwirklicht, aber es wird sehr schnell sehr komplex (Stichwort Mondphasen). Es wäre eigentlich auch relativ leicht umsetzbar, wenn die Symbolzahl auch ein Datenpunkt statt Zahl sein könnte/dürfte.
                                      • darkbluD Offline
                                        darkbluD Offline
                                        darkblu
                                        #1182
                                        @haus-automatisierung ,
                                        könntest du mir bitte erklären, was es mit dieser Warnmeldung auf sich hat ?
                                        Ich lasse nun alle Datenpunkte per Blockly in eigene Datenpunkte schreiben, alle 45 Sekunden.
                                        Ich dachte die sekündliche live Abfrage wäre zu viel, scheinbar nicht.
                                        Das log ist trotzdem ruck zuck wieder voll mit dieser Meldung (für alle 8 Apps).
                                        Oder liegt es doch an der Signalstärke der Ulanzi ?
                                        Der RSSI schwankt so zwischen -62 und -72
                                        Vielen Dank
                                        Raspi 4, 4GB für Influxdb 1.8 und Grafana
                                        Raspi 5, 8 GB für ioBroker
                                        Threadnetzwerk per Apple
                                        • darkbluD darkblu
                                          Vielen Dank
                                          #1183
                                          @darkblu sagte in Test Adapter Awtrix-Light:
                                          Wäre gut wenn ich das könnte. Ist aber eventuell ab 0.77 gefixt
                                          https://github.com/Blueforcer/awtrix-light/issues/261
